The right way to qualify for Kona
October 10 2016
Sam Gyde competed in his seventh Kona Ironman this year and has won his age group three times. On Saturday he finished a solid third in his M40-44 age group. The 41-year-old Belgian says getting to Kona is all about having the right perspective.
Sam Gyde had no background in endurance sports before he started triathlon when he was 27. Until then, he couldn’t even swim. He completed his first Ironman in 2007, at age 32.
Since, he has competed all over the world, and won his age group at the Ironman World Championships in Kona, Hawaii three times. This year, he achieved his fastest time ever (08h42m) at the Ironman Austria-Karnten.
After competing at Kona seven times, he’s well qualified to explain how to get there. He says if you have “endurance genes” it’s fully possible for busy people with families and jobs to qualify. But you have to play it smart.
Image by sportograf.com
Slow and steady
Long distance triathlon is something you should build slowly. It’s important you build a very solid base and capitalise on that. It's really important to listen to your body, to track your data, to have a good coach who can be objective about your training. You could get to Kona in your first year of training, but I think in the long term it’s better to build slowly and progressively. It will help you to keep enjoying the sport.
Strength at home
The training required to qualify is intense, especially if you have to balance it with family and work. Having a balance in life and getting support from the people around you is important. You have to find mutual goals with your family; if all the sacrifices come from one side only, then it doesn’t work so well.
Don’t overdo it
My personal belief is many people overdo their training. You don’t need to train more than 20 hours a week. If you have a well-balanced training programme of around 15 hours a week, with some peak weeks, it’s enough. Volume is important, but don’t obsess about it. The right focus with the right intensity is much more important.
Focus on the right disciplines
Spend time on training whatever discipline will give the most gains. Sometimes it really pays off to focus on the things you don’t like. And some things are time consuming and offer little gains. For example, I’m a weak swimmer and it takes lots of time to go to a swimming pool. You have to ask whether investing all of that time is worth it. These are decisions to be smart about.
Work with a coach
It’s important to have a coach who can look at things from a distance. If you’re slacking or if something happens in life and disrupts your training, a coach will stop you from panicking, and will find a work around. If things are going really well, and you have plenty of time to train, a coach will help you to hold back to avoid going into overdrive.
Go with your strengths
To choose a race to qualify at, follow your strengths. If you know you’ll lose a lot of time swimming in choppy, open water, then don’t choose a race with an ocean swim. If you’re a strong biker, go for a more challenging bike race. If you cope well with the heat, then choose a race that matches. Focus on your own strengths.
Image by finisherpix.com
Pick the right race
The number of qualifying slots of a race is proportionate to the number of starters. There are some races with a lot more slots than others. There are races with a very limited number of slots that are very competitive. In the US, qualifying is usually less competitive than Europe. And races early in the year are usually less competitive, but it means you have to train during winter.
Qualifying is harder for some
For some people, and some age groups, it’s very hard to qualify. It’s especially difficult for women to qualify since there are less women competing in Ironman races. Usually that means there’s only one slot available for each age group. With some male age groups there are a lot of slots. If you finish second, third or fourth, you often still qualify. Whereas, as a woman, even if you come second, you won’t.
Don’t be fooled
People look at the history of qualifications to find out what the times were for a race in the previous years, but a race with a slow qualification time this year might have a very fast qualification time next year. The best bet is to look at your own strengths and weaknesses and select a race accordingly.
Focus on one race
For ordinary working people, it’s hard to combine different races in one year with normal job and family commitments. If you find yourself in this category, the best bet is to work on your base and focus on one peak qualification race. If it works out, great, if it doesn’t, try again next year. In my first two Ironman races I failed to qualify by 30 seconds.
Click here for more information about how to qualify for the Kona Ironman.
Main image by finisherpix.com
READ MORE
Talking training with sub-8h Ironman Patrik Nilsson
Patrik Nilsson – Training for the love of it
おすすめのSuunto製品
あなたへのおすすめ
Suunto Race S vs Race 2: Size, Weight, and Battery Life Compared
Suunto Race SとRace 2を比較。サイズ・重さ・バッテリーで選ぶならどっち?
Suuntoのスポーツウォッチを検討している人にとって、迷いやすいのが「Suunto Race S」と「Suunto Race 2」の違いです。 どちらもAMOLEDディスプレイ、オフラインマップ、115以上のスポーツモード、トレーニング分析機能を備えた、ランニングやトレイルランニング、レース、日々のトレーニングに活用できる高性能モデルです。Suunto Race Sは「小さく、軽く、日常に...
Suunto Vertical vs. Vertical 2: Key Differences Explained
Suunto Vertical vs Vertical 2|どちらを選ぶべき?5つの違いを徹底比較
「Suunto Verticalを買おうと思っていたら、Vertical 2が出ていた」「初代とどこが変わったのか、値段差に見合う進化があるのか知りたい」——そんな疑問を持つ方に向けて、この記事では2モデルの違いを5つのポイントに絞って整理します。 どちらを選ぶべきかの判断基準も最後に明確にまとめていますので、ぜひ最後まで読んでみてください。 Suunto Vertical と Vertic...
How to play music on a running watch | Run without your phone with Suunto Run × Spark
ランニングウォッチで音楽再生する方法|スマホなしで走れるSuunto Run × Sparkの使い方
ランニング中に音楽を聴きたいけれど、スマートフォンを持って走るのは重い。ポケットやランニングポーチの中で揺れるのが気になる。そんな悩みを感じたことはありませんか? 音楽再生に対応したランニングウォッチを使えば、スマートフォンを持たずに、より身軽に走ることができます。 Suunto Runは、ウォッチ本体に音楽を保存できるオフライン音楽機能を搭載したランニングウォッチです。Suunto ...
How to use HRV to optimize your recovery
HRV(心拍変動)とは?正常値の見方と回復・トレーニングへの活かし方
「しっかり練習しているのに記録が伸びない」「いつもより疲れが残っている」と感じるときは、トレーニング量だけでなく、身体の回復状態にも目を向けてみましょう。回復を把握するための指標として活用されているのが、HRV(心拍変動)です。 HRVは、心拍数そのものではなく、心拍と心拍の間隔に生じるわずかなゆらぎを示します。毎日の数値を継続して確認することで、トレーニング、睡眠、ストレスなどに...
