SUUNTO AMBIT3 PEAK
Download PDF
SAFETY
Types of safety precautions:
- is used in connection with a procedure or situation that may result in serious injury or death.
- is used in connection with a procedure or situation that will result in damage to the product.
- is used to emphasize important information.
Safety precautions:
DO NOT USE FOR SCUBA DIVING.
ALLERGIC REACTIONS OR SKIN IRRITATIONS MAY OCCUR WHEN PRODUCT IS IN CONTACT WITH SKIN, EVEN THOUGH OUR PRODUCTS COMPLY WITH INDUSTRY STANDARDS. IN SUCH EVENT, STOP USE IMMEDIATELY AND CONSULT A DOCTOR.
DO NOT EXPOSE TO RAPID TEMPERATURE CHANGES.
DO NOT APPLY SOLVENT OF ANY KIND.
DO NOT APPLY INSECT REPELLENT.
TREAT AS ELECTRONIC WASTE.
DO NOT KNOCK OR DROP.
Buttons and menus
Suunto Ambit3 Peak has five buttons which allow you to access all the features.
- press to access the start menu
- press to start, pause or resume an exercise or timer
- press to increase a value or move up in the menu
- keep pressed to stop and save an exercise
- press to change displays
- press to accept a setting
- keep pressed to access/exit the options menu
- keep pressed to access/exit the options menu in sport modes
- press to activate the backlight
- press to decrease a value or move down in the menu
- keep pressed to lock/unlock the buttons
- press to change bottom row view
- keep pressed to toggle the display between light and dark
- keep pressed to access shortcut (see Shortcuts )
- press return to the previous menu
- press to add a lap during exercise
When changing values, you can increase the speed by keeping or pressed until the values start to scroll faster.
Set up
Your Suunto Ambit3 Peak wakes up automatically when you attach it to your computer or a USB charger using the supplied USB cable.
To start using your sports watch:
- Connect your sports watch to a power source with the supplied USB cable.
- Disconnect the USB cable if you are using a computer (to unlock buttons).
- Press or to scroll to the desired language and press to select.
- Pair with Suunto app (see Suunto app ) by pressing or skip by pressing .
- Follow the startup wizard to complete initial settings. Set values with or and press to accept and go to the next step.
- Reconnect USB cable and charge until battery indicator is 100%.
Fully charging an empty battery takes about 2-3 hours. Buttons are locked while the USB cable is attached and connected to a computer.
You can exit the startup wizard at any time by keeping pressed.
The startup wizard takes you through the following settings:
- Units
- Time
- Date
- Personal settings (gender, age, weight)
Adjusting settings
You can change the settings of your Suunto Ambit3 Peak directly in the watch or through Movescount (see Movescount ).
To change the settings in the watch:
- Keep pressed to enter the options menu.
- Scroll the menu with and .
- Press to enter a setting.
- Press and to adjust the setting values.
- Press to return to the previous menu or keep pressed to exit.
3D distance
Suunto Ambit3 Peak can take both elevation gain and loss into account when measuring distance. This gives you a more realistic distance measurement when you are exercising in hilly or mountainous terrain. In this scenario, 3D distance is greater than 2D distance.
If you are using 3rd-party software to analyze your tracks, check how the track distance is calculated. If the calculation is using 2D distance, you may not want to activate 3D distance in your watch.
Otherwise, if you are frequently exercising in hilly or mountainous terrain, you should activate 3D distance.
To activate 3D distance:
- While in a sport mode, keep pressed to enter the options menu.
- Scroll to ACTIVATE with and press .
- Scroll to 3D distance and press to switch to 3D distance.
- Keep pressed to exit.
Activity monitoring
In addition to the recovery time shown in your exercise log, Suunto Ambit3 Peak monitors you overall activity, both exercise and daily activity. Activity monitoring gives you a complete picture of your activity, the calories you are burning, and your recovery time.
Activity monitoring is available as a default display in Time . You can view the display by pressing (last display).
You can show/hide the activity monitoring display from the start menu under Displays » Activity . Toggle with .
The activity monitoring display has three views which you can change by pressing .
- Activity today : calorie consumption today; the dotted line on the bar graph indicates average daily calorie consumption for the past seven days, not including today
- Week activity : daily calorie consumption over the last seven days with today furthest to the right; the dotted line on the bar graph and lower row indicate average daily calorie consumption for the past seven days, not including today
- Recovery time : recovery time for the next 24 hours based on recorded exercises and daily activity\
Alti-Baro
With Alti-baro you can view the current altitude or barometric pressure. Press in Time mode to view the ALTI & BARO display.
You can show/hide the Alti-baro display under the start menu Displays » Alti-Baro . Toggle with .
You can access different views depending on which profile is activated by pressing .
Three profiles are available: Automatic , Barometer and Altimeter . For information on setting profiles, see Matching profile to activity .
Sunrise and sunset time views are available when GPS has been activated. If GPS is not active, sunrise and sunset times are based on the last recorded GPS data.
Getting correct readings
Suunto Ambit3 Peak constantly measures absolute air pressure using the built-in pressure sensor. Based on this measurement and reference values, it calculates altitude or sea level air pressure.
Keep the area around the sensor free of dirt and sand. Never insert any objects into the sensor openings.
If your outdoor activity requires accurate sea level air pressure or altitude, you need to calibrate your Suunto Ambit3 Peak by entering either your current altitude or the current sea level air pressure.
Absolute air pressure and known altitude reference = sea level air pressure. Absolute air pressure and known sea level air pressure = altitude.
The altitude of your location can be found from most topographic maps or Google Earth. A sea level air pressure reference for your location can be found using the websites of national weather services.
If Suunto FusedAlti
Changes in local weather conditions will affect altitude readings. If local weather changes often, it is advisable to reset the current altitude reference value frequently, preferably before starting your journey when the reference values are available. As long as the local weather stays stable, you do not need to set reference values.
To set the sea level pressure and altitude reference values:
- Scroll to Alti-baro with and enter with .
- Scroll to Reference with and enter with . The following setting options are available:
- FusedAlti : GPS is switched on and the watch starts calculating altitude based on FusedAlti.
- Manual altitude : Set your altitude manually.
- Sea level pressure : Set the sea level pressure reference value manually.
- Set the reference value using and . Accept the setting with .
You can access the Reference setting by keeping pressed when in Alti-Baro display.
You can also set your altitude during your exercise, see Setting altitude during exercise .
The Altimeter profile should be selected when your outdoor activity involves changes in altitude (e.g. hiking in hilly terrain).
The Barometer profile should be selected when your outdoor activity does not involve changes in altitude (e.g. soccer, sailing, canoeing).
To get correct readings, you need to match the profile to your activity. You can either let Suunto Ambit3 Peak decide a suitable profile for the activity, or choose a profile yourself.
You can define the profile as part of the sport mode settings in Movescount, or in your Suunto Ambit3 Peak .
To set the Alti & Baro profile:
- Press to select Profile .
- Scroll the profile options ( Automatic , Altimeter , Barometer ) with or . Select a profile with .
Use example: Setting the altitude reference value
You’re on the second day of your two-day hike. You realize that you forgot to switch from the Barometer profile to the Altimeter profile when you started moving in the morning.You know that the current altitude readings given by your Suunto Ambit3 Peak are wrong. So, you hike to the nearest location shown on your topographic map for which an altitude reference value is provided. You correct your Suunto Ambit3 Peak altitude reference value accordingly and switch from Barometer to Altimeter profile. Your altitude readings are correct again.
Incorrect readings
If your Altimeter profile is on for an extended period of time with the device in a fixed location while the local weather changes, the device will give incorrect altitude readings.
If your Altimeter profile is on and the weather changes frequently while you climb in altitude or go down in altitude, the device will give you incorrect readings.
If the Barometer profile is on for an extended period of time as you climb in altitude or go down in altitude, the device assumes that you are standing still and interprets your changes in altitude as changes in sea level air pressure. It will therefore give you incorrect sea level air pressure readings.
Using Altimeter profile
The Altimeter profile calculates altitude based on reference values. The reference value can either be sea level air pressure value or altitude reference value. When the Altimeter profile is activated, the altimeter icon is shown on the display.
When the Altimeter profile is activated, you can access the following views:
- top row: your current altitude
- middle row: graph displaying altitude changes over the past 24 hours (15 min. recording interval)
- bottom row: change with to show time, temperature, sunrise/sunset, or reference sea level pressure
If you are wearing your Suunto Ambit3 Peak on your wrist, you will need to take it off in order to get an accurate temperature reading because your body temperature will affect the initial reading.
Using Barometer profile
The Barometer profile shows the current sea level air pressure. This is based on the reference values added in the settings and the constantly measured absolute air pressure.
Changes in the sea level air pressure are presented graphically in the middle row of the display.
When the Barometer profile is activated, the barometer icon is shown on the display.
When the Barometer profile is activated, Suunto Ambit3 Peak shows you the following barometric information:
- top row: the current sea level air pressure
- middle row: a graph displaying sea level pressure changes over the past 24 hours (15 min. recording interval)
- bottom row: change with to show time, temperature, sunrise/sunset, or reference altitude
Altitude reference is the latest altitude used in Alti & Baro mode. It can be:
- the altitude you have set as altitude reference in the Barometer profile, or
- the latest altitude logged in the Automatic profile before changing to the Barometer profile.
Using Automatic profile
The Automatic profile switches between the Altimeter and Barometer profiles according to your movements. When the Automatic profile is active, the device will automatically switch between interpreting changes in air pressure as changes in altitude or changes in weather.
It is not possible to measure weather and altitude changes at the same time, as both cause a change in the surrounding air pressure. Suunto Ambit3 Peak senses vertical movement and switches to measuring altitude, when needed. When altitude is shown, it is updated with a maximum delay of 10 seconds.
If you are at a constant altitude (less than 5 meters of vertical movement within 12 minutes), Suunto Ambit3 Peak interprets all pressure changes as weather changes. The measurement interval is 10 seconds. The altitude reading remains steady and if the weather changes, you will see changes in the sea level air pressure reading.
If you are moving in altitude (more than 5 meters of vertical movement within 3 minutes), Suunto Ambit3 Peak interprets all pressure changes as movements in altitude.
Depending on which profile is active, you can access the Altimeter or Barometer profile views with .
When you are using the Automatic profile, barometer or altimeter icons are not shown on the display.
Autopause
Autopause pauses the recording of your exercise when your speed is less than 2 km/h (1.2 mph). When your speed increases to more than 3 km/h (1.9 mph), the recording continues automatically.
You can turn Autopause on/off for each sport mode in Movescount under the advanced settings for the sport mode.
You can also turn Autopause on/off during exercise without any effect on your Movescount settings.
To turn Autopause on/off during exercise:
- While you are in a sport mode, keep pressed to access the options menu.
- Scroll to Activate with and select with .
- Scroll to Autopause with and select with .
- Toggle on/off with or .
Autoscroll
Set your watch to automatically scroll through your sport mode displays while exercising by using Autoscroll .
In Movescount, you can turn Autoscroll on/off for each sport mode and define how long the displays are shown.
You can also turn Autoscroll on/off during exercise without any effect on your Movescount settings.
To turn Autoscroll on/off during exercise:
- Scroll to Autoscroll with and select with .
Backlight
Pressing activates the backlight.
By default, the backlight turns on for a few seconds and turns off automatically. This is the Normal mode.
There are four backlight modes:
Mode :
- Normal : The backlight turns on for a few seconds when you press and when the alarm clock sounds.
- Off : The backlight is not switched on by pressing a button or when the alarm clock sounds.
- Night : The backlight turns on for a few seconds when you press any button and when the alarm clock sounds.
- Toggle : The backlight turns on when you press and stays on until you press again.
Your Suunto Ambit3 Peak has two backlight settings: one 'general' setting and one for sport modes.
You can change the general backlight setting in the watch settings under General » Tones/display » Backlight . See Adjusting settings . You can also change the general setting in Movescount.
You sport modes can use the same backlight mode as the general setting (default), or you can define a different mode for each sport mode under the advanced settings in Movescount.
In addition to the mode, you can adjust the backlight brightness (in percent), either in the watch settings under General » Tones/display » Backlight or in Movescount.
When the and buttons are locked, you can still activate the backlight by pressing .
Button lock
Keeping pressed locks and unlocks buttons.
You can change the button lock behavior in the watch settings under General » Tones/display » Button lock .
Your Suunto Ambit3 Peak has two button lock settings: one for general use, Time mode lock , and one for when you are exercising, Sport mode lock :
Time mode lock :
- Actions only : Start and options menus are locked.
- All buttons : All buttons are locked. Backlight can be activated in Night mode.
Sport mode lock
- Actions only : , and the options menu are locked during exercise.
Select the Actions only button lock setting for sport modes to avoid accidentally starting or stopping your log. When the and buttons are locked, you can still change displays by pressing and views by pressing .
Compass
Suunto Ambit3 Peak has a digital compass that allows you to orient yourself in relation to magnetic north. The tilt-compensated compass gives you accurate readings even if the compass is not horizontally level.
You can show/hide the compass display from the start menu under DISPLAYS » Compass . Toggle with .
The compass display includes the following information:
- middle row: compass heading in degrees
- bottom row: change view to current heading in cardinals, to time or empty with
The compass switches to power saving mode after one minute. Reactivate it with .
Calibrating compass
If you have not used the compass before, you must first calibrate it. Turn and tilt the watch in multiple directions until the watch beeps, indicating calibration is complete.
If you have already calibrated the compass and want to re-calibrate it, you can access the calibration option in the options menu.
If the calibration is successful, the text Calibration successful is displayed. If the calibration does not succeed, the text Calibration failed is displayed. To retry the calibration, press .
To manually start compass calibration:
- Select to GENERAL with .
- Scroll to Compass with and select with .
- Press to select Calibration .
Setting declination
To ensure correct compass readings, set an accurate declination value.
Paper maps point to true north. Compasses, however, point to magnetic north – a region above the Earth where the Earth’s magnetic fields pull. Because magnetic North and true North are not at the same location, you must set the declination on your compass. The angle in between magnetic and true north is your declination.
The declination value appears on most maps. The location of magnetic north changes yearly, so the most accurate and up-to-date declination value can be obtained from the internet (for example www.magnetic-declination.com ).
Orienteering maps, however, are drawn in relation to magnetic north. This means that when you are using orienteering maps you need to turn the declination correction off by setting the declination value to 0 degrees.
To set the declination value:
- Press to enter general .
- Scroll to Compass using and select with .
- Scroll to Declination with and select with .
- Turn the declination off by selecting – , or select W (west) or E (east).
- Set the declination value with or .
- Press to accept the setting.
You can also access the compass settings by keeping pressed in Compass mode.
Setting bearing lock
You can mark the direction to your target in relation to North with the bearing lock feature.
To lock a bearing:
- With the compass active, hold the watch in front of you and turn yourself towards your target.
- Press to lock the current degree displayed on the watch as your bearing.
- An empty triangle indicates the locked bearing in relation to the North indicator (solid triangle).
- Press to clear the bearing lock.
While using the compass in an exercise mode, the button only locks and clears the bearing. Exit the compass view to make a lap with .
Countdown timer
You can use the countdown timer to count down from a preset time to zero. The timer makes a short sound every second during the last 10 seconds and sounds an alarm when zero is reached.
You can show/hide the countdown timer from the start menu under Displays » Countdown . Toggle with .
To set the countdown time:
- Press to until you reach the countdown timer display.
- Press to adjust the countdown time.
- Set the hours and minutes with and . Accept with .
- Press to start the countdown.
You can pause/continue the countdown by pressing .
Displays
Your Suunto Ambit3 Peak comes with several different features, such as compass (see Compass ) and stopwatch (see Stopwatch ), that are handled as displays that can be viewed by pressing . Some of them are permanent, and others you can show or hide as you like.
To show/hide displays:
- Press to enter the start menu.
- Scroll to Displays by pressing and press .
- In the list of display, toggle any feature on/off by scrolling to it with Start Stop or Light Lock and pressing Next. Keep pressed to exit the displays menu if needed.
Your sport modes (see Sport modes ) also have multiple displays that that you can customize to view different information while you exercise.
Adjusting display contrast
Increase or decrease the display contrast of your Suunto Ambit3 Peak in the watch settings.
To adjust the display contrast:
- Press to enter the General settings.
- Press to enter Tones/display .
- Scroll to Display contrast with and enter with .
- Increase the contrast with , or decrease it with .
Inverting display color
Change the display between dark and light through the settings in the watch or in Movescount, or by simply using the default button shortcut (see Buttons and menus ). You can also define the display color for a sport mode in Movescount.
To invert the display in the watch settings:
- Scroll to Invert display with and invert with .
Exercising with sport modes
Use sport modes (see Sport modes ) to record exercise logs and view various information during your exercise.
You can access the sport modes under Exercise menu by pressing .
Using Suunto Smart Sensor
A Bluetooth® Smart compatible heart rate sensor, such as the Suunto Smart Sensor, can be used with your Suunto Ambit3 Peak to give you more detailed information about your exercise intensity.
While exercising, the heart rate sensor enables:
- heart rate in real time
- average heart rate in real time
- heart rate in graph form
- calories burned during exercise
- guidance to exercise within defined heart rate limits
- Peak Training Effect
And after exercise, the heart rate sensor provides:
- total calories burned during exercise
- peak heart rate
- recovery time
If you use the Suunto Smart Sensor, you also have the added advantage of heart rate memory. The Suunto Smart Sensor memory function buffers data whenever the transmission to your Suunto Ambit3 Peak is interrupted.
This allows you to get accurate exercise intensity information in activities such as swimming where water blocks the transmission. It also means you can even leave your Suunto Ambit3 Peak behind after starting a recording. For more information, please refer to the Suunto Smart Sensor User Guide.
Without a heart rate sensor, your Suunto Ambit3 Peak provides calorie consumption and recovery time for running and cycling activities where speed is used to estimate intensity. However, we recommend using a heart rate sensor to get accurate intensity readings.
Refer to the user guide for Suunto Smart Sensor or other Bluetooth Smart compatible heart rate sensor for additional information.
Putting on Suunto Smart Sensor
To start using the Suunto Smart Sensor:
- Snap the sensor firmly into the strap connector.
- Adjust the strap length as needed.
- Moisten the strap electrode areas with water or electrode gel.
- Put the strap on so that it fits snugly and the Suunto logo is facing up.
The Smart Sensor turns on automatically when it detects a heart beat.
Wear the strap against your bare skin for best results.
Refer to the Suunto Smart Sensor User Guide for additional information and troubleshooting.
Dry skin under the belt electrodes, a loose belt, and synthetic shirt materials can cause abnormally high heart rate readings. Moisten the belt electrodes well and tighten the belt to avoid heart rate peaks. If you are otherwise concerned about your heart rate, please consult a doctor.
Starting an exercise
To start exercising:
- Press to enter Exercise .
- Scroll the sport mode options with or and select a suitable mode with .
- The watch automatically starts searching for a heart rate belt signal, if the selected sport mode uses a heart rate belt. Wait for the watch to notify that the heart rate and/or GPS signal have been found, or press to select Later . The watch continues to search the heart rate/GPS signal.
- Press to start recording your exercise. To access additional options while exercising, keep pressed.
During exercise
Suunto Ambit3 Peak gives you a wealth of information during your exercise. The information varies depending on the sport mode you have selected (see Sport modes ). You get even more information, if you use a heart rate belt and GPS during exercise.
Here are some ideas on how to use the watch during exercise:
- Press to see scroll through your sport mode displays.
- Press to see different information the bottom row of the display.
- To avoid accidentally stopping your log recording or making unwanted laps, lock the buttons by keeping pressed.
- Press to pause recording. To resume recording, press again.
Recording tracks
Depending on the sport mode you have selected, your Suunto Ambit3 Peak allows you to record various information during exercise.
If your sport mode has GPS enabled, Suunto Ambit3 Peak also records your track during your exercise. You can view the track in Suunto app as part of the recorded exercise.
Making laps
During your exercise, you can make laps either manually or automatically by setting the autolap interval in Movescount. When you are making laps automatically, Suunto Ambit3 Peak records the laps based on the distance you have specified in Movescount.
To make laps manually, press during the exercise.
Suunto Ambit3 Peak shows you the following information:
- top row: split time (duration from the start of the log)
- middle row: lap number
- bottom row: lap time
The exercise summary always shows at least one lap, your exercise from start to finish. The laps you have made during the exercise are shown as additional laps.
Navigating during exercise
If you want to run a route or to a point of interest (POI), you can select a sport mode, such as Run a Route, and begin navigating immediately.
You can also navigate a route or to a POI during your exercise in other sport modes that have GPS activated.
To navigate during exercise:
- While you are in a sport mode with GPS activated, keep pressed to access the options menu.
- Press to select navigation .
Scroll to
POIs (Points of interest)
or
Routes
with
and select with
The navigation guidance is shown as the last display on the selected sport mode.
To deactivate navigation, go back to Navigation in the options menu and select End navigation .
If the GPS accuracy setting (see GPS accuracy and power saving ) of your sport mode is Good or lower, while navigating GPS accuracy switches to Best . Battery consumption is therefore higher.
Using compass during exercise
You can activate the compass and add it to a custom sport mode during your exercise.
To use the compass during exercise:
- The compass is shown as the last display on the custom sport mode.
To deactivate the compass, go back to Activate in the options menu and select End compass .
If you do not want to use FusedAlti (see FusedAlti ) and know exactly what your current elevation is (for instance, from a sign on a well-traveled mountain trail), you can set your manually set your altitude while recording an exercise. Manually setting the altitude turns off FusedAlti if it was on.
To set your altitude during exercise:
- Scroll to ALTI-BARO with and select with .
- Select Altitude with .
- Set your altitude using and .
- Accept and exit by keeping pressed.
Find back
Suunto Ambit3 Peak automatically saves the starting point of your exercise, if you are using GPS. With Find back, Suunto Ambit3 Peak can guide you directly back to your starting point (or to the location where the GPS fix was established).
To find back:
- Scroll to Find back with and select with . The navigation guidance is shown as the last display on the selected sport mode.
Firmware updates
You can update your Suunto Ambit3 Peak software through Suuntolink. Make sure to sync your watch with Suunto app before you update the software, all logs will be deleted from the watch during the update.
To update your Suunto Ambit3 Peak software:
- Upload your exercises to Suunto app.
- Install Suuntolink if you have not done so already ( suuntolink ).
- Connect your Suunto Ambit3 Peak to your computer with the supplied USB cable and follow the instructions.
FusedAlti
FusedAlti
By default, altitude is measured with FusedAlti during exercises that use GPS and during navigation. When GPS is switched off, altitude is measured with the barometric sensor.
If you do not want to use FusedAlti in altitude measurement, you can disable it in the options menu.
To disable FusedAlti:
- Keep pressed to access the options menu.
- Scroll to FusedAlti with and select with .
- Set FusedAlti Off with or and accept with .
When the device is in time mode, you can search a new reference for barometric altitude with FusedAlti. This activates the GPS for a maximum of 15 minutes.
To search a new reference for barometric altitude with FusedAlti:
- Scroll to Auto adjust with and select with . GPS is switched on and the device starts calculating altitude based on FusedAlti.
In good conditions it takes 4 – 12 minutes for FusedAlti to activate. During that time, Suunto Ambit3 Peak shows barometric altitude and ~ is shown with the altitude reading to indicate that the altitude may not be correct.
FusedSpeed
FusedSpeed
FusedSpeed benefits you the most when you need highly reactive speed readings during training, for example, when running on uneven terrain or during interval training. If you temporarily lose the GPS signal, for example, Suunto Ambit3 Peak is able to continue showing accurate speed readings with the help of the GPS calibrated accelerometer.
To get the most accurate readings with FusedSpeed, only glance shortly at the watch when needed. Holding the watch in front of you without moving it reduces the accuracy.
FusedSpeed is automatically enabled for running and other similar types of activities, such as orienteering, floor ball and football (soccer).
To enable FusedSpeed for a custom sport mode, ensure you select an activity that uses FusedSpeed. This is indicated at the end of the sport mode advanced settings section in Movescount.
Icons
The following icons are displayed in Suunto Ambit3 Peak :
alarm |
altimeter |
barometer |
battery |
Bluetooth activity |
button lock |
button press indicators |
chronograph |
current display |
down/decrease |
GPS signal strength |
heart rate |
incoming call |
interval timer |
message/notification |
missed call |
next/confirm |
pairing |
settings |
sport mode |
storm |
sunrise |
sunset |
up/increase |
POI icons
The following POI icons are available in Suunto Ambit3 Peak :
begin |
building/home |
camp/camping |
car/parking |
cave |
crossroad |
end |
food/restaurant/cafe |
forest |
geocache |
lodging/hostel/hotel |
meadow |
mountain/hill/valley/cliff |
road/trail |
rock |
sight |
water/river/lake/coast |
waypoint |
Interval timer
You can add an interval timer to each custom sport mode in Movescount. To add the interval timer to a sport mode, select the sport mode and go to Advanced settings . The next time you connect your Suunto Ambit3 Peak to your Movescount account, the interval timer is synchronized to the watch.
You can specify the following information in the interval timer:
- interval types ( high and low interval)
- duration or distance for both interval types
- number of times the intervals are repeated
If you do not set the number of repetitions for the intervals in Movescount, the interval timer continues until it has been repeated 99 times.
You can set an interval timer for each sport included in a multisport mode (see Using a multisport mode ). The interval timer restarts when the sport changes.
To activate/deactivate the interval timer:
- Scroll to activate with and select with .
- Scroll to Interval with and select with .
- Press or to set the interval timer On/Off and accept with . When the interval timer is active, the interval icon is shown at the top of the display.
Logbook
The logbook stores the logs of your recorded activities. The maximum number of logs and the maximum duration of a single log depend on how much information is recorded in each activity. GPS accuracy (see GPS accuracy and power saving ) and using the interval timer (see Interval timer ), for example, directly impact the number and duration of logs that can be stored.
You can view the log summary of your activity right after you have stopped recording or through the logbook under the start menu.
The information shown in the log summary is dynamic: it changes depending factors such as sport mode and whether or not you used an heart rate belt or GPS. By default, all logs include at minimum the following information:
- sport mode name
- time
- date
- duration
- laps
If the log has GPS data, the logbook entry includes a view of the full route track as well as the altitude profile of the route.
You can see many more details of your recorded activities in Suunto app.
To view log summary after stopping a recording:
- Keep pressed to stop and save the exercise. Alternatively, you press to pause the recording. After pausing, stop by pressing , or continue recording by pressing . After pausing and stopping the exercise, save the log by pressing . If you do not want to save the log, press . If you do not save the log, you can still view the log summary after pressing , but the log is not stored in the logbook for later viewing.
- Press to view the log summary.
You can also view the summaries of all your saved exercises in the logbook. In the logbook the exercises are listed according to date and time.
To view summary log in the logbook:
- Scroll to Logbook with and enter with . Your current recovery time is shown.
- Scroll the logs with or and select a log with .
- Browse the summary views of the log with .
If the log includes multiple laps, you can view lap-specific information by pressing .
Memory left indicator
If more than 50 % of the logbook has not been synchronized with Suunto app, Suunto Ambit3 Peak displays a reminder when you enter the logbook.
The reminder is not displayed once the unsynced memory is full and Suunto Ambit3 Peak begins overwriting old logs.
Movescount
Movescount allows you to customize your watch to best meet your needs.
Start by installing SuuntoLink:
- Go to suuntolink .
- Download, install and open the latest version of SuuntoLink.
- Follow the instructions to create your Movescount account.
- Go to www.movescount.com and log in.
The first time your Suunto Ambit3 Peak is connected to Movescount, the watch settings are transferred from the watch to your Movescount account. The next time you connect your Suunto Ambit3 Peak to your Movescount account, changes in settings and sport modes you make in Movescount and in the watch are automatically synchronized.
Multisport training
You can use Suunto Ambit3 Peak for multisport training, easily switching between different sport modes (see Sport modes ) while exercising and viewing sport-specific data during your exercise and in the log summary.
You can change the sport manually during the exercise, or create a multisport mode to change sports in a specific order such as for a triathlon.
Switching sport modes manually
Suunto Ambit3 Peak allows you to switch to another sport mode during exercise without having to stop recording. All the sport modes you have used during the exercise are included in the log.
To switch the sport mode manually during exercise:
- While you are recording your exercise, keep pressed to access the sport modes.
- Scroll the list of sport mode options with or .
- Select a suitable sport mode with . Suunto Ambit3 Peak continues recording the log and the data for the selected sport mode.
Suunto Ambit3 Peak makes a lap each time you switch to another sport mode.
The log recording is not paused when you switch to another sport mode. You can pause the recording manually by pressing .
You can create your own multisport mode or use an existing default sport mode like Triathlon . The multisport mode can comprise a number of different sport modes in a specific order. Each sport can also have its own interval timer.
To use a multisport mode:
- Press to start recording the log.
- Keep pressed to change to the next sport while exercising.
Navigating with GPS
Suunto Ambit3 Peak uses the Global Positioning System (GPS) to determine your current position. GPS incorporates a set of satellites that orbit the Earth at an altitude of 20,000 km at the speed of 4 km/s.
The built-in GPS receiver in Suunto Ambit3 Peak is optimized for wrist use and receives data from a very wide angle.
Getting GPS signal
Suunto Ambit3 Peak activates GPS automatically when you select a sport mode with the GPS functionality, determine your location, or start navigating.
When you activate GPS for the first time, or have not used it for a long time, it might take longer than usual to get a GPS fix. Subsequent GPS starts will take less time.
To minimize GPS initiation time, hold the watch steady with GPS facing up and make sure you are in an open area so that the watch has a clear view of the sky.
Regularly synchronize your Suunto Ambit3 Peak with Suunto app to get the latest satellite orbit data (GPS optimization). This reduces the time needed to get the GPS fix and improves track accuracy.
Troubleshooting: No GPS signal
- For an optimal signal, point the GPS part of the watch upwards. The best signal can be received in an open area with a clear view of the sky.
- The GPS receiver usually works well inside tents and other thin covers. However, objects, buildings, dense vegetation or cloudy weather can reduce the GPS signal reception quality.
- GPS signal does not penetrate any solid constructions or water. Therefore do not try to activate GPS for example inside buildings, caves, or under water.
GPS grids and position formats
Grids are lines on a map that define the coordinate system used on the map.
Position format is the way the GPS receiver's position is displayed on the watch. All the formats relate to the same location, they only express it in a different way. You can change the position format in the watch settings under General » Format » Position format .
You can select the format from the following grids:
latitude/longitude is the most commonly used grid
and has three different formats:
- WGS84 Hd.d°
- WGS84 Hd°m.m'
- WGS84 Hd°m's.s
- UTM (Universal Transverse Mercator) gives a two-dimensional horizontal position presentation.
- MGRS (Military Grid Reference System) is an extension of UTM and consists of a grid zone designator, 100,000-meter square identifier and a numerical location.
Suunto Ambit3 Peak also supports the following local grids:
- British (BNG)
- Finnish (ETRS-TM35FIN)
- Finnish (KKJ)
- Irish (IG)
- Swedish (RT90)
- Swiss (CH1903)
- UTM NAD27 Alaska
- UTM NAD27 Conus
- UTM NAD83
- NZTM2000 (New Zealand)
Some grids cannot be used in the areas north of 84°N and south of 80°S, or outside the countries that they are intended for.
When customizing sport modes, you can define the GPS fix interval using the GPS accuracy setting in Movescount. The shorter the interval, the better the accuracy during exercise.
By increasing the interval and lowering the accuracy, you can extend the battery life.
The GPS accuracy options are:
- Best: ~ 1 sec fix interval, highest power consumption
- Good: ~ 5 sec fix interval, moderate power consumption
- OK: ~ 60 sec fix interval, lowest power consumption
- Off: no GPS fix
Notifications
If you have paired your watch with Suunto app, you can receive notifications such as incoming calls and text messages on your watch. When a notification arrives, a pop-up appears on the watch.
To get notifications on your watch:
- Press to scroll to CONNECTIVITY and press .
- Press to scroll to Settings and press .
- Press to scroll to Notifications and press .
- Toggle on/off with and press .
- Exit by keeping pressed.
With notifications on, your Suunto Ambit3 Peak gives an audible alert and displays a notification icon in the bottom row with each new event.
To view notifications on your watch:
- Scroll to Notifications with and select with .
- Scroll through the notifications with or .
Up to 10 notifications can be listed. Notifications remain in your watch until you clear them from your mobile device. However, notifications older than one day are hidden from view in the watch.
PODs and HR sensors
Pair your Suunto Ambit3 Peak with Bluetooth® Smart compatible bike, foot and Power PODs to receive additional information during exercise.You can pair up to five PODs at a time:
- three bike PODs, these can be speed, distance and/or cadence bike PODs, but only one can be connected at a time
- one foot POD
- one power POD
The Suunto Smart Sensor included in your Suunto Ambit3 Peak package (optional) is already paired. Pairing is required only if you want to use a different Bluetooth Smart compatible heart rate sensor.
Points of interest
Pairing procedures may vary depending on the POD or heart rate (HR) sensor type. Please refer to the user guide for the device you are pairing with your Suunto Ambit3 Peak before continuing.
To pair a POD or heart rate sensor:
- Activate the POD or heart rate sensor. If you are pairing a Suunto Smart Sensor, see Putting on Suunto Smart Sensor .
- Scroll to Pair with and select with .
- Scroll the options with and and press to select a POD or heart rate sensor to pair.
- Hold your Suunto Ambit3 Peak close to the device you are pairing and wait for Suunto Ambit3 Peak to notify that pairing was successful. If the pairing fails, press to retry, or to return to the pairing setting.
If you pair a power POD, you may need to define additional parameters in your Suunto Ambit3 Peak . These include, but are not limited to:
- Left crank or Right crank
- Left pedal or Right pedal
- Rear dropout
- Chainstay
- Rear wheel or Rear hub
Using foot POD
When using a foot POD, the POD is auto calibrated by GPS at short intervals during exercise. However, the foot POD always remains the source of speed and distance when it is paired and active for the given sport mode.
Foot POD auto calibration is on by default. It can be turned off in the sport mode options menu under Activate , if the foot POD is paired and is used for the selected sport mode.
For more accurate speed and distance measurements, you can manually calibrate the foot POD. Perform the calibration on an accurately measured distance, for instance, on a 400 meter running track.
To calibrate foot POD with Suunto Ambit3 Peak :
- Attach foot POD to your shoe. For more information, see user guide for the foot POD you are using.
- Choose a sport mode (for example Running ) in the start menu.
- Start running at your usual pace. When you cross the starting line, press to start the recording.
- Run a distance of 800–1000 meters (about 0.500–0.700 miles) at your usual pace (for example two laps on a 400 meter track).
- Press when you reach the finish line to pause the recording.
- Press to stop recording. After stopping the exercise, save the log by pressing . If you do not want to save the log, press . Scroll with through summary views, until you reach the distance summary. Adjust the distance shown on the display to the actual distance you ran with and . Confirm with .
- Confirm the POD calibration by pressing . Your foot POD has now been calibrated.
If the foot POD connection was unstable during the calibration exercise, you might not be able to adjust the distance in the distance summary. Make sure that foot POD is attached properly according to instructions and try again.
If you are running without a foot POD, you can still get running cadence from the your wrist. Running cadence measured from wrist is used together with FusedSpeed (see FusedSpeed ) and is always on for specific sport modes including running, trail running, treadmill, orienteering, and track and field.
If a foot POD is found at start of an exercise, running cadence measured from wrist is overwritten by foot POD cadence.
Calibrating power PODs and slope
Suunto Ambit3 Peak automatically calibrates your power POD when it finds the POD. You can also calibrate the power POD manually at any time during an exercise.
To manually calibrate a power POD:
- Stop pedaling and lift your feet off the pedals.
- Scroll to Calibrate Power POD with and select with .
Suunto Ambit3 Peak starts calibrating the POD and indicates if the calibration succeeded or failed. The bottom row of the display shows the current frequency used with the power POD. The previous frequency is shown in parentheses.
If your power POD has an auto zero feature, you can turn this on/off through your Suunto Ambit3 Peak .
To set auto zero on/off:
- After the calibration is completed, press .
- Set auto zero On/Off with and accept with .
- Wait until the setting is completed.
- Repeat procedure if setting fails or power POD is lost.
You can calibrate the slope for power PODs that use Crank Torque Frequency (CTF).
To calibrate the slope:
- After the power POD calibration is complete, press .
- Set the correct value according to your power POD manual with and accept with .
Points of interest
Suunto Ambit3 Peak includes GPS navigation which allows you to navigate to a pre-defined destination stored as a point of interest (POI).
You can also navigate when you are recording an exercise (see Navigating during exercise ).
To navigate to a POI:
- Scroll to Navigation using and enter with .
Scroll to
using
and select with
The watch displays the number of saved POIs and free space available for new POIs. - Scroll to the POI you wish to navigate to with or and select with .
- Press to select Navigate . If you are using the compass for the first time, you need to calibrate it (see Calibrating compass ). After activating the compass, the watch starts searching for a GPS signal and displays GPS found after acquiring the signal.
- Start navigating to the POI. The watch displays the following information:
- indicator showing the direction to your target (see further explanation below)
- your distance from the target
- The watch informs you that you have arrived at your target.
When stationary or moving slowly (<4 km/h), the watch shows you the direction to the POI (or waypoint if navigating a route) based on the compass bearing.
While moving (>4 km/h), the watch shows you the direction to the POI (or waypoint if navigating a route) based on GPS.
The direction to your target, or bearing, is shown with the empty triangle. Your direction of travel, or heading, is indicated by the solid lines at the top of the display. Aligning these two ensures you are moving in the correct direction.
Checking your location
Suunto Ambit3 Peak allows you to check the coordinates of your current location using GPS.
To check your location:
- Press to select Location .
- Press to select Current .
- The watch starts searching for a GPS signal and displays GPS found after acquiring the signal. After that your current coordinates are shown on the display.
You can also check your location while you are recording an exercise by keeping pressed to access the options menu.
Adding your location as a POI
Suunto Ambit3 Peak allows you to save your current location or define a location as a POI. You can navigate to a saved POI anytime, for example, during your exercise.
You can store up to 250 POIs in the watch. Note that also routes take up this quota. For example, if you have a route with 60 waypoints, you can additionally store 190 POIs in the watch.
To save a location as a POI:
- Select CURRENT or DEFINE to manually change longitude and latitude values.
- Press to save the location.
- Select a suitable POI type for the location. Scroll through the POI types with or . Select a POI type with .
- Select a suitable name for the location. Scroll through the name options with or . Select a name with .
- Press to save the POI.
Deleting a POI
You can delete a POI in the watch.
To delete a POI:
- Scroll to navigation using and enter with .
Scroll to
using
and select with
The watch displays the number of saved POIs and free space available for new POIs. - Scroll to the POI you wish to delete with or and select with .
- Scroll to Delete with . Select with .
- Press to confirm.
Recovery
Your Suunto Ambit3 Peak provides two indicators for following your need to recover after training: recovery time and recovery status.
Recovery time
Recovery time is an estimate in hours of how long your body needs to recuperate after training. The time is based on the duration and intensity of the training session, as well as your overall fatigue.
Recovery time accumulates from all types of exercise. In other words, you accumulate recovery time on long, low intensity training session as well as at high intensity.
The time is cumulative across training sessions, so if you train again before the time has expired, the newly accumulated time is added to the remainder from your previous training session.
The number of hours you accumulated for a given training session is shown in the summary at the end of the session.
The total number of hours of recovery time you have remaining is shown as a view of in the activity monitoring display (see Activity monitoring ).
Because recovery time is an estimation only, the accumulated hours are counted down steadily regardless of your fitness level or other individual factors. If you are very fit, you may recover faster than estimated. On the other hand, if you have the flu, for example, your recovery may be slower than estimated.
To get an accurate indication of your actual recovery state, we recommend using one of the recover tests (see Recovery status ).
Recovery status
Recovery status indicates the amount of stress on your autonomic nervous system. The less stress you have, the more recovered you are. Knowing your state of recovery helps you optimize your training and avoid over training or injury.
You can check your recovery status with the quick recovery test or sleep recovery test, powered by Firstbeat. The tests require a Bluetooth-compatible heart rate sensor that measures heart rate variability (R-R interval), such as Suunto Smart Sensor.
Your recovery status is indicated with 0-100% result scale as explained in the table below.
Result | Explanation |
81-100 | Fully recovered. OK to train up to very hard intensity. |
51-80 | Recovered. OK to train up to hard intensity. |
21-50 | Recovering. Train easy. |
0-20 | Not recovered. Rest to recover. |
Values below 50% measured on several consecutive days indicate an increased need to rest.
Test calibration
Both the sleep test and quick test need to be calibrated in order to provide accurate results.
The calibration tests define what 'fully recovered' means for your body. With each calibration test, your watch adjusts the results scale of the test to match your unique heart rate variability.
You need to perform three calibration tests for both tests. These need to be done when you have no accumulated recovery time. Ideally, you also feel fully recovered and are not ill or stressed during these calibration tests.
During the calibration period, you may get results that are higher or lower than expected. These results are indicated in the watch as your estimated recovery status until the calibration is completed.
Once you have completed the calibration, the latest result is displayed when you enter the logbook instead of recovery time.
Quick recovery test
The quick recovery test, powered by Firstbeat, is an alternative way to measure your recovery status. The sleep recovery test is a more accurate method to measure your recovery status. But for some individuals, wearing a heart rate sensor throughout the night may not be feasible.
The quick recovery test only takes a few minutes. For best results, you should lie down, stay relaxed, and not move around during the test.
We recommend performing the test in the morning after waking up. This helps ensure you get comparable results day to day.
You need to perform three tests while you are feeling well recovered and have no accumulated recovery time to calibrate the test algorithm.
The calibration tests do not need to be done in sequence, but they need to be at least 12 hours apart.
During this calibration period, you may get results that are higher or lower than expected. These results are indicated in the watch as your estimated recovery status until the calibration is completed.
To perform a quick recovery test:
- Put on your heart rate belt and ensure the electrodes are moist.
- Lie down and relax in a quiet environment free from disturbances.
- Press , scroll to RECOVERY with , and select with .
- Scroll to Quick test and select with .
Wait for the test to complete.
When the test is complete, scroll through the results
with
and
If the lowest heart rate during the test is below your rest heart rate defined in Movescount, your rest heart rate is updated the next time you sync with Movescount.
The results of this test do not impact your accumulated recovery time.
Sleep recovery test
The sleep recovery test, powered by Firstbeat, provides a reliable indicator of you recovery status after a night's sleep.
The calibration tests do not need to be done in sequence.
To perform a sleep recovery test:
- Scroll to Sleep test and select with .
- If you want to cancel the test, press .
- When you are ready to get up in the morning, end the test by pressing or .
When the test is ended, scroll through the results with and .
The sleep recovery test requires at least two hours of good heart rate data to produce results. The results of this test do not impact your accumulated recovery time.
Routes
You can create a route in Movescount, or import a route created with another service.
To add a route:
- Sync your Suunto Ambit3 Peak with Movescount using Suuntolink and the supplied USB cable.
Routes could also be deleted through Movescount.
Navigating a route
You can navigate a route you have recorded from an exercise (see Recording tracks ).
You can also navigate with sport modes (see Navigating during exercise ).
To navigate a route:
- Scroll to Navigation with and enter with .
- Scroll to Routes with and enter with . The watch displays the number of saved routes and after that a list of all your routes.
- Scroll to the route you want to navigate with or . Select with .
Press
and select
Navigate
Alternatively, you can select View to first preview a route and the altitude profile of the route. - The watch displays all the waypoints on the selected route. Scroll to the waypoint you want to use as the starting point with or . Accept with .
- If you selected a waypoint in the middle of the route, Suunto Ambit3 Peak prompts you to select the direction of the navigation. Press to select Forwards or to select Backwards . If you selected the first waypoint as the starting point, Suunto Ambit3 Peak navigates the route forward (from the first to the last waypoint). If you selected the last waypoint as the starting point, Suunto Ambit3 Peak navigates the route backwards (from the last to the first waypoint).
- If you are using the compass for the first time, you need to calibrate it (see Calibrating compass ). After activating the compass, the watch starts searching for a GPS signal and displays GPS found after acquiring the signal.
- Start navigating to the first waypoint on the route. The watch informs you when you are approaching the waypoint and automatically starts navigating to the next waypoint on the route.
- Before the last waypoint on the route the watch informs you that you have arrived at your destination.
To skip a waypoint on a route:
- While you are navigating a route, keep pressed to access the options menu.
- Press to select Navigation .
- Scroll to Skip waypoint with and select with . The watch skips the waypoint and starts navigating directly to the next waypoint on the route.
During navigation
During navigation, press to scroll the following views:
- the full track view showing the whole route
- zoomed-in view of the route. You can change the map orientation in the watch settings under GENERAL » Map.
- Heading up: Displays the zoomed-in map with the heading pointing up.
- North up: Displays the zoomed-in map with the north pointing up.
- waypoint navigation view
Full track view
The full track view shows you the following information:
- (1) arrow indicating your location and pointing to the direction of your heading.
- (2) the next waypoint on the route
- (3) the first and last waypoint on the route
- (4) The closest POI is shown as an icon.
- (5) scale on which the full track view is shown
In the full track view the north is always upwards.
Waypoint navigation view
The waypoint navigation view shows you the following information:
- (1) arrow pointing to the direction of the next waypoint
- (2) your distance to the next waypoint
- (3) the next waypoint you are headed towards
Altitude profile view
The altitude profile view shows you the following information:
- Accumulated ascent
- Real-time profile with dotted vertical line showing currently position
- Remaining ascent
If you are using barometer or automatic profile (see Matching profile to activity ), you should change the alti-baro setting to altimeter for best altitude profile accuracy.
Running performance level
Running performance level is a combined measurement of your physical fitness and your running efficiency, powered by Firstbeat.
Physical fitness
Running performance level uses an estimation of your VO2max, a global standard for aerobic fitness and endurance performance. V02max indicates your body’s maximal capability to transport and utilize oxygen.
V02max is affected by the condition of your heart, lungs, circulatory system, and the ability of your muscles to utilize oxygen in energy production. VO2max is the most important single denominator of endurance performance of an athlete.
In addition, research has indicated that VO2max is also an important measure for health and wellbeing. At optimum running efficiency, your running performance level corresponds to your real VO2max (ml/kg/min).
Running efficiency
Running performance level also takes into account running efficiency, a measurement of your running technique. This measurement also takes into account external factors such as terrain, running surface, weather, and running gear.
During a run
Your Suunto Ambit3 Peak provides real-time running performance feedback during your run.
The real-time feedback is available as a graph display in the default Running sport mode. You can add this graph to any sport mode that uses the running activity type. The real-time difference (see below) can also be used as a data field in your custom running sport modes.
During your run, the graph display shows your four data points, as illustrated below.
- Baseline: for each run, your running performance baseline is calibrated to compensate for external variables such as terrain and to wait for your heart rate to stabilize.
- Real-time level: this is your real-time running performance level for the current run displayed per kilometer/mile.
- Real-time difference: this shows you the real-time difference between the calibrated running performance baseline and your real-time running performance level for the current run.
- Distance: total distance for the current recording. The graph shows the last six kilometers (~4 miles).
Interpreting the results
If you are new to running or just haven't been out for a while, your running performance may be quite low at first. But as your physical fitness and running technique improve, you should see a corresponding increase in running performance.
Over a 4-20 week period, you may see an increase in running performance level up to 20%. If your running performance level is already good, it is difficult to improve further. In this situation, running performance level is better used as an endurance indicator.
Following the real-time difference indicator provides detailed, granular information on daily performance and fatigue during the run. Endurance runners can use this information to learn how much fatigue seems manageable during long intensive runs. During races, this information helps you pace yourself properly.
Illustrated below are three samples running performance levels during runs. In the first graph (1), performance is good. In the second (2), performance is bad and may indicate over training, illness, or just generally bad conditions. In the third graph (3), you see a typical long distance run where performance level drops steadily later in the run, indicate onset of fatigue.
Service menu
To access the service menu, keep and pressed simultaneously until the watch enters the service menu.
The service menu includes the following items:
Info
- Air pressure : shows the current absolute air pressure and temperature.
- BLE : shows the current Bluetooth Smart version.
- Version : shows the current software and hardware version.
Test
- LCD test : allows you to test that the LCD works properly.
Action
- Power off : allows you to put the watch into deep sleep.
- GPS reset : allows you to reset GPS.
- Clear data : clear recovery test calibration
Power off is a low power state. Connect the USB cable (with power source) to wake up the watch. The initial setup wizard starts. All settings except time and date are maintained. Just confirm them through the startup wizard.
The watch switches to power saving mode when it is static for 10 minutes. The watch re-activates when moved.
Service menu content is subject to change without notice during updates.
Resetting GPS
In case the GPS unit cannot find a signal, you can reset GPS data in the service menu.
To reset GPS:
- In the service menu, scroll to Action with and enter with .
- Press to scroll to GPS reset and enter with .
- Press to confirm GPS reset, or press to cancel.
Resetting GPS resets GPS data, compass calibration values and recovery time. Saved logs are not removed.
Shortcuts
By default, when you keep pressed in Time mode, you toggle the display between light and dark. This shortcut can be changed to a different menu item.
To define a shortcut:
- Keep pressed to enter the options menu or press to enter the start menu.
- Browse to the menu item to which you want to create a shortcut.
- Keep pressed to create the shortcut.
Shortcuts cannot be created to all possible menu items, such as individual logs.
In other modes, keeping pressed accesses predefined shortcuts. For example, when the compass is active, you can access the compass settings by keeping pressed.
Sport modes
Sport modes are your way to record exercises and other activities with your Suunto Ambit3 Peak . For any activity, you can select a sport mode from the set of predefined sport modes that came with your watch. If you cannot find a suitable sport mode, create your own custom sport modes through Movescount.
Different information is shown on the displays during exercise depending on the sport mode. The selected sport mode also affects exercise settings, such as heart rate limits and autolap distance.
In Movescount you can create custom sport modes, edit the predefined sport modes, delete sport modes, or simply hide them so that they are not shown in your exercise menu (see Starting an exercise ).
Custom sport modes
A custom sport mode can contain 1 to 8 different sport mode displays. You can choose which data appears on each display from a comprehensive list. You can customize, for example, sports-specific heart rate limits, what PODs to search for, or the recording interval to optimize accuracy and battery duration.
Any sport mode with GPS activated can also use the Quick Navigation option. By default, this option is off. When you select POI or Route, you get a pop-up list of the POIs or routes you have defined in your watch at the start of your exercise.
You can transfer up to 10 different sport modes created in Movescount to your Suunto Ambit3 Peak .
Stopwatch
The stopwatch is a display that can be turned on or off from the start menu.
To activate the stopwatch:
- Scroll to DISPLAYS with and press .
- Scroll to Stopwatch with and press .
You can now start to use the stopwatch or press to go back to the Time display. To get back to the stopwatch, press to scroll through the displays until you see the stopwatch.
To use the stopwatch:
- In the activated stopwatch display, press to start measuring time.
- Press to make a lap, or press to pause the stopwatch. To view the lap times, press when the stopwatch is paused.
- Press to continue.
- To reset the time, keep pressed when the stopwatch is paused.
While the stopwatch is running, you can:
- press to switch between the time and lap time shown on the bottom row of the display.
- switch to time mode with .
- enter the options menu by keeping pressed.
If you no longer want to see the stopwatch display, deactivate the stopwatch.
To deactivate the stopwatch:
- Scroll to End stopwatch with and press .
Suunto app
With the Suunto app, you can further enrich your Suunto Ambit3 Peak experience by analyzing and sharing your trainings, connecting to partners and much more. Pair with the mobile app to get notifications on your Suunto Ambit3 Peak .
To pair your watch with Suunto app:
- Download and install Suunto app on your compatible mobile device from the App Store, Google Play in addition to several popular app stores in China.
- Start Suunto app and turn on Bluetooth if it is not on already.
- On your watch, keep pressed to enter the options menu.
- Scroll to PAIR with and select with
- Press to select MobileApp .
- Return to the app and tap the watch icon in the upper left corner of the screen. When the name of the watch appears, tap PAIR.
- Enter the passkey shown on your watch display into the paring request field on your mobile device and tap PAIR to finalize the connection.
Some features require an internet connection over Wi-Fi or mobile network. Carrier data connection fees may apply.
Syncing with mobile app
If you have paired your Suunto Ambit3 Peak with Suunto app, all your new training sessions are automatically synced when the Bluetooth connection is active and in working range. The Bluetooth icon on your Suunto Ambit3 Peak flashes when data is being synced.
This default setting can be changed from the options menu.
To turn off automatic syncing:
- Keep pressed to enter the options menu.
- Scroll to CONNECTIVITY with and select with .
- Scroll to Settings with and select with .
- Press Next again to enter the MobileApp sync setting.
- Toggle off with and keep pressed to exit.
Suunto Apps
Suunto Apps allow you to further customize your Suunto Ambit3 Peak . Visit Suunto App Zone under Community in Movescount.com to find Apps, such as various timers and counters, available for your use. If you cannot find what you need, create your own App with Suunto App Designer. You can create Apps, for example, for calculating your estimated marathon result, or the slope grade of your skiing route.
Suunto Apps in Movescount refers to apps you can use in your watch. Not to be confused with Suunto app which is a mobile app used for analyzing and sharing your trainings, connecting to partners and much more.
To add Suunto Apps to your Suunto Ambit3 Peak :
- Go to the App zone section in Movescount community to browse existing Suunto Apps. To create your own App, select App Designer .
- Add Suunto App to a sport mode. Connect your Suunto Ambit3 Peak to your Movescount account to synchronize Suunto App to the watch. The added Suunto App will show the result of its calculation while you exercise.
You can add up to five Suunto Apps to each sport mode.
Swimming
You can use your Suunto Ambit3 Peak for recording swimming exercises in a pool or openwater.
When used together with the Suunto Smart Sensor, you can also record your heart rate while you are swimming. The heart rate data is automatically uploaded to your Suunto Ambit3 Peak once you get out of the water.
Pool swimming
When using the pool swimming sport mode, Suunto Ambit3 Peak measures your swimming speed based on the pool length. Each pool length creates a lap that is shown in Suunto app.
To record pool swimming:
- Scroll to Pool swimming using and select with .
- Select the pool length. You can select the pool length from the predefined values, or select the custom option to specify the pool length. Scroll the values with and and accept with .
- Press to start recording your swimming.
Swimming styles
You can teach your Suunto Ambit3 Peak to recognize your swimming style. After teaching the swimming styles, Suunto Ambit3 Peak detects them automatically when you start swimming.
To teach swimming styles:
- While you are in the Pool swimming sport mode, keep pressed to enter the options menu.
- Press to select Swimming .
- Press to select Teach swim style .
- Scroll the swimming style options with and . Select a suitable swimming style with . You can exit the setting and continue your exercise by selecting End . The available swimming style options are:
- fly (butterfly)
- back (backstroke)
- breast (breaststroke)
- free (freestyle)
- Swim the pool length in the swimming style you selected.in
- After you have finished swimming, press to save the style. If you do not want to save the style, press to return to the swimming style selection.
You can exit teaching swimming styles any time by keeping pressed.
To reset taught swimming styles back to defaults:
- In the Pool swimming mode, keep pressed to enter the options menu.
- Scroll to Reset taught styles with and select with .
Swimming drills
You can do swimming drills any time during your swimming workout. If you do a drill with a swimming style that the watch does not detect as swimming (for example, using only your legs), you can add the pool length manually for each drill to keep your total distance correct.
Do not add the drill distance until you have finished your drill.
To do a drill:
- While you are recording your pool swimming, keep pressed to access the options menu.
- Press to enter Swimming .
- Press to select Drill and start swimming your drill.
- After you have finished your drill, press to adjust the total distance, if necessary.
- To end the drill, go back to Swimming in the options menu and select End drill .
Openwater swimming
When using the openwater swimming mode, Suunto Ambit3 Peak measures your swimming speed using GPS and shows you real-time data during the swim.
To record an outdoor swimming log:
- Scroll to Openwater swim with and select with .
- Wait for the watch to notify that a GPS signal has been found.
- Press to start recording your swimming log.
Press to add laps manually during the swim.
Time
The time display on your Suunto Ambit3 Peak shows the following information:
- top row: date
- middle row: time
- bottom row: change with to show additional information such as weekday, dual time, daily step count, and battery level.
To access the time settings:
- Scroll to Time/date using and enter with .
Under the Time/date menu you can set the following:
- Time
- Date
- GPS timekeeping
- Dual time
- Alarm
To change time settings:
- In the Time/date menu, scroll to the desired setting with or and select the setting with .
- Change the values with and and save with .
- Go back to the previous menu with , or keep pressed to exit.
Alarm clock
You can use your Suunto Ambit3 Peak as an alarm clock.
To access the alarm clock and set the alarm:
- In the options menu, go to General , then to Time/date and Alarm .
- Set the alarm on or off with or . Accept with .
- Go back to the settings with , or keep pressed to exit the options menu.
When the alarm is switched on, the alarm symbol is shown on most of the displays.
When the alarm sounds, you can:
- Select Snooze by pressing . The alarm stops and restarts every five minutes until you stop it. You can snooze up to 12 times for a total of one hour.
- Select Stop by pressing . The alarm stops and restarts the same time the following day, unless you switch the alarm off in the settings.
When snoozing, the alarm icon blinks in the Time display.
Time syncing
Your Suunto Ambit3 Peak time can be updated through your mobile phone, computer (Suuntolink) or GPS time.
When you connect your watch to the computer with the USB cable, Suuntolink by default updates your watch time and date according to the computer clock.
GPS timekeeping
GPS timekeeping corrects the offset between your Suunto Ambit3 Peak and the GPS time. GPS timekeeping corrects the time automatically once a day, or after you have adjusted the time manually. Also the dual time is corrected.
GPS timekeeping corrects the minutes and seconds, but not the hours.
GPS timekeeping corrects the time accurately, if it is less than 7.5 minutes wrong. If the time is wrong more than that, GPS timekeeping corrects it to the closest 15 minutes.
GPS timekeeping is activated by default. To deactivate it:
- In the options menu, go to General , then to Time/date and GPS timekeeping .
- Set the GPS timekeeping on or off with and . Accept with .
- Go back to the settings with , or keep pressed to exit.
Track back
With Track back , you can retrace your route at any point during an exercise. Suunto Ambit3 Peak creates temporary waypoints to guide you back to your starting point.
To track back during exercise:
- While you are in a sport mode that uses GPS, keep pressed to access the options menu.
- Scroll to Track back with and select with .
You can now start navigating your way back the same way as during route navigation.
Track back can also be used from the logbook with exercises that include GPS data. Follow the same procedure as in Navigating a route . Scroll to Logbook instead of Routes , and select a log to start navigating.
Weather indicators
In addition to the barometer graph (see Using Barometer profile ), Suunto Ambit3 Peak has two weather indicators: weather trend and storm alarm.
The weather trend indicator is displayed as a view the time display, providing you a quick way to check weather changes.
The weather trend indicator is comprised of two lines forming an arrow. Each line represents a 3-hour period. A change in barometric pressure greater than 2 hPa (0.59 inHg) over three hours triggers a change the direction of the arrow. For example:
pressure dropping heavily over the last six hours |
pressure was steady, but rising heavily over the last three hours |
pressure was rising heavily, but dropping heavily over the last three hours |
Storm alarm
A significant drop in barometric pressure typically means a storm is coming and you should take cover. When the storm alarm is active, Suunto Ambit3 Peak sounds an alarm and flashes a storm symbol when the pressure drops 4 hPa (0.12 inHg) or more during a 3-hour period.
The storm alarm does not work if you have altimeter profile activated. See Matching profile to activity .
To activate Storm alarm :
- Scroll to Alti-baro with and enter with .
- Press to select Storm alarm .
- Set the storm alarm On or Off with with or and accept with .
When a storm alarm sounds, pressing any button ends the alarm. If no button is pressed, the alarm repeats once after five minutes. The storm symbol remains on the display until the weather conditions stabilize (pressure drop slows down).
A special lap (called 'storm alarm') is generated when a storm alarm occurs while recording an exercise.
You can also activate or deactivate the storm alarm through the options menu in a sport mode.
Handling guidelines
Handle the unit with care – do not knock or drop it.
Under normal circumstances the watch does not require servicing. After use, rinse it with fresh water, mild soap, and carefully clean the housing with a moist soft cloth or chamois.
Remember to register your Suunto Ambit3 Peak at support to get personalized support.
Water resistance
Suunto Ambit3 Peak is water resistant to 100 meters/330 feet/10 bars. The meter value relates to an actual diving depth and is tested in the water pressure used in the course of the Suunto water resistance test. This means you can use the watch for swimming and snorkeling, but it should not be used for any form of diving.
Water resistance is not equivalent to functional operating depth. The water resistance marking refers to static air/water tightness withstanding shower, bathing, swimming, poolside diving and snorkeling.
To maintain water resistance, it is recommended to:
- never use the device for other than intended use.
- contact an authorized Suunto service, distributor or retailer for any repairs.
- keep the device clean from dirt and sand.
- never attempt to open the case yourself.
- avoid subjecting the device to rapid air and water temperature changes.
- always clean your device with fresh water if subjected to salt water.
- never knock or drop the device.
Charging the battery
The duration on a single charge depends on how Suunto Ambit3 Peak is used and in what conditions. Low temperatures, for example, reduce the duration of a single charge. In general, the capacity of rechargeable batteries decreases over time.
In case of abnormal capacity decrease due to defective battery, Suunto warranty covers the battery replacement for one year or for at maximum 300 charging times, whichever comes first.
The battery icon indicates the charge level of the battery. When the battery charge level is less than 10 %, the battery icon blinks for 30 seconds. When the battery charge level is less than 2 %, the battery icon blinks continuously.
Charge the battery by attaching it to your computer with the supplied USB cable, or charge with a USB-compatible wall charger. It takes approximately 2-3 hours to fully charge an empty battery.
Go to Movescount to change the GPS fix interval of your sport modes to save battery life. For more information, see GPS accuracy and power saving .
Replacing Smart Sensor battery
The Suunto Smart Sensor uses a 3-Volt lithium cell (CR 2025).
To replace the battery:
- Remove the sensor from the belt strap.
- Open the battery cover with a coin.
- Replace the battery.
- Firmly close the battery cover.
Technical specifications
General
- Operating temperature: -20° C to +60° C/-5° F to +140° F
- Battery charging temperature: 0° C to +35° C/+32° F to +95° F
- Storage temperature: -30° C to +60° C/-22° F to +140° F
- Weight: 89 g/3.14 oz (Black), 92 g/3.25 oz (Sapphire)
- Water resistance ( Suunto Ambit3 Peak ): 100 m/328 ft/10 bar
- Water resistance (Suunto Smart Sensor): 20 m/66 ft
- Lens: mineral crystal glass (sapphire crystal in Sapphire models)
- Power: rechargeable lithium-ion battery
- Battery life: ~ 20 - 200 hours depending on selected GPS accuracy
Memory
- Points of Interest (POIs): max. 250
Radio transceiver
- Bluetooth® Smart compatible
- Communication frequency: 2402-2480 MHz
- Maximum transmission power: <0 dBm (conducted)
- Range: ~3 m/9.8 ft
Barometer
- Display range: 950 to 1060 hPa/28.05 to 31.30 inHg
- Resolution: 1 hPa/0.03 inHg
Altimeter
- Display range: -500 m to 9999 m/-1640 ft to 32805 ft
- Resolution: 1 m/3 ft
Thermometer
- Display range: -20° C to +60° C /-4° F to +140° F
- Resolution: 1°
Chronograph
- Resolution: 1 s until 9:59'59, after that 1 min
Compass
- Resolution: 1 degree/18 mils
GPS
- Technology: SiRF star V
- Frequency band: 1575.42 MHz
Manufacturer
Suunto Oy
Tammiston kauppatie 7 A
FI-01510 Vantaa
FINLAND
Compliance
CE
Hereby, Suunto Oy, declares that the radio equipment type OW143 is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: EUconformity .
FCC compliance
This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions:
(1) this device may not cause harmful interference, and
(2) this device must accept any interference received, including interference that may cause undesired operation. This product has been tested to comply with FCC standards and is intended for home or office use.
Changes or modifications not expressly approved by Suunto could void your authority to operate this device under FCC regulations.
NOTE: This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
- Reorient or relocate the receiving antenna.
- Increase the separation between the equipment and receiver.
- Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
- Consult the dealer or an experienced radio/TV technician for help.
Amer Sports United States
2030 Lincoln Avenue
84401 Ogden
United States
+1 855 258 0900
ISED REGULATORY COMPLIANCE
This device contains licence-exempt transmitter(s) that comply with Innovation, Science and Economic Development Canada’s licence-exempt RSS(s).
(1) this device may not cause interference, and
(2) this device must accept any interference, including interference that may cause undesired operation of the device.
NOM-121-SCT1-2009
Trademark
Suunto Ambit3 Peak , its logos, and other Suunto brand trademarks and made names are registered or unregistered trademarks of Suunto Oy. All rights are reserved.
Patent notice
This product is protected by pending patent applications and their corresponding national rights: EP 11008080, EU designs 001332985-0001 or 001332985-0002, US 13/833,755, US 61/649,617, US 61/649,624, US 61/649,632 (HR belt: US 13/071,624, US 13/832,049, US 13/832,598, US 13/917,668, US 13/397,872, USD 667,127, US 8,386,009, US 8,750,959, US 8,814,574, US 8,886,281). Additional patent applications have been filed.
International Limited Warranty
Warranty Period
The Warranty Period is two (2) years for Watches, Smart Watches, Dive Computers, Heart Rate Transmitters, Dive Transmitters, Dive Mechanical Instruments, and Mechanical Precision Instruments unless otherwise specified.
The Warranty Period is one (1) year for accessories including but not limited to Suunto chest straps, watch straps, chargers, cables, rechargeable batteries, bracelets and hoses.
The Warranty Period is five (5) years for failures attributable to the depth measurement (pressure) sensor on Suunto Dive Computers.
Exclusions and Limitations
- normal wear and tear such as scratches, abrasions, or alteration of the color and/or material of non-metallic straps, b) defects caused by rough handling, or c) defects or damage resulting from use contrary to intended or recommended use, improper care, negligence, and accidents such as dropping or crushing;
- printed materials and packaging;
- defects or alleged defects caused by use with any product, accessory, software and/or service not manufactured or supplied by Suunto;
- non-rechargeable batteries.
- has been opened beyond intended use;
- has been repaired using unauthorized spare parts; modified or repaired by unauthorized Service Center;
- serial number has been removed, altered or made illegible in any way, as determined at the sole discretion of Suunto; or
- has been exposed to chemicals including but not limited to sunscreen and mosquito repellents.
You must provide proof of purchase to access Suunto warranty service. You must also register your product online at apac.suunto.com/register to receive international warranty services globally. For instructions how to obtain warranty service, visi t , contact your local authorized Suunto retailer, or call Suunto Contact Center.
Limitation of Liability
Copyright
© Suunto Oy 9/2014. All rights reserved. Suunto, Suunto product names, their logos and other Suunto brand trademarks and names are registered or unregistered trademarks of Suunto Oy. This document and its contents are proprietary to Suunto Oy and are intended solely for the use of clients to obtain knowledge and information regarding the operation of Suunto products. Its contents shall not be used or distributed for any other purpose and/or otherwise communicated, disclosed or reproduced without the prior written consent of Suunto Oy. While we have taken great care to ensure that information contained in this documentation is both comprehensive and accurate, no warranty of accuracy is expressed or implied. This document content is subject to change at any time without notice. The latest version of this documentation can be downloaded at apac.suunto.com .
