Get the most out of your Suunto product by checking the product manual, watching the how-to videos, and reading the Questions and Answers. Select your product from the drop-down menu below.
is used in connection with a procedure or situation that may
result in serious injury or death.
CAUTION:
is used in connection with a procedure or situation that will
result in damage to the product.
is used to emphasize important information.
is used for extra tips on how to utilize the features and
functions of the device.
Safety precautions
WARNING:
Keep the USB cable away from medical devices such as pacemakers,
as well as key cards, credit cards and similar items. The USB
cable device connector includes a strong magnet which may
interfere with the operation of medical or other electronic
devices and items with magnetically stored data.
WARNING:
Allergic reactions or skin irritations may occur when the
product is in contact with skin, even though our products comply
with industry standards. In such event, stop use immediately and
consult a doctor.
WARNING:
Always consult your doctor before beginning an exercise program.
Overexertion may cause serious injury.
WARNING:
Only for recreational use.
WARNING:
Do not entirely rely on the GPS or battery lifetime of the
product. Always use maps and other backup material to ensure
your safety.
CAUTION:
Do not apply solvent of any kind to the product, as it may
damage the surface.
CAUTION:
Do not apply insect repellent on the product, as it may damage
the surface.
CAUTION:
Do not throw the product away, but treat it as electronic waste
to preserve the environment.
CAUTION:
Do not knock or drop the product, as it may get damaged.
CAUTION:
Colored textile straps might bleed onto other fabrics or skin
when new or wet.
At Suunto we use advanced sensors and algorithms to generate
metrics that can help you in your activities and adventures. We
strive to be as accurate as possible. However, none of the data
our products and services collect is perfectly reliable, nor are
the metrics they generate absolutely precise. Calories, heart
rate, location, movement detection, shot recognition, physical
stress indicators and other measurements may not match the real
world. Suunto products and services are intended for
recreational use only and are not meant for medical purposes of
any kind.
GETTING STARTED
Touch screen and buttons
Suunto 9 Peak
has a touch screen and three buttons you can use to navigate
through displays and features.
Swipe and tap
swipe up or down to move in displays and menus
swipe right and left to backwards and forwards in displays
swipe left or right to see additional displays and details
tap to select an item
tap the display to view alternate information
tap and hold to open in-context options menu
double-tap to return to time display from other displays
Upper button
press to move up in views and menus
Middle button
press to select an item
press to press to change displays
keep pressed to got back in settings menu
keep pressed to open in-context options menu
Lower button
press to move down in views and menus
While recording an exercise:
Upper button
press to pause or resume recording
keep pressed to change activity
Middle button
Lower button
press to mark a lap
keep pressed to lock and unlock buttons
Software updates
Software updates add important improvements and new features to
your watch.
Suunto 9 Peak
is updated automatically, if it is connected to Suunto app.
When an update is available and your watch is connected with
Suunto app, the software update will be downloaded to the watch
automatically. The status of this download can be viewed in Suunto
app.
Once the software is downloaded to your watch, the watch will
update itself during the night as long as the battery level is at
least 50% and no exercise is being recorded simultaneously.
If you want to install the update manually before it happens
automatically during the night, navigate to
Settings
General
and select
Software update
When the update is complete, the release notes will be visible
in Suunto app.
Suunto app
With the Suunto app, you can further enrich your
Suunto 9 Peak
experience. Pair your watch with the mobile app to sync your
activities, get mobile notifications, insights and more.
You cannot pair anything if airplane mode is on. Turn off
airplane mode before pairing.
To pair your watch with Suunto app:
Ensure your watch Bluetooth is on. Under the settings menu, go
to
Connectivity
Discovery
and enable it if it is not already.
Download and install Suunto app on your compatible mobile
device from the iTunes App Store, Google Play in addition to
several popular app stores in China.
Start Suunto app and turn on Bluetooth if it is not on
already.
Tap the watch icon in the upper-left of the app screen and
then tap “PAIR” to pair your watch.
Verify the pairing by typing the code that is displayed on
your watch in the app.
Some features require an internet connection over Wi-Fi or
mobile network. Carrier data connection fees may apply.
Optical heart rate measurement from the wrist is an easy and
convenient way to track your heart rate. Best results for
heart rate measurement may be affected by the following
factors:
The watch must be worn directly against your skin. No
clothing, however thin, can be between the sensor and your
skin
The watch may need to be higher on your arm than where
watches are normally worn. The sensor reads blood flow
through tissue. The more tissue it can read, the better.
Arm movements and flexing muscles, such as gripping a tennis
racket, can change the accuracy of the sensor readings.
When your heart rate is low, the sensor may not be able to
provide stable readings. A short warm up of a few minutes
before you start the recording helps.
Skin pigmentation and tattoos block light and prevent
reliable readings from the optical sensor.
The optical sensor may not provide accurate heart rate
readings for swimming activities.
For higher accuracy and quicker responses to changes in your
heart rate, we recommend using a compatible chest heart rate
sensor such as Suunto Smart Sensor.
WARNING:
The optical heart rate feature may not be accurate for every
user during every activity. Optical heart rate may also be
affected by an individual’s unique anatomy and skin
pigmentation. Your actual heart rate may be higher or lower
than the optical sensor reading.
WARNING:
Only for recreational use; the optical heart rate feature is
not for medical use.
WARNING:
Always consult a doctor before beginning a training program.
WARNING:
Allergic reaction or skin irritations may occur when
products are in contact with skin, even though our products
comply with industry standards. In such event, stop use
immediately and consult a doctor.
Adjusting settings
You can adjust all watch settings directly in the watch.
To adjust a setting:
Swipe down until you see the settings icon and tap the
icon.
Scroll through the settings menu by swiping up or down or
by pressing the upper or lower buttons.
Select a setting by tapping the setting name or pressing
the middle button when the setting is highlighted. Go back
in the menu by swiping right or selecting
Back
For settings with a value range, change the value by
swiping up or down or by pressing the upper or lower
button.
For settings with just two values, such as on or off,
change the value by tapping the setting or pressing the
middle button.
You can also access general settings from the watch face
by keeping the middle button pressed to open the shortcuts
menu.
Titanium bracelet adjustment
If your
Suunto 9 Peak
comes with a titanium bracelet, the length of the bracelet
can be adjusted to match your wrist by removing links or
adding links provided in the product box. We strongly advise
this adjustment be done by a professional clocksmith or
jeweler.
Due to the high risk of damaging the parts of the bracelet
while adjusting the length, Suunto strongly recommends you
take your watch to a jeweler or other professional to
adjust the size of the titanium bracelet. It should also
be explicitly noted that any adjustment using unsuitable
working methods and/or tools shall be deemed improper care
of the product. Suunto International Limited Warranty does
not cover possible defects or damage resulting from it.
For an improved sporting experience, Suunto recommends using
a silicone strap while exercising.
While recording an exercise you can lock the buttons by keeping
the lower right button pressed. Once locked, you cannot perform
any actions that requires button interaction (create laps,
pause/end exercise etc.) but it is possible to scroll the display
views and you can turn on the backlight with any button press if
the backlight is in automatic mode.
To unlock everything, keep the lower right button pressed again.
When you are not recording an exercise, the screen locks and dims
after one minute of inactivity. To activate the screen, press any
button.
The screen also goes to sleep (blank) after a period of
inactivity. Any movement turns the screen on again.
Automatic backlight
The backlight has three features that you can adjust: the level of
brightness (
Brightness
), how the standby backlight activates (
Standby
), and whether the backlight activates when you raise and turn
your wrist (
Raise to wake
The backlight features can be adjusted from the settings under
General
Backlight
The Brightness setting determines the overall intensity of the
backlight; Low, Medium or High.
The Standby setting controls the screen brightness when there
is no active backlight turned on (e.g. triggered by button
presses). The three Standby options are:
Adaptive: The standby light is adaptive to its surrounding
lighting conditions.
Fixed: The standby light is fixed to the brightness setting.
Off: The standby light is off.
The Raise to wake feature activates standby backlight in
regular time mode and activates backlight in exercise mode
when your wrist is lifted to watch reading position. The three
Raise to wake options are:
On: Raising your wrist in regular time mode or during an
exercise will activate backlight.
Exercise only: Raising your wrist will only turn on the
backlight during an exercise.
Off: The Raise to wake feature is turned off.
You can also set the backlight to be always on. Keep the middle
button pressed to enter the
Shortcuts
menu, scroll to
Backlight
and toggle the switch to force backlight on.
Tones and vibration
Tones and vibration alerts are used for notifications, alarms and
other key events and actions. Both can be adjusted from the
settings under
General
Tones
Under
General
Tones
General
, you can select from the following options:
All on
: all events trigger an alert
All off
: no events trigger alerts
Buttons off
: all events other than pushing buttons trigger alerts.
Under
General
Tones
Alarms
you can switch vibrations on and off.
You can select from the following options:
Vibration
: vibration alert
Tones
: sound alert
Both
: both vibration and sound alert.
Bluetooth connectivity
Suunto 9 Peak uses Bluetooth technology to send and receive
information from your mobile device when you have paired your
watch with the Suunto App. Same technology is also used when
pairing PODs and sensors.
However, if you do not want your watch to be visible for Bluetooth
scanners, you can activate or deactivate the discovery setting
Connectivity
Discovery
The Bluetooth can also be completely turned off by activating
airplane mode, see Airplane mode.
Airplane mode
Activate airplane mode when needed to turn off wireless
transmissions. You can activate or deactivate airplane mode from
the settings under
Connectivity
To pair anything with your device, you need to first turn off
airplane mode if you have it on.
Do Not Disturb mode
The Do Not Disturb mode is a setting that mutes all sounds and
vibrations and dims the screen, making it a very useful option
when wearing the watch in, for example, a theater or any
environment where you want the watch to operate as usual, but
silently.
To turn on/off the Do Not Disturb mode:
From the watch face, keep the middle button pressed to open the
shortcuts menu.
Swipe up or press the lower button to scroll down to the Do Not
Disturb mode.
Tap the screen or press the middle button to confirm your
selection.
If you have an alarm set, it sounds as normal and disables Do Not
Disturb mode unless you snooze the alarm.
Notifications
If you have paired your watch with the Suunto app, you can get
notifications of incoming calls and text messages, for example, on
your watch.
When you pair your watch with the app, notifications are on by
default. You can turn them off from the settings under
Notifications
Messages recieved from some apps used for communication might not
be compatible with Suunto 9 Peak.
When a notification arrives, a pop-up appears on the watch face.
If the message doesn't fit on the screen, press the lower right
button or swipe up to scroll through the full text.
Press
Actions
to interact with the notification (the available options vary
depending on your phone and which of your mobile apps sent the
notification).
For apps used for communcations you can use your watch to send a
Quick reply
. You can select and modify the predefined messages in Suunto app
(only available for Android users).
Notification history
If you have unread notifications or missed calls on your mobile
device, you can view them on your watch.
From the watch face, press the middle button and then press the
lower button to scroll through the notification history.
The notification history is cleared when you check the messages on
your mobile device.
Time and date
You set time and date during the initial startup of your watch.
After this, your watch uses GPS time to correct any offset.
Once you have paired with Suunto app, your watch gets updated
time, date, time zone and daylight-saving time from mobile
devices. Under
General
Time/date
, tap
Auto time update
to toggle the feature on and off.
You can manually adjust time and date from the settings under
General
Time/date
where you can also change time and date formats.
In addition to the main time, you can use dual time to follow the
time at a different location, for example, when you are traveling.
Under
General
Time/date
, tap
Dual time
to set the time zone by selecting a location.
Alarm clock
Your watch has an alarm clock that can sound once or repeat on
specific days. Activate the alarm from the settings under
Alarm
Alarm clock
Besides standard fixed alarms, you will also find an adaptive
alarm type based on data for sunrise and sunset. See Sunrise and
sunset alarms.
To set a fixed alarm time:
From the watch face, press the middle button to open the
shortcuts menu and scroll to
Alarms
First select how often you want the alarm to sound. The
options are:
Once
: alarm sounds once in the next 24 hours at the set time
Weekdays
: alarm sounds at the same time Monday thru Friday
Daily
: alarm sounds at the same time every day of the week
Set the hour and minutes and then exit the settings.
When the alarm sounds, you can dismiss it to end the alarm, or you
can select the snooze option. The snooze time is 10 minutes and
can be repeated up to 10 times.
If you let the alarm continue to sound, it will automatically
snooze after 30 seconds.
Language and unit system
You can change your watch language and unit system from the
settings under
General
Language
Watch faces
Suunto 9 Peak comes with several watch faces to choose from, both
digital and analog styles.
To change the watch face:
From your current watch face view, keep the middle button
pressed to open the shortcuts menu.
Scroll to
Watch face
and tap or press the middle button to enter.
Swipe up and down to scroll through the watch face previews and
tap on the one you want to use.
Swipe up and down to scroll through the color options and tap on
Each watch face has additional information, such as date or dual
time. Tap the display to switch between views.
Moon phases
In addition to sunrise and sunset times, your watch can track moon
phases. The moon phase is based on date you have set in your
watch.
The moon phase is available as a view in the outdoor style watch
face. Tap on the screen to change the lower row until you see the
moon icon and percentage.
The phases are presented as an icon with percentage as follows:
Power savings
Your watch includes a power saving option that turns off all
vibration, daily HR and Bluetooth notifications to extend battery
life during normal daily use. For power saving options while
recording activities, see Battery power management.
Enable/disable power saving from the settings under
General
Power saving
Power saving is automatically enabled when the battery level
reaches 10%.
Sunrise and sunset alarms
The sunrise/sunset alarms in your Suunto 9 Peak are adaptive
alarms based on your location. Instead of setting a fixed time,
you set the alarm for how much in advance you want to be alerted
before the actual sunrise or sunset.
The sunrise and sunset times are determined via GPS, so your watch
relies on the GPS data from the last time you used GPS.
To set sunset/sunrise alarms:
Press the middle button to open the shortcut menu.
Scroll down to
Alarms
and enter by pressing the middle button.
Scroll to the alarm that you want to set and select by
Set the desired hours prior to sunrise/sunset by scrolling
up/down with the upper and lower buttons and confirming with
the middle button.
Set minutes in the same way.
Press the middle button to confirm and exit.
A watch face is also availalbe that shows sunrise and sunset
times.
Sunrise and sunset times and alarms require a GPS fix. The times
are blank until GPS data is available.
Storm alarm
A significant drop in barometric pressure typically means a storm
is coming and you should take cover. When the storm alarm is
active, Suunto 9 Peak sounds an alarm and displays a storm symbol
when the pressure drops 4 hPa (0.12 inHg) or more during a 3-hour
period.
To activate the storm alarm:
Scroll down to
Alarms
Scroll to
Storm alarm
and toggle on/off by pressing the middle button.
When a storm alarm sounds, pressing any button ends the alarm. If
no button is pressed, the alarm notification lasts for one minute.
The storm symbol remains on the display until the weather
conditions stabilize (pressure drop slows down).
Position formats
The position format is the way your GPS position is displayed on
the watch. All the formats relate to the same location, they only
express it in a different way.
You can change the position format in the watch settings under
Navigation
Position format
Latitude/longitude is the most commonly used grid and has three
different formats:
WGS84 Hd.d°
WGS84 Hd°m.m'
WGS84 Hd°m's.s
Other common position formats available include:
UTM (Universal Transverse Mercator) gives a two-dimensional
horizontal position presentation.
MGRS (Military Grid Reference System) is an extension of UTM and
consists of a grid zone designator, 100,000-meter square
identifier and a numerical location.
Suunto 9 Peak also supports the following local position formats:
BNG (British)
ETRS-TM35FIN (Finnish)
KKJ (Finnish)
IG (Irish)
RT90 (Swedish)
SWEREF 99 TM (Swedish)
CH1903 (Swiss)
UTM NAD27 (Alaska)
UTM NAD27 Conus
UTM NAD83
NZTM2000 (New Zealand)
Some position formats cannot be used in the areas north of 84° and
south of 80°, or outside the countries that they are intended for.
If you are outside the allowed area, your location coordinates
cannot be displayed on the watch.
Device info
You can check details of your watch software and hardware from the
settings under
General
About
In addition to 24/7 activity monitoring, you can use your watch
to record your training sessions or other activities to get
detailed feedback and follow your progress.
To record an exercise:
Put on a heart rate sensor (optional).
Swipe down or press the upper button to open the launcher.
Tap the exercise icon or press the middle button.
Swipe up or down to scroll through the sport modes and tap
on the one you want to use. Alternatively, scroll with the
upper and lower buttons and select with the middle button.
Above the start indicator, a set of icons appear, depending
on what you are using with the sport mode (such as heart
rate and connected GPS). The arrow icon (connected GPS)
flash gray while searching and turn green once a signal is
found. The heart icon (heart rate) flash gray while
searching and when once a signal is found, it turns into a
colored heart attached to a belt if you are using a heart
rate sensor or a colored heart without the belt if you are
using the optical heart rate sensor. There is also a battery
estimation visible, that tells you how many hours you can
exercise before the battery runs out.
If you are using a heart rate sensor but the icon turns to
green only (meaning that the optical heart rate sensor is
active), check that the heart rate sensor is paired, see
Pairing PODs and sensors, and select the sport mode again.
You can wait for each icon to turn green or start the
recording as soon as you like by pressing the middle button.
Once the recording is started, the selected heart rate
source is locked and cannot be changed during the ongoing
training session.
While recording, you can switch between displays with the
middle button or by using the touch screen if it is enabled.
Press the upper button to pause the recording. Stop and save
with the lower button or continue with the upper button.
If the sport mode you selected has options, such as setting a
duration target, you can adjust them before starting the
recording by swiping up or pressing the lower button. You can
also adjust sport mode options while recording by keeping the
middle button pressed.
During the recording, you can tap on the screen to get a pop-up
that shows current time and battery level.
If you are using a multisport mode, switch sports by keeping the
upper button pressed.
After you stop the recording, you are asked how you felt. You
can answer or skip the question. (See Feeling) Then you get a
summary of the activity that you can browse through with the
touch screen or buttons.
If you made a recording you don't want to keep, you can delete
the log entry by scrolling to the bottom of the summary and
tapping the delete button. You can also delete logs in the same
way from the logbook.
Sport modes
Your watch comes with a wide range of pre-defined sport modes.
The modes are designed for specific activities and purposes,
from a casual walk outside to a triathlon race.
When you record an exercise (see Recording an exercise), you can
swipe up and down to see the short list of sport modes. Tap the
icon at the end of the short list to view the complete list and
see all sport modes.
Each sport mode has a unique set of displays that show different
data depending on the selected sport mode. You can edit and
customize the data shown on the watch display during your
exercise with Suunto app.
It is possible to set different targets with your Suunto 9 Peak
when exercising.
If the sport mode you selected has targets as an option, you can
adjust them before starting the recording by swiping up or
To exercise with general target:
Before you start an exercise recording, swipe up or press the
lower button to open the sport mode options.
Tap
Target
Select
Duration
or
Distance
Select your target.
Swipe right to go back to the sport mode options.
When you have general targets activated, a target gauge is
visible on every data display showing your progress.
You will also receive a notification when you have reached 50%
of your target and when your selected target is fulfilled.
To exercise with intensity target:
Tap
Intensity zones
Select
HR zones
Pace zones
or
Power zones
. (The options depends on selected sport mode and if you have
a power pod paired with the watch).
Select your target zone.
Navigating during exercise
You can navigate a route or to a POI while you are recording an
exercise.
The sport mode you are using needs to have GPS enabled to be
able to access the navigation options. If the sport mode GPS
accuracy is OK or Good, when you select a route or POI, the GPS
accuracy is changed to Best.
To navigate during exercise:
Create a route or POI in Suunto app and sync your watch if you
haven't done so already.
Select a sport mode that uses GPS and then swipe up or press
the lower button to open the options. Alternatively, start
your recording first, and then keep the middle button pressed
Scroll to
Navigation
and tap the setting or press the middle button.
Swipe up and down or press the upper and lower buttons to
select a navigation option and press the middle button.
Select the route or POI you want to navigate and press the
middle button. Then press the upper button to start
navigating.
If you have not started the exercise recording yet, the last
step takes you back to the sport mode options. Scroll up to the
start view and start your recording as normal.
While exercising, swipe right or press the middle button to
scroll to the navigation display where you will see the route or
POI that you selected. For more information on the navigation
display, see Navigating to a POI and Routes.
While in this display you can swipe up or press the lower button
to open your navigation options. From the navigation options,
you can, for example, select a different route or POI, check
your current location coordinates, as well as end navigation by
selecting
Breadcrumb
Snap to route
In urban surroundings the GPS can struggle to follow you
correctly. If you select one of you predefined routes and follow
that route, the watch GPS is used purely to locate where you are
on the predefined route, not actually creating a track from the
run. The recorded track will be identical to the route used for
the run.
To use Snap to route during exercise:
Create a route in Suunto app and sync your watch if you
Scroll to
Navigation
and tap it or press the middle button.
Select
Snap to route
Select the route you want to use and press the middle button.
Press the upper button or tap
Navigate
Start your exercise as normal and follow the selected route.
Your Suunto 9 Peak has a battery power management system uses
intelligent battery technology to help ensure you watch does not
run out of power when you need it most.
Before you start recording an exercise (see Recording an
exercise) you see an estimate of how much battery life you have
left in the current battery mode.
There are four predefined battery modes;
Performance
(default),
Endurance
Ultra
and
Tour
. Changing between these modes will change the lifetime of the
battery but also change the performance of the watch.
By default, Ultra and Tour mode disable all HR tracking (both
wrist and chest). To enable HR tracking (in Ultra and Tour mode)
go to
Options
under the start indicator.
While in the start display, tap
Options
Battery mode
to change battery modes and see how each mode affects the
You can also quickly change the battery mode in the start
display by pressing the upper button.
In addition to these four predefined battery modes, you can
create a custom battery mode with your own desired settings. The
custom mode is specific for that sport mode, making it possible
to create a custom battery mode for every sport mode.
If while exercising you start navigating or use navigation data
like estimated time of arrival (ETA), the GPS goes to
Best
, regardless of the battery mode.
Battery notifications
In addition to the battery modes, your watch uses smart
reminders to help you ensure you have enough battery life for
your next adventure. Some reminders are preemptive based on, for
example, your activity history. You also get notified, for
example, when the watch notices you are running low on battery
while recording an activity. It will automatically suggest
changing to a different battery mode.
Your watch will alert you once when the battery is at 20% and
again at 10%.
Swimming
You can use your Suunto 9 Peak for swimming in pools or
openwater.
When you use a pool swimming sport mode, the watch relies on the
pool length to determine distance. You can change the pool
length as needed under the sport mode options before you start
swimming
Openwater swimming relies on GPS to calculate distance. Because
GPS signals do not travel under water, the watch needs to come
out of the water periodically, such as with the freestyle
stroke, to get a GPS fix.
These are challenging conditions for GPS, so it is important
that you have a strong GPS signal before you jump in the water.
To ensure good GPS, you should:
Sync your watch with your online account before you go
swimming to optimize your GPS with the latest satellite orbit
data.
After you select an openwater swimming sport mode and a GPS
signal is acquired, wait at least three minutes before
starting your swim. This gives the GPS time to establish
strong positioning.
Interval training
Interval workouts are a common form of training consisting of
repetitive sets of high and low intensity efforts. With Suunto 9
Peak, you can define in the watch your own interval training for
each sport mode.
When defining your intervals, you have four items to set:
Intervals: on/off toggle that enables interval training. When
you toggle this on, an interval training display is added to
your sport mode.
Repetitions: the number of interval + recovery sets you want
to do.
Interval: the length of your high intensity interval, based on
distance or duration.
Recovery: the length of your rest period between intervals,
based on distance or duration.
Keep in mind that if you use distance to define your intervals,
you need to be in a sport mode that measures distance. The
measurement can be based on GPS, or from a foot or bike POD, for
example.
If you are using intervals, you cannot activate navigation.
To train with intervals:
the lower button to open the sport mode options.
Scroll down to
Intervals
Toggle intervals on and adjust the settings described above.
Scroll back up to the start view and start your exercise as
normal.
Swipe left or press the middle button until you reach the
intervals display and press the upper button when you are
ready to start your interval training.
If you want to stop the interval training before you have
completed all your repetitions, keep the middle button
pressed to open the sport mode options and toggle off
Intervals
While you are in the intervals display, buttons work as normal,
for example, pressing the upper button pauses the exercise
recording, not just the interval training.
After you have stopped your exercise recording, interval
training is automatically toggled off for that sport mode. The
other settings, however, are maintained so you can easily start
the same workout the next time you use the sport mode.
Display theme
To increase the readability of your watch screen while
exercising or navigating, you can change between light and dark
themes.
With the light theme, the display background is light and the
numbers dark.
With the dark theme, the contrast is reverse, with the
background dark and the numbers light.
The theme is a global setting that you can change in your watch
from any of your sport mode options.
To change display theme in sport mode options:
Go to any sport mode and swipe up or press the lower button to
Scroll down to
Theme
Switch between Light and Dark by swiping up or down or by
pressing the upper and lower buttons, and accept with the
middle button.
Scroll back up to exit the sport mode options, and start (or
exit) the sport mode.
Autopause
Autopause pauses the recording of your exercise when your speed
is less than 2 km/h (1.2 mph). When your speed increases to more
than 3 km/h (1.9 mph), the recording continues automatically.
You can turn autopause on/off for each sport mode the sport mode
settings in the watch before you start your exercise recording.
If autopause is on during a recording, a pop-up notifies you
when the recording is paused automatically.
Tap the resume pop-up to check the current time and battery
level.
You can let the recording resume automatically when you start
moving again, or manually resume from the pop-up screen by
Feeling
If you are training regularly, following how you feel after each
session is an important indicator of your overall physical
condition. A coach or personal trainer can also use your feeling
trend to track your progress over time.
There are five degrees of feeling to choose from:
Poor
Average
Good
Very good
Excellent
What these options mean exactly are up to you (and your coach)
to decide. The important thing is that you use them
consistently.
For each training session, you can record how you felt in the
watch directly after stopping the recording by answering the '
How was it?
' question.
You can skip answering the question by pressing the middle
button.
Media controls
Your Suunto 9 Peak can be used to control the music, podcast,
other media played on your phone or being cast from your phone
to another device. The media controls are on by default but can
be turned off under
Settings
Media controls
You need to pair your watch with your phone before you can use
Media controls.
To access the media controls, press the middle button from watch
face or, during an exercise, press the middle button until the
media control display is shown.
In the media control display, the buttons have the following
functions:
Play/Pause:
Upper right button
Next track/episode:
Lower right button
Previous track/episode:
Upper right button (long press)
Volume:
Lower right button (long press), will open volume controls
In the volume controls display, the upper right button
will increase the volume and the lower right button will
decrease the volume. Press the middle button to return to
media control display.
Press the middle button to exit the media control display.
If your watch has a touch screen, the media controls can also be
used by tapping the icons on the screen.
Logbook
You can access the logbook by swiping down or pressing the upper
button until you see the logbook icon..
Tap on the log entry you want to view and scroll through the log
by swiping up or down or by pressing the upper right or lower
right buttons.
The log entry remains gray until it has been synced with your
online account.
To exit the log, swipe right or keep the middle button pressed.
You can also just double-tap on the screen to return to the
watch face.
Navigation
Altitude navigation
If you are navigating a route that has altitude information, you
can also navigate based on ascent and descent using the altitude
profile display. While in the main navigation display (where you
see your route), swipe left or press the middle button to switch
to the altitude profile display.
The altitude profile display shows you the following
information:
top: your current altitude
center: altitude profile showing your current position
bottom: remaining ascent or descent (tap screen to change
views)
If you stray too far off from the route while using altitude
navigation, your watch will give you an
Off route
message in the altitude profile display. If you see this
message, scroll to the route navigation display to get back on
track before continuing with altitude navigation.
Bearing navigation
Bearing navigation is a feature that you can use outdoors to
follow the target path for a location you see or have looked at
from map ahead. You can use this feature stand alone as a
compass or together with a paper map.
If you set the target distance and altitude while setting the
direction, your watch can be used to navigate to that target
location.
To use bearing navigation during an exercise (only available for
outdoor activities):
Tap
Navigation
Select
Bearing
If needed, calibrate the compass by following the on-screen
instructions.
Point the blue arrow on the screen towards your target
location and press the middle button.
If you do not know the distance and altitude to the location,
select
No
Press the middle button to acknowledge the set bearing and go
If you know the distance and altitude to the location, select
Yes
Enter the distance and altitude to the location.
Press middle button to acknowledge the set bearing and go back
To use bearing navigation without exercising:
Scroll to
Navigation
by swiping down or pressing the top button.
Select
Bearing
instructions.
select
No
and follow the blue arrow to the location.
If you do know the distance and altitude to the location,
select
Yes
Enter the distance and altitude to the location and follow the
blue arrow to the location. The display will also show the
distance and altitude left to the location.
Set a new bearing by swiping up or by pressing the lower
button.
End the navigation by pressing the top button.
Compass
Suunto 9 Peak has a digital compass that allows you to orient
yourself in relation to magnetic north. The tilt-compensated
compass gives you accurate readings even if the compass is not
horizontally level.
You can access the compass from the launcher under
Navigation
Compass
The compass display includes the following information:
Arrow pointing to magnetic north
Heading cardinal
Heading in degrees
Time of day (local time) or battery level; tap on screen to
change views
To exit the compass, swipe right or keep the middle button
pressed.
While you are in the compass display, you can swipe up from the
bottom of the screen or press the lower button to open a list of
shortcuts. The shortcuts give you quick access to navigation
actions such as checking the coordinates of your current
location or selecting a route to navigate.
Swipe down or press the upper button to exit the list of
shortcuts.
Calibrating compass
If the compass is not calibrated, you are prompted to calibrate
the compass when you enter the compass display.
If you want to re-calibrate the compass, you can start the
calibration again from the settings under
Navigation
Navigation settings
Calibrate compass
Setting declination
To ensure correct compass readings, set an accurate declination
value.
Paper maps point to true north. Compasses, however, point to
magnetic north – a region above the Earth where the Earth’s
magnetic fields pull. Because magnetic North and true North are
not at the same location, you must set the declination on your
compass. The angle in between magnetic and true north is your
declination.
The declination value appears on most maps. The location of
magnetic north changes yearly, so the most accurate and
up-to-date declination value can be found from websites such as
www.magnetic-declination.com
Orienteering maps, however, are drawn in relation to magnetic
north. If you are using an orienteering map, you need to turn
the declination correction off by setting the declination value
to 0 degrees.
You can set your declination value from the settings under
Navigation
Navigation settings
Declination
Find back
If you are using GPS when recording an activity, Suunto 9 Peak
automatically saves the starting point of your exercise. With
Find back, Suunto 9 Peak can guide you directly back to your
starting point.
To start Find back:
Start an exercise with GPS.
Swipe left or press the middle button until you have reached
the navigation display.
Swipe up or press the lower button to open the shortcut
menu.
Scroll to Find back and tap the screen or press the middle
button to select.
The navigation guidance is shown as the last display on the
To view additional details about your current position:
From the Find back view, swipe up or press the lower button
Select
Details
Swipe up or press the lower button to scroll through the
list.
Swipe right or press the middle button to exit the details view.
Routes
You can use your Suunto 9 Peak to navigate routes. Plan your
route with Suunto app and transfer it to your watch with the
next sync.
To navigate on a route:
Scroll to
Navigation
and tap on the icon or press the middle button.
Scroll to
Routes
and press the middle button to open your list of routes.
Scroll to the route you want to navigate to and press the
middle button.
Select
Start exercise
if you want to use the route for exercising or select
Navigate only
if you only want to navigate the route.
If you only navigate the route, nothing will be save or
logged in Suunto app.
Press the upper button again at any time to stop navigating.
Tap the screen to switch between the overview map and a more
detailed view.
In the detailed view, zoom in and out by tapping the screen or
keeping the middle button pressed. Adjust the zoom level with
the upper and lower buttons.
While you are in the navigation display, you can swipe up from
the bottom of the screen or press the lower button to open a
list of shortcuts. The shortcuts give you quick access to
navigation actions such as saving your current location or
selecting another route to navigate.
It is also possible to start an exercise from the shortcut list.
Selecting
Start exercise
will open the sport modes menu and you can start recording your
exercise. If you end the exercise, the navigation will also end.
All sport modes with GPS also have a route selection option. See
Navigating during exercise.
Navigation guidance
As you navigate a route, your watch helps you stay on the
correct path by giving you additional notifications as you
progress along the route.
For example, if you go more than 100 m (330 ft) off route, the
watch notifies you that you are not on the right track, as well
as lets you know when you are back on route.
Once you reach a waypoint of POI on the route, you get an
informative popup showing you the distance and estimated time en
route (ETE) to the next waypoint or POI.
If you navigating a route that crosses itself, such as a
figure-8, and you make a wrong turn at the crossing, your watch
assumes you are intentionally going in a different direction on
the route. The watch shows the next waypoint based on the
current, new direction of travel. So, keep an eye on your
breadcrumb trail to ensure you are going the right way when you
are navigating a complicated route.
Turn-by-turn navigation
When creating routes in Suunto app, you can choose to activate
turn-by-turn instructions. When the route is transferred to your
watch and used for navigation, it will give you turn-by-turn
instructions with a sound alert and information on which way to
turn.
Turn-by-turn navigation powered by Komoot
If you are a Komoot member, you can find or plan routes with
Komoot and sync these to your Suunto 9 Peak via Suunto app. In
addition, your exercises recorded with your watch will
automatically be synchronized to Komoot.
When using route navigation with your Suunto 9 Peak together
with routes from Komoot, your watch will give you turn-by-turn
instructions with a sound alert and a text on which way to turn.
To use turn-by-turn navigation powered by Komoot:
Register at Komoot.com
In Suunto app, select partner services.
Select Komoot and connect by using the same credentials you
used at the Komoot registration.
All your selected or planned routes (called “tours” in Komoot)
in Komoot will automatically synchronize to Suunto app, which
you then easily can transfer to your watch.
Follow the instructions in section Routes and select your route
from Komoot to get turn-by-turn instructions.
A point of interest, or POI, is a special location, such as
camping spot or vista along a trail, you can save and navigate
to later. You can create POIs in Suunto app from a map and do
not have to be at the POI location. Creating a POI in your watch
is done by saving your current location.
Each POI is defined by:
POI name
POI type
Date and time created
Latitude
Longitude
Elevation
You can store up to 250 POIs in your watch.
Adding and deleting POIs
You can add a POI to your watch either with Suunto app or by
saving your current location in the watch.
If you are outside with your watch and come across a spot you
want to save as a POI, you can add the location directly in your
watch.
To add a POI with your watch:
Scroll to
Navigation
Your location
Wait for the watch to activate GPS and find your location.
When the watch displays your latitude and longitude, press the
upper button to save your location as a POI and select the POI
type.
By default the POI name is the same as the POI type (with a
running number after it). You can edit the name later in
Suunto app.
Deleting POIs
You can remove a POI by deleting the POI from the POI list in
the watch or removing it in Suunto app.
To delete a POI in your watch:
Scroll to
Navigation
POIs
Scroll to the POI you want to remove from the watch and press
the middle button.
Scroll to the end of the details and select
Delete
When you delete a POI from your watch, the POI is not
permanently deleted.
To permanently delete a POI, you need to delete the POI in
Suunto app.
Navigating to a POI
You can navigate to any POI that is in your watch POI list.
When navigating to a POI, your watch uses full power GPS.
To navigate to a POI:
Scroll to
Navigation
Scroll to POIs and press the middle button to open your list
of POIs.
Scroll to the POI you want to navigate to and press the middle
button.
Press the upper button to start navigating.
The POI navigation has two views:
POI view with direction indicator and distance to the POI
map view showing your current location relative to the POI and
your breadcrumb trail (the track you have traveled)
Swipe left or right, or press the middle button, to switch
between views.
While in the POI view, tap on the screen to see additional
information in the lower row such as altitude difference between
current position and POI and estimated time of arrival (ETA) or
en route (ETE).
In the map view, other POIs nearby are shown in gray. Tap on the
screen to switch between the overview map and a more detailed
view. In the detailed view, you adjust the zoom level by
pressing the middle button and then zooming in and out with the
While navigating, you can swipe up from the bottom of the screen
or press the lower button to open a list of shortcuts. The
shortcuts give you quick access to POI details and actions such
as saving your current location or selecting another POI to
navigate to, as well as ending navigation.
POI types
The following POI types are available in Suunto 9 Peak:
generic point of interest
Bedding (animal, for hunting)
Begin (start of a route or trail)
Big game (animal, for hunting)
Bird (animal, for hunting)
Building, home
Cafe, food, restaurant
Camp, camping
Car, parking
Cave
Cliff, hill, mountain, valley
Coast, lake, river, water
Crossroad
Emergency
End (end of a route or trail)
Fish, fishing spot
Forest
Geogache
Hostel, hotel, lodging
Info
Meadow
Peak
Prints (animal tracks, for hunting)
Road
Rock
Rub (animal marking, for hunting)
Scrape (animal marking, for hunting)
Shot (for hunting)
Sight
Small game (animal, for hunting)
Stand (for hunting)
Trail
Trail cam (for hunting)
Waterfall
Daily activity
Activity monitoring
Your watch keeps track of your overall activity level throughout
the day. This is an important factor whether you just aim to be
fit and healthy or you are training for an upcoming competition.
It is good to be active, but when training hard, you need to
have proper rest days with low activity.
The activity counter automatically resets at midnight every day.
At the end of the week (Sunday), the watch provides a summary of
your activity showing your average for the week and daily
totals.
From the watch face display, swipe up or press the lower button
to see your total steps for the day.
Your watch counts steps using an accelerometer. The total step
count accumulates 24/7, also while recording training sessions
and other activities. However, with some specific sports, such
as swimming and cycling, steps are not counted.
In addition to steps, you can tap on the display to see
estimated calories for the day.
The large number in the center of the display is the estimated
amount of active calories you have burned so far during the day.
Below this you see the total calories burned. The total includes
both active calories and your Basal Metabolic Rate (see below).
The ring in both displays indicates how close you are to your
daily activity goals. These targets can be adjusted to your
personal preferences (see below)
You can also check your steps over the last seven days with a
swipe to the left. Swipe left or press the middle button again
to see calories consumption.
Swipe up to check your activity over the last seven days in
numbers instead of a graph.
Activity goals
You can adjust your daily goals for both steps and calories.
While in the activity display, tap and hold your finger on the
screen or keep the middle button pressed to open the activity
goal settings.
When setting your steps goal, you define the total number of
steps for the day.
The total calories you burn per day is based on two factors:
your Basal Metabolic Rate (BMR) and your physical activity.
Your BMR is the amount of calories your body burns while at
rest. These are the calories your body needs to stay warm and
perform basic function like blink your eyes or beat your heart.
This number is based on your personal profile, including factors
such as age and gender.
When you set a calorie goal, you define how many calories you
want to burn in addition to your BMR. These are your so-called
active calories. The ring around the activity display advances
according to how many active calories you burn during the day
compared to your goal.
Instant HR
The instant heart rate (HR) display provides a quick snapshot of
your heart rate.
From the watch face view, swipe up or press the lower button to
scroll to the HR display.
Swipe down or press the upper button to exit the display and
return to the watch face view.
Daily HR
The daily HR display provides a 12-hour view of your heart rate.
This is a helpful source of information about, for example, your
recovery after a hard training session.
The display shows your heart rate over 12 hours as a graph. The
graph is plotted using your average heart rate based on
24-minute time slots. In addition, by swiping up or pressing the
lower button, you get an estimation of your average hourly
calorie consumption rate and your lowest heart rate during the
12-hour period.
Your minimum heart rate from the last 12 hours is a good
indicator of your recovery state. If it is higher than normal,
you probably are not yet fully recovered from your last training
session.
If you record an exercise, the daily HR values reflect the
elevated heart rate and calorie consumption from your training.
But keep in mind that the graph and consumption rates are
averages. If your heart rate peaks at 200 bpm while exercising,
the graph does not show that maximum value, but rather the
average from the 24 minutes during which you hit that peak rate.
Before you can see the daily HR display values, you need to
activate the daily HR feature. You can toggle the feature on or
Activity
. If you are in the daily HR display, you can also access the
activity settings by keeping the middle button pressed.
With the daily HR feature on, your watch activates the optical
heart rate sensor on a regular basis to check your heart rate.
This slightly increases battery power consumption.
Once activated, your watch needs 24 minutes before it can start
display daily HR information.
To view daily HR:
to scroll to the HR display.
Swipe left to enter the daily HR display.
Swipe up or press the lower button to see your calorie
consumption.
Blood oxygen
WARNING:
Suunto 9 Peak is not a medical device and the blood oxygen level
indicated by Suunto 9 Peak is not intended for diagnosing or
monitoring medical conditions.
You can measure your blood oxygen levels with Suunto 9 Peak.
Blood oxygen level can provide an indication of overtraining or
fatigue and the measurement can also be a helpful indicator of
high altitude acclimation progress.
Normal blood oxygen levels are between 96% and 99% at sea level.
At high altitudes, healthy values can be slightly lower.
Successful acclimation to high altitude makes the value increase
again.
You can see your blood oxygen level in the Heart rate view:
From the watch face, press the lower button or swipe up to
enter the
Heart rate
display.
Tap to enter the
Blood oxygen
display.
Hold your hand still while the watch is measuring.
If the measuring failed, please follow the in-watch
instructions.
When the measuring is complete, your blood oxygen value is
displayed.
You can also measure your blood oxygen level during your sleep,
see Sleep tracking.
Outdoor insight
Suunto 9 Peak constantly measures absolute air pressure using
the built-in pressure sensor. Based on this measurement and your
altitude reference value, it calculates altitude or air
pressure.
CAUTION:
Keep the area around the two air pressure sensor holes located
at six o'clock on the side of your watch free of dirt and sand.
Never insert any objects into the holes as this may damage the
sensor.
Swipe up or press the lower button to view the current altitude
and barometric pressure.
Tap the display to view the current temperature.
Swipe left or press the middle button to switch between
altimeter and barometer trend graphs.
Be sure to have your altitude reference value set correctly (see
Altimeter). The altitude of your current location can be found
from most topographic maps or major on-line map services such as
Google Maps.
Changes in local weather conditions affect altitude readings. If
local weather changes often, you should reset the altitude
reference value regularly, preferably before starting your next
journey.
While in the altimeter or barometer graph view, keep the middle
button pressed for quick access to the outdoor settings where
you can adjust the reference value.
Automatic alti-baro profile
Weather and altitude changes both cause a change in air
pressure. To handle this, Suunto 9 Peak automatically switches
between interpreting changes in air pressure as altitude or
weather changes based on your movement.
If your watch senses vertical movement, it switches to measuring
altitude. When you are viewing the altitude graph, it is updated
with a maximum delay of 10 seconds.
If you are at a constant altitude (less than 5 meters of
vertical movement within 12 minutes), your watch interprets air
pressure changes as weather changes and adjusts the barometer
graph accordingly.
Altimeter
Suunto 9 Peak uses barometric pressure to measure altitude. To
get accurate readings, you need to define an altitude reference
point. This can be your current elevation if you know the exact
value. Alternatively, you can use FusedAlti (see FusedAlti™) to
set your reference point automatically.
Set your reference point from the settings under
Outdoor
Training insight
Your watch provides an overview of your training activity.
Swipe up or press the lower button to scroll to the training
insight view
Swipe left or press the middle button twice to see a graph with
all your activities for the last 3 weeks and the average
duration. Tap the screen to toggle between the different
activities you have done for the last 3 weeks.
Swipe up or press the lower right button to see a summary of
your current week. The summary includes duration and calories.
Swiping up when a specific activity is chosen will show details
of that activity.
Recovery
Recovery time is an estimate in hours of how long your body
needs to recuperate after training. The time is based on the
duration and intensity of your recorded activities, as well as
your overall fatigue.
Recovery time accumulates from all types of exercise. In other
words, you accumulate recovery time on long, low intensity
training session as well as at high intensity.
The time is cumulative across training sessions, so if you train
again before the time has expired, the newly accumulated time is
added to the remainder from your previous training session.
To view your recovery time, from the watch face, swipe up or
press the lower right button until you see the training and
recovery display. Tap to toggle between training and recovery.
Because recovery time is an estimation only, the accumulated
hours count down steadily regardless of your fitness level or
other individual factors. If you are very fit, you may recover
faster than estimated. On the other hand, if you have the flu,
for example, your recovery may be slower than estimated.
Sleep tracking
A good night's sleep is important for a healthy mind and body.
You can use your watch to track your sleep and follow how much
sleep you are getting on average.
When you wear your watch to bed, Suunto 9 Peak tracks your sleep
based on accelerometer data.
To track sleep:
Go to your watch settings, scroll down to
Sleep
Toggle on
Sleep tracking
Set the times for going to bed and waking up according to
your normal sleep schedule.
After you have defined your bedtime, you can choose to have your
watch in Do Not Disturb mode during your sleeping hours and also
choose if you want to measure your Blood oxygen during your
sleep.
Step 3 above, defines your bedtime. Your watch uses that period
to determine when you are sleeping (during your bedtime) and
reporting all sleep as one session. If you get up for a drink of
water during the night, for example, your watch still counts any
sleep after that as the same session.
If you go to bed
before
your bedtime and also wake up
after
your bedtime, your watch does not count that as a sleep session.
You should set your bedtime according to the earliest you may go
to bed and the latest you may wake up.
Once you have enabled sleep tracking, you can also set your
sleep target. A typical adult needs between 7 and 9 hours of
sleep per day, though your ideal amount of sleep may vary from
the norms.
Sleep trends
When you wake up, you are greeted with a summary of your sleep.
The summary includes, for example, the total duration of your
sleep, as well as the estimated time you were awake (moving
around) and the time you were in deep sleep (no movement).
In addition to the sleep summary, you can follow your overall
sleep trend with the sleep insight. From the watch face, press
Sleep
display. The first view shows your last sleep compared to your
sleep target.
While in the sleep display, you can swipe left to see your
average sleep over the last seven days. Swipe up to see your
actual sleeping hours for the last seven days.
While in the average sleep display you can swipe left to see a
graph over your average HR values for the last seven days.
Swipe up to see the actual HR values for the last seven days.
From the
Sleep
display, you can keep the middle button pressed to access sleep
tracking settings.
All sleep measurements are based on movement only, so they are
estimates that may not reflect your actual sleep habits.
Sleep quality
In addition to duration, your watch can also assess sleep
quality by following your heart rate variability during sleep.
The variation is an indication of how well your sleep is helping
you rest and recover. Sleep quality is shown on scale from 0 to
100 in the sleep summary, with 100 being the best quality.
Measuring heart rate and blood oxygen while sleeping
If you wear your watch during the night, you can get additional
feedback on your heart rate and blood oxygen level (needs to be
activated in the sleep tracking settings) while sleeping. To
keep the optical heart rate on during the night, ensure that
Daily HR is enabled (see Daily HR).
Automatic Do Not Disturb mode
You can use the auto Do Not Disturb setting to automatically
enable Do Not Disturb mode while you sleep.
Stress and recovery
Your resources are a good indication of your body's energy
levels and translate into your ability to handle stress and cope
with the day's challenges.
Stress and physical activity deplete your resources, while rest
and recovery restore them. Good sleep is an essential part of
ensuring your body has the resources it needs.
When your resource levels are high, you will likely feel fresh
and energetic. Going for a run when your resources are high
means you'll probably have a great run, because your body has
the energy it needs to adapt and improve as a result.
Being able to track your resources can help you manage and use
them wisely. You can also use your resource levels as a guide to
identify stress factors, personally effective recovery boosting
strategies, and the impact of good nutrition.
Stress and recovery uses optical heart sensor readings and to
get those during the day, daily HR must be enabled, see Daily
HR.
It is important that your Max HR and Rest HR are set to match
your heart rate to ensure that you get the most accurate
readings. By default, the Rest HR is set to 60 bpm and the Max
HR is based on your age.
These HR values can easily be changed in the settings under
PERSONAL
Use the lowest heart rate reading measured during your sleep as
your Rest HR.
Press the lower right button to scroll to the stress and
recovery display.
The gauge around this display indicates your overall resource
level. If it is green, it means you are recovering. The status
and time indicator tell you your current state (active,
inactive, recovering or stressed) and for how long you have been
in that state. In this screenshot, for example, you have been
recovering for the last four hours.
Press the middle button to see a bar chart of your resources
over the last 16 hours.
The green bars indicate periods where you have been recovering.
The percentage value is an estimate of your current resource
level.
Fitness level
Good aerobic fitness is important for your overall health,
well-being and sports performance.
Your aerobic fitness level is defined as VO2max (maximal oxygen
consumption), a widely recognized measure of aerobic endurance
capacity. In other words, VO2max shows how well your body can
use oxygen. The higher your VO2max, the better you can use
oxygen.
The estimation of your fitness level is based on detecting your
heart rate response during each recorded running or walking
workout. To get your fitness level estimated, record a run or
walk with a duration for at least 15 minutes while wearing your
Suunto 9 Peak.
Your watch is able to provide an estimation of your fitness
level for all running and walking workouts.
Your current estimated fitness level is shown in the fitness
level display. From the watch face, press the lower right button
to scroll to the fitness level display.
If the watch hasn't estimated your fitness level yet, the
fitness level display will instruct you further.
Historical data, from recorded running and walking workouts,
plays a role in ensuring the accuracy of your VO2max estimate.
The more activities you record with your Suunto 9 Peak, the more
accurate your VO2max estimate becomes.
There are eight fitness levels, from low to high: Very poor,
Poor, Fair, Average, Good, Very good, Excellent and Superior.
The value is dependent of your age and gender and the higher
value you have, the better your fitness level is.
Tap the screen to view your estimated fitness age. Fitness age
is a metric value that reinterprets your VO2max value in terms
of age. Regularly engaging in the right types of physical
activity will help you boost your VO2max value and reduce your
fitness age.
Improvement of VO2max is highly individual and it depends on
factors such as age, gender, genetics and training background.
If you are already very fit, increasing your fitness level will
be slower. If you are just starting to exercise regularly, you
may see a quick increase in fitness.
Chest heart rate sensor
You can use a Bluetooth® Smart compatible heart rate sensor,
such as the Suunto Smart Sensor, with your Suunto 9 Peak to get
accurate information about your exercise intensity.
If you use the Suunto Smart Sensor, you also have the added
advantage of heart rate memory. The sensor memory function
buffers data if the connection to your watch is interrupted, for
example, when swimming (no transmission under water).
It also means you can even leave your watch behind after
starting a recording. For more information, please refer to the
Suunto Smart Sensor User Guide.
Refer to the user guide for Suunto Smart Sensor or other
Bluetooth® Smart compatible heart rate sensor for additional
information.
See Pairing PODs and sensors for instructions on how to pair an
HR sensor with your watch.
Pair your watch with Bluetooth Smart PODs and sensors to collect
additional information, such as cycling power, when recording an
exercise.
Suunto 9 Peak supports the following types of PODs and sensors:
Heart rate
Bike
Power
Foot
You cannot pair anything if airplane mode is on. Turn off
airplane mode before pairing. See Airplane mode.
To pair a POD or sensor:
Go to your watch settings and select
Connectivity
Select
Pair sensor
to get the list of sensor types.
Swipe down to see the whole list and tap on the sensor type
you want to pair.
Follow the instructions in the watch to complete pairing
(refer to sensor or POD manual if needed), pressing the middle
button to advance to the next step.
If the POD has required settings, such as crank length for a
power POD, you are prompted to enter a value during the pairing
process.
Once the POD or sensor is paired, your watch searches for it as
soon as you select a sport mode that uses that sensor type.
You can see the full list of paired devices in your watch from
the settings under
Connectivity
Paired devices
From this list, you can remove (unpair) the device if needed.
Select the device you want to remove, and tap
Forget
Calibrating bike POD
For bike PODs, you need to set the wheel circumference in your
watch. The circumference shall be in millimeters and it is done
as a step in the calibration. If you change the wheels (with new
circumference) of your bike, the wheel circumference setting in
the watch must also be changed.
To change the wheel circumference:
In settings, go to
Connectivity
Paired devices
Select
Bike POD
Select the new wheel circumference.
Calibrating foot POD
When you pair a foot POD, your watch automatically calibrates
the POD using GPS. We recommend using the automatic calibration,
but you can disable it if needed from the POD settings under
Connectivity
Paired devices
For the first calibration with GPS, you should select a sport
mode where the foot POD is used and the GPS accuracy is set to
Best
. Start the recording and run at a steady pace on a level
surface, if possible, for at least 15 minutes.
Run at your normal average pace for the initial calibration, and
then stop the exercise recording. The next time you use the foot
POD, the calibration is ready.
Your watch automatically re-calibrates the foot POD as needed
whenever GPS speed is available.
Calibrating power POD
For power PODs (power meters), you need to initiate the
calibration from the sport mode options in your watch.
To calibrate a power POD:
Pair a power POD with your watch if you have not done so
already.
Select a sport mode that uses a power POD and then open the
mode options.
Select
Calibrate power POD
and follow the instructions in the watch.
You should re-calibrate the power POD from time to time.
Timers
Your watch includes a stopwatch and countdown timer for basic
time measurement. From the watch face, open the launcher and
scroll up until you see the timer icon. Tap the icon or press
the middle button to open the timer display.
When you first enter the display, it shows the stopwatch. After
that, it remembers whatever you used last, stopwatch or
countdown timer.
Set timer
shortcuts menu where you can change the timer settings.
Stopwatch
Start the stopwatch by pressing the middle button.
Stop the stopwatch by pressing the middle button. You can resume
by pressing the middle button again. Reset by pressing the lower
button.
Exit the timer by swiping right or keeping the middle button
pressed.
Countdown timer
In the timer display, swipe up or press the lower button to open
the shortcuts menu. From there you can select a pre-defined
countdown time or create custom countdown time.
Stop and reset as needed wtih the middle and lower buttons.
pressed.
Intensity zones
Using intensity zones for exercising helps guide your fitness
development. Each intensity zone stresses your body in different
ways, leading to different effects on your physical fitness.
There are five different zones, numbered 1 (lowest) to 5
(highest), defined as percentage ranges based on your maximum
heart rate (max HR), pace or power.
It is important to train with intensity in mind and understand
how that intensity should feel. And don't forget, regardless of
your planned training, that you should always take time to warm
up before an exercise.
The five different intensity zones used in Suunto 9 Peak are:
Zone 1: Easy
Exercising in zone 1 is relatively easy on your body. When it
comes to fitness training, intensity this low is significant
mainly in restorative training and improving your basic fitness
when you are just beginning to exercise, or after a long break.
Everyday exercise – walking, climbing stairs, cycling to work,
etc. – is usually performed within this intensity zone.
Zone 2: Moderate
Exercising at zone 2 improves your basic fitness level
effectively. Exercising at this intensity feels easy, but
workouts with a long duration can have a very high training
effect. The majority of cardiovascular conditioning training
should be performed within this zone. Improving basic fitness
builds a foundation for other exercise and prepares your system
for more energetic activity. Long duration workouts at this zone
consume a lot of energy, especially from your body’s stored fat.
Zone 3: Hard
Exercising at zone 3 begins to be quite energetic and feels like
pretty hard going. It will improve your ability to move quickly
and economically. In this zone, lactic acid begins to form in
your system, but your body is still able to completely flush it
out. You should train at this intensity at most a couple of
times per week, as it puts your body under a lot of stress.
Zone 4: Very hard
Exercising at zone 4 will prepare your system for competition
type events and high speeds. Workouts in this zone can be
performed either at constant speed or as interval training
(combinations of shorter training phases with intermittent
breaks). High-intensity training develops your fitness level
quickly and effectively, but done too often or at too high
intensity may lead to overtraining, which may force you to take
a long break from your training program.
Zone 5: Maximal
When your heart rate during a workout reaches zone 5, the
training will feel extremely hard. Lactic acid will build up in
your system much faster than it can be removed, and you will be
forced to stop after a few minutes at most. Athletes include
these maximum-intensity workouts in their training program in a
very controlled manner, fitness enthusiasts do not require them
at all.
Heart rate zones
Heart rate zones are defined as percentage ranges based on your
maximum heart rate (max HR).
By default, your max HR is calculated using the standard
equation: 220 - your age. If you know your exact max HR, you
should adjust the default value accordingly.
Suunto 9 Peak has default and activity-specific HR zones. The
default zones can be used for all activities, but for more
advanced training, you can use specific HR zones for running and
cycling activities.
Set max HR
Set your maximum HR from the settings under
Training
Intensity zones
Default zones
Tap the max HR (highest value, bpm) or press the middle
button.
Select your new max HR by swiping up or down or by pressing
the upper right or lower right buttons.
Tap your selection or press the middle button.
To exit the HR zones view, swipe right or keep the middle
button pressed.
You can also set your maximum HR from the settings under
General
Personal
Set default HR zones
Set your default HR zones from the settings under
Training
Intensity zones
Default zones
Scroll up/down and tap or press the middle button when the HR
zone you want to change is highlighted.
Select your new HR zone by swiping up or down or by pressing
button pressed.
Selecting
Reset
in the HR zones view will reset the HR zones to the default
value.
Set activity specific HR zones
Set your activity specific HR zones from the settings under
Training
Intensity zones
Advanced zones
Tap the activity (running or cycling) that you want to edit or
press the middle button when the activity is highlighted.
Press the middle button to toggle the HR zones on.
button pressed.
Using HR zones when exercising
When you record an exercise (see Recording an exercise), and
have selected heart rate as an intensity target (see Using
targets when exercising), an HR zone gauge, divided into five
sections, is shown around the outer edge of the sport mode
display (for all sport modes that support HR). The gauge
indicates in which HR zone you are currently training by
lighting up the corresponding section. The small arrow in the
gauge indicates where you are within the zone range.
Your watch alerts you when you hit your selected target zone.
During your exercise the watch will prompt you to speed up or
slow down, if your heart rate is outside the selected target
zone.
In addition, a dedicated display for intensity zones can be
added if you customize the current sport mode you are using. The
zone display shows your current HR zone in the middle field, how
long you have been in that zone, and how far away you are in
beats per minute to the next zones up or down. The background
color of the bar also indicates which HR zone you are training
in.
In the exercise summary, you get a breakdown of how much time
you have spent in each zone.
Pace zones
Pace zones work just like HR zones but the intensity of your
training is based on your pace instead of your heart rate. The
pace zones are shown either as metric or imperial value
depending on your settings.
Suunto 9 Peak has five default pace zones that you can use or
you can define your own.
Pace zones are available for running and cycling.
Set pace zones
Set your activity specific pace zones from the settings under
Training
Intensity zones
Advanced zones
Tap
Running
or
Cycling
Swipe or press the lower button and select pace zones.
Swipe up/down or press the upper or lower buttons and press
the middle button when the pace zone you want to change is
highlighted.
Select your new pace zone by swiping up/down or by pressing
the upper or lower buttons.
Press the middle button to select the new pace zone value.
Swipe right or press and hold the middle button to exit the
pace zones view.
Using pace zones when exercising
have selected pace as an intensity target (see Using targets
when exercising ) a pace zone gauge, divided into five sections,
is viewed. These five sections are shown around the outer edge
of the sport mode display. The gauge indicates the pace zone you
have chosen as an intensity target by lighting up the
corresponding section. The small arrow in the gauge indicates
slow down, if your pace is outside the selected target zone.
In addition, there is a dedicated display for pace zones in the
sport mode default display. The zone display shows your current
pace zone in the middle field, how long you have been in that
zone, and how far away you are in pace to the next zones up or
down. The middle bar also lights up, indicating that you are
training in the correct pace zone.
FusedAlti™
FusedAlti™ provides an altitude reading that is a combination
of GPS and barometric altitude. It minimizes the effect of
temporary and offset errors in the final altitude reading.
By default, altitude is measured with FusedAlti during exercises
that use GPS and during navigation. When GPS is switched off,
altitude is measured with the barometric sensor.
FusedSpeed™
FusedSpeed™ is a unique combination of GPS and wrist
acceleration sensor readings for measuring your running speed
more accurately. The GPS signal is adaptively filtered based on
wrist acceleration, giving more accurate readings at steady
running speeds and a quicker responses to changes in speed.
FusedSpeed benefits you the most when you need highly reactive
speed readings during training, for example, when running on
uneven terrain or during interval training. If you temporarily
lose the GPS signal, for example, Suunto 9 Peak is able to
continue showing accurate speed readings with the help of the
GPS calibrated accelerometer.
To get the most accurate readings with FusedSpeed, only glance
shortly at the watch when needed. Holding the watch in front of
you without moving it reduces the accuracy.
FusedSpeed is automatically enabled for running and other
similar types of activities, such as orienteering, floor ball
and football (soccer).
SuuntoPlus™ guides bring real-time guidance on your Suunto
watch from your favorite sports and outdoor services. You can
also find new guides from SuuntoPlus™ Store or create new ones
with tools such as Suunto app workout planner.
SuuntoPlus™
Scroll to the guide you want to use and press the middle
button.
Go back to the start view and start your exercise as normal.
Press the middle button until you reach the SuuntoPlus™
guide, which is shown as a separate display.
Ensure that your Suunto 9 Peak has the latest software version
and that you have synced your watch with Suunto app.
SUUNTOPLUS™ SPORTS APPS
SuuntoPlus™ sports apps equip your Suunto 9 Peak with new tools
and new insights to give you inspiration and new ways to enjoy
your active lifestyle. You can find new sports apps from
SuuntoPlus™ Store where new apps are being published for your
Suunto 9 Peak. Select the ones you find interesting and sync
them to your watch and get more out of your exercises!
To use SuuntoPlus™ sports apps:
Before you start an exercise recording, scroll down and select
SuuntoPlus™
Select the sports app you want.
If the sports app is using an external device or sensor, it
will make the connection automatically.
Scroll up to the start view and start your exercise as normal.
SuuntoPlus™ sports app, which is shown as a separate display.
After you have stopped the exercise recording, you can find
the SuuntoPlus™ sports app result in the summary, if there
was a relevant result.
You can select which SuuntoPlus™ sports apps you want to use in
the watch in Suunto app. Visit
Suunto.com/Suuntoplus
to see which sports apps are available for your watch.
CARE AND SUPPORT
Handling guidelines
Handle the unit with care – do not knock or drop it.
Under normal circumstances, the watch does not require servicing.
On a regular basis, rinse it with fresh water, mild soap, and
carefully clean the housing with a moist, soft cloth or chamois.
Use only original Suunto accessories - damage caused by
non-original accessories is not covered by warranty.
Battery
The duration on a single charge depends on how you use your watch
and in what conditions. Low temperatures, for example, reduce the
duration of a single charge. In general, the capacity of
rechargeable batteries decreases over time.
In case of abnormal capacity decrease due to defective battery,
Suunto covers battery replacement for one year or maximum 300
charging times, whichever comes first.
When the battery charge level is less than 20% and later 5%, your
watch displays a low battery icon. If the charge level gets very
low, your watch goes into a low power mode and display a charge
icon.
Use the supplied USB cable to charge your watch. Once the battery
level is high enough, the watch wakes up from lower power mode.
Disposal
Please dispose of the device in accordance with local regulations
for electronic waste. Do not throw it in the garbage. If you wish,
you may return the device to your nearest Suunto dealer.
For compliance related information and detailed technical
specifications, see “Product Safety and Regulatory Information”
delivered together with your Suunto 9 Peak or available at
www.suunto.com/userguides
CE
Hereby, Suunto Oy, declares that the radio equipment type OW194 is
in compliance with Directive 2014/53/EU. The full text of the EU
declaration of conformity is available at the following internet
address: www.suunto.com/EUconformity.
