PREPARE FOR SNOW
SuuntoSki — November 06 2015
When the snow falls, you want to be ready. And fit! Nothing will kill the fun quicker than an early season injury, so we asked pro skier Greg Hill for his best advice. “It’s definitely time to start getting ready,” he says. Below, he outlines the exercises you need to be doing to be in good shape for the snow.
STOP TALKING
Obviously keeping up on our cardio is very important, biking, running, treadmill whatever we have time for. But it’s important to do at least three sessions of 20 minutes each week. This is to just keep our cardio at par, but to improve it we need to push ourselves a little harder. That means three longer runs or bike rides of an hour but then 10% of that should be in the pushing hard phase – pushing so hard you can't speak! Put another way: 90% of our exercise should be in the ‘able to talk’ phase and then 10% in the ‘unable to talk’ phase.
GET DOWN!
Run or walk downhill. Hiking down from alpine hikes, or running downhill is a great way to shock your muscles and get them ready for the endless downhill descents. This imitates the impact of hard turns and the repetition of the sport.
HOLD THE WALL
Too busy? Go for a ‘wall sit’ and start extending the times you can sit against a wall. Get your legs at 90º, with your back against the wall and hold it there. This replicates the constant quad stress and strength you will need to crush the big runs. It’s an isometric strength training. Nothing moves or flexes – it just holds. Try two minutes and build up. (NOTE: Greg has quads of steel. We tried this and failed so don’t feel bad starting at 1 minute and pushing from there.)
JUMP!
It’s the classic ski training exercise but that’s because it works on developing power. There are many different games to play but the main thing is exploding up as high as possible and then landing and absorbing the shock smoothly. Reps of 20 and three or four sets to start off.
WEIGHTS
All around strength is also a big factor – core strength being key to balance and good skiing. So if you can, an all around weight routine will help immensely.
STAY UP LATE WATCHING YOUTUBE
Lastly, get excited for the ski season! Watch ski videos, dream up adventures, fuel your desire as much as possible. It’s the mind that will drive your body so get it excited!
Images by Bruno Long Photography
おすすめのSuunto製品
あなたへのおすすめ
Suunto Race S vs Race 2: Size, Weight, and Battery Life Compared
Suunto Race SとRace 2を比較。サイズ・重さ・バッテリーで選ぶならどっち?
Suuntoのスポーツウォッチを検討している人にとって、迷いやすいのが「Suunto Race S」と「Suunto Race 2」の違いです。 どちらもAMOLEDディスプレイ、オフラインマップ、115以上のスポーツモード、トレーニング分析機能を備えた、ランニングやトレイルランニング、レース、日々のトレーニングに活用できる高性能モデルです。Suunto Race Sは「小さく、軽く、日常に...
Suunto Vertical vs. Vertical 2: Key Differences Explained
Suunto Vertical vs Vertical 2|どちらを選ぶべき?5つの違いを徹底比較
「Suunto Verticalを買おうと思っていたら、Vertical 2が出ていた」「初代とどこが変わったのか、値段差に見合う進化があるのか知りたい」——そんな疑問を持つ方に向けて、この記事では2モデルの違いを5つのポイントに絞って整理します。 どちらを選ぶべきかの判断基準も最後に明確にまとめていますので、ぜひ最後まで読んでみてください。 Suunto Vertical と Vertic...
How to play music on a running watch | Run without your phone with Suunto Run × Spark
ランニングウォッチで音楽再生する方法|スマホなしで走れるSuunto Run × Sparkの使い方
ランニング中に音楽を聴きたいけれど、スマートフォンを持って走るのは重い。ポケットやランニングポーチの中で揺れるのが気になる。そんな悩みを感じたことはありませんか? 音楽再生に対応したランニングウォッチを使えば、スマートフォンを持たずに、より身軽に走ることができます。 Suunto Runは、ウォッチ本体に音楽を保存できるオフライン音楽機能を搭載したランニングウォッチです。Suunto ...
How to use HRV to optimize your recovery
HRV(心拍変動)とは?正常値の見方と回復・トレーニングへの活かし方
「しっかり練習しているのに記録が伸びない」「いつもより疲れが残っている」と感じるときは、トレーニング量だけでなく、身体の回復状態にも目を向けてみましょう。回復を把握するための指標として活用されているのが、HRV(心拍変動)です。 HRVは、心拍数そのものではなく、心拍と心拍の間隔に生じるわずかなゆらぎを示します。毎日の数値を継続して確認することで、トレーニング、睡眠、ストレスなどに身体がどの...
