Suunto Blog
Endurance Training: How to Build Endurance
Every run starts to feel hard before you get very far, and you keep falling short of your target distance. You want more endurance, but you're not sure how to structure your training. Using running as the example, this guide covers the main types of endurance training, how to build endurance gradually, and how to track your progress. Table of Contents What Is Endurance Training? What Are Examples of Endurance Training? How to Build Endurance How to Monitor Your Endurance Training Progress Takeaways FAQ What Is Endurance Training? Endurance training is a structured approach to improving your body's ability to sustain activity and resist fatigue. It helps you keep going for longer and hold your performance as fatigue sets in. Endurance can be viewed through several lenses: physiological function, athletic goals, or how the body produces energy. From a physiological perspective, two types matter most for training: Cardiorespiratory Endurance: The ability of your heart, lungs, and circulatory system to deliver oxygen to working muscles and support sustained activity. Muscular Endurance: The ability of your muscles to contract repeatedly or hold an effort over time. Where muscular strength is about how much force you can produce, muscular endurance is about how long you can sustain an effort or how many repetitions you can complete. Running, cycling, and swimming draw on both, though the balance varies with the activity and the muscles involved. The sections below cover common endurance training methods so you can find an approach that fits your current fitness level and goals. What Are Examples of Endurance Training? Many types of exercise build endurance, and the right choice depends on your current fitness and what you want to improve. Walking, especially brisk walking, is a good starting point for building endurance and a regular exercise habit. If your goal is better running, make running your main activity and use cycling or swimming as complements. Once you've chosen your main activity, vary your training to target different aspects of endurance. For running, common approaches include: Easy Runs: Build your aerobic base by accumulating training time at a comfortable, sustainable effort. They’re a key part of everyday endurance training. Long Runs: Go longer than your usual runs to practice sustaining activity over an extended period. Focus on gradually increasing duration rather than trying to run faster at the same time. Tempo Runs: Practice maintaining a steady effort that feels challenging but controlled. Tempo runs are often used to develop the ability to sustain efforts near lactate threshold intensity. Interval Training: Break a workout into repeated efforts separated by easier activity or rest. High-intensity interval training (HIIT) is one common form. The main training benefit depends on the intensity and duration of each effort, along with the recovery between intervals. These methods differ in duration, intensity, and recovery structure. Combine them to suit your goals and use only the ones that serve them. A plan that fits you matters more than one that covers everything. How to Build Endurance Building endurance starts with a clear training goal and a routine you can stick with. For running, that means starting with what you can comfortably manage now, then building your ability to sustain effort and hold your pace late in a run through consistent training and gradual adjustments. Train Consistently Look at how much time you have each week and pick training days you can stick to. Start with a run duration you can finish comfortably rather than building your plan around a workout that leaves you struggling. If you're new to regular running, begin with fewer sessions, shorter runs, or a run-walk approach. If you already have a running base, build from your current routine rather than making every run the same length. Run-walk sessions are a good place to start if you're just establishing the habit. Leave time for recovery between training days, too. Here's an example starting week to use as a reference. Adjust it to your fitness level and how your body responds. Monday: Run-walk session. Warm up with a walk, alternate easy running with walking, then finish with a cooldown walk. Tuesday: Rest or take an easy walk, depending on how you feel and what your schedule allows. Wednesday: Run-walk session. Repeat Monday's workout and see whether you can complete it comfortably. Thursday and Friday: Rest or do light activity such as walking. Saturday: Optional run-walk session. If two sessions a week feel comfortable and you're recovering well between them, consider adding a third. Otherwise, stick with two. Sunday: Rest or take an easy walk, depending on how you feel. Use this example to establish a routine rather than as a set of workouts you must complete. Find a schedule you can maintain before adding sessions or making them longer. Match Intensity to Your Goal Choose your effort based on the goal of each workout, rather than always trying to run easier or push yourself harder. For easy runs that build your aerobic base, start at an effort where you can hold a comfortable conversation and use your personal Zone 2 range as an additional reference. For tempo runs or threshold training, set your intensity according to the specific workout and your personal heart rate zones. During the run, use your breathing, perceived effort, and heart rate to check whether you’re working at the right intensity. If the effort is clearly higher than the workout calls for, slow down rather than forcing yourself to hold the planned pace. With a compatible Suunto sports watch paired with a heart rate belt, you can also use Suunto ZoneSense intensity feedback to help assess whether your effort matches the goal of the session. Progress Gradually Once you can complete your current training consistently and recover well, make small adjustments toward your goals. To run continuously for longer, gradually extend your running intervals or reduce the share of time spent walking. To increase your overall volume, extend one session or adjust how often you run each week. Change one variable at a time, and watch how you handle the following workouts and how you recover before increasing the load again. Adapting to your current routine is a cue to consolidate before adding more. Lock in your progress first, then build gradually. How to Monitor Your Endurance Training Progress You don’t need to run faster or farther every time to tell whether your endurance is improving. Choose a workout you can repeat under similar conditions, then compare your performance over time. Look for changes such as: Spending more time running within the same workout duration: You need fewer walking breaks or stops, allowing you to spend more time running. Taking longer to reach the point where running feels difficult: You can maintain your usual effort for longer than before. Maintaining a steadier effort in the second half of the run: As fatigue sets in, you slow down less, take fewer breaks, or are less likely to cut the workout short. Consistent changes across multiple sessions, rather than a single good run, can indicate improving endurance. Rather than increasing your training load immediately, maintain your current routine to consolidate progress, then adjust gradually based on your goals and recovery. If progress stalls, check your training consistency and recovery first. A noticeable drop in pace after extending your runs may mean you started too fast or increased the duration too much. A decline across several sessions calls for a review of your overall training load and recovery time. Seek professional evaluation for persistent pain or significant discomfort. A Suunto watch and the Suunto app can record workout data, including running time. You can also make a note after each session of when or where you started to feel noticeably fatigued and how often you needed to stop, making it easier to compare your runs later. When reviewing your progress, account for differences in weather, fueling, and training intensity. Takeaways Start with a level of training you can complete consistently, then build your routine and make gradual adjustments based on your goals and how your body responds. Track your performance over time to identify progress, and allow enough time for recovery so you can keep training sustainably. FAQ Can you build endurance without running? Absolutely! Walking, cycling, and swimming all build endurance. If your goal is better running, they make good complements, but you'll still need running-specific workouts. Is HIIT better than endurance training? It depends on your goals. HIIT is itself a form of endurance training, focused on performance at higher intensities, and you can combine it with other methods to suit your needs. Can you do endurance training every day? That depends on the intensity and duration of your workouts and how well you recover. Beginners do well to schedule rest days or non-running days between runs. Does endurance training build muscle? Muscular endurance and muscle size are two different goals. Running, cycling, and swimming mainly develop endurance. If you want to build muscle, add strength training with progressively increasing loads.
October 14 2026
Munich Marathon with the Suunto running community
Shake-out runs, familiar faces and Suunto Run 2 on the wrist. Here’s how we shared marathon week with Munich’s running community. Some of the best moments of marathon week happen before the start. An easy run with new faces. A conversation that settles the nerves. Another slice of pizza, because tomorrow is a big day. This October, Suunto joined the Munich Marathon as Official Timing Partner. Together with forceLab and FCF.club, we brought runners together for four days of community activities, with Suunto Run 2 ready for a test run. A place to find your people At forceLab in central Munich, our Marathon Hub welcomed around 350 people across four days. Local run clubs kicked things off with an easy 8 km shake-out, followed by a chance to hang out over food and drinks. The programme made space for the rest of race preparation, too: Pilates for runners, a women’s marathon-fuelling workshop and time to meet the people sharing the same countdown to Sunday. By Saturday, the creative corner was busy with personalised shirts, beaded bracelets and homemade cheer signs. Then came the pizza party. Carb-loading is always better with company. Good company with Alina and Danny Alina Jäger, known as @clippedinandfree, joined the community activities at the hub, where women’s running was a big part of the week. The FCF.club Friday run became a Suunto special, welcoming women of all paces, with different pace groups and demo watches to try. Find your group, settle into your stride and enjoy the kilometres together. Over at the expo, around 200 people came by the Suunto stand to meet Daniel Hernes, aka @danny_run. It was a chance to meet a familiar face from the Germany running world in person and share the excitement of marathon weekend. Take Suunto Run 2 for a spin We brought Suunto Run 2 along for the kilometres before race day. Runners could strap one on for a community test run and explore its features with our team at the expo. Its lightweight design, bright AMOLED display and easy access to pace, distance and heart rate make it a companion for everything from an easy group run to the effort you’ve been training for. Munich gave runners the chance to see how it felt on their own wrist, at their own pace. A relay with a Suunto twist On race day, 40 women took on the marathon relay in Suunto shirts, using Suunto watches as their batons. Each handover carried the community spirit onto the course, with one teammate finishing their leg and another ready to keep it going. Across the races, Suunto flags also helped runners spot the pacers and find the group working towards their target time. Thanks for every shared kilometre Munich To everyone who joined a run, tried a watch, made a cheer sign or came along to meet the community: thank you for being part of it. Pick your next route, bring a friend and see where the run takes you. We’ll see you out there. Adventure starts here.
October 14 2026
Recovery Runs: How and When to Do Them
Yesterday's workout was tough, and your legs still feel heavy. Should you head out for an easy run or take the day off? Knowing what a recovery run is for, and how to approach one, makes that call much easier. Table of Contents What Is a Recovery Run? Recovery Run vs. Easy Run Should You Do a Recovery Run Today? How to Do a Recovery Run How to Tell If Your Recovery Run Is Too Hard Takeaways FAQ What Is a Recovery Run? A recovery run is a short, low-intensity run, usually scheduled after a hard workout or long run. It's a form of active recovery that keeps you moving while adding as little training stress as possible to a body that's still fatigued. Despite a common belief, it won't flush out yesterday's lactate or guarantee a faster recovery. Its value lies in keeping you moving at minimal cost. Recovery Run vs. Easy Run Both should feel comfortable, but they do different jobs in a training plan. Easy runs build aerobic mileage. Recovery runs keep your training load low when you're already tired, so they're usually shorter than your regular easy runs, with the intensity dialed back further if needed. There's no universal pace cutoff between the two, and a recovery run doesn't have to be slower than every easy run you do. Should You Do a Recovery Run Today? To decide, weigh how you feel today against what your training plan calls for: A recovery run may be a good fit: You're only mildly fatigued, have no pain, walk and run normally, and can keep the effort easy. The run also suits your current running frequency and fits your existing plan. You may not need one: If you run only two or three times a week with rest days in between, an extra session just to "help" recovery adds little. When to Choose Rest, Walking, or Cross-Training If those conditions don't apply, skip the recovery run and adjust based on how tired or uncomfortable you feel: Switch to light activity: If you can't keep a run easy but still want to move, try a short walk or a familiar low-intensity activity like cycling or swimming. Keep it easy, and leave the planned workout volume behind. Prioritize rest: Much less sleep than usual, overall exhaustion, or several workouts in a row feeling harder than normal are all good reasons to skip the run. Protect your sleep rather than cutting into it to fit in a session. Stop running: Localized pain, pain that gets worse, or a change in your form to avoid discomfort are all signs to end the run. Persistent or recurring pain needs its own attention, so get a professional assessment if needed. After an all-out half marathon or marathon, don’t follow the same recovery plan you’d use after a typical long run. If walking still feels awkward or you’re noticeably exhausted, it’s too soon to jump back into running. If you’re unsure how you’re feeling, use recent sleep data, training load, and HRV trends to help guide your decision. If your HRV stays outside your normal range for several nights, consider it alongside how you feel. One night’s reading alone shouldn’t determine your training plan. How to Do a Recovery Run Once you've decided to go, keep it simple: pick a route, set a time limit, and start easy. Here's how to approach effort, duration, and route, followed by a step-by-step example. Set Your Effort Start at an effort where you can speak in full sentences without difficulty. RPE 2 to 3 out of 10 is a useful starting point. Your breathing should stay steady enough for natural conversation without any conscious control. Your legs may still feel a little tired, but the run shouldn't get progressively harder. If you use heart rate, treat it as a way to check that your effort is still easy, not a reason to speed up to reach a particular zone. Different devices may define heart rate zones using maximum heart rate, heart rate reserve, or lactate threshold heart rate. Avoid applying percentages or zone boundaries from one method directly to another. Adjust your pace to how you feel that day. Start slower than usual and use the first few minutes to check that your breathing and running form feel natural. There’s no need to hit a target pace or run slower than every one of your regular easy runs. Set a Time Limit Plan your recovery run by time rather than setting a distance you have to cover. 20–30 minutes can be a practical starting point, as suggested in some running training guides. This is a general guideline, not a target you need to hit. If your usual runs are shorter or you’re not feeling your best, go shorter. Set a time limit before heading out, with room to finish early, and count any walking toward your total time. Even if you feel good, there’s no need to extend the run or make up the distance from your original plan. Choose an Easy Route Choose a flat, familiar route with an easy way to turn back to limit the extra effort that hills and technical terrain can add. Slow down on climbs and walk when needed. There’s no reason to push harder just to keep running continuously. Weather can affect how easy a run feels, too. In hot, humid, or windy conditions, the same pace may take more effort. Slow down, shorten the run, or head out during a cooler part of the day. An indoor treadmill is another option. A Simple Recovery Run Example Here’s how a 30-minute recovery run might look in practice. This example is for runners who already run regularly, feel only mildly fatigued, and have no pain. It’s a starting point, not a one-size-fits-all training prescription. First 5 minutes: Start with a very easy jog and let your breathing and stride settle in. Don’t rush to hit a particular pace. Middle 20 minutes: Settle into a steady, easy jog at the effort level described above. If you take short walking breaks, count that time toward the 20 minutes. Final 5 minutes: Keep jogging easily or gradually transition to walking. There’s no need to pick up the pace at the end. If the effort starts to feel noticeably harder at any point, you can finish early. There’s no need to complete the full 30 minutes. Afterward, record the actual duration and how the run felt overall, including whether you finished early or took walking breaks. If you’d like your watch to guide you through each stage, you can create a structured workout in Suunto App, set the duration for each stage, and sync it to a compatible Suunto sports watch. How to Tell If Your Recovery Run Is Too Hard If the run starts to feel harder as you go, or leaves you noticeably more fatigued afterward, it’s worth reassessing the effort and duration. Here’s what to look for during and after the run, and how to adjust. During the Run These signs suggest your recovery run may be too hard: You could hold a natural conversation at first, but now you can only manage short sentences and your breathing is noticeably heavier. Holding the same pace takes more effort, your legs feel increasingly heavy, and your stride starts to feel forced. Your pace stays about the same, but your heart rate keeps climbing and the effort feels noticeably harder. If you notice these changes, slow down first. If your breathing and running form still don’t feel easy, switch to walking or end the run early. Even if your heart rate stays within your target zone, don’t ignore a clear increase in effort. After the Run If you feel noticeably more fatigued after the run than you did before heading out, the session may have been too long or too hard. New pain or worsening discomfort is another sign that your current approach needs to change. Think back over the run and check whether you went longer than planned, struggled more in the second half, or pushed harder on hills. If you use Suunto, you can also review your duration, heart rate graph, and time in each zone in the app to help pinpoint where the effort changed. Consider your recent training load, sleep, and fueling when looking for possible causes. Then decide whether to shorten the run, lower the intensity, or take a rest day. Don’t assume the recovery run itself is the only reason you feel fatigued. Takeaways A recovery run exists to keep extra training stress low. Make sure you're ready to run, set an easy effort and a duration you can cut short, adjust as you go, and record the actual workload afterward. Resting, walking, or finishing early can all be the right training decision. FAQ Are recovery runs necessary? No. Recovery runs are optional. Whether one makes sense depends on your training plan, weekly mileage, and how you feel that day. Why does running slower feel awkward? Slow running often feels awkward when you try to keep your usual stride length or cadence. Let your form adjust naturally to the slower pace instead. If it still feels awkward, mix in walking breaks, and stop if you feel any pain. Can a recovery run be just one mile? Yes. There's no minimum distance for a recovery run. One mile can be enough for a short, easy outing, depending on your usual routine and how you feel that day. Do recovery runs count toward weekly mileage? Yes. Recovery runs count toward your weekly mileage, and their duration and intensity add to your overall training load.
October 12 2026
Polarized Training: How to Set Zones and Plan Your Week
If your recovery is dragging and your performance has stalled, the fix may lie in how you distribute training intensity rather than how hard you work. Too much time in the middle can leave you working too hard to recover well, but not hard enough to get a strong training stimulus. Polarized training helps shift that balance. Most of your training stays easy, while a smaller amount is reserved for high-intensity work. This article explains how polarized training works, how to set your intensity zones, how to structure your training week, and how to adjust based on your data and how you feel. Table of Contents Polarized Training Explained: How It Compares to 80/20 and Pyramidal Training Does Polarized Training Really Work? How to Find Your Polarized Training Zones? How to Structure a Polarized Training Week? How to Track Your Polarized Training Progress? Takeaways FAQ Polarized Training Explained: How It Compares to 80/20 and Pyramidal Training Polarized training is a way of distributing training intensity across three broad levels: most training is done at low intensity, a smaller amount at high intensity, and relatively little at moderate intensity. These three intensity levels are typically defined using the first lactate threshold (LT1) and second lactate threshold (LT2). Polarized training is often associated with 80/20 training. The 80/20 approach generally means spending around 80% of your training at low intensity and the remaining 20% on quality work, which can include moderate-intensity, threshold, or high-intensity training. Strictly speaking, polarized training places more emphasis on keeping moderate-intensity work to a minimum. The two approaches are closely related, but they aren’t exactly the same. Looking at the relative share of low-, moderate-, and high-intensity training, polarized training differs from two other common approaches to endurance training: Training Model Intensity Distribution Polarized training Most training is low intensity, followed by high intensity, with the least at moderate intensity Pyramidal training Most training is low intensity, followed by moderate intensity, with the least at high intensity Threshold training Places more emphasis on training around threshold, with a larger share of moderate-intensity work The difference between these models isn’t just how much time you spend at each intensity. It’s also about how you distribute training stress. Polarized training keeps most sessions at low intensity to help manage fatigue and maintain consistency, while a smaller amount of high-intensity work provides a clear training stimulus. Does Polarized Training Really Work? Polarized training is not a set formula that guarantees better results. Research suggests that, among some trained runners and endurance athletes, a polarized intensity distribution may improve endurance performance, short-distance performance or running economy. However, the available research is limited by sample sizes and training conditions. Training volume, fitness level, recovery capacity, and the timing of the training cycle can all affect the outcome, so the same results should not be expected for every runner. From a training-management perspective, the value of polarized training is less about hitting an exact percentage every week and more about being intentional with how you distribute your effort. Most training stays at low intensity, moderate-intensity work is kept in check, and a smaller amount of high-intensity work provides a clear stimulus. For newer runners, building a consistent training routine and finding a training load they can recover from is usually more important than following a strict polarized ratio. For runners with an established training base, polarized training can be used as a framework for managing training stress. How to Find Your Polarized Training Zones? Finding your polarized training zones starts with identifying the two key boundaries: LT1 and LT2. These thresholds can then be used to define your intensity zones. In day-to-day training, use heart rate, pace, breathing, and perceived effort together to check whether you’re training at the right intensity. Find Your Lactate Threshold 1 & 2 Blood lactate or respiratory gas testing can directly identify LT1 and LT2, along with the heart rate and pace associated with each threshold. This is one of the most direct ways to set your personal training zones. If you don’t have access to laboratory testing, your training data and structured field tests can still give you useful reference points: LT1: The aerobic threshold can be a practical reference for LT1. Choose a flat, familiar route and run at an easy, steady effort. You should be able to hold a natural conversation and keep your breathing relaxed. If your heart rate continues to rise noticeably during the second half of the run, your effort may already be approaching or exceeding the upper end of your low-intensity range. Consistent heart rate and pace across multiple runs can help you establish an initial estimate of LT1. LT2: Runners with an established training base can use a structured field test or a threshold estimate from their device as a reference. The duration, intensity, and calculation method should follow the specific testing protocol being used. These methods can give you a starting point for setting your training zones, but they don’t replace laboratory testing. It’s best to cross-check your estimates against data from multiple workouts and how you feel during training. Set Your Three Polarized Training Zones Once you’ve identified LT1 and LT2, you can use these two thresholds to divide your training into three intensity zones: Three-Zone Model Physiological Boundary Role in Polarized Training Zone 1: Low Intensity Below LT1 Builds aerobic training volume Zone 2: Moderate Intensity Between LT1 and LT2 Kept relatively low in polarized training Zone 3: High Intensity Above LT2 Provides high-intensity stimulus For example, if your LT1 heart rate is around 145 bpm and your LT2 is around 170 bpm, you could initially treat anything below 145 bpm as low intensity, 145 to 170 bpm as moderate intensity, and anything above 170 bpm as high intensity. Note that Zone 2 in this three-zone model is the moderate zone between LT1 and LT2, which differs from the easy “Zone 2” used in five-zone heart rate models Use Pace, Breathing and Effort to Check Your Intensity Heart rate is useful for tracking training zones, but when you’re actually running, it also helps to check your pace, ability to talk, and perceived effort. Zone 1: Pace is below the pace associated with LT1. Your breathing stays relaxed, you can speak in full sentences naturally, and the effort feels sustainable for a long time. Zone 2: Pace falls between the paces associated with LT1 and LT2. Your breathing becomes deeper, and holding a full conversation starts to feel difficult, but you can still maintain a steady rhythm. Zone 3: Pace is above the pace associated with LT2. Your breathing is noticeably harder, and you can usually only speak a few words or short phrases. This zone is often trained through intervals. Keep in mind that heart rate can lag behind your effort during interval workouts. Use your target pace, perceived effort, and the quality of each interval to help control the intensity. With a Suunto sports watch, you can adjust your personal heart rate zones based on your threshold heart rate and review the time spent in each zone after a workout. This can help you see whether your actual training intensity matches your plan. If wrist-based heart rate is affected by factors such as arm movement, a heart rate belt can provide more consistent data. How to Structure a Polarized Training Week? Once you’ve set your personal training zones, start planning your week around them. Keep your total running volume at a level you can manage consistently, then add high-intensity sessions, a long run, and recovery days. Finally, check your overall intensity distribution to make sure it matches your plan. Arranging Training and Recovery Across the Week When planning your week, use the number of sessions to control how often you do high-intensity work, then check the time spent in each zone to see how your actual intensity is distributed. For interval workouts, count the warm-up, work intervals, recovery periods, and cool-down based on their actual intensity. Time spent in each zone usually won’t match the percentage of workouts, and there’s no need to force the numbers to hit a specific ratio. A typical week can be structured around these steps: Set a sustainable number of runs and total volume. Start with the running frequency and weekly training time you’ve already adapted to. Then factor in work, rest, and other activities to determine how much training time you can realistically use that week. Choose the key workouts for the week. Based on your training background and goals, decide whether to include a high-intensity interval session and whether to include one longer run. Schedule the biggest training loads and recovery around them. If your week includes both high-intensity intervals and a longer run, try to separate them and place rest or low-intensity runs before and after these sessions. Strength training and other demanding activities should also be considered as part of your overall training load. Fill the remaining time with low-intensity running. Keep most other runs below LT1, with the frequency and duration staying within what you can currently recover from. For example, if you can consistently run five times a week, you could use one session for high-intensity intervals and keep the other four primarily at low intensity, with one of those runs being longer. If you can only run three or four times a week, you can reduce the number of low-intensity runs and decide whether to keep the high-intensity session based on how well you’re recovering. There’s no need to squeeze the same five-run workload into fewer days. When using the Suunto app to plan interval workouts, you can follow the structured workout guide to set work and recovery phases and sync the workout to a compatible watch. Adjusting Your Training Week For Everyday Training: Your training schedule doesn’t have to look exactly the same every week. If you’re still carrying fatigue, shorten your low-intensity runs, push back your high-intensity session, or temporarily reduce your overall volume. If you occasionally miss a workout, there’s no need to make it up right away. Avoid stacking extra training onto the days around it and creating an unnecessarily heavy load. For Race Preparation: When preparing for a half marathon or marathon, you can add a limited amount of threshold or race-pace work based on the demands of the event, while reducing some of your usual high-intensity intervals. Your weekly intensity distribution may become more pyramidal during this phase. Whether this approach makes sense depends on how well it matches your race demands and whether you can maintain a consistent balance between training and recovery. How to Track Your Polarized Training Progress? When reviewing your polarized training, look beyond performance and recovery. You also need to check whether your actual intensity distribution matches the plan: Is most of your training still low intensity? Can you maintain the quality of your high-intensity sessions? Reviewing Your Intensity Distribution Start by comparing the total time you’ve spent in each intensity zone over the past few weeks. If runs that were supposed to stay at low intensity regularly creep above LT1, you may be accumulating more moderate-intensity work than intended. If your high-intensity time has increased noticeably, look at where that extra intensity is coming from. Is it part of your planned training, or is it the result of running too fast, tackling more hills, or not recovering enough? When making these comparisons, look at total training volume as well as the percentages. Even if the intensity distribution stays about the same, an increase in total running time can still mean more overall fatigue. If you use a Suunto watch, you can use the Training Zone feature in the Suunto app to review your weekly intensity distribution and six-week average trends. You can also look at changes alongside chronic training load (CTL) and recovery-related data to get a broader picture of your recent training. Recognizing Progress and Making Adjustments Progress with polarized training isn’t only about getting faster. Other signs include better control during low-intensity runs, consistent output during high-intensity workouts, and less lingering fatigue that affects the sessions that follow. Low-intensity runs regularly drift into moderate intensity: Slow down, choose a flatter route if needed, or shorten the run so the effort stays within your target zone. Repeatedly struggle to complete high-intensity workouts as planned: Check whether you’ve had enough recovery beforehand. You may need to reduce the amount of high-intensity work or leave more time between demanding sessions. If your training is going smoothly, you can keep your current approach and track changes in performance under similar route and weather conditions over time. When you do need to adjust your plan, change the factor that appears to have the biggest impact first, then use your subsequent training data to see whether the adjustment is working. Takeaways The main lesson from polarized training is to put your limited energy where it matters most. A good training week isn’t just about how much you complete. It’s also about whether you can recover well enough to start the next week ready to train. When every workout has a clear purpose, it becomes easier to stay consistent and spot when something needs to change. Think of intensity distribution as a tool to guide your decisions, not a fixed target you have to hit. The right balance can change as your schedule, training background, and race goals change. What matters most is finding an approach that lets you keep building fitness, recover between workouts, and gradually move toward your goals. FAQ Is Polarized Training the Same as 80/20 Training? They’re closely related, but the emphasis differs. 80/20 training puts around 80% of your time at low intensity and 20% into quality work, which can include threshold sessions. Polarized training keeps moderate-intensity work to a minimum and puts most of that quality time into high-intensity efforts. Does Polarized Training Work for Cycling and Swimming? Yes, but the intensity zones and training sessions should be specific to each sport. Running heart rate zones shouldn’t be directly applied to cycling or swimming, and interval duration and recovery should be adjusted accordingly. Does Cross-Training Count Toward the 80/20 Split? Aerobic cross-training such as cycling and swimming can be included in your overall aerobic training distribution, as long as you use the same method for tracking all activities. Strength training isn’t included in the 80/20 split, but the fatigue it creates should still be factored into your recovery plan. Can Easy Runs Include Strides? Yes. You can add a few short strides to an easy run, gradually building speed and taking full recovery between each one. Because the fast efforts are brief, the overall run can still remain mostly low intensity. When tracking your intensity distribution, count the time spent in each zone based on the actual intensity of each effort.
October 05 2026
Suunto ZoneSense: Real-Time HRV Training Intensity Guide
You head out for an easy aerobic run, then find yourself picking up the pace without meaning to. Or you're ready for a solid tempo session but aren't sure what pace feels right today. In both cases, the question is the same: does your effort match the goal of the session? A familiar heart rate doesn't always mean your body is feeling the same. Suunto ZoneSense analyzes heart rate variability (HRV) during exercise to show how hard your body is really working. On an easy long run or during long intervals, you can use that real-time feedback on your wrist to adjust your effort as you go. Table of Contents Get to Know Suunto ZoneSense Understand Your Real-Time ZoneSense Feedback Get Started with ZoneSense Use ZoneSense in Training and Racing Three Habits for More Accurate Feedback Let ZoneSense Guide Your Next Workout Get to Know Suunto ZoneSense Suunto ZoneSense is a real-time exercise intensity monitoring technology developed jointly by Suunto and MoniCardi, a spin-off from Tampere University. It uses heart rate variability (HRV) to analyze how your heart responds to exercise, showing aerobic, anaerobic and VO₂ max intensity ranges in green, yellow and red. For runners, this helps you match training to how your body feels today. A pace that feels easy one day may take more effort the next. ZoneSense gives you another reference alongside heart rate zones, pace and how you feel, helping you decide whether to ease back or hold your rhythm. Understand Your Real-Time ZoneSense Feedback ZoneSense uses changes in the time between heartbeats to show how your body is responding to exercise. It turns complex physiological signals into colors and time-in-zone readings on your wrist. During a workout, you can check whether your effort matches what you set out to do. How Heartbeat Patterns Reveal Intensity Your heart doesn't beat at perfectly even intervals like a metronome. The time between one beat and the next varies slightly. This is heart rate variability, or HRV. As exercise intensity changes, the patterns in those intervals change too. ZoneSense uses Dynamical Detrended Fluctuation Analysis (DDFA) to analyze changes in beat-to-beat R-R intervals and identify signals linked to cardiac stress. It compares those changes with your personal aerobic baseline to assess your current intensity range, going beyond your heart rate at a single moment. You don't need a lab test before you start using ZoneSense. As you train, the system builds and updates your personal aerobic baseline. It then uses changes in your HRV relative to that baseline to assess your intensity. Regular, steady aerobic sessions at an easy effort help ZoneSense keep your baseline up to date, so its intensity feedback better reflects how your body is responding that day. What the ZoneSense Colors Mean On Suunto watches that support live ZoneSense, the ZoneSense SuuntoPlus sports app displays this feedback in three colors: green for aerobic intensity, yellow for anaerobic intensity and red for the VO₂ max intensity range. ZoneSense zone What the effort feels like DDFA reference Relative to your personal baseline Green: Aerobic intensity Below your aerobic threshold. The effort feels relatively easy and can be held steadily for longer periods. Above −0.2 Yellow: Anaerobic intensity Between your aerobic and anaerobic thresholds. Breathing deepens and the effort feels more demanding. Approximately −0.5 to −0.2 Red: VO₂ max intensity Above your anaerobic threshold. Breathing is heavy and the effort is usually hard to sustain for long. Below −0.5 ZoneSense keeps updating the intensity display as these patterns change, giving you a quick view of the stress your body is under while you train. How to Read ZoneSense During a Workout Raise your wrist to see your current intensity zone. Along with the color, you can check how long you've stayed in that zone and the total time spent in green, yellow and red throughout the workout. Use these readings to check your effort against the plan as you train, then review your time in each zone afterward. Start with 10 minutes of easy warming up. ZoneSense doesn't show intensity data for the first 10 minutes, and that period doesn't count toward your time in each zone. Your body is still adapting to exercise, and the system needs to gather data for that day's assessment. After the warm-up, use the feedback on your wrist to help guide your effort. Get Started with ZoneSense Once you know what the colors and time-in-zone readings mean, follow these steps to bring ZoneSense into your daily training. You'll need a Suunto sports watch that supports live ZoneSense, the Suunto app on your phone and a compatible chest strap heart rate belt that records beat-to-beat R-R interval data, such as Suunto Smart Heart Rate Belt 2. Check your watch's compatibility and update its software before you start. Connect your watch in the Suunto app, open the SuuntoPlus Store, then search for ZoneSense and save it to your watch. Select the ZoneSense sports app before your next workout, and it will stay selected for later sessions in the same sport mode. Put on your heart rate belt and pair it with your watch. Check that heart rate data is coming from the belt before you start recording. Warm up easily for 10 minutes, then check the ZoneSense screen to see your intensity. Use ZoneSense in Training and Racing Once ZoneSense is running, the next step is to check whether your intensity matches the session's goal. Easy runs, threshold sessions, long intervals and races each call for a different level of effort. These four scenarios show how you can use real-time feedback to find the right rhythm. Aerobic Endurance Runs: Keep Your Effort Easy and Steady Easy aerobic runs build the endurance base the rest of your training rests on, so the goal is to keep the effort relaxed from start to finish. After your 10-minute warm-up, aim to stay in green, which shows you're working below your aerobic threshold. If the reading moves into yellow, slow your pace, shorten your stride on the climbs or take a short walk break, then let it settle back into green. On longer runs, fatigue and heat can make the same pace cost more effort in the later stages, so keep checking ZoneSense through the second half and adjust before an easy run turns into a harder session than you planned. These steady sessions do double duty. They build your aerobic fitness and keep your personal ZoneSense baseline up to date, which makes the feedback more useful in your harder workouts. Threshold Training: Find a Comfortably Hard Rhythm A tempo run takes effort, but it should be an effort you can hold for the planned duration. After warming up, gradually increase your pace and watch ZoneSense move from green toward yellow. Entering yellow means you've crossed your aerobic threshold. If the session calls for staying in yellow, find a pace that feels hard but controlled, then keep it steady. If the reading drifts into red when the plan is to stay below your anaerobic threshold, ease back. After the workout, the Suunto app can also estimate your threshold heart rate when suitable data is available. Review several sessions to check the values are consistent before using a single result to change your heart rate zones. Long Intervals: Follow the Intensity of Each Repeat ZoneSense works best with longer intervals lasting more than three minutes. When you increase the intensity, your body needs time to respond. The reading usually needs around two to three minutes of steady effort to better reflect how hard you're working. For example, during a session of six seven-minute repeats, check the reading in the middle and later stages of each repeat. Use it alongside pace and how you feel to judge whether you're reaching the planned intensity Yellow or red may be appropriate, depending on the session's goal. Don't sprint off the line just to make the color change sooner. If a repeat ends while ZoneSense is still green, consider the goal, your pace and your breathing before deciding what it means. The color alone doesn't tell you whether the repeat was effective. Follow your planned recovery between repeats while watching how your body and the reading respond. For short intervals of around one minute or for sprints, use pace or power to guide your effort. ZoneSense has a delay, so it can't immediately reflect each short burst of speed. Race Day: Use Live Intensity to Adjust Your Pace It's easy to get pulled along by the runners around you at the start of a race. Set off at an effort you know from training. Once ZoneSense starts showing data, check the color alongside your pace and how you feel to see whether you're working harder than planned. If the reading moves into a higher range than expected early on, ease back a little and see how your body responds. Yellow or red doesn't automatically mean your pace is wrong. The right intensity depends on the race distance and your pacing plan. Get familiar with the feedback in training first. Learn how each zone feels and how long you can sustain the effort. That experience will make the data on your wrist more useful on race day. Three Habits for More Accurate Feedback Whether you're training or racing, useful ZoneSense feedback starts with a reliable aerobic baseline and accurate heartbeat data. Keep these three habits in mind: Include regular easy aerobic sessions. ZoneSense uses these steady, lower-intensity efforts to learn and update your personal DDFA baseline. Starting each workout with an easy warm-up also helps it assess your condition that day. Use a compatible heart rate belt. ZoneSense needs accurate beat-to-beat interval data. Wrist and arm optical heart rate sensors can't provide the data it needs during exercise. Even if your watch is showing a heart rate, check that the reading is coming from the belt. Choose your metrics to suit the workout. ZoneSense is useful for steady runs and long intervals. For short intervals and sprints, give priority to pace or power. Match the metric to the session's goal so you know what to look for. As you gain experience, you'll become more familiar with how each color feels, making it easier to adjust your effort in the next session. Let ZoneSense Guide Your Next Workout ZoneSense gives you another way to understand how your body responds to training. Use it alongside heart rate, pace and how you feel to judge when to hold your rhythm and when to ease back. On your next easy run, put on your heart rate belt and start with a 10-minute warm-up. Then let ZoneSense show you how hard you're working.
October 01 2026
Suunto Run vs Suunto Run 2: Key Differences Explained
Suunto Run and Suunto Run 2 are both lightweight running watches, built for everyday training, structured sessions and race day. Run 2 keeps the same focused design and adds a 2,000-nit AMOLED display, around 10 days of battery life, offline maps, new-generation GPS and wrist heart rate tracking, and EnergySense for real-time guidance on how long your current effort will last. Here is what changed from Suunto Run to Run 2, and what each difference means on the run. Table of Contents Suunto Run vs Run 2: Key differences at a glance 1. A brighter AMOLED display 2. Longer battery life 3. More storage and offline maps 4. Updated GPS and wrist heart rate tracking 5. EnergySense adds real-time endurance guidance Suunto Run or Run 2? Suunto Run vs Run 2: Key differences at a glance Feature Suunto Run Suunto Run 2 Display 1.32" AMOLED, 600 nits 1.32" AMOLED, up to 2,000 nits Size 46 × 46 × 11.5 mm 46 × 46 × 11.7 mm Case weight 32 g 35 g Battery capacity 295 mAh 380 mAh Daily use with 1 h outdoor exercise/day Up to 8 days Up to 10 days High-performance GPS Up to 20 hours Up to 24 hours Storage 4 GB 4 GB or 64 GB Offline music Yes Yes Offline maps No Yes GPS & wrist heart rate — Updated EnergySense No Yes On the wrist, Run 2 is almost identical to Run: the same 46 × 46 mm case, just 0.2 mm thicker, with a 35 g watch body. The real changes are in the display, battery, navigation, tracking and in-run guidance. 1. A brighter AMOLED display Both watches use a 1.32-inch AMOLED display, and Run 2 raises brightness from 600 to 2,000 nits. You will notice it most in bright sunlight, when a quick glance needs to show your pace, heart rate, distance or next interval clearly. And because the screen size is unchanged, the watch stays just as compact on your wrist. 2. Longer battery life Run 2 moves from 295 mAh to 380 mAh, which works out to 29 percent more battery capacity. Battery Suunto Run Suunto Run 2 Daily use with 1 h outdoor exercise/day Up to 8 days Up to 10 days High-performance GPS Up to 20 h Up to 24 h In daily use with an hour of outdoor training a day, that takes you from around 8 days to around 10 days, and high-performance GPS recording rises from 20 to 24 hours. That is enough to cover a full training week on one charge, with extra margin for long runs and race day. 3. More storage and offline maps Suunto Run comes with 4 GB of storage for offline music. Run 2 comes in 4 GB and 64 GB versions. If you want to carry a large music library alongside your downloaded maps, the 64 GB version gives you far more room. The bigger upgrade is offline maps. Download maps of your area to Run 2 before you head out, and you can see the roads, trails and terrain around you right on your wrist, even on a route you have never run. Suunto offline maps are free and available worldwide. That opens up running beyond the road. If you want to try trail running or explore new routes, Run 2 is ready for it, so one watch covers your everyday runs, your long runs and your weekend exploring. Both watches also play offline music through Bluetooth headphones, so you can leave your phone at home. 4. Updated GPS and wrist heart rate tracking Run 2 moves to new-generation dual-band GPS (L1 + L5) across five satellite systems: GPS, GLONASS, Galileo, BeiDou and QZSS. Your recorded track sits closer to your actual route, giving you pace and distance you can trust. Heart rate comes from a 12-channel optical sensor behind 2.5D curved sensor glass, giving you a steadier read on training intensity and a more reliable foundation for your training load and recovery data. You will feel the difference most in sessions where effort changes quickly, like intervals, progression runs and races. 5. EnergySense adds real-time endurance guidance Both watches include marathon-focused tools such as Marathon Mode and Ghost Runner to help you train and race to your pace targets. Run 2 adds EnergySense. Pace tells you how fast you are running and heart rate tells you how hard you are working. EnergySense tells you how long you can keep it up. As you run, it estimates your remaining endurance in real time and shows how your current intensity is drawing it down. It works with three key metrics: Endurance: A live estimate of how much endurance you have left. Sustain: With a distance target set, how much farther you could go at your current intensity. Remaining: How much distance is left to reach your target. Together, they put your pace in context. Say you are 30 km into a marathon and your pace feels good. If Sustain is comfortably ahead of Remaining, you have the margin to hold or even push. If the two start to close, it is time to ease off before the final kilometers cost you. You can also run EnergySense with no distance target set. It tracks your intensity and remaining endurance throughout, which makes it just as useful on long runs and in training as it is on race day. EnergySense launches on Run 2 as a beta feature and will keep improving through future updates. Suunto Run or Run 2? Both watches share the same lightweight, running-first foundation. Suunto Run covers the essentials of everyday training and race preparation. Run 2 is built for your next breakthrough, with a 2,000-nit display, around 10 days of battery life, offline maps, new-generation GPS and heart rate tracking, and EnergySense. If you want more navigation, more battery margin and real-time guidance when it counts, Run 2 is the one to choose.
September 28 2026
