Suunto Blog
Aerobic vs Anaerobic Exercise: Key Differences and Training
The key difference between aerobic and anaerobic exercise is how your body supplies energy for movement. From an easy run to a sprint up a steep hill, how hard and how long you exercise changes the contribution of each energy system, and how your body adapts to training. Understanding those differences gives every workout a clear purpose. This guide covers common aerobic and anaerobic activities, how to gauge exercise intensity, and how to combine both types of training for endurance, strength, or speed.
Table of Contents
What Is the Difference Between Aerobic and Anaerobic Exercise?
How Do Your Energy Systems Work Together?
Is Aerobic or Anaerobic Exercise Better for Your Goals?
How Do You Combine Aerobic and Anaerobic Training?
How Can Intensity Be Monitored in Aerobic and Anaerobic Training?
Takeaways
FAQ
Aerobic and anaerobic exercise differ in their main energy pathways, typical intensity, and duration. Here’s what each involves, along with common examples and a comparison of their key features.
1. What Is Aerobic Exercise?
Aerobic exercise relies primarily on aerobic metabolism, which uses oxygen to produce adenosine triphosphate (ATP), the energy that powers muscle contractions. This pathway supports sustained activity, such as an easy run or a steady bike ride.
Common examples include easy running, steady cycling, continuous swimming, and hiking. At an easy intensity, you should be able to talk comfortably. Build duration gradually to suit your fitness and recovery.
2. What Is Anaerobic Exercise?
Anaerobic exercise relies primarily on the phosphagen system and anaerobic glycolysis to replenish ATP quickly. These energy pathways do not directly require oxygen and support short bursts of intense exercise. “Anaerobic” describes how that energy is supplied; it doesn’t mean you stop breathing or no longer need oxygen.
Common examples include short running or cycling sprints, heavy strength training with low repetitions, and short sets of explosive jumps. Allow enough recovery between repetitions or sets to maintain speed, force, and good technique.
3. Key Differences Between Aerobic and Anaerobic Exercise
The table below summarizes the typical differences in energy supply, intensity, duration, activities, and training benefits.
Feature
Aerobic Exercise
Anaerobic Exercise
Main energy supply
Primarily aerobic metabolism, providing a sustained supply of energy
Greater reliance on the phosphagen system and anaerobic glycolysis for rapid energy during short, intense bursts
Typical intensity
Low to moderate
High to near-maximal
Duration
Minutes to hours or longer
Seconds to a few minutes per intense bout
Common activities
Easy running, steady cycling, continuous swimming, hiking
Short sprints, heavy lifting with low repetitions, explosive jumps
Typical training benefits
Cardiovascular fitness and endurance
Strength, muscle growth, explosive power, or speed endurance
The comparison above outlines the typical energy demands of each type of exercise. In practice, aerobic and anaerobic systems work together, with their contributions shifting as you move. During a run, a steady, sustainable pace relies mainly on aerobic metabolism. Accelerating, climbing a hill, or sprinting increases the demand for anaerobic energy. When you slow down, aerobic metabolism continues to fuel movement and support recovery.
Running, cycling, or strength training alone doesn’t tell you which energy system contributes most. That depends on the intensity, duration, how you perform each movement, and how much recovery you allow.
Both have a place in training. The right emphasis depends on what you want to improve. Long distances call for sustained energy, sprints and jumps demand explosive power, and muscle growth requires targeted strength training. Start with the result you want, then choose the training that develops it. Labeling an activity aerobic or anaerobic only tells part of the story.
1. For Endurance and Cardiovascular Fitness
If you want to run farther, finish a long ride, or stay strong through the second half of a hike, aerobic training builds an essential foundation. Regular aerobic training can increase stroke volume, the amount of blood your heart pumps with each beat, and promote adaptations in muscle capillaries and mitochondria. Together, these changes improve oxygen delivery and use, helping you keep going longer.
Endurance develops through consistent training. Low-intensity exercise lets you build duration and frequency while keeping fatigue manageable. That consistency also prepares you for harder workouts, which is why Zone 2 training plays an important role in an endurance plan.
2. For Improving VO₂max
To improve VO₂max, build on steady aerobic training with targeted high-intensity aerobic intervals. These intervals help you accumulate time exercising near your VO₂max.
High-intensity aerobic intervals place greater demands on your heart’s pumping capacity and your muscles’ ability to use oxygen, providing a focused stimulus to improve VO₂max. Allow enough recovery to maintain the quality of these demanding sessions.
3. For Strength, Muscle Growth, and Power
To build strength, muscle, or explosive power, prioritize resistance training that relies heavily on anaerobic energy during each set. The ACSM position stand on resistance training identifies different training priorities for each goal:
Build strength: Heavier loads, a full range of motion, and an appropriate number of sets and weekly sessions help improve maximal strength.
Build muscle: Higher weekly training volume supports muscle growth. Eccentric overload training, which emphasizes loading the lowering phase, can also help.
Develop power: Moderate loads, low to moderate training volume, and fast movement through the concentric (lifting or pushing) phase help develop explosive power.
Aerobic training can complement this work by improving cardiovascular fitness. Strength, muscle growth, and power still require training that specifically targets those qualities.
4. For Fat Burning and Weight Loss
Both aerobic and anaerobic training can be part of a fat-loss plan. The key is to build exercise habits you can sustain and maintain a calorie deficit (using more energy than you consume over time).
Aerobic exercise increases energy expenditure through sustained activity, while strength training helps preserve strength and lean body mass. The proportion of fat you burn during a workout doesn’t determine how much body fat you lose over time. Choose a training routine you can stick with, supported by adequate nutrition and recovery.
Start with your weekly schedule. Combine sustained aerobic exercise with strength training, sprints, or other work that supports your goals, then decide whether to spread those sessions across different days or combine them on the same day. Give each workout a clear purpose and leave enough time to recover.
1. Set Your Training Priority
Work out how much time you can train each week, then schedule your priority workouts first. For endurance, build your week around sustained aerobic training and add intervals, sprints, or strength work as needed. For strength, protect the quality of your lifting sessions and fit aerobic exercise around them. When running, cycling, and strength training fall on the same day, start with the workout that matters most to your current goal and requires you to be fresh.
Be specific about what each session involves and how long it will take. Set a duration or distance for aerobic workouts. For sprints, account for repetitions and recovery intervals. For strength training, plan your exercises, sets, reps, and rest between sets. Include recovery time when fitting workouts into your schedule.
2. Plan Your Training Schedule
You can alternate training types across the week: strength training on Monday, followed by an easy run or ride on Tuesday. If your week includes running intervals, sprints, and heavy lower-body lifting, avoid stacking these demanding sessions on consecutive days. Separate them with easy training, upper-body strength work, or rest days.
You can also combine both types within one workout. After warming up, perform short sprints with full recovery between sets, then cool down with an easy jog. Another option is to follow a strength session with some easy aerobic exercise. If you train twice in one day, leave several hours between sessions where possible. Adjust the second workout’s duration or intensity based on how you feel after the first.
3. Balance Intensity and Recovery
Consider the combined load of both types of training. When adding strength work or sprints, start by shortening some existing workouts or moving sessions to different days. Once you can consistently complete the work and recover well, gradually increase duration, repetitions, or load. If fatigue keeps affecting your technique or ability to finish the next workout, reduce volume, lower intensity, or take a rest day.
If running or cycling is your main focus, the 80/20 principle can help guide your endurance training: keep most of it at low intensity, with a smaller share devoted to harder work. This describes intensity distribution, not “80% aerobic and 20% anaerobic.” Schedule strength training separately while accounting for its contribution to your overall recovery needs.
Compatible Suunto watches and the Suunto app provide insights such as Chronic Training Load (CTL) and heart rate variability (HRV) trends. Read these alongside your performance, sleep, and perceived fatigue to assess how well your schedule is working and adjust future training volume and intensity.
Once your training is planned, use heart rate, breathing, and perceived effort to check whether you’re exercising at the intended intensity. During sustained runs or rides, these cues help you keep your effort on track. For short sprints or strength work, also pay attention to speed, weight, repetitions, and technique.
A Suunto sports watch lets you check your current heart rate zone. Depending on the model, zones can be set using your maximum heart rate, heart rate reserve, or lactate threshold heart rate. See the heart rate zone guide for details. Without looking at your watch, comfortable conversation is a useful sign of an easy effort. Needing a breath after just a few words points to a higher intensity. You can also rate your perceived effort on a scale of 0–10: the CDC describes moderate intensity as about 5–6 and vigorous intensity as about 7–8.
These methods tell you how hard you’re working. A high heart rate or heavy breathing doesn’t automatically mean you’re training anaerobically, and a short sprint may end before your heart rate has time to rise fully. Always interpret those cues in the context of the workout.
Takeaways
Aerobic and anaerobic training both belong in a training plan. The energy systems work together, with their contributions changing as intensity and duration shift. Sustained aerobic training builds an endurance base, while intervals, sprints, and strength work provide targeted challenges to develop speed, power, and strength. Start with your goal, then use heart rate, pace, how you feel, workout quality, and recovery trends to adjust your plan. Your own judgment matters more here than any fixed training ratio.
FAQ
Is a 5K Run Aerobic or Anaerobic?
A 5K is primarily an aerobic endurance event. The exact balance of aerobic and anaerobic energy depends on your pace, changes in pace, finish time, and fitness. Accelerations and sprints increase anaerobic demand at those moments, so no single energy split applies to every 5K.
Is It Better to Run Aerobically or Anaerobically?
Aerobic running should form the foundation of your regular endurance training. Add anaerobic work if you want to improve sprint speed and explosive power. Adjust the balance to your running goals and how well you recover.
Is VO₂max Aerobic or Anaerobic?
VO₂max is an aerobic fitness measure that reflects your maximum capacity to take in and use oxygen. Improving it means developing your aerobic capacity. Both sustained aerobic training and high-intensity aerobic intervals can help.
Can You Do Aerobic and Anaerobic Training on the Same Day?
Yes. Plan the order around your main goal and allow for recovery between sessions. If strength is your priority, you can lift first. If endurance performance matters most, make sure you’re fresh enough to complete your planned run or ride well.
Lactate Threshold Explained: Test It, Improve Your Pace
If you want to run faster and hold a harder effort for longer, lactate threshold is worth understanding. It can help you choose training intensities that match your current fitness and track your progress over time.
This guide covers what lactate threshold is, what running near it feels like, and how to test it and read the results. It also looks at how the right training lifts your threshold pace so you can sustain faster running for longer.
At a Glance
Lactate threshold is an exercise intensity marked by changes in your blood lactate levels.
Knowing yours helps you pick training paces and gauge your endurance.
Blood lactate testing pinpoints it. Performance tests and devices estimate it.
There is no universal ideal. Track your own threshold pace or power over time.
A mix of aerobic work, threshold training, and recovery raises your threshold.
Table of Contents
What Is Lactate Threshold?
Why Test Your Lactate Threshold?
How Can You Test or Estimate Your Lactate Threshold?
What Is a Good Lactate Threshold?
How to Improve Lactate Threshold?
Takeaways
FAQ
Your body makes and uses lactate the whole time you exercise. Some fuels the muscles that produce it. Some travels through the blood to feed other tissues, including the heart. It is a constant cycle of production and reuse. At easy intensities, production and clearance stay roughly balanced, so blood lactate holds fairly steady.
Push harder and that balance shifts. Production starts to outpace your body's ability to move, use, and clear lactate, so blood levels climb. Lactate threshold marks the point where this response changes noticeably. It is a useful way to tell intensities apart, but the shift is gradual. You do not flip from one state to another the moment you cross it.
Three related concepts often come up when discussing lactate threshold: LT1, LT2, and MLSS.
LT1 (First Lactate Threshold): The intensity at which blood lactate rises noticeably above its low-intensity baseline during an incremental exercise test. Exercise below LT1 generally feels relatively easy.
LT2 (Second Lactate Threshold): The higher-intensity turning point where the blood lactate curve rises more sharply during an incremental exercise test. It is the main reference for threshold training in this article.
MLSS (Maximal Lactate Steady State): The highest constant exercise intensity at which blood lactate remains approximately stable, determined through repeated constant-load tests. It is closely related to LT2, but the two are assessed differently and are not interchangeable.
A test gives you more than a heart rate, pace, or lactate reading. It tells you what effort you can hold at different intensities, so you can build training around your current fitness.
1. Understand endurance capacity
Endurance is about both how fast you can go and how long you can hold that speed. Two runners might match each other over a short distance, yet one holds a quicker steady pace for much longer. That gap comes down to who can sustain harder efforts. A faster threshold pace usually points to a greater ability to keep running fast.
2. Set training intensity
Two runners with the same max heart rate can hit threshold at very different intensities. Your results, read alongside heart rate, pace, cycling power, and lactate response, help you set intensities that fit you.
On Suunto Run series, for instance, you can build heart rate zones from max heart rate, heart rate reserve, or lactate threshold heart rate. You can set pace and power zones separately too, so you have several ways to manage intensity within one workout.
3. Track long-term improvement
Retesting every so often shows whether your training is paying off. Under similar conditions, a faster threshold pace means you can run quicker at an effort near your threshold. If your threshold heart rate holds steady while the pace at it improves, that points to better endurance.
Lactate threshold can be determined through blood lactate testing or estimated indirectly from race results, field tests, or training data recorded by a device. These approaches provide different information, so choose one that fits your testing options and training needs.
1. Direct Method: Blood Lactate Testing
Blood lactate testing typically follows an incremental protocol. You start at a low intensity, then increase pace or power in stages, with blood samples taken at each stage to measure lactate concentration. The tester plots a lactate curve and uses it to identify a threshold and its corresponding pace, power, or heart rate.
The test measures blood lactate concentration directly, but the threshold itself must be determined by interpreting the curve. One common approach is D-max, or the maximal distance method, which uses the shape of the lactate curve to identify the threshold.
2. Indirect Methods: Performance Tests and Device Estimates
If blood lactate testing is not available, the following methods can provide estimates of threshold pace, power, or heart rate to guide your training:
Race results: Training models use recent race performances to estimate threshold pace and help you choose training intensities. For example, VDOT uses race performance to estimate a threshold training pace, providing an indirect indication of your ability to run near lactate threshold.
Field tests: A running test over a set duration or distance can use pace and heart rate data to estimate threshold pace or threshold heart rate.
Sports watches: Some Suunto sports watches estimate metrics such as lactate threshold and VO₂ max from training data, helping runners choose training intensities and track changes over time.
These methods do not measure blood lactate directly. Results depend on your performance during the test, environmental conditions, data quality, and the algorithm used. Whichever approach you choose, keep the method, procedure, and conditions as consistent as possible when tracking progress over time.
For runners, a faster pace at lactate threshold generally indicates better endurance when measured using the same test method under similar conditions. A higher threshold heart rate or blood lactate concentration does not necessarily mean better fitness. Likewise, the percentage of VO₂ max or maximum heart rate at which your threshold occurs cannot tell the whole story. Focus on your threshold pace and how it changes over time.
1. Blood Lactate Concentration at Threshold
Researchers have traditionally used a blood lactate concentration of 4 mmol/L to define a fixed lactate threshold. This approach is also commonly associated with OBLA, or the onset of blood lactate accumulation. In the 1980s, Mader and colleagues further explored the rationale for using 4 mmol/L to identify the anaerobic threshold.
However, lactate responses vary considerably between individuals. The same physiological turning point can occur at different blood lactate concentrations. Some athletes show a sharper rise in lactate at lower concentrations, while others reach that point at higher levels.
Research has reported blood lactate concentrations ranging from approximately 1.4 to 7.5 mmol/L at the individual anaerobic threshold (IAT). A fixed concentration makes testing easier to standardize, but it may not accurately capture each athlete's physiological threshold.
2. Lactate Threshold as a Percentage of Maximum Effort
The intensity at which lactate threshold occurs can also be expressed relative to VO₂ max or maximum heart rate. Better-trained runners generally reach their threshold at a higher percentage of their maximum capacity, while beginners and less-trained runners tend to reach it at a lower relative intensity.
VO₂ max primarily reflects cardiorespiratory capacity, while lactate threshold is closely linked to metabolic function in the muscles. Research describes lactate threshold occurring at around 60% of VO₂ max in untrained individuals and approximately 75–90% of VO₂ max in endurance-trained individuals. These ranges help explain differences in training status, but they are not fixed benchmarks for deciding whether your own threshold is “normal.”
Three types of training can help improve your lactate threshold: low-intensity aerobic work to build your base, threshold training to improve the pace you can sustain, and high-intensity intervals to develop your maximum aerobic capacity.
Low-Intensity Aerobic Training
Low-intensity aerobic training centers on easy, sustained running. Zone 2 training in commonly used five-zone models falls into this category. The effort generally stays below your LT1, with steady breathing and comfortable conversation. Start with a duration you can comfortably manage and gradually extend your runs as you adapt.
Over time, this training helps increase capillary density and mitochondrial content in your muscles, improving oxygen delivery and aerobic energy production. It also supports lactate transport and its use as fuel through oxidation. Together, these adaptations build the aerobic foundation for sustained running.
Lactate Threshold Training
Lactate threshold training involves running at an intensity close to your LT2. Your breathing is noticeably deeper, and you can speak only in short phrases, but your pace and form remain under control. Accumulating time at this intensity can improve your threshold pace, helping you sustain faster running.
You can train at this effort through continuous runs or intervals. A Tempo Run is often performed near lactate threshold, but its definition varies between training systems. A tempo run is therefore not always the same as a threshold run, so let the purpose of the workout guide your intensity.
Another common approach is cruise intervals. For example, you might break the workout into efforts of around 5–10 minutes, with 1–2 minutes of easy jogging between them. These short recoveries help you maintain a consistent effort and accumulate more time near lactate threshold without excessive fatigue.
Whether you choose a continuous run or cruise intervals, the goal is to hold the intended effort. If your pace drops sharply early in the workout or you need a long recovery between efforts, you may be running harder than the session calls for.
High-Intensity Interval Training
High-intensity intervals alternate faster running above lactate threshold with recovery periods. During the hard efforts, breathing is heavy and talking is difficult. Easy jogging between efforts helps you prepare for the next repetition. Aim for a consistent pace across repetitions, and adjust the amount of work to your fitness and recovery.
This training can improve VO₂ max, raising your aerobic ceiling and supporting further gains in threshold pace. Use it alongside threshold training, with easy runs or rest days between these harder sessions to allow for recovery.
Learn more about Recovery here.
Takeaways
Lactate threshold gives you a sharper way to read endurance. It explains why the same pace can feel very different to two runners, and it gives your training a clearer aim than just running faster.
A higher number isn't the whole point. The better question is whether you can run faster and hold it for longer at the same heart rate and effort. Track your threshold pace over time with a consistent method, and read it alongside VO₂ max, training load, and race results for the full picture.
FAQ
Are Lactate Threshold, Anaerobic Threshold, and Ventilatory Threshold the Same?
Not quite. Anaerobic threshold is an older idea describing a metabolic shift during exercise. Lactate and ventilatory thresholds come from changes in blood lactate and breathing gases. Runners often use LT2 and VT2 to estimate anaerobic threshold, but they don't always land at the same intensity.
What Is the Difference Between Lactate Threshold and Threshold Heart Rate?
Lactate threshold is an exercise intensity identified from changes in blood lactate. Threshold heart rate is your heart rate at that intensity. It can help guide your training, but a higher number does not necessarily mean better endurance.
Is VO₂ Max the Same as Lactate Threshold? Which Is More Important?
No. VO₂ max is the most oxygen you can take in and use. Lactate threshold shows how much of that capacity you can tap during sustained, harder efforts. Both shape endurance, and which matters more depends on your race distance, fitness, and training needs.
Is Lactic Acid Threshold the Same as Lactate Threshold?
People use them for the same thing. In exercise physiology, “lactate threshold” is the more accurate and widely used term.
Threshold Heart Rate Explained: How to Use It for Smarter Training
Heart rate tells endurance athletes how hard they are working. You have probably come across maximum heart rate, resting heart rate and heart rate zones already. As your training gets more structured, threshold heart rate (THR) gives you another useful reference for choosing the right intensity.
Your threshold heart rate shows how your body responds to different training demands. This guide covers what it is, how to find yours and how to use it in everyday training.
Table of Contents
What Is Threshold Heart Rate?
How to Determine Your Threshold Heart Rate?
How to Understand Your Threshold Heart Rate Value?
How to Use Threshold Heart Rate?
Why Does My Threshold Heart Rate Change?
Takeaways
FAQ
Threshold heart rate (THR) is your heart rate when you exercise at threshold intensity. In endurance training, it usually means lactate threshold heart rate (LTHR).
In plain terms, it is your heart rate during a sustained, higher-intensity effort. Runners and cyclists use it to set personal heart rate zones, manage workout intensity and read their training alongside pace or power. It shows how the heart responds when you work near threshold.
A threshold is a transition region, not an on-off switch. As intensity rises, your body shifts gradually from a fairly stable effort toward a more demanding one.
You can find your THR three ways: a field test, a device estimate or laboratory testing. Field tests and device estimates are the most practical for everyday training, so this section focuses on those two. Lab testing needs specialized equipment and controlled conditions, but it gives a closer look at physiological responses such as changes in blood lactate.
1. Field Test
A 30-minute time trial is a common way to estimate THR. It suits runners who have a solid training base and can hold a hard effort. Using Joe Friel's method, the steps are:
a. Warm up well, then run at the hardest steady effort you can hold for 30 minutes.
b. Record your pace and heart rate the whole way.
c. Take your average heart rate over the final 20 minutes as your estimated THR. For functional threshold pace, use your average pace over the full 30 minutes.
2. Suunto Estimation
Some Suunto sports watches use your training data to estimate THR. You will find the result in the watch’s Progress widget, alongside metrics like VO₂ max and predicted race times. What appears, and how, depends on your model, software version and how much training data you have logged.
You can also run the SuuntoPlus Threshold Test for a structured running test. It uses the heart rate and pace from the session to estimate your LTHR and threshold pace, then you can use the results to set or adjust your training zones.
Pick a route with consistent terrain, steer clear of extreme weather and big elevation changes, and keep your effort steady. One result can be skewed by how you feel that day, so read it alongside your longer-term trends. These estimates guide your training. They do not replace lab testing.
Say your estimated running THR is 170 bpm. That gives you a reference for running near threshold, based on that test. On its own, the number does not define your fitness, mean every workout should hit 170 bpm, or tell you to stop the moment you go past it.
Start with the test method, the sport and the matching pace or power. Pace and power show your output; breathing and perceived effort tell you how sustainable it is. VO₂ max is your maximum oxygen uptake and FTP is your functional threshold power. Do not convert either one straight into a THR.
To track progress, read heart rate next to output. Say two tests under similar conditions both put your THR around 170 bpm, but your pace improves from 5:00/km to 4:45/km. That points to better performance.
THR helps you set personal training zones, manage sustained efforts and read performance alongside pace. It works best when your output is steady. During short intervals, or when your condition changes, lean more on pace, power and how the effort feels.
1. Set a Personalized Intensity Reference
Runners hit threshold intensity at different heart rates. The same bpm can feel easy for one runner and put another right at threshold. Testing your own THR gives you a personal reference for setting zones across different workouts.
These zones help you match effort to the session. They keep easy days easy and check that hard efforts stay near the intended intensity. They also stop you getting carried away and creeping faster just because the pace feels good. Adjust to how you feel, and load your zones into a compatible device like Suunto Run 2 so you can check them as you run.
2. Control Sustained Hard Efforts
Hard sustained workouts need an effort you can hold to the end of every rep. THR helps you check you are near the planned intensity, but heart rate lags when you speed up. Keep your opening pace in check so you do not go out too fast and fade.
Start a continuous threshold run or a long cruise interval at a manageable pace, and let your heart rate rise into the target range on its own. Then use your breathing and perceived effort to judge whether you can hold it. Do not surge just to reach the target number sooner.
If your heart rate keeps climbing while your pace drops and the effort feels harder and harder, slow down or cut the rep short. Afterward, compare the first and second halves of the session, or the same points in each rep. A clearly slower pace at a similar heart rate late in the workout means you were struggling to hold output. Factor in terrain, weather and fatigue before you read too much into it.
3. Track Progress and Reassess Over Time
Once you have a THR, use it to guide workouts and track performance over time. Watch how it moves alongside pace, power and perceived effort, not just whether the number goes up.
Compare these across several sessions under similar conditions. A faster pace or higher power at a similar THR usually means you are producing more output for the same physiological effort. A lower heart rate at the same pace or power can also point to progress. A higher heart rate with lower output and greater perceived effort tends to reflect fatigue, weather or other conditions.
If a change holds across several workouts, or your zones keep feeling out of step with your effort, retest with the same method and update them. One odd reading or a small swing is not a reason to change anything.
4. Know When Not to Chase Heart Rate
Your THR comes from a test under specific conditions. In training, your heart rate also depends on how fast it responds, your surroundings and your physical state. In these situations, let the workout’s purpose, your pace or power and your perceived effort set the intensity:
Short intervals and hill sprints: Hit the prescribed output and duration. Do not push harder just because your heart rate still looks low.
Rolling terrain: Do not speed up early in a climb because your heart rate has not caught up yet. After a descent, there is no need to accelerate just to hold the target.
Heat or heavy fatigue: If your usual pace feels unusually hard, ease off rather than forcing your normal pace and heart rate.
Racing: Set your effort by the distance and your target finish time. In longer races especially, do not push up to THR early.
Your estimated THR can shift with the test method, the sport and the quality of your data. During exercise, your actual heart rate also responds to your surroundings, your physical state and how long you have been going. Knowing why helps you make sense of the numbers.
Different tests and devices: Lab tests, field tests and device estimates use different methods, so results can differ. A loose sensor, signal dropouts or bad readings can also throw off the result.
Different sports: Test running and cycling separately, and set your zones for each.
Different conditions: Temperature, humidity and altitude all affect exercise heart rate, and so do sleep, stress, recovery, illness and caffeine. Keep conditions as similar as you can when you retest, so the comparison means something.
Heart rate drift: Over a long effort, your heart rate can creep up even when pace or power holds steady. It is tied to changes like rising body temperature and fluid loss, and it gets worse in the heat. If your heart rate keeps climbing on an easy session, ease the pace and stay on top of hydration and cooling.
Takeaways
Use your THR to set zones that fit your training plan, then adjust your effort by pace and feel. Do not chase a heart rate number at the expense of what the session is for. To judge progress, look for long-term gains under similar conditions, like running faster at the same heart rate, rather than whether the threshold number itself has gone up.
FAQ
Why is my threshold heart rate different from my maximum heart rate?
They measure different things. Maximum heart rate is the highest your heart rate can go. THR is a reference for sustained, higher-intensity work. There is no fixed ratio between them.
Why does my heart rate exceed my threshold during training?
Going briefly above THR is normal in efforts like hard intervals, race surges or hill reps. It guides your intensity; it is not a ceiling for every session.
Is a higher threshold heart rate better?
No. THR varies from person to person and cannot compare athletic ability. Look for gains in threshold pace or power under similar conditions, not a higher heart rate.
How often should I update my threshold heart rate?
Retest when your fitness changes noticeably, or when repeated workouts under similar conditions show your zones no longer fit your effort. A single fluctuation does not call for an update.
Should a 5K be run at threshold pace?
If you are racing for your fastest time, most runners go faster than threshold pace. If the 5K is a threshold workout, holding threshold pace is the point.
Why are my zones different when based on maximum heart rate and LTHR?
The two methods use different reference values and can apply different percentage boundaries. So zones with the same name can represent different intensities. Check which system your training plan uses and match your device settings to it.
Trail Running for Beginners: How to Get Started
Trail running can be anything from a smooth forest path to a steep mountain trail with rocks, roots and uneven ground. If you are new to it, you do not need big mountains, long distances or the ability to run every step to get started.
Distance tells only part of the story. Elevation, terrain and weather all change how hard a run feels. The best approach for beginners is simple. Start with a route you can handle, keep your effort steady and build confidence as you get used to the terrain.
Part 1: How to Start Trail Running Without Overdoing It
1. Start with a Route You Can Manage
For your first few trail runs, choose a route that is easy to follow, not too long, and without sustained steep climbs or long stretches of rough ground. It also helps to pick something you can shorten or turn back from if the run takes longer than expected.
Not sure where to start? Look at routes that are popular with other runners and read the recent comments or notes. They give you a sense of trail conditions, tricky sections and how the route actually feels. Just remember that popular does not mean easy. Check the distance, elevation and terrain before you decide it suits your current level.
2. Give Your First Runs the Right Goal
Success on your first few runs does not have to mean a certain pace or distance. Give yourself time to get used to the terrain, notice how different surfaces and climbs change things, and learn what feels comfortable.
Pick a route you actually want to explore and leave room to enjoy it. A lot of trail running is about moving through new terrain, taking in your surroundings and seeing where the trail leads.
A good first trail run is one you finish feeling in control, and wanting to go again.
3. Match Your Gear to the Route
For a short, easy trail close to home, you need less gear than you think. Wear shoes you already find comfortable, carry your phone and bring water if the run will take longer than usual.
Road shoes are fine on smooth, dry paths. If the trail is muddy, loose, rocky or steep, trail shoes with more grip and protection are the better choice. Check the weather before you leave, and pack an extra layer if conditions might change.
On unfamiliar routes, make sure you can follow the trail reliably, whether that is a downloaded route, an offline map or a GPS watch. As your runs get longer or more remote, add food, more water and other essentials. There is no need to carry everything from day one.
4. Manage Effort, Not Pace
Pace swings a lot on trails. You might cruise a smooth section, drop to a jog or hike on a steep climb, then change speed again on a rocky descent. Holding one pace across all of it usually means working too hard on the difficult parts.
Aim for an effort you can sustain for the whole route instead of chasing a pace.
Let your breathing and how hard you feel you are working be your main guides. If a climb pushes you harder than you want, slow down or walk. Heart rate is another useful reference on longer climbs, but it works best alongside how you actually feel.
5. Know When to Walk Uphill
On steep climbs, walking often beats trying to run every step. If your breathing is getting out of control, or your running has slowed to barely more than a shuffle, switch to a brisk hike and keep moving steadily.
This helps you control your effort, save energy for the rest of the route and get running again more easily once the trail levels out. Walking uphill is not a failure. On many trails it is just good pacing.
6. Take Descents Slowly at First
Downhill can feel easier because your breathing settles. But uneven ground and higher speed also make it easier to lose control, trip or land a foot badly.
Keep your steps short, look a few metres ahead and scan for rocks, roots and changes in the surface. Let your arms move naturally for balance, and do not rush just because gravity makes speed easy.
If the terrain feels too steep or technical, slow down or walk until you feel in control again. Building downhill confidence gradually is safer than running fast before your footing and balance are ready.
Part 2: How to Avoid Injury When Starting Trail Running
Trail running can be harder on your ankles, knees and lower legs. The ground is uneven, and descents load your legs more than flat road does. For beginners, trouble usually shows up when the terrain gets harder too quickly, downhill speed gets away from you, or footing turns unreliable.
A few simple habits go a long way.
Build Up Gradually
Avoid increasing distance, climbing and technical terrain all at once. Make one part harder at a time and give your body a few runs to adjust before progressing again.
Adjust to the Surface
Slow down when the ground turns loose, rocky or slippery. On rocky sections, shorten your steps and pick stable places to land rather than trying to hold your speed. On mud or wet ground, avoid sudden changes of direction and give yourself more time to brake or turn.
Wet roots and rocks get especially slick, so step carefully and walk if you are unsure of your footing.
Take Extra Care on Descents
Downhill running loads your legs more and leaves less time to fix a bad step. Keep your steps short, stay controlled and ease off on steep, loose or rocky sections. Walk if you no longer feel confident in your footing.
Slow Down When Fatigue Affects Your Form
As you get tired, foot placement and balance can become less precise. If you start stumbling, dragging your feet or feeling less in control, slow down or walk.
Sharp pain, joint pain or pain that changes the way you move is a reason to stop rather than push through.
Part 3: How to Get Better at Trail Running
Trail running takes more than aerobic fitness. You also need leg strength for climbing and descending, and enough time on uneven ground to move confidently as the terrain shifts.
You do not have to train all of this at once. Focus on a few basics and build from there.
Build Your Endurance
Aerobic endurance is still the foundation. Keep most of your running at an easy, sustainable effort, and slowly extend how long you can stay moving comfortably.
If you already run on the road, keep it up. The aerobic fitness you have built still counts.
Walking and hiking count too, especially if you are new to running or getting ready for longer days out.
Strengthen Your Legs
Climbing takes repeated force from your calves, glutes and thighs. Descending asks your legs to control your body with every step.
Simple exercises like squats, lunges, calf raises and step-ups build that strength. You do not need a complicated gym plan. One or two short strength sessions a week is enough to support your running.
Train on Trails
Some things only improve with time on real trails. Gentle hills let you practise climbing at a steady effort, descents build confidence and control, and uneven ground sharpens your balance and foot placement.
Start with terrain you can handle comfortably. Then add steeper climbs, longer descents or rougher surfaces as they start to feel familiar.
Takeaway
If you are new to trail running, start with manageable routes, a steady effort and enough time to adapt. As your endurance, strength and confidence grow, you can take on tougher terrain.
The more time you spend on trails, the better you get at reading them: when to push, when to back off and how to keep moving well.
EnergySense Explained: Marathon Pacing on Suunto Watches
Most marathons feel comfortable early on. The challenge comes later, when the pace that felt easy at 10K starts to cost more than you planned. What you need most at that point is a clear read on how hard you're working and how much you have left.
EnergySense on Suunto Run 2 gives you that read in real time, estimating your current effort and remaining capacity so you can make better pacing decisions in marathons and long runs.
In this guide, we'll cover what EnergySense shows, how to set it up, how to read the display, and how to use it on the run.
Table of Contents
What Is EnergySense?
Why Marathon Pacing Is Difficult
How to Set Up EnergySense
How to Read the EnergySense Display
How to Use EnergySense
Using EnergySense with Marathon Time
EnergySense vs. ZoneSense
What to Know Before Using EnergySense
Summary
EnergySense is a Suunto Run 2 feature built to help you manage your effort from start to finish. Using your live running data, it estimates your current effort level and how much capacity you have left. It runs on the watch alone, ready for everyday long runs and race day.
Pace and heart rate show what you're doing right now. EnergySense adds a view of what that effort means for the rest of your run, helping you decide whether to:
Maintaining your current pace
Slowing down to conserve energy for later
Increasing your pace when you still have enough capacity
Early in a race, it’s easy to get carried along by the runners around you or pick up the pace simply because you still feel fresh. But time gained in the first half can come at a cost later, when the extra effort starts to catch up with you.
Even at the same pace, the effort required can vary throughout a run. Heat, humidity, hills, headwinds, and how you feel on the day can all affect how hard your body is working. This means that pace alone may not always reflect the actual effort you are putting in.
By keeping an eye on your remaining energy with EnergySense, you have another way to judge whether your planned pace is still sustainable. Instead of sticking to a target pace simply because it is on plan, you can adjust earlier when the effort is higher than expected.
To use EnergySense, select Marathon mode, set your target distance, and turn on EnergySense.
a. Select Marathon mode.
b. Set the target distance for your race or training session.
c. Scroll down and turn on EnergySense (Beta).
You can also enable EnergySense directly from the target-distance selection screen. Menu names and setup steps may change with future software updates.
Tip: For EnergySense to provide more relevant pacing estimates, you need to complete at least three outdoor runs at a steady pace beforehand. EnergySense uses data from these runs to estimate your endurance and running ability. If you are using the feature for the first time, record a few runs before using it during a race.
The EnergySense screen shows your current pace and heart rate, along with an estimate of how far you can continue at your current effort, your remaining energy, and the distance left to your target.
Current pace: Your current running pace
Current heart rate: Your heart rate during the activity
Estimated sustainable distance: An estimate of how far you can continue running based on your current pace and available energy
Remaining energy: An estimate of your remaining endurance, shown as a percentage
Distance to target: The distance remaining to your selected target
Green
A green display means that the estimated distance you can sustain is greater than the distance remaining in the race. This indicates that you may be able to maintain your current pace to the finish.
Orange
An orange display means that the estimated distance you can sustain is shorter than the distance remaining in the race. This can be a useful signal to adjust early—for example, by easing your pace, taking on fluids, or refueling.
The color shown by EnergySense does not guarantee that you will finish the race or maintain your current pace. Always take the course, weather conditions, fueling, hydration, and how you feel into account.
EnergySense can be useful not only on race day, but also during long runs and marathon-pace workouts. Using it in training gives you a chance to see how the readings change alongside your perceived effort, making the information easier to interpret when you race.
Early in the Run: Avoid Going Out Too Fast
Right after the start, it’s easy to run faster than planned without feeling much fatigue. If your remaining energy is dropping faster than expected, consider settling into a more sustainable pace once the initial congestion has cleared.
Mid-Run: Check Whether Your Effort Is Sustainable
In the middle of the run, pay attention to the balance between your current effort and the distance still to go. Rather than reacting to a single change in the numbers, look at the trend over a longer section and compare it with your breathing and how your legs feel.
Late in the Run: Decide When to Use What You Have Left
If you still have energy in reserve later in the run, you can consider increasing your pace based on the remaining distance and course conditions.
If your remaining energy is already low, it may make more sense to hold your pace rather than push harder, while focusing on your running form, hydration, and fueling.
Suunto Run 2 also features Marathon Time, which calculates a projected finish time based on your current pace and updates it as you run.
While EnergySense provides an estimate of how much energy you have left, Marathon Time shows your projected finish time if you continue running at your current pace.
Using the two together can help you adjust your pace while balancing your target time with your current effort, rather than pushing too hard simply to stay on track for a specific finish time.
Although their names are similar, EnergySense and Suunto ZoneSense differ not only in purpose, but also in the equipment required to use them.
Feature
Required equipment
What it mainly shows
Best used for
EnergySense
Compatible Suunto watch (currently Suunto Run 2)
Current effort and estimated remaining energy
Managing stamina and pacing during marathons and long runs
ZoneSense
Compatible Suunto watch + heart rate belt
Exercise intensity based on HRV and your body’s response that day
Managing intensity across aerobic, anaerobic, and VO₂max zones
Put simply, EnergySense helps you decide how to distribute your effort all the way to the finish, while ZoneSense helps you understand which intensity zone you are currently training in.
EnergySense can be used with a compatible watch alone. ZoneSense, on the other hand, requires a compatible heart rate belt to capture beat-to-beat R-R interval data. Understanding the purpose of each feature and the equipment it requires makes it easier to use EnergySense for race strategy and ZoneSense for managing training intensity.
The effort and remaining energy shown by EnergySense are estimates designed to support pacing decisions. Your actual performance can also be affected by factors such as weather, elevation changes, hydration, fueling, sleep, and your physical condition. Do not rely on numbers alone. Pay attention to physical warning signs such as unusual breathing difficulty, pain, or dizziness. If you feel unwell, stop exercising.
EnergySense is also currently available as a beta feature. The data shown may not always be consistent, so treat it as reference information rather than a definitive measure. Availability, supported devices, displayed data, and functionality may change in the future. Before using EnergySense, make sure the Suunto app and your watch software are up to date, and check the information shown on your device.
Summary
Good marathon pacing is not only about sticking to your target pace. It is just as important to adjust your effort based on how your body is responding on the day. EnergySense provides real-time estimates of your current effort and remaining energy, helping you decide whether to maintain your pace, ease off, or speed up during the race.
At just 35 g, Suunto Run 2 combines EnergySense and Marathon Time, allowing you to manage your running from everyday training through to race day.
From Road to Trail: How to Transition to Trail Running
You know how to train, how to pace yourself and how to build endurance on the road. But what happens when the road ends?
If you are thinking about trying trail running, you may be asking: Am I ready? Does my road fitness still count? What do I need to change?
The good news is that your road fitness is a real foundation to build on. This guide covers what carries over, what changes once the surface stops cooperating, and how to ease into trail running one step at a time.
Part 1: Are You Ready to Move From Road to Trail?
Yes. If you already run regularly, you have a solid fitness base to build on. Regular running is the qualification here, and pace, distance and race results are beside the point.
What matters more is choosing a trail that matches your current ability.
Which Trail Should You Start On?
Before your first trail run, weigh three things:
Elevation: how much climbing and descending will you take on?
Technical difficulty: is the trail smooth and runnable, or rocky, loose and uneven?
Duration and conditions: how long are you likely to be out, and what are the weather and trail conditions like?
Difficulty comes from gradient, surface and conditions as much as from distance. A short, steep or technical route can be far more demanding than a longer, smoother one.
How Much Should You Run?
For your first few trail runs, work in time rather than mileage. If you normally run for an hour on the road, start with a similar hour on an approachable trail and let the distance land where it lands.
Part 2: What Should You Keep From Road Running?
A lot more than you might think. Everything you built on the road comes with you.
Aerobic Fitness
The aerobic engine you built on the road stays valuable on the trail. Road runs remain an effective way to maintain that fitness, especially in weeks when trails are hard to reach.
Endurance and Consistency
Your ability to keep moving for long periods, and to train consistently week after week, still matters. Plenty of your running can stay on the road.
Speed
Speed matters too. Faster running supports your overall running ability, even as pace becomes a less reliable measure of performance on varied terrain.
All of it carries over. What changes is how you apply it in a different environment.
Part 3: What Needs to Change on the Trail?
The fitness comes with you. How you manage effort, distance and a less predictable environment is what shifts.
Pace → Effort
On the road, pace is a useful way to judge your effort. On trails, climbs, descents and changing surfaces can swing your pace dramatically from one kilometer to the next.
Instead of holding your usual road pace, keep your effort appropriate for the terrain in front of you.
Distance → Time on Feet
The same distance takes much longer on a trail, especially once elevation or technical ground is involved.
That makes time on feet the more useful way to think about a trail run. A slower pace often means a harder run, because the terrain keeps you out there longer.
Running → Running Plus Hiking
Trail running includes hiking. On steep climbs and demanding ground, hiking is often the more efficient way to manage your effort.
It is a normal part of the sport, and experienced trail runners do it on every big climb.
Predictable Surface → Variable Terrain
Road running lets you settle into a consistent rhythm. Trails ask you to adapt to changes in gradient and surface throughout the run.
Your pace and effort will move with the terrain. Learning to work with that variability is the heart of the transition.
Part 4: Tips for a Smooth Transition
Keep the running routine you already have and add trail-specific sessions where they fit, giving yourself time to adapt.
Start with manageable trails: choose smoother routes with moderate elevation first, then build distance, elevation or technicality as you get comfortable with the demands.
Build time on feet, not just mileage: a trail run takes much longer than the same distance on the road, so base your early sessions on familiar run durations.
Keep your first runs simple: pick straightforward routes where you know what to expect and can cut the run short easily. That leaves you free to focus on terrain, effort and elevation while everything else stays familiar.
Plan for the extra time: the same distance takes longer on the trail, so build that into your preparation. Think about how long you expect to be out and plan hydration and fuel around it, especially on longer or more remote runs.
A watch with free offline maps and route navigation helps here too. Load the route before you leave, follow it through the climbs, and track time on feet and ascent alongside pace.
Ready to work on your trail-running technique? Get expert advice on uneven terrain, climbing and trail skills from eight-time World Mountain Running Grand Prix champion Jonathan Wyatt.
Takeaway
Moving from road to trail is a change of environment, not a change of identity. The fitness and experience you already have still count, and you are simply learning to apply them somewhere new.
Readiness here is something you build by going. Start with what you have, choose trails that meet you where you are, and let experience guide what comes next.
Road to Trail Running FAQ
1. Am I Ready to Start Trail Running?
If you run regularly, yes. Regular running is the only prerequisite. Choose a trail that matches your current ability and start there.
2. How Long Should My First Trail Run Be?
Work in time rather than distance. If an hour is a normal road run for you, start with an hour on an approachable trail and let the distance fall where it falls.
3. Is It Normal to Walk During a Trail Run?
Yes. Hiking the steep climbs is standard practice at every level of the sport, and it is usually the most efficient way to manage your effort.
4. Do I Need Trail Running Shoes to Start?
On smooth, dry trails, road shoes will carry you through your first few runs. Once you move onto loose, rocky or wet ground, trail shoes give you the grip and underfoot protection that makes the difference.
5. Will Trail Running Make Me Slower on the Road?
Trail running builds strength, stability and aerobic fitness that all support your road running. Keeping some faster road sessions in the week maintains your leg speed and your feel for pace.
6. How Do I Judge Trail Difficulty?
Look at elevation gain, technical difficulty and expected duration together. A short, steep, rocky route can be far harder than a longer, smoother one.
