6 must-read skimo articles to get set for winter adventure
SuuntoSki — January 13 2023
A little knowledge goes a long way, and when it comes to the fitness level and safety skills required for skimo this is even more so the case. So to help you prepare and get pumped for this pow season, we put together six of our most important and helpful articles with tips galore about how to train, follow a safe track and deal with avalanche danger.
Scroll down now and soak up the know-how.
© Mark Smiley
8 avalanche safety checks to tick off before the ski season
In this article, pro mountain guide and outdoor educator Mark Smiley lays out all small tasks you need to do before commencing your skimo season. Once you’ve read it, check out Mark’s Mountain Sense online courses, including his Comprehensive Guide to Avalanche Safety.
14 tips for backcountry skiing this winter
In this one, Mark Smiley continues dispensing oodles of backcountry wisdom. Having awesome skimo adventures is all about preparation and being open to learning how to improve. Small things, like finding the right adventure buddy, managing your pack weight and more, are the building blocks to rewarding and safe days in the mountains.
© www.berhasen.com
6 tips for faster skimo
It’s not speed for speed’s sake. Getting faster in the mountains isn’t about chasing adrenalin; when you’re fitter, and faster it’s easier to enjoy trips that take less time and therefore safer. In this article, sports scientist and skimo coach Susi Kraft lays out a training plan to help you improve your pace out there.
8 tools for tracking the weather with Suunto
Up above the treeline and exposed to cold and weather, you need to keep a close eye on the weather. This article shares eight ways your Suunto watch can help you track it, from storm, sunset and sunrise alarms through to awesome partners like MyRadar.
© Mark Smiley
7 tips to find a safe track up the mountain
What are the signs of a good track up a mountain, and what are the warning signs to watch out for that signal to stay clear of a particular line? Mark Smiley explains what to look out for and how to use your Suunto watch and other tech to find and follow a safe track.
6 tips for mountain navigation
Freerider and the man behind the Arctic Lines project, Suunto ambassador Antti Autti explains how he navigates in the mountains when he is out on one of his epic adventures above the Arctic Circle. Safety is a key value in everything he does so he has an established process to keep his trips safe for him and his team.
Lead image by Jaakko Posti
おすすめのSuunto製品
あなたへのおすすめ
Suunto Race S vs Race 2: Size, Weight, and Battery Life Compared
Suunto Race SとRace 2を比較。サイズ・重さ・バッテリーで選ぶならどっち?
Suuntoのスポーツウォッチを検討している人にとって、迷いやすいのが「Suunto Race S」と「Suunto Race 2」の違いです。 どちらもAMOLEDディスプレイ、オフラインマップ、115以上のスポーツモード、トレーニング分析機能を備えた、ランニングやトレイルランニング、レース、日々のトレーニングに活用できる高性能モデルです。Suunto Race Sは「小さく、軽く、日常に...
Suunto Vertical vs. Vertical 2: Key Differences Explained
Suunto Vertical vs Vertical 2|どちらを選ぶべき?5つの違いを徹底比較
「Suunto Verticalを買おうと思っていたら、Vertical 2が出ていた」「初代とどこが変わったのか、値段差に見合う進化があるのか知りたい」——そんな疑問を持つ方に向けて、この記事では2モデルの違いを5つのポイントに絞って整理します。 どちらを選ぶべきかの判断基準も最後に明確にまとめていますので、ぜひ最後まで読んでみてください。 Suunto Vertical と Vertic...
How to play music on a running watch | Run without your phone with Suunto Run × Spark
ランニングウォッチで音楽再生する方法|スマホなしで走れるSuunto Run × Sparkの使い方
ランニング中に音楽を聴きたいけれど、スマートフォンを持って走るのは重い。ポケットやランニングポーチの中で揺れるのが気になる。そんな悩みを感じたことはありませんか? 音楽再生に対応したランニングウォッチを使えば、スマートフォンを持たずに、より身軽に走ることができます。 Suunto Runは、ウォッチ本体に音楽を保存できるオフライン音楽機能を搭載したランニングウォッチです。Suunto ...
How to use HRV to optimize your recovery
HRV(心拍変動)とは?正常値の見方と回復・トレーニングへの活かし方
「しっかり練習しているのに記録が伸びない」「いつもより疲れが残っている」と感じるときは、トレーニング量だけでなく、身体の回復状態にも目を向けてみましょう。回復を把握するための指標として活用されているのが、HRV(心拍変動)です。 HRVは、心拍数そのものではなく、心拍と心拍の間隔に生じるわずかなゆらぎを示します。毎日の数値を継続して確認することで、トレーニング、睡眠、ストレスなどに身体がどの...
