Technical specifications
Dimensions and weight:
- Max. diameter: 40 mm / 1.57 in
- Length: 80 mm / 3.15 in
- Weight: 95 g / 3.4 oz
- Threading: 7/16” - 20UNF
- Hex base size: 19 mm
Operating conditions
Maximum depth of operation: 150 m / 492 ft (complying with EN
13319)
Operating temperature: 0 °C to 40 °C / 32 °F to 104 °F
Diving in freezing conditions may damage the dive computer. Make
sure the device does not freeze when wet.
Storage temperature: -20 °C to +50 °C / -4 °F to +122 °F
Store in a dry place at room temperature.
WARNING:
Do not expose the device to temperatures above or below the given
limits, otherwise it might get damaged or you might be exposed to
safety risk.
Pressure measurements
Rated working pressure: 300 bar / 4351 psi
Battery
Type: 3.6 V 1/2 AA Primary lithium-thionyl chloride (Li-SOCl2)
Low temperature or an internal oxidation of the battery may
activate the battery warning even though the battery has enough
capacity. In this case, the warning usually disappears when the
dive mode is activated again.
Do not try to replace the battery by yourself! It should always be
replaced by an authorized Suunto Service Center.
Radio transceiver
Frequency band: single channel 123 kHz
- Maximum output power: 360 mW
See the appropriate product user guides for information on range.
Manufacturer
Suunto Oy
Tammiston kauppatie 7 A
FI-01510 Vantaa FINLAND
Compliance
For compliance related information, see “Product Safety and
Regulatory Information” delivered together with your
Suunto Tank POD
or available at
SuuntoTankPodSafety
Trademark
Suunto Tank POD
, its logos, and other Suunto brand trademarks and made names are
registered or unregistered trademarks of Suunto Oy. All rights are
reserved.
Patent notice
This product is protected by pending patent applications and their
corresponding national rights: US 13/803,795, US 13/832,081, US
13/833,054, US 14/040,808, US 7,349,805, and US 86608266.
Additional patent applications may be filed.
International Limited Warranty
Suunto warrants that during the Warranty Period Suunto or a Suunto
Authorized Service Center (hereinafter Service Center) will, at its
sole discretion, remedy defects in materials or workmanship free of
charge either by a) repairing, or b) replacing, or c) refunding,
subject to the terms and conditions of this International Limited
Warranty. This International Limited Warranty is valid and
enforceable regardless of the country of purchase. The International
Limited Warranty does not affect your legal rights, granted under
mandatory national law applicable to the sale of consumer goods.
Warranty Period
The International Limited Warranty Period starts at the date of
original retail purchase.
The Warranty Period is two (2) years for Watches, Smart Watches,
Dive Computers, Heart Rate Transmitters, Dive Transmitters, Dive
Mechanical Instruments, and Mechanical Precision Instruments unless
otherwise specified.
The Warranty Period is one (1) year for accessories including but
not limited to Suunto chest straps, watch straps, chargers, cables,
rechargeable batteries, bracelets and hoses.
The Warranty Period is five (5) years for failures attributable to
the depth measurement (pressure) sensor on Suunto Dive Computers.
Exclusions and Limitations
normal wear and tear such as scratches, abrasions, or
alteration of the color and/or material of non-metallic
straps, b) defects caused by rough handling, or c) defects or
damage resulting from use contrary to intended or recommended
use, improper care, negligence, and accidents such as dropping
or crushing;
- printed materials and packaging;
defects or alleged defects caused by use with any product,
accessory, software and/or service not manufactured or supplied by
Suunto;
- non-rechargeable batteries.
Suunto does not warrant that the operation of the Product or
accessory will be uninterrupted or error free, or that the Product
or accessory will work with any hardware or software provided by a
third party.
This International Limited Warranty is not enforceable if the
Product or accessory:
- has been opened beyond intended use;
has been repaired using unauthorized spare parts; modified or
repaired by unauthorized Service Center;
serial number has been removed, altered or made illegible in any
way, as determined at the sole discretion of Suunto; or
has been exposed to chemicals including but not limited to
sunscreen and mosquito repellents.
You must provide proof of purchase to access Suunto warranty
service. You must also register your product online at
apac.suunto.com/register
to receive international warranty services globally. For
instructions on how to obtain warranty service, visit
apac.suunto.com/warranty
, contact your local Suunto retailer, or contact Suunto support at
apac.suunto.com/support
Limitation of Liability
To the maximum extent permitted by applicable mandatory laws, this
International Limited Warranty is your sole and exclusive remedy and
is in lieu of all other warranties, expressed or implied. Suunto
shall not be liable for special, incidental, punitive or
consequential damages, including but not limited to loss of
anticipated benefits, loss of data, loss of use, cost of capital,
cost of any substitute equipment or facilities, claims of third
parties, damage to property resulting from the purchase or use of
the item or arising from breach of the warranty, breach of contract,
negligence, strict tort, or any legal or equitable theory, even if
Suunto knew of the likelihood of such damages. Suunto shall not be
liable for delay in rendering warranty service.
