Climbing with Matthias Scherer and Tanja Schmitt
SuuntoClimb — August 01 2014
Matthias Scherer and Tanja Schmitt are one of the most unique climbing partnerships around today. The new film Velocity is coming out this month. Below, Matthias introduces us to their world.
How did you get started?
I stated ice climbing in winter 92. I was all alone on my first climb and I will never forget that day – I knew instantly that I had found my path! Climbing back in those days was very committing due to the equipment – especially the extremely hard to set ice screws. In 1994 I moved to the Chamonix Valley and had many great ice adventures in this tremendous place.
For the last 13 years I've climbed now with Tanja. Our ice seasons often start in October and end in April! In that way we have ascended successfully over 500 ice falls. For 10 years we've lived in Cogne in the Aosta valley, one of the best places for water ice climbing in the Alps.
What is your philosophy?
Full commitment - respect the nature including all beings - be self-responsible - Life in every breath!
What is it about ice climbing that is appealing for you?
Ice climbing is a true adventure. We love this aspect beside the fascination of the surreal beauty that frozen water creates.
And why this form of climbing and not any others?
Since I can remember ice and snow had a strong attraction for me and winter was and is for me always the happiest time of the year. In my heart I am a fighter - I want to have fair fights: In ice climbing you can not cheat - there are no bolts to grab or other fixed anchors. You have to find your own way up with your means – all this mixed up with the clear cold air, snow whirling around you and the regularly starts and returns under a wonderful winter night sky – I cannot imagine anything better!
Matthias and Tanja ©Mathhias Scherer
Are there any memories that stand out?
'Kjerrskredkvelven', in Norway, with nearly 1,000m of height and many hard pitches up to WI6, one of the hardest ice falls on the planet. It was definitely a very strong moment for our team! Everything worked out, the crux pitch was for me a real challenge and even when Tanja was hit by falling ice very high up on the climb we motivated each other to go on. Tanja resisted the pain and the cold and she led in the dark the last and very demanding pitch while I took care of the endless descent on Abalakovs. A great day where you can only prevail with a great partner...
Any epics?
Yeah – many! If you spend up to 90 days in a winter on ice and mixed some misfortunes will happen. Great thing is, that you can be lucky and you can learn. We learned a lot over the past years. Most important: If things get messy, don't get stressed – slow down and do everything double safe – that saved us in a lot of epics!
What features of the Ambit do you like?
For the approaches especially in Canada the navigation on the Ambit is an absolutely perfect tool. We saved last winter so much time in the dense Canadian forests, not getting lost!
Main image shows Matthias on Repentance, Cogne ©Tanja Schmitt
おすすめのSuunto製品
あなたへのおすすめ
Suunto Race S vs Race 2: Size, Weight, and Battery Life Compared
Suunto Race SとRace 2を比較。サイズ・重さ・バッテリーで選ぶならどっち?
Suuntoのスポーツウォッチを検討している人にとって、迷いやすいのが「Suunto Race S」と「Suunto Race 2」の違いです。 どちらもAMOLEDディスプレイ、オフラインマップ、115以上のスポーツモード、トレーニング分析機能を備えた、ランニングやトレイルランニング、レース、日々のトレーニングに活用できる高性能モデルです。Suunto Race Sは「小さく、軽く、日常に...
Suunto Vertical vs. Vertical 2: Key Differences Explained
Suunto Vertical vs Vertical 2|どちらを選ぶべき?5つの違いを徹底比較
「Suunto Verticalを買おうと思っていたら、Vertical 2が出ていた」「初代とどこが変わったのか、値段差に見合う進化があるのか知りたい」——そんな疑問を持つ方に向けて、この記事では2モデルの違いを5つのポイントに絞って整理します。 どちらを選ぶべきかの判断基準も最後に明確にまとめていますので、ぜひ最後まで読んでみてください。 Suunto Vertical と Vertic...
How to play music on a running watch | Run without your phone with Suunto Run × Spark
ランニングウォッチで音楽再生する方法|スマホなしで走れるSuunto Run × Sparkの使い方
ランニング中に音楽を聴きたいけれど、スマートフォンを持って走るのは重い。ポケットやランニングポーチの中で揺れるのが気になる。そんな悩みを感じたことはありませんか? 音楽再生に対応したランニングウォッチを使えば、スマートフォンを持たずに、より身軽に走ることができます。 Suunto Runは、ウォッチ本体に音楽を保存できるオフライン音楽機能を搭載したランニングウォッチです。Suunto ...
How to use HRV to optimize your recovery
HRV(心拍変動)とは?正常値の見方と回復・トレーニングへの活かし方
「しっかり練習しているのに記録が伸びない」「いつもより疲れが残っている」と感じるときは、トレーニング量だけでなく、身体の回復状態にも目を向けてみましょう。回復を把握するための指標として活用されているのが、HRV(心拍変動)です。 HRVは、心拍数そのものではなく、心拍と心拍の間隔に生じるわずかなゆらぎを示します。毎日の数値を継続して確認することで、トレーニング、睡眠、ストレスなどに身体がどの...
