7 reasons to love running at night
SuuntoRun — September 23 2015
True, you may not get to enjoy the same distant views, but there are good reasons to love running at night, says elite trail runner Gediminas Grinius – who trains on top of his full time job. Here are his top 7 reasons to put on your headtorch and high visibility jacket and get out the door for a night run!
Aside from working full time, Gediminas is also a father of two. © Gediminas Grinius
Explore your wild side
At night your senses are more attuned says Gediminas. “With less of an emphsis on vision, you become more alert to your surroundings and that brings out your wild side, especially when alone. And that’s the best remedy after a long day in the office.”
Escape the heat
Running in warm temperatures isn’t all great, says this year’s Transgrancanaria winner. “Running at night lets you avoid the day’s heat,” he says, “which is better for training”.
Find new beauty
“Running at night breaks up the routine and you can find new beauty in the same trails – especially for those like me who don’t have a lot of hills to train on.”
Avoid the traffic
Turn your commute into training, says Gediminas. “That way you avoid the traffic and you beat the ‘no time for sport’ excuse. Commuting to the office in the winter months means running in the dark is unavoidable,” he adds.
Prepare for ultras
Use night running to prepare for an ultra. “Almost all 100 mile races have a night element in it,” he says. And for regular trail runners, most 100 km races have a night element as well!”
Improve your technical downhills
“While running at night you must trust your sixth sense more often,” says Gediminas. “Sometimes your feet are your only sensors on the ground and you have to turn your brain off and trust your feet to know where to step. This is exactly the same as when you have to run on technical terrain so running at night is a good way to make you better on super technical downhills.”
Unleash the dog!
“Zoro is my best running partner and the enjoys freedom as much as I do, but because of a lot of distractions during the day (people, other dogs) it's the best time to set him free at night.”
おすすめのSuunto製品
あなたへのおすすめ
Suunto Race S vs Race 2: Size, Weight, and Battery Life Compared
Suunto Race SとRace 2を比較。サイズ・重さ・バッテリーで選ぶならどっち?
Suuntoのスポーツウォッチを検討している人にとって、迷いやすいのが「Suunto Race S」と「Suunto Race 2」の違いです。 どちらもAMOLEDディスプレイ、オフラインマップ、115以上のスポーツモード、トレーニング分析機能を備えた、ランニングやトレイルランニング、レース、日々のトレーニングに活用できる高性能モデルです。Suunto Race Sは「小さく、軽く、日常に...
Suunto Vertical vs. Vertical 2: Key Differences Explained
Suunto Vertical vs Vertical 2|どちらを選ぶべき?5つの違いを徹底比較
「Suunto Verticalを買おうと思っていたら、Vertical 2が出ていた」「初代とどこが変わったのか、値段差に見合う進化があるのか知りたい」——そんな疑問を持つ方に向けて、この記事では2モデルの違いを5つのポイントに絞って整理します。 どちらを選ぶべきかの判断基準も最後に明確にまとめていますので、ぜひ最後まで読んでみてください。 Suunto Vertical と Vertic...
How to play music on a running watch | Run without your phone with Suunto Run × Spark
ランニングウォッチで音楽再生する方法|スマホなしで走れるSuunto Run × Sparkの使い方
ランニング中に音楽を聴きたいけれど、スマートフォンを持って走るのは重い。ポケットやランニングポーチの中で揺れるのが気になる。そんな悩みを感じたことはありませんか? 音楽再生に対応したランニングウォッチを使えば、スマートフォンを持たずに、より身軽に走ることができます。 Suunto Runは、ウォッチ本体に音楽を保存できるオフライン音楽機能を搭載したランニングウォッチです。Suunto ...
How to use HRV to optimize your recovery
HRV(心拍変動)とは?正常値の見方と回復・トレーニングへの活かし方
「しっかり練習しているのに記録が伸びない」「いつもより疲れが残っている」と感じるときは、トレーニング量だけでなく、身体の回復状態にも目を向けてみましょう。回復を把握するための指標として活用されているのが、HRV(心拍変動)です。 HRVは、心拍数そのものではなく、心拍と心拍の間隔に生じるわずかなゆらぎを示します。毎日の数値を継続して確認することで、トレーニング、睡眠、ストレスなどに身体がどの...
