Made in Finland
Limited lifetime warranty
Control marking holes
Exceptionally stable & fast needle
Baseplate with magnifying lens
Luminescent markings for low light
| Free returns
Lightweight sports watch designed for runners
The ultimate performance watch out now!
Shopping Cart
Money-back guarantee
30-Days Return
Warranty Repair
A compact, accurate compass for hiking and orienteering, also in poor visibility?
30-Days Return
Warranty Repair
Made in Finland
Suunto A-30 is a reliable baseplate compass for navigating and surviving in extreme conditions. Depending on the variant, A-30 comes with Metric UTM scales and inch ruler or USGS UTM scales.
The Earth’s magnetic field does not flow evenly between the magnetic poles along the surface of the planet. To compensate for the natural tilt in the magnetic field, Suunto compasses use one of two balancing systems and you should choose the variant best serving your needs.
One is a two-zone system with needles balanced for either the northern or southern hemisphere. The second is a unique globally balanced system. A single needle is balanced to work anywhere in the world. This is achieved by a breakthrough construction allowing the needle and magnet to tilt independently.
The compass liquid used by Suunto is specially formulated to provide damping over a large temperature range while preventing the needle from sticking.
The lanyard with wristlock is easy to detach for working with the map.
All Suunto compasses are handcrafted at our factory with 100% renewable energy.
