Kilian Jornet’s game plan for speed ascent of Everest
SuuntoClimb, SuuntoRunAugust 09 2016
Suunto ambassador Kilian Jornet is acclimatizing in the Himalaya so he can attempt to set a fastest known time (FKT) record on the highest mountain in the world – Everest. We caught up with him and found out the game plan for his daring project.
It’s literally the “high point” of his Summits of My Life project – alpinist, runner and adventurer Kilian Jornet’s personal mission to set ascent and descent records on the most important mountains on the planet, culminating with Everest.
Denali, Mont Blanc, the Matterhorn, Aconcagua, Kilimanjaro – all have seen records fall to Kilian. But now he’s readying himself for the ultimate challenge.
He has been preparing for months. Intense training, sleeping nights at 4500 m in the European Alps, and now he's in Nepal, doing the same at 6000 m.
“The highest I have been is 7700 m,” Kilian says. “I was feeling good then, but there is a big difference after 8200 m and after 8500 m.
“It’s really important to be well acclimatized to around 6000 m. So I will spend many nights at around this altitude. And then it’s important I go to around 8000 m before the attempt.”
Kilian and his team has arrived in Kathmandu and is getting ready for the expedition.
Depending on how well he acclimatizes, Kilian expects to make a FKT (fastest known time) attempt around mid September. It also depends on weather and snow conditions.
The plan is a light and fast, alpine-style ascent. He will carry only what he can fit a backpack. To keep weight down, he and his team have designed light, but warm boots made for purpose. He won’t be fixing ropes or using supplementary oxygen on the ascent. He will attempt the ascent from the north side, via either Norton-couloir or Horbein-couloir depending on conditions.
Two previous ascents are in the back of Kilian’s mind as time references. The first is a speed record set by Italian mountaineer Hans Kammerlander in 1996. Hans climbed from Base Camp to the summit of Everest via the North Col in 17 hours. The second reference is an “unprecedented and unrepeated” ascent in 1986 by Swiss climbers Erhard Loretan and Jean Troillet. They climbed the North Face via the Hornbein-couloir in a single alpine-style push without oxygen, ropes, or tents and descended again – all in 43 hours.
“It’s good to know these times as a reference for pace at altitude,” Kilian says. “I will take this as knowledge and will see how far I can go."
“It’s a big mountain, and we have a long term perspective. We will try this year, but probably we will need to come again next year."
“You need to go for it so if conditions are good and if I’m feeling good, I should try. But it’s important to have the patience to wait for this good moment.”
READ MORE
This is how Kilian prepares for Everest
Main image: © Daniel Prudek/Shutterstock.com
おすすめのSuunto製品
あなたへのおすすめ
Suunto Race S vs Race 2: Size, Weight, and Battery Life Compared
Suunto Race SとRace 2を比較。サイズ・重さ・バッテリーで選ぶならどっち?
Suuntoのスポーツウォッチを検討している人にとって、迷いやすいのが「Suunto Race S」と「Suunto Race 2」の違いです。 どちらもAMOLEDディスプレイ、オフラインマップ、115以上のスポーツモード、トレーニング分析機能を備えた、ランニングやトレイルランニング、レース、日々のトレーニングに活用できる高性能モデルです。Suunto Race Sは「小さく、軽く、日常に...
Suunto Vertical vs. Vertical 2: Key Differences Explained
Suunto Vertical vs Vertical 2|どちらを選ぶべき?5つの違いを徹底比較
「Suunto Verticalを買おうと思っていたら、Vertical 2が出ていた」「初代とどこが変わったのか、値段差に見合う進化があるのか知りたい」——そんな疑問を持つ方に向けて、この記事では2モデルの違いを5つのポイントに絞って整理します。 どちらを選ぶべきかの判断基準も最後に明確にまとめていますので、ぜひ最後まで読んでみてください。 Suunto Vertical と Vertic...
How to play music on a running watch | Run without your phone with Suunto Run × Spark
ランニングウォッチで音楽再生する方法|スマホなしで走れるSuunto Run × Sparkの使い方
ランニング中に音楽を聴きたいけれど、スマートフォンを持って走るのは重い。ポケットやランニングポーチの中で揺れるのが気になる。そんな悩みを感じたことはありませんか? 音楽再生に対応したランニングウォッチを使えば、スマートフォンを持たずに、より身軽に走ることができます。 Suunto Runは、ウォッチ本体に音楽を保存できるオフライン音楽機能を搭載したランニングウォッチです。Suunto ...
How to use HRV to optimize your recovery
HRVとは?心拍変動を理解してトレーニングの回復を最適化する方法
「練習しているのになかなか記録が伸びない」「疲れが取れない」と感じたことはありませんか?その原因は、回復の質にあるかもしれません。近年、アスリートから健康意識の高いビジネスパーソンまで幅広い層で注目されているのが HRV(心拍変動) という指標です。 この記事では、HRVとは何か、正常値の考え方、HRVが低いときに体に何が起きているのか、そしてSUUNTOのスマートウォッ...
