Four pointers for running while pregnant
SuuntoRun — February 14 2019
© Lymbus/Sergi Colomé
Being pregnant has meant Emelie Forsberg has had to make some adjustments to her schedule, and reduce the volume of her training. However, it hasn’t stopped her running. While she is taking more care, she is trying to stay active for as long as she can.
“I think (running while pregnant) is so individual, so you can’t compare one woman to another,” Forsberg says. “My first priority is always to listen to my body, especially now that I’m pregnant. I will try to stay active as long as I can. I don’t have any niggles or problem so far.”
According to Andrew Shennan, professor of obstetrics at Kings College in London, running while pregnant is perfectly safe if not overdone. Many people, he says, have misunderstandings about women’s bodies during pregnancy. They are capable of more than you might think.
“Pregnancy is quite a profound state in terms of how it changes your body, however it’s not that delicate,” Shennan says. “In fact, all the evidence says that staying fit and healthy and continuing exercise is a perfectly reasonable thing to do.”
1. Running is safe (within reason)
Shennan and his colleagues did a study on 1200 pregnant runners. The study compared those that stopped running with those that continued, and then compared those that continued into different phases of pregnancy, and also by their running volume, and those that stopped. The study found the pregnancies of women who chose to give up running were no different from those who continued to exercise throughout their pregnancy.
“All the evidence on moderate exercise and recreational exercise is that doing it regularly and consistently does not influence when you go into labour, or the way your baby grows and develops,” Shennan says. “You can be reassured that mild exercise is perfectly reasonable.”
2. It’s actually a good thing
Not only is moderate, regular exercise safe, it’s also a good thing. Shennan says there is good evidence that being a good weight and physically fit is helpful for pregnancy and during labor.
“From a general point of view we encourage women to exercise about 30 minutes everyday,” he says. “Entering pregnancy at an optimal weight is a very good prerequisite for a healthy pregnancy. We know that healthy pregnancies create healthy children. Being fit and healthy will programme your baby in utero for lifelong health.”
Professor Andrew Shennan is Professor of Obstetrics at King’s College London, based at St. Thomas’ Hospital.
3. Don’t push it
Yes, running is safe and even healthy, but caution is required. Because pregnant women pump 40 % more blood, their hearts have to work harder, increasing their average heart rate.
“The placenta is very sensitive to blood flow and doesn’t have autoregulation like other organs have,” Shennan says. “This means that if you are becoming a bit hypoxic (low in oxygen), it will have a direct effect on the placenta. Therefore, it’s really important not to push it. If you are running in the red zone that’s probably not a good thing. I would stay within your comfort zone, and listen to your body.
“Remember the benefits you get from exercising at suboptimal levels are often underestimated. Focus on maintaining your fitness while pregnant rather than trying to gain.”
4. Avoid falling at all costs
Hormone activity in pregnancy softens ligaments, and reduces bone mass, increasing the risk of injury. The ability to balance and posture change in the second and third trimester. All of this means women can become more injury prone.
“The lesson is be careful and not to do crazy things,” Shennan says. “The one big thing to avoid is trauma. We know that trauma, direct impact to the uterus, is a bad thing. If you have a little fall, and you knock your bump, there can be what we call subclinical bleeds behind the placenta and they can build up and cause a catastrophic event a day or two later. So even minor trauma is not good thing.”
Final word: enjoy your running
When Shennan was conducting the study of 1200 pregnant runners, one woman contacted him to ask if she should continue running. She said she had cut down her training volume to 20 km a day. Shennan said he didn’t know whether that was safe. She continued running in this way and encountered no problems during her pregnancy or the birth.
“As an obstetrician, I’m not encouraging woman to do that because I think it’s probably a bit much,” he says. “However, I do encourage pregnant woman to carry on doing their accustomed exercise. Just be prepared to slow down a bit.”
Lead image: Photo by Curtis MacNewton on Unsplash
おすすめのSuunto製品
あなたへのおすすめ
Suunto Race S vs Race 2: Size, Weight, and Battery Life Compared
Suunto Race SとRace 2を比較。サイズ・重さ・バッテリーで選ぶならどっち?
Suuntoのスポーツウォッチを検討している人にとって、迷いやすいのが「Suunto Race S」と「Suunto Race 2」の違いです。 どちらもAMOLEDディスプレイ、オフラインマップ、115以上のスポーツモード、トレーニング分析機能を備えた、ランニングやトレイルランニング、レース、日々のトレーニングに活用できる高性能モデルです。Suunto Race Sは「小さく、軽く、日常に...
Suunto Vertical vs. Vertical 2: Key Differences Explained
Suunto Vertical vs Vertical 2|どちらを選ぶべき?5つの違いを徹底比較
「Suunto Verticalを買おうと思っていたら、Vertical 2が出ていた」「初代とどこが変わったのか、値段差に見合う進化があるのか知りたい」——そんな疑問を持つ方に向けて、この記事では2モデルの違いを5つのポイントに絞って整理します。 どちらを選ぶべきかの判断基準も最後に明確にまとめていますので、ぜひ最後まで読んでみてください。 Suunto Vertical と Vertic...
How to play music on a running watch | Run without your phone with Suunto Run × Spark
ランニングウォッチで音楽再生する方法|スマホなしで走れるSuunto Run × Sparkの使い方
ランニング中に音楽を聴きたいけれど、スマートフォンを持って走るのは重い。ポケットやランニングポーチの中で揺れるのが気になる。そんな悩みを感じたことはありませんか? 音楽再生に対応したランニングウォッチを使えば、スマートフォンを持たずに、より身軽に走ることができます。 Suunto Runは、ウォッチ本体に音楽を保存できるオフライン音楽機能を搭載したランニングウォッチです。Suunto ...
How to use HRV to optimize your recovery
HRV(心拍変動)とは?正常値の見方と回復・トレーニングへの活かし方
「しっかり練習しているのに記録が伸びない」「いつもより疲れが残っている」と感じるときは、トレーニング量だけでなく、身体の回復状態にも目を向けてみましょう。回復を把握するための指標として活用されているのが、HRV(心拍変動)です。 HRVは、心拍数そのものではなく、心拍と心拍の間隔に生じるわずかなゆらぎを示します。毎日の数値を継続して確認することで、トレーニング、睡眠、ストレスなどに身体がどの...
