1 / 9
Suunto Core 2
Suunto Core 2
Suunto Core 2
Suunto Core 2
Suunto Core 2
Suunto Core 2
Suunto Core 2
Suunto Core 2
Suunto Core 2
1/9
rotation-icon
Photos
360°View
Money-back guarantee
30-Days Return
Warranty Repair
SKU: SS051780000
Suunto Core 2
Sale price$449 AUD
Classic ABC outdoor watch for off-grid adventures.
  • Altimeter, barometer, and compass for essential outdoor navigation
  • Weather trends and storm alarm for changing conditions
  • Military-grade durability
  • Up to 15 months of battery life
  • Switchable red / green backlight
Quantity
Free shipping on orders of A$100 or more.
30-Days Return
Warranty Repair
Altimeter & barometer
Offline compass
Testing applies only to selected MIL-STD-810 procedures by China National Accreditation Service for Conformity Assessment (CNAS), and does not imply military certification or military use. Not specifically endorsed by any branch of the military, U.S. or otherwise.
Red / green backlight
10 ATM water resistance
Up to 15 months battery life
Built for off-grid exploration
Suunto Core 2 combines altimeter, barometer and compass functionality with a durable design built for life outdoors. From hikes to off-grid adventures, it helps you track elevation, stay aware of changing weather and keep your bearings.
Stay ahead of changing conditions
Core 2 combines altitude and barometric data to help you read the outdoors as conditions shift. Track your ascent, monitor pressure trends and get storm alerts when the weather starts to turn.
Altitude awareness
Environmental
monitoring
Storm alerts
Monitor your elevation and barometric pressure in real time, follow pressure trends to understand shifting environmental conditions, and stay aware of what lies ahead.
Storm alarm
Receive early warnings when rapid pressure drops indicate approaching storms, helping you react before conditions deteriorate.
Altitude difference
Compare your current altitude against a set reference point to track vertical progress during climbs.
Altimeter & barometer calibration
Set reference values for barometric pressure (including sea level pressure) and current altitude to ensure accurate readings in changing outdoor conditions.
Keep your bearings
When landmarks fade or the route becomes unclear, Core 2 helps you stay oriented with a precise digital compass, bearing lock and magnetic declination. Reliable direction when you need to keep moving forward.
Precise digital compass
Reliable bearing lock
Magnetic declination
Built for extended adventures
When you’re far from charging cables, power outlets and everyday conveniences, dependable battery performance matters. Suunto Core 2 uses a replaceable battery and low battery alert to help you stay prepared, with up to 15 months of battery life in basic time mode.
Up to 15 months in basic time mode
Replaceable CR3032 battery
Low battery alert
Designed for visibility and durability
Core 2 is designed for outdoor use where readability and durability matter. The high-visibility display stays clear in daylight, while red and green backlight options support low-light use. MIL-STD-810 tested durability helps it handle rough use on the trail, at camp and in the field.
Red backlight helps preserve night vision in low-light conditions, supporting nighttime navigation. Green backlight enhances visibility for everyday outdoor use in dark environments.
MIL-STD tested durability
Tested to military standards (MIL-STD-810), the watch will make sure your journey is safe and successful even in the toughest and most demanding conditions. Suunto Core 2 has passed 7 tests, Including heat, humidity, salt fog, solar radiation, low pressure, icing/freezing rain, and dust.
Tough & clear display
Gorilla Glass screen provides superior scratch resistance and impact protection. High-contrast display ensures clear readability in bright outdoor conditions for quick at-a-glance information.
Plan your time in the wild
In the outdoors, timing is just as important as direction and distance. Suunto Core 2 provides essential tools for planning activities around daylight conditions, managing time across journeys, and staying aware of natural cycles.
Time awareness
Sunrise/sunset
Plan activities around available daylight.
Moon phase
Understand natural light conditions throughout the month.
Dual time
Keep track of home and local time during travel.
Time planning & control
Stopwatch & countdown timer
Measure activity duration and track elapsed time.
Daily alarms
Stay on schedule during early starts and multi-day trips.
Intuitive button
control
With larger buttons and a more intuitive interface, Suunto Core 2 is easier to operate in real-world outdoor conditions. Key functions are always within easy reach, reducing complexity and helping you stay focused on the adventure ahead.
Suunto Core 2 Watch Buttons Layout
1
Light / Lock
Activate the backlight or lock the buttons to prevent accidental presses.
2
Back
Return to the previous screen or exit menus quickly.
3
Start / Stop / Up (↑)
Perform key actions and navigate upward through menus and settings.
4
Mode
Switch between key functions and settings.
5
Down (↓)
Navigate downward through menus and settings.
What’s new in Suunto Core 2
Suunto Core 2
Suunto Core 2
Suunto Core
Suunto Core
Red / green backlight Green backlight
10 ATM water resistance 3 ATM water resistance
Up to 15 months battery life Up to 12 months battery life
Gorilla glass display Mineral crystal display
Larger & easier to use buttons -
Silicone strap Elastomer strap
Moon phase -
Step counter -
Bluetooth sync and updates -
IN THE BOX
  • 1 Suunto Core 2 watch ×1
  • 2 Suunto 22mm Athletic 2 Silicone Strap, All Black ×1
  • 3 Quick guide ×1
  • 4 Warranty ×1
FAQ
Product overview
[5]
Product overview[5]
Core 2 features[10]
Battery[3]
Durability & water resistance[3]
Connectivity[2]
Product overview
[5]
Is Core 2 a smartwatch?
No, and that's the point. Core 2 is a classic ABC outdoor watch, built around an altimeter, barometer, and compass rather than apps, GPS, or a touchscreen. It focuses on the essentials that keep you oriented and safe outdoors, with the long battery life and durability a smartwatch can't match.
What are the main features of Core 2?
Core 2 combines an altimeter, barometer, and offline compass for navigation and weather awareness, plus a storm alarm, sunrise and sunset times, and moon phase. It's built to military durability standards, rated to 10 ATM water resistance, runs up to 15 months on a replaceable battery, and has a high-contrast dot-matrix display with a switchable red and green backlight.
What is the difference between Suunto Core and Core 2?
Core 2 keeps the tool-watch DNA of the original Core and upgrades nearly everything around it: a switchable red and green backlight, stronger 10 ATM water resistance, a higher-contrast display, and larger buttons with better feedback. It also adds Bluetooth for time sync and updates, moon phases, and a refreshed, more modern design.
Can it be used offline?
Yes. Core 2 is designed to work completely off-grid. The altimeter, barometer, and compass all run without GPS, a phone, or a signal, so you stay oriented and informed even where there's no connectivity at all.
Can it be used in extreme environments?
Yes. Core 2 is tested to durability standards and built to handle heat, cold, moisture, shock, and rough handling. With 10 ATM water resistance and a long-life replaceable battery, it's made for demanding outdoor conditions.
How is altitude measured?
Core 2 measures altitude with its barometric sensor, reading changes in air pressure to track your current elevation and your total ascent and descent. Because it's barometric rather than GPS-based, it responds quickly and works anywhere. Calibrate it at a known elevation for best accuracy.
Why is altitude inaccurate sometimes?
Barometric altitude depends on air pressure, which also changes with the weather. When a weather system moves in and pressure shifts, your altitude reading can drift even if you haven't moved. Recalibrating at a known elevation resets it and keeps readings accurate.
What is barometric pressure used for?
Core 2 uses barometric pressure two ways: to calculate your altitude, and to track weather trends. By watching how pressure rises or falls over time, you can anticipate changing conditions, and a sharp drop triggers the storm alarm for early warning.
How does storm alert work?
Core 2 continuously monitors barometric pressure, and when it detects a rapid drop that signals worsening weather, it sounds a storm alarm. That early heads-up gives you time to seek shelter or adjust your plans before conditions turn.
How accurate is the compass?
Core 2 has a precise digital compass with bearing lock to hold a heading, plus magnetic declination adjustment so you can align magnetic north with true north for your location. It works entirely offline. For best accuracy, calibrate it regularly and keep it away from magnetic interference.
Does it support dual time zones?
Yes. Core 2 lets you track a second time zone alongside your local time, which is handy for travel or staying in sync with people back home.
How does sunrise/sunset work?
Core 2 calculates sunrise and sunset times based on the date and your location, so you can plan daylight around hikes, camp setup, or the trip back before dark. It also shows the moon phase to help you plan night activities.
Does the Suunto Core 2 have an alarm?
Yes. Core 2 includes a daily alarm, so you can wake for an early start or set reminders on the trail.
Does Suunto Core 2 have a stopwatch?
Yes. Core 2 has a built-in stopwatch for timing activities, intervals, or anything else you need to track.
Does it have a backlight?
Yes, and it's switchable. Core 2 offers a green backlight for high contrast in haze and low light and a red backlight that protects your night vision, so you can read the display clearly whatever the conditions.
What battery does Core 2 use?
It uses a CR3032 coin cell battery, which is user-replaceable.
How long does the battery last?
Battery life varies by usage, but typically can last up to 15 months with standard use.
Is battery replacement difficult?
Users can replace it themselves, but it is recommended to use official replacement parts.
Can it connect to a phone?
Yes, it supports synchronization and settings management via the Suunto app.
What if syncing fails?
Check if Bluetooth is enabled, ensure the device is within range, or try re-pairing.
Yes, core functions work independently without a phone connection.
Does Core 2 have GPS?
No. Core 2 is an ABC watch, not a GPS watch. Instead of satellite tracking, it uses an altimeter, barometer, and compass to help you navigate and read conditions. Leaving out GPS is exactly what gives it such long battery life and true off-grid reliability.
Does Core 2 have Bluetooth?
Yes. Core 2 connects to the Suunto app over Bluetooth to sync the time, sunrise and sunset data, and your step count, and to receive over-the-air updates. Day to day it works fully on its own, so the connection is there when you want it, not something you rely on outdoors.
Specifications
  • Measurements
    49 x 49 x 14.84 mm / 1.93 × 1.93 × 0.58 "
  • Weight
    74g with strap
  • Bezel material:
    Stainless steel
  • Glass material:
    Corning Gorilla Glass
  • Case material:
    Composite
  • Strap material:
    Silicone
  • What's in the box?
    Suunto Core 2 and Quick Guide
  • Country of manufacture
    CN
Technical specifications
  • Bezel material:
    Stainless steel
  • Glass material:
  • Case material:
    Composite
  • Strap material:
    Silicone
  • Weight:
    74g with strap
  • Water resistance:
    10 ATM
  • Battery type:
  • Battery Voltage
    3 V
  • User replaceable battery:
  • Time, date:
  • Alarm clock:
  • Dual time:
  • Countdown timer:
  • Languages:
    EN/DE/ES/FR
  • Backlight:
    Red and green
  • Configurable backlight:
    activation: 1 button, all buttons
  • Button lock:
  • Display size:
    1.3 inch
  • Display type:
    Dot-matrix display
  • Battery indicator:
  • Metric and imperial units:
  • Wrist sizes:
  • Stopwatch timer:
  • Moon Phase:
  • Step Counter:
COMPASS
  • Digital compass
  • Direction scale:
    degrees
  • Needle:
    north indicator
  • Needle
    north indicator
  • Bearing lock with orienting indicator:
  • Compass accuracy:
    5°
  • Compass resolution:
    1°
PHYSICAL SPECIFICATIONS
  • Operating temperature:
    -20 °C to +60 °C / -4 °F to +140 °F
  • Storage temperature:
BATTERY LIFE
  • In time mode:
    Up to 15 months
DIVING FUNCTIONS
FREEDIVING
  • Depth meter for snorkeling:
    10m
OUTDOOR FUNCTIONS
ALTIMETER
  • Barometric altitude:
  • Altitude graph:
  • Total ascent/descent:
    air pressure based
  • Automatic alti/baro profile:
  • Altitude difference:
  • Log recording rate:
    1Hz
  • Resolution:
    30min
  • Range:
    -100 - 10,000 m
WEATHER
  • Sea level pressure:
  • Sea level pressure graph:
    Not support
  • Weather trend indicator:
  • Temperature:
  • Temperature display range:
  • Sunrise/sunset times:
  • Storm alarm:
  • Pressure resolution:
    1 hPa / 0.03 inHg
  • Temperature resolution:
    1 °C / 1 °F
  • Max weather recording length:
    7 days
CONNECTIVITY
CONNECTIVITY
  • Frequency Band
    2402–2480 MHz
  • Connection Range
    ~10 m
  • App Support
SPORT EXPERTISE
HUNTING
  • Red backlight, compatible with night vision goggles
Recommended Products
SUPPORT FOR SUUNTO CORE 2
