Another record falls to the king of speed
SuuntoRun — July 15 2014
Keeping up with Kilian Jornet is a full time job for his fans this summer. Less than a month after ascending north America's highest mountain Denali in record time the trail-running, speed-ascending legend has smashed another record – this time the Hardrock 100 ultra run. It's one of the world's toughest ultras and the most famous in America.
But help is at hand. Thanks to the new connected capabilities of the Ambit3, it's possible to relive and share Kilian's epic feat, in which he knocked 42 minutes off the previous record to finish in a time of 22h 41m.
The video below reveals just how fast he was running.
The Hardrock, a 160km race with a total climb of 20,722m, holds legendary status for ultra runners the world over and had been on Kilian's tick list since he was a teenager.
“I’m thrilled for this result, this was the last race left from the list I made when I was 16. I’m very satisfied both for the victory and the record, but also because I’ve had very good feeling from the begining. It has been almost a perfect race,” said Kilian after the race.
“The path is very beautiful, both for the track and the landscapes,” he added. It’s one of this races that I wouldn’t let any single part left, it was great to run here. The lowest point of the race is at 3.000m so it’s a very technical race in high height, which makes it special. Without even hesitate, this is one of the nicest races I’ve ever done.”
Thought this was epic? Prepare to be amazed by Kilian's record ascent of Denali.
Photo: ©Jordi Saragossa
おすすめのSuunto製品
あなたへのおすすめ
Suunto Race S vs Race 2: Size, Weight, and Battery Life Compared
Suunto Race SとRace 2を比較。サイズ・重さ・バッテリーで選ぶならどっち?
Suuntoのスポーツウォッチを検討している人にとって、迷いやすいのが「Suunto Race S」と「Suunto Race 2」の違いです。 どちらもAMOLEDディスプレイ、オフラインマップ、115以上のスポーツモード、トレーニング分析機能を備えた、ランニングやトレイルランニング、レース、日々のトレーニングに活用できる高性能モデルです。Suunto Race Sは「小さく、軽く、日常に...
Suunto Vertical vs. Vertical 2: Key Differences Explained
Suunto Vertical vs Vertical 2|どちらを選ぶべき?5つの違いを徹底比較
「Suunto Verticalを買おうと思っていたら、Vertical 2が出ていた」「初代とどこが変わったのか、値段差に見合う進化があるのか知りたい」——そんな疑問を持つ方に向けて、この記事では2モデルの違いを5つのポイントに絞って整理します。 どちらを選ぶべきかの判断基準も最後に明確にまとめていますので、ぜひ最後まで読んでみてください。 Suunto Vertical と Vertic...
How to play music on a running watch | Run without your phone with Suunto Run × Spark
ランニングウォッチで音楽再生する方法|スマホなしで走れるSuunto Run × Sparkの使い方
ランニング中に音楽を聴きたいけれど、スマートフォンを持って走るのは重い。ポケットやランニングポーチの中で揺れるのが気になる。そんな悩みを感じたことはありませんか? 音楽再生に対応したランニングウォッチを使えば、スマートフォンを持たずに、より身軽に走ることができます。 Suunto Runは、ウォッチ本体に音楽を保存できるオフライン音楽機能を搭載したランニングウォッチです。Suunto ...
How to use HRV to optimize your recovery
HRV(心拍変動)とは?正常値の見方と回復・トレーニングへの活かし方
「しっかり練習しているのに記録が伸びない」「いつもより疲れが残っている」と感じるときは、トレーニング量だけでなく、身体の回復状態にも目を向けてみましょう。回復を把握するための指標として活用されているのが、HRV(心拍変動)です。 HRVは、心拍数そのものではなく、心拍と心拍の間隔に生じるわずかなゆらぎを示します。毎日の数値を継続して確認することで、トレーニング、睡眠、ストレスなどに身体がどの...
