Suunto Wear app is designed for sports and outdoor use. You can
use the buttons instead of the touch screen when needed. If
you’re wearing gloves or underwater, you can use the three
buttons on the right to navigate Suunto Wear app, track your
exercise and zoom in on the map.
To edit your profile information later, open Suunto Wear app,
swipe up and go to General options.
Suunto mobile app on your phone
For the full
Suunto 7
sports experience, you need Suunto mobile app – on your phone.
With Suunto app on your phone you can:
- Sync and save your exercises from your watch
- Get detailed insights on your training
- Follow your daily activity trends and history
- Follow your exercise trends and history
- View your outdoor exercise tracks on the map
Explore heatmaps to see where others have been exercising
Create your own routes or use other popular routes and sync
them to your watch
- Share your best moments with friends
Connect to other sport services like Strava and Relive
Get started
Connect to your favorite sport services
Using multiple watches with Suunto mobile app
Get started
Suunto mobile app works with mobile devices running Android
6.0 & Bluetooth 4.0 or later and iOS 11.0 or later.
Supported features may vary across watches, phones and
countries.
New to Suunto
If you haven’t yet, pair your watch with the Wear OS by
Google app on your phone.
Learn more
Download and install Suunto app from Google Play Store or
App store.
Make sure you have Bluetooth enabled
on your watch and on your phone
- Open Suunto app on your phone.
- Sign up with your preferred method.
- Follow the on-screen instructions.
After signing up, you will be directed to the watch view.
- Once you see your watch, tap “Connect”.
After your watch is connected, follow the quick introduction
to learn the basics about your new watch.
Already a Suunto app user
Learn more
If you are not automatically directed to the watch view, tap
the watch icon on the top left corner.
Once you see your new watch on the screen, tap
“Connect”
If you have another Suunto device already connected to
Suunto app, unpair your old device first, then continue
to connect
Suunto 7
with the app.
With Suunto app, you can connect to and sync your activities
with your favorite sport services like Strava and Relive.
- Tap “Profile” tab.
Tap “Connect to other services” and choose which services
you want to connect to and follow on-screen instructions.
For the full list of Suunto’s partners go to
suunto.com/partners
You can have only one device connected to Suunto app at a
time. When you have paired your watch with the Wear OS by
Google app on your phone, unpair your other device from Suunto
mobile app, then connect
Suunto 7
with the app.
Suunto maps
Suunto Wear app has free outdoor maps and 15 sport-specific
heatmaps to explore – even when you are offline. Optimized for
the outdoors, Suunto maps highlight altitude differences with
accurate contour lines and show popular cycling and skiing
tracks in addition to basic trails. Heatmaps visualize where
others have trained so that you can follow the most popular
routes.
With Suunto maps, you can:
- See your location and direction
- Explore your surroundings with outdoor maps
Navigate with routes and explore new places with heatmaps
- Have easy access to maps during your exercise
- See your track on the map during your exercise
Download custom offline maps on your watch and use maps
without an internet connection
Get local offline maps downloaded to your watch
automatically when connected to Wifi while charging
Get started
Map gestures
Map view
Map styles
Heatmaps
Offline maps
Can’t see the map?
Exercise with maps
Route navigation
Get started
To use Suunto maps, you need to be
connected to the Internet
or
have offline maps
downloaded to your watch.
Press the top right button to open
Suunto Wear app
Press the top right button or swipe down to view the map.
Be patient, activating the map can take a few seconds.
- Browse the map to explore your surroundings.
To go back to start, keep the bottom right button pressed or
swipe up from the bottom of the screen to close the map.
To exit Suunto Wear app, press the Power button or swipe
right.
Map gestures
Zoom in and out
Use top and bottom right buttons.
Pan the map
Touch and drag the map.
Center the map
When the map is panned, tap the map.
During exercise, the map will automatically center in a
couple of seconds after you start moving.
Map view
Location
The black circle indicates your current position on the map.
The circle is gray if the watch does not have accurate current
location.
Heading arrow
The heading arrow inside the location indicator displays the
direction you are headed.
Map scale
The numeric value at the bottom of the map screen displays
distance from your current location to places around you. The
distance is measured from the center of the screen to the thin
circle on the outer rim (radius).
Map styles
Suunto Wear app has several map styles to choose from – an
outdoor map, a winter map and 15 types of heatmaps for
different sports like running, trail running, cycling and
swimming. By default, the map view displays the Suunto outdoor
map.
Change map style
Heatmaps
Heatmaps show the most popular tracks explored by the Suunto
community around the world, based on millions of exercises.
Discover new places to train in your own neighborhood or find
out where the locals train when you are somewhere new. You can
also explore heatmaps directly on Suunto mobile app.
Suunto Wear app has heatmaps for:
- running
- trail running
- cycling
- mountain biking
- all trails
- all walking
- mountaineering
- swimming
- surf & beach
- all paddling
- cross-country skiing
- downhill
- ski touring
- roller skiing / skating
- golf
Explore with heatmaps
Heatmaps are created based on exercises that are shared
publicly.
Popular starting points
When heading to a new place or route, it’s often hard to
figure out where to start. Check out popular starting points
in Suunto Wear app or Suunto mobile app. The popular starting
points are visible on the heatmap as small dots.
Offline maps
With Suunto Wear app you can have Suunto maps downloaded on
your watch, leave your phone behind and use maps without an
Internet connection. Suunto Wear app downloads and updates
local offline maps with heatmaps for you automatically when
your watch is charging and connected to Wifi. You can also
create custom offline maps for your travels and adventures
away from home.
With offline maps you can:
use Suunto maps and heatmaps without a phone or an Internet
connection
- enjoy a faster maps browsing experience
- avoid roaming and data costs
All heatmap styles are included in offline map downloads.
Download a custom offline map
Get offline maps for routes
Connect to Wifi
Get local offline maps automatically
Local offline maps and heatmaps are updated and downloaded
automatically from an area around when your watch is charging
and connected to Wifi based on your last known location. The
downloaded map area varies from 35 km × 35 km to 50 km × 50 km
(from 22 mi × 22 mi to 31 mi × 31 mi) depending on where you
are located.
You will get a notification on your watch when the map
download is complete.
Can’t see the map?
Be patient, activating the map can take a few seconds. If you
still can’t see the map after waiting:
Make sure your watch is connected to the Internet.
If there is no Wifi available, check that your watch is
connected to the Wear OS companion app on your phone and
that your phone has an Internet connection.
Learn more
Make sure your watch has found a GPS signal.
Suunto Wear app needs to know your location to show you the
right map. If your watch keeps searching for location, make
sure you are outside in an open area.
Learn more
Get offline maps.
With offline maps, you can enjoy a faster and smoother map
experience without being connected to your phone or the
Internet.
Learn more
Different sports and measurements
Suunto Wear app provides accurate and insightful sports
measurements via built-in GPS, barometer and wrist heart rate
sensor. The way your exercise is recorded – what you see on
the screen during your exercise and what data you can see
afterwards – depends on the sport mode you choose.
Sport modes
Heart rate during exercise
Follow your progress with laps
GPS: speed, distance & location
Altitude, ascent & descent
Barometer
Sport modes
Suunto Wear app has over
70 sport modes
(different sports), ready to track all your sports – run,
bike, swim, hike – you choose. Each sport mode has 2 to 4
exercise views to show the most relevant stats during your
exercise and a map when you are exercising outdoors.
For instance, if you go running, you can follow your progress
every kilometer or mile with automatic lap updates, see your
running pace and view your track on the map. If you choose
pool swimming, you get both your swimming intervals and
overall progress tracked automatically. Easy!
Customize sport modes
With a wide range of pre-defined sport modes, your
Suunto 7
always shows the most relevant data during your exercise. In
addition to the pre-defined sport modes, you can also create
custom sport modes using Suunto app.
Learn how to
create custom sport modes (Android).
Learn how to
create custom sport modes (iOS).
Tracking your heart rate during exercise tells you precisely
how hard – or easy – your heart is working. Measuring your
heart rate can help you to avoid making one of the most common
mistakes – training too hard too often, which puts you at risk
for injury and burnout.
Sport modes in Suunto Wear app are tailored to show heart rate
in a meaningful way for each activity. Depending on the sport
mode you choose, you can for example follow your current heart
rate, average heart rate, heart rate during specific laps, or
at which heart rate zone you are exercising.
After your exercise you can see detailed information of your
efforts and exercise intensity such as what was your average
heart rate, what was the peak training effect (PTE) or
estimated recovery time. If you are not familiar with all of
the terms, you can learn more in the
Glossary
How to wear your watch to improve HR measurements
HR zones
Suunto Wear app has five different heart rate zones, numbered
from 1 (lowest) to 5 (highest), defined as percentage range
based on your maximum heart rate (max HR).
Understanding heart rate zones when exercising helps to guide
your fitness development. Each zone stresses your body in
different ways, leading to different effects on your physical
fitness.
ZONE 1: EASY
Exercising in zone 1 is relatively easy on your body. When it
comes to fitness training, intensity this low is significant
mainly in restorative training and improving your basic
fitness when you are just beginning to exercise, or after a
long break. Everyday exercise – walking, climbing stairs,
cycling to work, etc. – is usually performed within this
intensity zone.
ZONE 2: MODERATE
Exercising at zone 2 improves your basic fitness level
effectively. Exercising at this intensity feels easy, but
workouts with a long duration can have a very high training
effect. The majority of cardiovascular conditioning training
should be performed within this zone. Improving basic fitness
builds a foundation for other exercises and prepares your
system for more energetic activity. Long duration workouts at
this zone consume a lot of energy, especially from your body’s
stored fat.
ZONE 3: HARD
Exercising at zone 3 begins to be quite energetic and feels
like pretty hard going. It will improve your ability to move
quickly and economically. In this zone, lactic acid begins to
form in your system, but your body is still able to completely
flush it out. You should train at this intensity at most a
couple of times per week, as it puts your body under a lot of
stress.
ZONE 4: VERY HARD
Exercising at zone 4 will prepare your system for competition
type events and high speeds. Workouts in this zone can be
performed either at constant speed or as interval training
(combinations of shorter training phases with intermittent
breaks). High-intensity training develops your fitness level
quickly and effectively, but done too often or at too high
intensity may lead to overtraining, which may force you to
take a long break from your training program.
ZONE 5: MAXIMAL
When your heart rate during a workout reaches zone 5, the
training will feel extremely hard. Lactic acid will build up
in your system much faster than it can be removed, and you
will be forced to stop after a few minutes at most. Athletes
include these maximum-intensity workouts in their training
program in a very controlled manner, fitness enthusiasts do
not require them at all.
How are heart rate zones calculated?
Heart rate zones are defined as percentage range based on your
maximum heart rate (max HR). Your max HR is calculated using
the standard equation: 220 - your age.
The default zones used in Suunto Wear app, based on
percentages of your maximum heart rate, are:
Zone 5: 87–100%
Zone 4: 82–86%
Zone 3: 77–81%
Zone 2: 72–76%
Zone 1: < 71%
To adjust your max. heart rate, see
Profile settings
Laps are a great way to follow your progress during exercise
and to analyze your efforts in more detail afterwards. With
Suunto Wear app you can create lap marks manually or choose a
sport mode that creates laps automatically for you.
Autolaps
Sport modes, like running, cycling, and indoor rowing, come
with automatic lap updates to follow your progress based on
certain distance or time. For instance, with running sport
mode, your watch alerts you every kilometer or mile and shows
your average pace and heart rate of your last kilometer on the
screen.
To follow and compare your efforts real-time between different
laps, go to the dedicated lap table view. In most sport modes
it is the second exercise screen.
Mark a lap manually during exercise
In addition to autolaps, you can manually mark laps to track
different sections of your exercise. For example, during an
interval session, you could create a lap mark for both your
intervals and rest periods to help analyze your session
afterwards or you could mark a lap to time reaching a
milestone or a turning point on your regular training route.
To mark a lap
, press the bottom right button when you are in an exercise
view. You will briefly see the key stats for that section of
your exercise.
With some sport modes, such as Track and field, you can also
compare your manually marked laps real-time in the lap table
view.
View laps stats after exercise
To see your lap stats after your exercise, scroll down in the
exercise summary and select
Laps
Sync your exercises to Suunto mobile app on your phone to
analyze your laps in more detail.
Suunto 7
uses GPS (location information) during exercise to draw your
track on the map and – together with accelerometer data – for
measurements like speed and distance.
Suunto 7
can also use Glonass and BeiDou for location information.
How to improve GPS accuracy
To provide the best accuracy for your exercise stats,
Suunto 7
uses, by default, 1 second GPS fix rate to update GPS location
information. However, there are several other factors that
also affect the signal strength and GPS accuracy.
See
Change the location accuracy
to change the GPS accuracy.
If you notice challenges with GPS accuracy, try these tips:
1. Wait for GPS signal before starting an exercise
Before starting your exercise recording, go outside and wait
for the watch to find the GPS signal. When the watch is
searching for a GPS signal, the arrow icon in the start view
is gray. Once the GPS signal is found, the arrow icon will
turn white.
When you are open water swimming or exercising in difficult
terrain, we recommend you wait a couple of additional minutes
after the signal is found to allow the watch to download all
needed GPS data to get a more accurate track.
2. Move to an open area
The GPS signal strength can be affected by your surroundings
and terrain such as:
3. Keep your watch connected to Wifi
Connect your watch to Wifi to optimize your GPS with the
latest satellite orbit data. Your watch can acquire a GPS
signal faster when GPS data is up to date.
If you can’t connect to Wifi, you get GPS updates once a
week via Bluetooth.
4. Use the latest software for your watch
We continuously improve the software of our watches and fix
possible bugs. Ensure you have the latest software installed
on your watch.
Learn how to update your watch
Suunto Wear app uses FusedAlti™– a combination of GPS and
barometric altitude – to provide an altitude reading and
derived ascent and descent values during exercise.
Barometer
Suunto 7
has a built-in pressure sensor that measures absolute air
pressure. Suunto Wear app uses both GPS and air pressure data
(FusedAlti™) to provide a more accurate altitude reading.
CAUTION:
Keep the area around the air pressure sensor holes on the
left-side of your watch free of dirt and sand. Never insert
any objects into the holes as this may damage the sensor.
Start an exercise
Before you begin
Start an exercise
Waiting to start
Avoid accidental touch and button actions during exercise
Before you begin
Start an exercise
Press the
top right button
to open Suunto Wear app.
Tap the activity below the start button to open a list of
sport modes.
Browse the list and
select a sport mode
you wish to use.
Learn more about sport modes.
Optional
: Change the Location accuracy and the display settings
for the chosen sport mode.
Maximize battery life during exercise
When you’re ready to go,
press the middle button
or
swipe left on the start button
to start your exercise.
To get the most accurate HR and GPS data from the start, you
can wait until the arrow icon (location) and heart icon
(heart rate) above the start button turn white before
starting your exercise.
If the heart rate icon stays gray, try moving your watch on
your wrist about two fingers up from the wrist bone. If the
arrow icon stays gray, move outside to an open area and wait
for a better GPS signal.
Waiting to start
If you stay in the start view for a while, for example when
you wait for your watch to acquire its GPS location or get
ready to start your race, you might see that the display
switches to a low-power mode. Don’t worry, you can still
start your exercise recording immediately by pressing the
middle button.
Wet conditions or, for instance, the gear you are wearing
can sometimes accidentally interrupt your exercise
recording. To avoid accidental taps and button presses
during exercise, you can lock the touch screen and button
actions.
Unwanted actions such as rain drops or a wet sleeve can
also drain your battery faster than expected by waking up
the display repeatedly without you noticing.
Lock touch screen and button actions
To lock the screen and button actions, keep the middle
button pressed.
- To unlock, keep the middle button pressed again.
When the screen and buttons actions are locked,
you can
- change the exercise view with middle button
- return to the watch face with Power button
zoom the map with the top right and bottom right buttons
you can’t
- pause or end the exercise
- create manual laps
- access exercise options or map options
- swipe the screen or pan the map
- tap to wake up screen
Control watch during exercise
Wake up display
Change exercise views
Open other apps while exercising
Buttons and touch screen use during exercise
Wake up display
While recording an exercise with Suunto Wear app the display
and gestures to interact with your watch are optimized for
sports and longer battery life.
Your stats during exercise are always visible but to wake up
the display, you can:
- Press the Power button
- Touch the screen
To wake up the display during exercise when in the map view,
you can:
- Turn your wrist
- Touch the screen
During water sports, like swimming and kayaking, the touch
screen for Suunto Wear app is disabled to avoid wet
conditions causing unwanted touch actions.
If you exit Suunto Wear app during any exercise (including
swimming), the touch screen will be enabled.
The stats you can follow during your exercise depend on the
sport mode you choose. Most sport modes have 2 to 4
different exercise views displaying the most relevant
exercise data for each sport. When you do outdoor sports,
you can also see your track on a map.
To change between views
- Press the middle button
- Swipe left or right
If you need to use another app during your exercise, for
example to skip a song or to check the weather, you can exit
Suunto Wear app and keep the exercise recording.
Press the Power button or touch the screen to wake up the
display.
- Press the Power button to go to the watch face.
- Use your watch as you wish.
Press the Power button to go back to the watch face.
Press the top right button to go back to your exercise.
Keep in mind that some actions and apps can consume a lot
of battery, which may affect how long you can record your
exercise.
You can start your exercise and adjust your watch during
exercise even with gloves on or underwater. All sport
features are optimized to work with buttons only if needed.
Change between views
Press the middle button or swipe left or right to see
different metrics or to check the map.
Pause
Press the top right button. Press again to resume.
End
Press the top right button, then press the bottom right
button.
Mark a lap
Press the bottom right button.
Lock buttons
Keep the middle button pressed.
Control the map
While in the map view, use the top right and bottom right
button to zoom in and out.
Adjust exercise options
Keep the bottom right button pressed or swipe up from the
bottom of the screen to open the menu.
Change map style
Pause and resume exercise
Make sure you are in an exercise view.
- Press the top right button to pause your exercise.
While paused, you can view your data and change displays
with the middle button or by swiping left or right.
To resume your exercise, press the top right button.
Check your location while paused
While paused, press the middle button until you are in the
map view.
While in the map view, you can zoom the map with the top
right and bottom right buttons and touch and drag the map
to move it around.
, press the middle button to return to an exercise view,
then press the top right button.
End and review exercise
End your exercise
View your exercise summary
Delete your exercise
View your exercise details in Suunto mobile app
Access your exercise diary on your watch
End your exercise
When you are finished and ready to end your exercise:
- Make sure you are in an exercise view.
- Press the top right button.
Then press the bottom button to end and save the exercise.
When you have finished your exercise, you will get an
exercise summary to see how you did. Scroll down to see
detailed information of your efforts and exercise intensity
such as what was your average heart rate, what was the peak
training effect (PTE) or estimated recovery time. If you are
not familiar with all of the terms, you can learn more in
the
Glossary
To exit the exercise summary
, you can:
- Swipe right
- Scroll down and select Close.
The content of the summary depends on the sport mode and
measured values.
If you don’t want to save the exercise you just recorded,
you can delete it from your watch before you exit the
summary.
- Scroll down to the bottom of the exercise summary.
- Tap Delete.
When your watch is connected to Suunto mobile app, your
exercises will be automatically synced and saved to the app
on your phone. In Suunto mobile app, you can view and
analyze your exercise in more detail, add photos and videos,
sync them to your favorite sport services like Strava and
Relive and share your best moments with friends.
Connect to Suunto mobile app
Suunto mobile app syncs exercises via Bluetooth so that
you can sync your exercises even when there is no Wifi
available.
To quickly check your previous exercises, open Suunto Wear
app on your watch and swipe up the menu. Scroll down and tap
Diary
to view your previous exercises, daily activity or sleep.
You can also access your Diary by tapping any of the
following Suunto Tiles: Heart rate, Resources, Today or
Sleep.
Remember to sync (and save) your exercises to Suunto
mobile app. If you ever need to reset your watch, all
unsynced exercises in the Diary will be lost.
Swimming with Suunto 7
Suunto 7
is a great companion for swimming with tailored sport
modes for swimming exercises in pools or in open water.
You can take your watch under water without a worry and
even press buttons – your watch is waterproof for up to 50
m.
Pool swimming
Open water swimming
To avoid unwanted touch actions caused by wet
conditions, the touch screen is disabled by default when
using swimming sport modes.
Pool swimming
With pool swimming sport mode, it is easy to follow your
overall progress as well as your swimming intervals.
Whenever you stop for a rest at the end of the pool, your
watch marks a swimming interval for you and shows it real
time in the lap table view.
Your watch relies on the pool length to determine the
swimming intervals and to measure your swimming pace and
distance. You can easily set pool length in exercise
options before you start swimming.
Learn how to
set pool length.
You can analyze the laps later in your exercise summary
on the watch or in Suunto mobile app on your phone.
Open water swimming
With open water swimming mode, you can follow your
swimming pace and distance as well as see your track on
the map. To find the best open water area near you, check
the swimming heatmap on your watch or explore heatmaps in
Suunto mobile app.
Open water swimming relies on GPS to calculate distance.
Because GPS signals do not travel underwater, the watch
needs to come out of the water periodically, such as with
the freestyle stroke, to get a GPS fix.
These are challenging conditions for GPS, so it is
important that you have a strong GPS signal before you
jump in the water. To ensure good GPS, you should:
the latest satellite orbit data.
Wait at least three minutes before starting your swim
after you select an open water swimming sport mode and
a GPS signal is acquired. This gives the GPS time to
establish strong positioning.
Exercise with maps
With Suunto Wear app, you have easy access to an outdoor
map and heatmaps when you’re exercising outdoors. You can
see your track on the map, use your own or other popular
routes to navigate with, use heatmaps to explore new
routes or follow your track to find your way back to where
you started from.
or
have offline maps
downloaded on your watch.
Start an exercise with maps
Leave the map to end your exercise
Find your way back
Route navigation
Whenever your watch is connected to Wifi while charging,
local maps with heatmaps are automatically downloaded on
your watch.
Learn more
Press the top right button to open Suunto Wear app.
Choose a sport mode
for an outdoor activity
with GPS
like running, cycling or mountaineering.
To change a map style, swipe up the menu and go to
Map options
Map style
Browse the list to find a map style or a heatmap you
would like to use.
You can scroll with buttons or touch.
Press the middle button or tap to select a new mapstyle.
Swipe right to exit the menu and scroll up back to the
start.
Press the middle button or swipe left on the start
button to start your exercise.
To follow your progress on the map, press the middle
button or swipe left or right until you see the map
view.
Can’t see the map?
Map gestures
Press the middle button or swipe left or right to leave
the map.
While in the exercise view, press the top right button
to pause.
Press the bottom right button to end and save the
exercise.
Suunto’s heatmaps make it easy to find new trails on the
go. Switch the heatmap on and see where other passionate
Suunto users have been exercising and explore the outdoors
with more confidence.
Change map style during exercise
When you are doing outdoor sports, you can see your track
and follow your progress on the map in real time. Use
Suunto’s outdoor maps to choose where to go next – check
where the forest path leads to or where the biggest hills
are.
Find your way back
During exercise, Suunto Wear app marks your starting point
and draws the route you have travelled as long as you have
GPS available – even if the map is not yet loaded. If you
need help to find your way back, go to the map view and
zoom out to see your full route and see which way you need
to go.
Route navigation
Suunto 7
offers you easy offline route navigation with outdoor
maps. It is possible to create your own routes or use
other popular routes from Suunto community as well as
other partner services via Suunto mobile app. The routes
are synced to your
Suunto 7
via Bluetooth and route navigation works with all outdoor
sport modes where a map is available and GPS is enabled.
Sync routes to watch
Select a route
Navigating a route
Deleting a route
It is possible to create your own routes or use other
popular routes from Suunto community as well as other
partner services via Suunto app.
To be able to sync routes to your watch make sure that it
is connected to Suunto mobile app and the Wear OS
companion app on your phone.
Learn how to
create routes in Suunto app (Android).
Learn how to
create routes in Suunto app (iOS).
a maximum of 15 routes can be stored in the watch.
When the watch is charging and connected to Wifi, an
offline map is downloaded for each route on watch
automatically. The download includes the basic outdoor map
(no heatmaps).
Select a route
When selecting a sport mode that uses GPS, a shortcut to
route selection is visible right below the selected sport
mode.
You can also go to
Map options
Select a route
to find a list of your routes. Tap or press the middle
button to select a route.
The map preview is visible for the route if the route has
an offline map downloaded.
View the route before exercise
The selected route can also be viewed on the map before
you started your exercise.
On the start view, press the top right button or swipe
down to view the map with an overview of the route length.
Tap the map to see a zoomed in view with distance
(birds-eye-view) to the starting point.
Select a route during exercise
During exercise, keep the bottom button pressed or swipe
up from the bottom of the screen to open the menu.
Select
Select a route
- Choose the route you want to use.
To exit the menu, press the top right button or swipe
down.
Navigating a route
The selected route is automatically visible in the map
view during exercise if the chosen sport mode has a map
available and GPS enabled. Depending on the selected sport
mode and while on route, you can see the distance left,
ETA (Estimated Time of Arrival) and ascent left or ETE
(Estimated Time Enroute) to the route end.
If you are using waypoints, the distance, ETA, ascent left
and ETE are referring to the next waypoint instead of the
route end.
Tap the map to see the overview of the route and the
distance to the route end. The watch automatically returns
to the default view after a while.
All route information is not visible in low-power mode.
Turn your wrist, touch the screen or press the Power
button to wake up the display.
As you navigate a route, your watch helps you stay on the
correct path by giving you additional notifications as you
progress along the route.
For example, if you go off route, the watch notifies you
that you are not on the right track, as well as lets you
know when you are back on route.
Once you reach a waypoint on the route, you get an
informative popup showing you the distance to the next
waypoint.
If you have changed the
Location accuracy
to Good a small delay for notifications can occur.
Deleting a route
If you want to remove a route from your watch but still
keep it in Suunto mobile app, select the route in the app
on your phone and uncheck the option Add to watch.
Make sure that your watch is connected to Suunto mobile
app and synced after the changes..
To delete a route completely from both the watch and
Suunto mobile app, select the route in Suunto mobile app
and choose the delete option.
Exercise with music
With
Suunto 7
, you have access to your music and other audio during
sports – even with gloves on or in wet conditions.
Automatic media controls
Open media controls during exercise
Pause and skip tracks with buttons
Listen to music without your phone
If you start playing music from your phone during
exercise, the media controls can appear on top of your
exercise views.
To exit the media control view
, swipe right.
Manage media controls
If you need to pause or skip tracks during exercise you
need to first leave Suunto Wear app, then open media
controls.
Using
a button shortcut
this is easy even with gloves on or in wet conditions:
Press the Power button to leave Suunto Wear app during
your exercise.
While on the watch face, press the middle button to open
media control view.
Adjust your music however you want, you can use touch or
buttons.
recording.
Your exercise continues to record even if you leave
Suunto Wear app.
The media controls app supports using buttons in addition
to touch gestures. With buttons, you can control your
music even if your hands are sweaty or you have gloves on.
Pause & play
Press the middle button to pause, press again to play.
Next track
Previous track
Exercise options
Tones & vibration during exercise
Pool length
Power saving
Suunto Wear app uses sound and vibration to notify you
during your exercise so that you can follow your progress
without checking the screen all the time. For example, you
hear a sound and feel the watch vibrate when you get an
automatic lap update to make sure you won’t miss key
stats.
Manage tones
Suunto Wear app
Swipe up the menu and go to
Exercise options
Tones & vibration
Turn Tones on or off.
Manage vibration
Suunto Wear app
Exercise options
Tones & vibration
Turn Vibration on or off.
Pool length
Your watch relies on pool length to determine the swimming
intervals and to measure your swimming pace and distance.
You can easily set pool length in exercise options before
you start swimming.
Set pool length
Suunto Wear app
- Tap the activity below the start button.
- Choose Pool swimming sport mode.
Exercise options
Pool length
- Set correct pool length.
- Return to the start view and start your exercise.
Power saving
Change the display settings
When you are recording an exercise,
Suunto 7
updates your location information every 1 second. To save
battery power, you can change the GPS accuracy before or
The Location accuracy options are:
Best: ~ 1 sec GPS fix interval, highest power
consumption
Good: ~ 10 sec GPS fix interval, moderate power
consumption
If you select Good Location accuracy your battery will
last longer during your outdoor workouts. For some sport
modes such as running or cycling, FusedTrack™ is used to
improve tracking quality. FusedTrack™ uses motion sensors
to log your movement between the different GPS readings,
which will provide better tracking of your exercise.
How to change the Location accuracy before an exercise:
Choose a sport mode for an outdoor activity with GPS
like running, cycling or walking.
Power saving
Location accuracy
Change Location accuracy to
Good
How to change the Location accuracy during an exercise:
Keep the bottom button pressed or swipe up from the
Power saving
Location accuracy
Good
The power-saving settings you choose are saved to the
sport mode. Selecting the same sport mode (ex. running)
a second time will automatically employ the previously
used power-saving configuration (Location accuracy,
display settings, etc).
By default, Display settings during exercise are set to
off to optimize battery life.
Always-on map
Manage Always-on map during exercise
Always-on map
If you are doing a workout where you need to see the map
at all times, you can choose to keep the map on during
exercise.
Good to remember:
Keeping the screen on through the whole exercise
significantly decreases the battery life.
As image persistence or screen burn-in is normal
behaviour for OLED displays, keeping your screen on
for long periods of time affects the life span of your
display.
Enable Always-on map before exercise
Activate
Always-on map
to see the map constantly without turning your wrist or
pressing the power button:
Choose the sport mode
you want to use.
Power saving
Display
Always-on map
Activate
Always-on map
Activating Always-on map will increase battery
consumption.
The Power saving settings you choose are saved to the
used Power saving configuration (Always-on map, Location
accuracy, etc).
Select
Power saving
Display
Always-on map
Activate
Always-on map
down.
Map options
Change map style
Select a route
Always-on map
Change map style
Suunto Wear app has different map styles. To change map
styles:
Suunto Wear app
Map options
Map style
Browse the list and select the preferred map style.
bottom of the screen to change the map style.
would like to use. You can scroll with buttons or touch.
style.
Keep exploring, the menu will close automatically after
your selection!
In addition to
automatically downloaded local maps
, Suunto Wear app allows you to download a custom offline
map for your adventures away from home. For example, if
you are not sure your travel destination has a Wifi
network available, you can download a map for the area in
advance.
- Make sure your watch is connected to Wifi.
Suunto Wear app
Map options
Offline map
Zoom the map with the top right and bottom right buttons
and touch and drag to pan the map to define a map area
to be downloaded.
Tap the check mark or press the middle button to select
the area.
The map will start downloading when the watch is
For local and custom offline maps, all heatmap styles
are included in the download.
You can save one custom map on your watch at a time.
General options
Profile settings
Units
Google Fit
Check your Suunto Wear app version
Profile settings
You can check your weight, height, birth year, gender,
resting heart rate and max heart rate in your personal
settings. To adjust the settings:
Suunto Wear app
General options
Profile
- Choose which setting you need to adjust.
- Adjust the setting.
To confirm, tap the check mark or press the middle
button.
Units
Suunto Wear app supports both metric (kg, km) and
imperial (mi., lbs) unit systems for setting your
personal information and for viewing your exercise
stats.
Suunto Wear app
General options
Units
button.
Google Fit
If you use Google Fit to track your daily activities and
want to see how your exercises, daily activity and sleep
recorded with Suunto Wear app impact your daily activity
goals, connect Suunto Wear app with Google Fit. When
connected, training insights from exercises recorded
with Suunto Wear app will also be accessible in Google
Fit.
Connect to Google Fit
- Go to Google Fit on your watch.
- Sign in to Google Fit with your Google account.
Go to
Suunto Wear app
General options
Google Fit
- Tap Connect.
Select the same Google account you used to sign in to
Google Fit.
Scroll down and tap the check mark to allow Suunto to
sync data recorded during your activity to Google Fit.
Diary
In the diary you can find your previous exercises and
see today’s daily activity stats and your last sleep.
To view your Diary on your watch:
Suunto Wear app
Swipe up the menu and tap
Diary
to open a list of exercise summaries.
Tap the exercise you would like to see in more detail.
