How to go the (ultra) distance – with Ryan Sandes
SuuntoRun — May 28 2015
From mastering the art of recovery to learning to hike, these are the tips from champion ultra runner Ryan Sandes that will see you through an ultra. This is part one of a three part series. Click here for part two and here for part three.
1. Listen to your body
When you're training for a 100 km race it’s important to have a training schedule, but you must be flexible with it. A lot of ultra runners get hell-bent on achieving their goals, causing them to lose sight of the bigger picture. You really have to listen to your body. If your body is not feeling up to it one week, then back off. If you’re feeling on top of the world, maybe you can do a bit more. Remember, the schedule is a guide only.
“Recovery is more important than running.” ©Craig Kolesky/Red Bull Content Pool
2. Stay mobile
Before I run, I often do 10 to 15 minutes of basic mobility exercises to ensure everything is firing when I start running. It’s important to build basic mobility exercises into your training, even if you only have time for two or three minutes before you start running. Side bridges, basic mountain climbers, bear crawls, A-marches, lunges and ABC drills are all helpful.
3. Better to be under than over trained
Training for an ultra marathon isn’t just about how many kilometers you run each week. I know a lot of guys who came into the sport and for two years did high mileages and won races, but then burned out. If you're new to the sport and you're doing a high mileage, you're really risking injury. For me, I'd rather go to a 100 km race 20 per cent under trained than one per cent over trained.
4. Have an off-season
It’s important to have an off-season. I don't mean taking three months off and doing absolutely nothing! It’s fine to take a month off and just hang out with your friends and have a party or two. But then spend the next two months doing strength work in a gym to prepare yourself for the season ahead. This helps prevent injuries.
5. Hike that long run
When you're trying to build up for an ultra distance trail race, it's important to incorporate hiking into your long runs. It helps you get extra time on your feet. You might start with an hour or two of hiking and then run for two hours afterwards, or hike for an hour, run for an hour.
6. Keep a log
Keep a logbook and write briefly after each run what you did and how you felt so you can look back and see what’s worked and what hasn’t.
7. Spend time on recovery
Recovery is more important than training! It's vital to make sure you're getting enough rest and sleep. If you're working full time then you need to be really careful, as it’s all a lot of stress on the body. Get regular massages, too. Our legs are like car wheels – you might have a Porsche, but if the wheel alignment is out, it's not going to drive well.
Main image: ©Kelvin Trautman / Red Bull Content Pool
おすすめのSuunto製品
あなたへのおすすめ
Suunto Race S vs Race 2: Size, Weight, and Battery Life Compared
Suunto Race SとRace 2を比較。サイズ・重さ・バッテリーで選ぶならどっち?
Suuntoのスポーツウォッチを検討している人にとって、迷いやすいのが「Suunto Race S」と「Suunto Race 2」の違いです。 どちらもAMOLEDディスプレイ、オフラインマップ、115以上のスポーツモード、トレーニング分析機能を備えた、ランニングやトレイルランニング、レース、日々のトレーニングに活用できる高性能モデルです。Suunto Race Sは「小さく、軽く、日常に...
Suunto Vertical vs. Vertical 2: Key Differences Explained
Suunto Vertical vs Vertical 2|どちらを選ぶべき?5つの違いを徹底比較
「Suunto Verticalを買おうと思っていたら、Vertical 2が出ていた」「初代とどこが変わったのか、値段差に見合う進化があるのか知りたい」——そんな疑問を持つ方に向けて、この記事では2モデルの違いを5つのポイントに絞って整理します。 どちらを選ぶべきかの判断基準も最後に明確にまとめていますので、ぜひ最後まで読んでみてください。 Suunto Vertical と Vertic...
How to play music on a running watch | Run without your phone with Suunto Run × Spark
ランニングウォッチで音楽再生する方法|スマホなしで走れるSuunto Run × Sparkの使い方
ランニング中に音楽を聴きたいけれど、スマートフォンを持って走るのは重い。ポケットやランニングポーチの中で揺れるのが気になる。そんな悩みを感じたことはありませんか? 音楽再生に対応したランニングウォッチを使えば、スマートフォンを持たずに、より身軽に走ることができます。 Suunto Runは、ウォッチ本体に音楽を保存できるオフライン音楽機能を搭載したランニングウォッチです。Suunto ...
How to use HRV to optimize your recovery
HRV(心拍変動)とは?正常値の見方と回復・トレーニングへの活かし方
「しっかり練習しているのに記録が伸びない」「いつもより疲れが残っている」と感じるときは、トレーニング量だけでなく、身体の回復状態にも目を向けてみましょう。回復を把握するための指標として活用されているのが、HRV(心拍変動)です。 HRVは、心拍数そのものではなく、心拍と心拍の間隔に生じるわずかなゆらぎを示します。毎日の数値を継続して確認することで、トレーニング、睡眠、ストレスなどに身体がどの...
