5 yoga moves for runners
SuuntoRun — January 05 2016
We all know that yoga is a good way to stretch and recover in between your training sessions. But which exercises in particular work best for runners? We asked yoga teacher and triathlete Sarah Odell. For all postures, aim to hold for a minimum of 30 seconds or five deep breaths.
The Butterfly
The Butterfly is really good for opening up the hips. It stretches the inner thighs and brings release to the lower back, particularly if you have tight hamstrings. If you find it difficult to keep your back straight, sit on a cushion, block or book to raise your hips so they’re higher than your knees. In the image below I’m sitting on a block.
Banarasana: the lunge (variation 1)
This is great for tight hip flexors and hamstrings. Make sure the front knee is directly over the ankle and also that it’s not rolling inwards. The knee should be in line with the second toe. If you’re on a hard surface, place a towel or cushion under your back knee. To increase the stretch, place your hands on the inside of your front foot, and to go deeper still, bring your elbows down as well.
Banarasana: the lunge (variation 2)
Here you’re getting an intense stretch into the quadricep muscles at the front of the thigh. It’s important to keep your hip bones facing forwards. Start with one arm and then try to catch your foot with both. It’s also great for the front of the chest. Push your foot away from your hands to increase the stretch.
Malasana: the squat
The is a great stretch for the ankles, groin and back. If your heels don’t touch the ground you can place a folded mat or blanket underneath, as I am in the image, for better balance to hold the posture longer. By placing the elbows against the knees you are stretching the inner thighs. Think about lengthening the tail bone towards the ground, keeping your back long and your chest open.
Viparita Karani: legs up wall
Swing your legs up, making sure you’re flat against the wall. If you have tight hamstrings, place a folded blanket underneath your buttocks and lower back to lift your hips. Let the legs fall out to the side and relax your upper body. If you have just come back from a run, this is very restorative, helps to flush the legs, relax the back and let the blood flow freely back to the heart. Combined with some deep breathing it’s also a great way to relax before going to bed. Vary this pose with the legs together or bend your knees, bringing the soles of the feet together, as in the Butterfly (see top).
Sarah Odell is a former adventure racer and triathlete. She teaches yoga and pilates at various health clubs and retreats.
MAIN IMAGE: © zooom.at/bergermarkus.com
おすすめのSuunto製品
あなたへのおすすめ
Suunto Race S vs Race 2: Size, Weight, and Battery Life Compared
Suunto Race SとRace 2を比較。サイズ・重さ・バッテリーで選ぶならどっち?
Suuntoのスポーツウォッチを検討している人にとって、迷いやすいのが「Suunto Race S」と「Suunto Race 2」の違いです。 どちらもAMOLEDディスプレイ、オフラインマップ、115以上のスポーツモード、トレーニング分析機能を備えた、ランニングやトレイルランニング、レース、日々のトレーニングに活用できる高性能モデルです。Suunto Race Sは「小さく、軽く、日常に...
Suunto Vertical vs. Vertical 2: Key Differences Explained
Suunto Vertical vs Vertical 2|どちらを選ぶべき?5つの違いを徹底比較
「Suunto Verticalを買おうと思っていたら、Vertical 2が出ていた」「初代とどこが変わったのか、値段差に見合う進化があるのか知りたい」——そんな疑問を持つ方に向けて、この記事では2モデルの違いを5つのポイントに絞って整理します。 どちらを選ぶべきかの判断基準も最後に明確にまとめていますので、ぜひ最後まで読んでみてください。 Suunto Vertical と Vertic...
How to play music on a running watch | Run without your phone with Suunto Run × Spark
ランニングウォッチで音楽再生する方法|スマホなしで走れるSuunto Run × Sparkの使い方
ランニング中に音楽を聴きたいけれど、スマートフォンを持って走るのは重い。ポケットやランニングポーチの中で揺れるのが気になる。そんな悩みを感じたことはありませんか? 音楽再生に対応したランニングウォッチを使えば、スマートフォンを持たずに、より身軽に走ることができます。 Suunto Runは、ウォッチ本体に音楽を保存できるオフライン音楽機能を搭載したランニングウォッチです。Suunto ...
How to use HRV to optimize your recovery
HRV(心拍変動)とは?正常値の見方と回復・トレーニングへの活かし方
「しっかり練習しているのに記録が伸びない」「いつもより疲れが残っている」と感じるときは、トレーニング量だけでなく、身体の回復状態にも目を向けてみましょう。回復を把握するための指標として活用されているのが、HRV(心拍変動)です。 HRVは、心拍数そのものではなく、心拍と心拍の間隔に生じるわずかなゆらぎを示します。毎日の数値を継続して確認することで、トレーニング、睡眠、ストレスなどに身体がどの...
