EMELIE TRAVELS TO TIBET TO CLIMB HIGHER THAN EVER BEFORE
SuuntoClimb — April 26 2017
Emelie Forsberg is travelling to Cho Oyu together with Kilian Jornet. After considering various options the couple chose this mountain that has a reputation as one of the least technically difficult 8000-meter peaks in the Himalayan range and that is reasonably accessible from the base camp. Kilian will use Cho Oyu as valuable preparation for climbing Everest. He will be traveling directly to the highest mountain on Earth after Cho Oyu.
Emelie, how are you feeling before attempting to climb your first 8000-meter peak?
I´m super exited and so motivated to give my all. I know it´s not sure at all that I can reach the summit, but the adventure and the journey there will be very interesting.
How did you prepare for this project? Did you train differently than you would otherwise at this time of the year?
We did sleep in an altitude tent, and I was not fresh after that so I couldn’t train the same as I normally do. I tried to do that in December and I was so tired after hard trainings. So I did a little longer days instead which can be good for the summit attempt.
What do you like about mountaineering?
I think mountaineering is just the step after skiing and running, when we come to more technical terrain, that’s when the mountaineering starts! I like it because it´s like the continuation of skiing and running, we need to be able to climb mountains to get ourselves there. I like the focus I need and that it´s so much more I need to learn. Every time I get more comfortable in mountaineering there are higher levels to go, so it never ends!
How do you like Tibet?
Never been there. It will be a new experience.
What’s the highest you have been so far?
”Only” 6600 meters!
How do you adapt to altitude?
It can be different from time to time, but I have never felt really bad in altitude. But over 7500m will be very different, I think.
What will the biggest challenges be for you?
The altitude for sure, and to be moving for over 20 hours.
What are the conditions like on Cho Oyu currently?
Normally in the beginning of May it´s pretty good conditions; not too icy, not too much snow, and pretty stable weather.
What’s the goal of this project?
For sure it would be a success if I can go to the summit, but everything is an experience that leads us somewhere.
おすすめのSuunto製品
あなたへのおすすめ
Suunto Race S vs Race 2: Size, Weight, and Battery Life Compared
Suunto Race SとRace 2を比較。サイズ・重さ・バッテリーで選ぶならどっち?
Suuntoのスポーツウォッチを検討している人にとって、迷いやすいのが「Suunto Race S」と「Suunto Race 2」の違いです。 どちらもAMOLEDディスプレイ、オフラインマップ、115以上のスポーツモード、トレーニング分析機能を備えた、ランニングやトレイルランニング、レース、日々のトレーニングに活用できる高性能モデルです。Suunto Race Sは「小さく、軽く、日常に...
Suunto Vertical vs. Vertical 2: Key Differences Explained
Suunto Vertical vs Vertical 2|どちらを選ぶべき?5つの違いを徹底比較
「Suunto Verticalを買おうと思っていたら、Vertical 2が出ていた」「初代とどこが変わったのか、値段差に見合う進化があるのか知りたい」——そんな疑問を持つ方に向けて、この記事では2モデルの違いを5つのポイントに絞って整理します。 どちらを選ぶべきかの判断基準も最後に明確にまとめていますので、ぜひ最後まで読んでみてください。 Suunto Vertical と Vertic...
How to play music on a running watch | Run without your phone with Suunto Run × Spark
ランニングウォッチで音楽再生する方法|スマホなしで走れるSuunto Run × Sparkの使い方
ランニング中に音楽を聴きたいけれど、スマートフォンを持って走るのは重い。ポケットやランニングポーチの中で揺れるのが気になる。そんな悩みを感じたことはありませんか? 音楽再生に対応したランニングウォッチを使えば、スマートフォンを持たずに、より身軽に走ることができます。 Suunto Runは、ウォッチ本体に音楽を保存できるオフライン音楽機能を搭載したランニングウォッチです。Suunto ...
How to use HRV to optimize your recovery
HRV(心拍変動)とは?正常値の見方と回復・トレーニングへの活かし方
「しっかり練習しているのに記録が伸びない」「いつもより疲れが残っている」と感じるときは、トレーニング量だけでなく、身体の回復状態にも目を向けてみましょう。回復を把握するための指標として活用されているのが、HRV(心拍変動)です。 HRVは、心拍数そのものではなく、心拍と心拍の間隔に生じるわずかなゆらぎを示します。毎日の数値を継続して確認することで、トレーニング、睡眠、ストレスなどに身体がどの...
