How to pace your triathlon right
September 17 2014
Triathlete and triathlon coach Brett Blankner says that pacing a triathlon successfully has three critical components: you should know how long the race will take you, understand the difference between aerobic and anaerobic capacity and be smart on the bike.
”People forget that a triathlon isn't three individual sports with a big break in between. Instead, you should look at it as one long aerobic event,” Blankner says.
“If this race will take you at least three hours, are you fit enough to keep moving forward for three whole hours? Have you trained three hours non-stop before? Should you be going this fast at the start when you have three hours left to go? Probably not.”
Going too hard has a very limited time-span and will end your race quickly
For pacing your triathlon right it is also crucial to learn the difference between aerobic and anaerobic energy systems and fuel accordingly.
“Once your heart rate goes above a certain level – the aerobic threshold – you are no longer aerobic and have to start borrowing energy against your anaerobic system. This is where heart rate can help you tremendously.”
“Going too hard has a very limited time-span and will end your race quickly. Your stomach shuts down so you can't digest fuel and your breathing becomes forced as your lungs try to ram air into your bloodstream.”
Blankner suggests using a method by Dr Phil Maffetone, the coach behind legendary triathlete Mark Allen.
“The heart rate limit for this is about 180 minus your age. If you stay under this number, you can breathe and digest fuel just fine and go all day. You can play with getting closer to and even well over this threshold number based on how short the race is and how close you are to the finish line. With some practice, it becomes the best tool available for great pacing.”
When you see somebody running well in a triathlon, you're not seeing a great runner. You're seeing a great cyclist.
The third critical component Blankner talks about is being smart on a bike. The bike portion of the race is so damaging to your running legs, that you need to make sure you train to limit that damage as much as possible.
“You can take a world-class marathoner and turn him into a slow walker in a triathlon if he can't bike well. If you end up walking on the run, your speed just dropped to near-zero.”
“When you see somebody running well in a triathlon, you're not seeing a great runner. You're seeing a great cyclist who can now run because the bike ride didn't hurt.”
Brett Blankner is an American ultra-endurance athlete and a coach, who also produces Zen & the Art of Triathlon podcast.
おすすめのSuunto製品
あなたへのおすすめ
Suunto Race S – The latest addition to the Suunto Race family
Suunto Race S|トレーニング、レース、リカバリーを支えるコンパクトなランニングGPSウォッチ
Suunto Race Sは、Suunto Raceの高いパフォーマンス機能を受け継ぎながら、より薄く、軽く、手首になじみやすいサイズに仕上げたスポーツウォッチです。 明るく見やすい1.32インチAMOLEDディスプレイ、無料で使えるオフラインマップ、95種類以上のスポーツモード、HRV測定に基づく回復サポートなどを搭載。トレーニングからレース、日常の健康管理まで、幅広いシーンをサポートしま...
New Suunto Ocean – a dive computer and GPS sports watch in one
スント オーシャン - ダイビングコンピューターとGPSスポーツウォッチを一体化
100% 再生可能エネルギーを使用してフィンランドで製造された Suunto Ocean は、地下の深淵を探求することから、標高を征服することまで、アクティブなライフスタイルに合わせて設計されています。複数のダイブモード、ワイヤレスのタンク圧サポート、スキューバおよびフリーダイブ用の広範囲なアラームセットを特徴とし、95 以上のデフォルトスポーツモード、GPS、気圧計、オフラインマップ、...
Suunto ZoneSense – a revolution for all endurance sports
スント ゾーンセンス - すべてのエンデュランススポーツに革命を起こす
長年にわたり、Suuntoはアスリートがより効率的にトレーニングできるよう支援してきましたが、その中で最も大きな課題の一つはトレーニング強度の正確な測定です。Suunto ZoneSenseは、MoniCardiの最先端技術を活用し、持久力トレーニングに新たな扉を開きます。 Suuntoは最新の革新であるSuunto ZoneSense技術の発表を誇りに思います。これは持久力トレーニング...
8 Essential running form drills
ランニングフォームを改善する8つのドリル|姿勢・接地・ピッチを整える練習方法
ランニングフォームを改善したいと思っても、「何から始めればいいかわからない」「姿勢や接地をどう直せばいいかわからない」と感じる人は多いかもしれません。 ランニングフォームは、意識するだけで大きく変えるのは難しいものです。姿勢、接地、腕振り、ピッチ、身体の連動を整えるには、走る前のドリルを取り入れるのがおすすめです。 ランニングドリルは、走る動きを分解して練習するためのメニューです。ウォームア...
