Head back to work on top of things with a Suunto 7 smartwatch
SuuntoClimb, SuuntoRide, SuuntoRun, SuuntoSwimAugust 31 2020
Summer holidays are coming to a close in the northern hemisphere and we’re returning to work. It takes time to refocus and build momentum. It’s completely understandable to feel challenged by all the pressures of maintaining a job, business, family, plus staying fit and eating well.
Technology can’t magic the pressure away, but it can help you stay on top of things, save you time and even serve as support to build positive habits. The Suunto 7 smartwatch is powered with Wear OS by Google, providing a buffet of apps designed to help you manage everyday life. We consulted our inhouse technology geeks about which apps they find the most helpful and they came up with nine.
Spotify
Spotify's Wear OS app enables you to listen to music on your Suunto 7 without your phone – and even when offline. Connect your Bluetooth headphones with your watch and download the tracks that you want to take with you!
Learn more about listening to music on the go with a Suunto 7 and Spotify here. And once you have it, check out Suunto’s workout playlists on Spotify.
Wrist Camera
Say goodbye to awkward selfies that strain your neck as you try to get you and your two friends all in the frame. This app lets you control and preview your phone camera remotely from your smartwatch. This simple app is easy to use. Find it in Google Play here.
Todoist
Stay on top of all the tasks you need to complete with the Todoist app. You can add, check, and complete tasks with your watch. You can also track your progress on meeting daily and weekly goals. Find it in Google Play here.
Google Keep
This handy note-taking service allows you to capture ideas, notes or tasks whenever they pop into your mind. You can dictate your thoughts and Keep will transcribe them. You can create reminders and tasks, and share them with others. Click here to get it.
Bring!
No more shopping lists on the back of crumpled receipts! Your shopping just got easier with this app which allows you to create and share shopping lists with your family or friends from multiple devices, including by simply speaking into your smartwatch! Get it here.
Wear Casts
This app allows you to listen to your favorite podcasts offline. When you head out for a run, you can tune in without having to take your phone with you. Get it here.
If you prefer audiobooks over podcasts, check out NavBooks. This app places your library on your wrist – also for offline listening.
Find my phone
This handy feature is part of the Wear OS system and means you won’t ever again lose your phone down the back of the couch and think your life is over. Unless you can’t find your watch, too, in which case you are entitled to panic! All you need to do is tap a button on your watch face to make your phone ring. Breathe.
Google Assistant
Wouldn’t be nice if we could all have a personal assistant? Well, Google Assistant more than suffices. Schedule events and reminders in your calendar, create shopping lists, check the weather – all by simply speaking to your watch.
Citymapper
Get live subway, bus and train times, and find the best route to get where you need to go with step-by-step instructions – all via your watch. Get it here.
Healthy Recipes
Never ever get cookie dough on your phone again! This handy app allows you to follow recipes from your watch face, with the phone safely placed away from the chaos.
Suunto 7 support: Here you'll find user guides, how to videos and more
Read more articles
Welcome to the season of the FKT
Start your path to mountain navigation mastery here
The benefits of training to music and making your best playlist
おすすめのSuunto製品
あなたへのおすすめ
Suunto Race S vs Race 2: Size, Weight, and Battery Life Compared
Suunto Race SとRace 2を比較。サイズ・重さ・バッテリーで選ぶならどっち?
Suuntoのスポーツウォッチを検討している人にとって、迷いやすいのが「Suunto Race S」と「Suunto Race 2」の違いです。 どちらもAMOLEDディスプレイ、オフラインマップ、115以上のスポーツモード、トレーニング分析機能を備えた、ランニングやトレイルランニング、レース、日々のトレーニングに活用できる高性能モデルです。Suunto Race Sは「小さく、軽く、日常に...
Suunto Vertical vs. Vertical 2: Key Differences Explained
Suunto Vertical vs Vertical 2|どちらを選ぶべき?5つの違いを徹底比較
「Suunto Verticalを買おうと思っていたら、Vertical 2が出ていた」「初代とどこが変わったのか、値段差に見合う進化があるのか知りたい」——そんな疑問を持つ方に向けて、この記事では2モデルの違いを5つのポイントに絞って整理します。 どちらを選ぶべきかの判断基準も最後に明確にまとめていますので、ぜひ最後まで読んでみてください。 Suunto Vertical と Vertic...
How to play music on a running watch | Run without your phone with Suunto Run × Spark
ランニングウォッチで音楽再生する方法|スマホなしで走れるSuunto Run × Sparkの使い方
ランニング中に音楽を聴きたいけれど、スマートフォンを持って走るのは重い。ポケットやランニングポーチの中で揺れるのが気になる。そんな悩みを感じたことはありませんか? 音楽再生に対応したランニングウォッチを使えば、スマートフォンを持たずに、より身軽に走ることができます。 Suunto Runは、ウォッチ本体に音楽を保存できるオフライン音楽機能を搭載したランニングウォッチです。Suunto ...
How to use HRV to optimize your recovery
HRV(心拍変動)とは?正常値の見方と回復・トレーニングへの活かし方
「しっかり練習しているのに記録が伸びない」「いつもより疲れが残っている」と感じるときは、トレーニング量だけでなく、身体の回復状態にも目を向けてみましょう。回復を把握するための指標として活用されているのが、HRV(心拍変動)です。 HRVは、心拍数そのものではなく、心拍と心拍の間隔に生じるわずかなゆらぎを示します。毎日の数値を継続して確認することで、トレーニング、睡眠、ストレスなどに...
