Help end plastic waste with your passion for running
SuuntoRun — May 18 2021
Passionate runners don’t need an excuse to lace up and head out the door, but having the added motivation of cleaning up our oceans provides a welcome boost! More than five million runners across the world got that by joining Run for the Oceans 2021 and clocking up more than 56 million kilometers to help end plastic waste.
The campaign, which ran between May 28 and June 8, is a joint initiative of adidas and its partner Parley, which is an innovative space for thought leaders to come together to save our oceans. Parley’s Global Clean Up Network is dedicated to removing plastic waste from beaches, islands and coastal communities. With every kilometer participants ran, adidas supported the clean up of the equivalent of 10 plastic bottles. After the huge turnout, adidas is now committed to cleaning up 250 tons of plastic waste to prevent it entering our oceans. What a success!
Kimi Schreiber hit the trails between May 28 and June 8 to stack up kilometers.
It also raises awareness
German trail runner, blogger and Suunto athlete Kimi Schreiber participated in the global event and was excited to run a high volume of kilometers to help remove as much plastic waste from the environment as she can. “Sport can change lives and now it’s giving people around the world the chance to get actively involved in helping nature and preserving it,” Kimi says. “I think the most important argument for participating is the issue of attention. With such a large and global event, you can create awareness on a whole new level and bring the issue of environmental pollution into people’s minds.”
How to participate
Sync Suunto app with adidas Running app and make sure you track every kilometer you run with your Suunto!
To sync your Suunto runs with adidas Running, connect your Suunto app account with adidas Running: Open Suunto app and tap “Profile”. Then click on “Connect to other services”. Select adidas Running and enter your adidas Running login details to connect the two apps. Get the adidas Running app here.
おすすめのSuunto製品
あなたへのおすすめ
Suunto Race S vs Race 2: Size, Weight, and Battery Life Compared
Suunto Race SとRace 2を比較。サイズ・重さ・バッテリーで選ぶならどっち?
Suuntoのスポーツウォッチを検討している人にとって、迷いやすいのが「Suunto Race S」と「Suunto Race 2」の違いです。 どちらもAMOLEDディスプレイ、オフラインマップ、115以上のスポーツモード、トレーニング分析機能を備えた、ランニングやトレイルランニング、レース、日々のトレーニングに活用できる高性能モデルです。Suunto Race Sは「小さく、軽く、日常に...
Suunto Vertical vs. Vertical 2: Key Differences Explained
Suunto Vertical vs Vertical 2|どちらを選ぶべき?5つの違いを徹底比較
「Suunto Verticalを買おうと思っていたら、Vertical 2が出ていた」「初代とどこが変わったのか、値段差に見合う進化があるのか知りたい」——そんな疑問を持つ方に向けて、この記事では2モデルの違いを5つのポイントに絞って整理します。 どちらを選ぶべきかの判断基準も最後に明確にまとめていますので、ぜひ最後まで読んでみてください。 Suunto Vertical と Vertic...
How to play music on a running watch | Run without your phone with Suunto Run × Spark
ランニングウォッチで音楽再生する方法|スマホなしで走れるSuunto Run × Sparkの使い方
ランニング中に音楽を聴きたいけれど、スマートフォンを持って走るのは重い。ポケットやランニングポーチの中で揺れるのが気になる。そんな悩みを感じたことはありませんか? 音楽再生に対応したランニングウォッチを使えば、スマートフォンを持たずに、より身軽に走ることができます。 Suunto Runは、ウォッチ本体に音楽を保存できるオフライン音楽機能を搭載したランニングウォッチです。Suunto ...
How to use HRV to optimize your recovery
HRV(心拍変動)とは?正常値の見方と回復・トレーニングへの活かし方
「しっかり練習しているのに記録が伸びない」「いつもより疲れが残っている」と感じるときは、トレーニング量だけでなく、身体の回復状態にも目を向けてみましょう。回復を把握するための指標として活用されているのが、HRV(心拍変動)です。 HRVは、心拍数そのものではなく、心拍と心拍の間隔に生じるわずかなゆらぎを示します。毎日の数値を継続して確認することで、トレーニング、睡眠、ストレスなどに身体がどの...
