Suunto Blog
Heart Rate Zones: How to Calculate and Train With Them
Heart rate zones turn a number on your wrist into something you can train by. In endurance sports like running and cycling, most systems split effort into five zones, Zone 1 through Zone 5, so you can see how hard you are actually working and choose the right intensity for the session in front of you. Zones are personal. They can be built from your maximum heart rate, your resting heart rate, or your lactate threshold heart rate, depending on the method behind them. That is also why the zones on one device can differ from the zones on another. At a Glance Heart rate zones turn effort into a scale you can train by, most commonly Zone 1 through Zone 5. Each zone serves a different purpose, from recovery and aerobic base work through to near-maximal efforts. Zones can be set from maximum heart rate, heart rate reserve, or lactate threshold heart rate, and each method draws different boundaries. Devices show different zones because they use different methods, different settings, and different ways of measuring heart rate. Check your zones against your breathing, your perceived effort, and how long you can hold each intensity. What Are Heart Rate Zones? A heart rate zone is a range of intensity defined by your heart rate in beats per minute (BPM). The five-zone model is the most widely used, running from Zone 1 up to Zone 5 as effort climbs from easy movement toward near-maximal work. Three-zone and four-zone models also exist, built on different thresholds for different training purposes. Heart rate, breathing, and overall physiological stress all climb together as intensity rises. That is what makes zones useful for more than a snapshot of effort. They tell you whether the intensity you are holding actually matches the purpose of the session. What Do the Different Heart Rate Zones Mean? The five-zone model splits heart rate into Zone 1 through Zone 5. Each zone sits at a different level of intensity and does a different job in your training. Here is what each one feels like and where it is normally used. Zone 1: Recovery and Low-Intensity Training Zone 1 is typically used for warm-ups, cool-downs, and recovery sessions. Breathing should feel very easy, and the overall training load is low, making it possible to keep moving for a long time without much strain. For example, after a high-intensity interval workout, easy movement in Zone 1 can help you gradually recover without adding much additional training stress. Zone 2: Aerobic Endurance Training Zone 2 is a common low-intensity zone for endurance training. The effort feels relatively easy, with steady breathing that you can maintain for an extended period. It’s often used for easy runs, long runs, and other aerobic base training. Over time, this type of training helps your body adapt to sustained exercise and improve its ability to maintain aerobic effort for longer periods. Zone 3: Tempo and Steady-State Training Zone 3 is more demanding than easy aerobic training. Your breathing becomes noticeably faster, but you can generally maintain a steady effort for a reasonable amount of time. Zone 3 can be used for steady-state runs, sustained moderate-intensity workouts, and some easier tempo runs. For runners, this type of training can help build the ability to maintain a faster pace for longer. Zone 4: High-Intensity Training Around Lactate Threshold Zone 4 generally represents a high level of training intensity and, in some heart rate zone models, includes intensities around the lactate threshold. Breathing becomes noticeably harder, and the effort is no longer as easy to sustain as Zone 2. However, you can still train in this zone through sustained runs or longer intervals. Zone 4 is commonly used for threshold workouts, higher-intensity tempo runs, and longer intervals to help runners improve their ability to maintain performance at high intensities. Zone 5: High-Intensity and Near-Maximal Effort Zone 5 generally corresponds to exercise intensity close to your maximum heart rate. Breathing is very heavy, and the effort can only be maintained for a relatively short period. It’s commonly used for VO₂ max intervals, short high-intensity repeats, and some sprint workouts. These sessions provide a strong cardiovascular and high-intensity stimulus, but they also place a greater amount of stress on the body, so adequate recovery is especially important. How Are Heart Rate Zones Calculated? There are several ways to calculate heart rate zones. The most common methods use Maximum Heart Rate (Max HR), Heart Rate Reserve (HRR), or Lactate Threshold Heart Rate (LTHR) as the basis for setting your zones. % Maximum Heart Rate The maximum heart rate method is one of the simplest ways to calculate heart rate zones. It uses a percentage of your maximum heart rate to define each training zone. Your maximum heart rate can be estimated using an age-based formula, such as the familiar “220 − age,” or determined through maximal-effort exercise testing, field testing, or laboratory testing. Age-based formulas are convenient, but individual differences can be significant, so the result may not accurately reflect your actual maximum heart rate. In a common five-zone model, the following percentages of maximum heart rate can be used as a general guide: Heart Rate Zone % Maximum Heart Rate Zone 1 Approx. 50–60% Zone 2 Approx. 60–70% Zone 3 Approx. 70–80% Zone 4 Approx. 80–90% Zone 5 Approx. 90–100% For a deeper look at maximum and resting heart rate, see Know Your Max and Resting Heart Rate. % Heart Rate Reserve The Heart Rate Reserve (HRR) method takes both maximum heart rate and resting heart rate into account, making it more personalized than simply using a percentage of maximum heart rate. However, the accuracy of the resulting zones still depends on having reliable maximum and resting heart rate values. First, calculate your heart rate reserve: HRR = Maximum Heart Rate − Resting Heart Rate Source: American Society for Preventive Cardiology Clinical Practice Statement You can then use the Karvonen method to calculate your target heart rate: Target Heart Rate (THR) = Resting Heart Rate + (% Intensity × HRR) Source: University of Minnesota For example, if your maximum heart rate is 190 BPM and your resting heart rate is 50 BPM, your heart rate reserve is 140 BPM. At 70% intensity, your target heart rate would be: 50 + (0.7 × 140) = 148 BPM % Lactate Threshold Heart Rate The Lactate Threshold Heart Rate (LTHR) method uses the heart rate associated with your lactate threshold as the reference for setting training zones. Lactate threshold can be thought of as a key point where, as exercise intensity increases, blood lactate begins to accumulate at a faster rate. It provides an indication of how well your body can sustain higher exercise intensities. The most direct approach is a graded exercise test in a laboratory, where blood lactate is measured at different exercise intensities and the lactate threshold is identified from the resulting curve. You can also estimate LTHR through structured field tests, such as a 30-minute Time Trial. One advantage of using LTHR to set heart rate zones is that it ties training intensity more closely to your individual threshold performance. However, the exact testing protocol and zone boundaries can vary depending on the training system being used. Why Are My Heart Rate Zones Different on Different Devices? If your heart rate zones look different across watches, apps, or training platforms, it does not necessarily mean one of them is wrong. The differences usually come down to three things: how the zones are calculated, the personal data used in the calculation, and how heart rate is measured. Different calculation methods and zone boundaries: One device may work from maximum heart rate, another from heart rate reserve or lactate threshold heart rate. Even on the same method, boundaries and algorithms differ. Some systems use three-zone or four-zone models built on physiological thresholds such as lactate threshold or ventilatory threshold, so both the number of zones and their edges can change from device to device. Inaccurate maximum or resting heart rate settings: If either value is set incorrectly on your device, every zone it calculates inherits that error. Different heart rate measurement methods: Wrist-based optical sensors estimate heart rate from changes in blood flow under the skin, while chest straps read the electrical signals produced by your heart. When intensity changes quickly, the two respond at different speeds, so the reading at any given moment can differ slightly, and so can the zone your device shows. In short, the first two factors move the boundaries of your zones. The third moves the heart rate that gets recorded against them. How to Know If Your Heart Rate Zones Are Right You can’t tell whether your heart rate zones are accurate by looking at the numbers on your watch alone. It’s also important to consider how you actually feel and perform during your workouts. Pay Attention to Breathing and Perceived Effort If your device shows that you’re in Zone 2 but you’re already struggling to catch your breath, your zone settings may need a second look. Likewise, if a workout classified as high-intensity Zone 4 feels easy from start to finish, your heart rate zones may not be aligned with your actual effort. If you want a better understanding of how your intensity changes during a workout, Suunto ZoneSense uses heart rate data to identify changes in exercise intensity, helping you see whether your actual effort matches the heart rate zone you’re targeting. Combine Heart Rate with Pace or Power If you can maintain the same pace at a lower heart rate over time, or run faster at the same heart rate, it generally indicates that your aerobic fitness is improving. Using a Suunto sports watch to track heart rate, pace, and training history can help you monitor these changes over time. During workouts, pairing it with a heart rate belt can also provide more responsive and consistent heart rate data. Otherwise, heart rate does not respond instantly to changes in exercise intensity. During short intervals lasting only a few dozen seconds, your effort may already be very high even though your heart rate has not yet reached Zone 5. For short intervals, heart rate alone may not tell the whole story, so it’s best to consider pace, power, and perceived effort together. Use Workout Duration as a Guide Lower-intensity zones like Zone 1 and Zone 2 should generally be sustainable for longer periods, while Zone 4 and Zone 5 are typically much harder to maintain for extended periods. If how a zone feels and how long you can sustain it consistently differ significantly from what the zone is supposed to represent, it may be worth taking another look at your maximum heart rate, resting heart rate, lactate threshold heart rate, and the zone model your device uses. Takeaways Heart rate zones are a moving target. As your fitness, maximum heart rate, resting heart rate, and lactate threshold shift, the zones built on them need revisiting too. Read them alongside training load, pace, power, and perceived effort, and heart rate stops being a number you glance at and becomes a tool you train with.
August 31 2026
Yao Miao — A More Professional Approach
Yao Miao has always known how to run. But becoming a better athlete isn't simply about running more. Over the past year, she has changed the way she trains — moving from relying on instinct and experience to building a more structured, professional approach. “Only through competition can you find a stronger version of yourself.” A More Complete System Today, Yao's training goes beyond running. With support from her coach and specialists in strength, nutrition and recovery, every part of her preparation has a purpose — from building strength and climbing ability to improving her speed and technical descents. The goal isn't simply to train harder. It's to train better. From Pace to Heart Rate When Yao first started training, she mainly focused on pace and distance. Today, heart rate has become a much more important part of her training strategy. Her training plans and race strategies are built around heart rate, helping her understand how hard she is actually working and how to manage her effort. For Yao, relying only on how her body feels isn't always accurate. The data gives her another layer of feedback — helping her control her pace, manage her effort and make better decisions throughout training and racing. Her Suunto watch puts that information on her wrist, turning every session into a clearer picture of how her body is responding. The data informs the strategy. Yao makes the decisions. Stronger Through Competition For Yao, racing is more than a test. It's a way to discover what she can improve. Every competitor, every difficult section and every race reveals another opportunity to become stronger. Her love for running hasn't changed. What changed? The way she trains to become better.
August 26 2026
Toni McCann’s Road Back to Chamonix
Toni McCann knows Chamonix well. She won the UTMB OCC in 2023, then stepped up to the UTMB CCC in 2024 and took the win. After not finishing the race in 2025, Toni is returning to the UTMB CCC in 2026 — but with a different mindset. “Just run for me, instead of running for other expectations.” For Toni, the past year has been about stepping away from the pressure of results and reconnecting with why she runs in the first place. A different approach Success can bring expectations. After winning in Chamonix, the pressure to perform can become part of the race itself. This time, Toni is focusing on her own process — enjoying the training, trusting her preparation and taking on the challenge on her own terms. Her preparation combines running, strength work, cycling, recovery and time in the mountains. Rather than focusing only on performance, she is also learning to listen to her body, knowing when to push and when to recover. Training and racing with Suunto Her Suunto Race 2 is part of that process, helping her understand both her body and the course. With HRV-based recovery insights, Toni can monitor how well her body is recovering and make more informed decisions about her training. Combined with heart rate and Climb Guidance, Suunto helps her prepare for the physical and mental demands of the UTMB CCC. The technology provides the information. Toni makes the decisions. Back to Chamonix The CCC course hasn’t changed. But Toni’s relationship with it has. This time, there is less pressure to prove and more freedom to run — on her own terms, for herself. What changed? The reason she runs.
August 26 2026
Suunto 90 Segment Challenge
Take on the climb. Earn the rewards. Take on the Suunto 90 Segment Challenge in Chamonix during the UTMB World Series Finals. Set on a section of the iconic Chamonix Vertical Kilometre course, this short, steep climb below the Brévent lift puts your legs to the test. JOIN ON STRAVA NOW Its 90-metre ascent is a nod to Suunto’s 90th anniversary and a taste of one of Chamonix’s iconic vertical challenges. It’s short enough to take on even when you’re saving your legs for the week’s races. Complete the segment and you’ll unlock a 15% discount at suunto.com and a chance to win a Suunto Race 2. And there’s more. From Monday to Thursday, August 24–27, the first 10 people each day to complete the segment and visit the Suunto booth at the Ultra-Trail Village will receive a Suunto gift. Be there early! HOW IT WORKS 1. Join the ChallengeJoin the Suunto 90 Segment Challenge on Strava. 2. Take on the segmentRun or hike the segment, record your effort and sync it to Strava. 3. Claim your rewardsAfter completing the Challenge, claim your reward to receive the Challenge badge, your 15% discount at suunto.com and a chance to win a Suunto Race 2. 4. Get your Suunto giftComplete the segment on August 24–27 and be among the first 10 people each day to visit the Suunto booth at the Ultra-Trail Village to claim a surprise Suunto gift. CHASE SEGMENTS. SEE YOUR PERFORMANCE. Want to know exactly how you’re doing while chasing a Strava Segment? With SuuntoPlus Segments, you can see your segment performance in real time right on your wrist, helping you pace your effort and push for your best. Learn more about chasing Strava Segments with Suunto Terms and conditions apply. Learn more here.
August 26 2026
Ida-Sophie Hegemann — Outside the Comfort Zone
Ida-Sophie Hegemann knows what it takes to adapt. From track running in flat northern Germany to living in Innsbruck, she has built her life around mountain trails. After last year’s finals, Ida realized that staying in her comfort zone was no longer enough—and to elevate her performance for Chamonix, everything had to change. “Are you really stepping out of your comfort zone when you’re writing your own training schedule?” For Ida, the past year has been about surrendering total control, embracing professional structure, and seeking out the discomfort needed to grow. Choosing Discomfort Self-coaching brought Ida far, but pushing to the highest level required external challenge. This time, Ida is trusting a new team—working with a new coach, a mental coach, and professional management to push her limits beyond what she would set for herself. Her preparation means embracing severe suffering: higher volume, weighted vest workouts, steep road repeats outside her home, and relentlessly targeting her biggest weakness—technical downhills—until it became a strength. Proof of Progress Suunto watch is an essential part of tracking that evolution. By analyzing her Suunto training logs, Ida compares current sessions against past years—seeing clear proof of higher elevation gains, faster speeds, and measurable progress. The data confirms the work is paying off when the training gets tough. From track running in flat northern Germany to living in Innsbruck, she has built her life around mountain trails. After last year’s finals, Ida realized that staying in her comfort zone was no longer enough—and to elevate her performance for Chamonix, everything had to change. Technology tracks growth. Ida delivers the performance. Ready for What’s Next The UTMB course hasn’t changed. But Ida’s preparation for it has. This time, she arrives with technical downhill confidence, a sharper mindset, and the strength of a fully professional system behind her. What changed? The depth of her preparation.
August 26 2026
Zone 2 Training for Runners: How to Find Your Zone 2
Zone 2 Training for Runners: How to Find Your Zone 2?
For endurance sports such as marathon and trail running, getting faster isn't simply about training harder. Long-duration performance depends on your body's ability to sustain energy production, handle training volume, and maintain a steady output over time. Through low-intensity, sustained aerobic work, Zone 2 training helps build this foundation. This article explains how to find your Zone 2, understand the principles behind it, and incorporate it effectively into your training plan. At a glance Zone 2 is a low-intensity aerobic training zone. Its primary value lies in building a strong aerobic foundation. There is no single method for finding your individual Zone 2. Zone 2 should be part of a complete training plan, not the entire plan. The benefits of Zone 2 are primarily seen through long-term changes. Consistency matters more than short-term intensity. What Is Zone 2 Training? Zone 2 is a training intensity zone defined by heart rate. In the commonly used five-zone heart rate model, training intensity is divided into different zones based on an individual's heart rate data, with Zone 2 representing a low-intensity aerobic zone. Different training systems may use data such as maximum heart rate (HR max) or lactate threshold to determine these zones. What Should Zone 2 Feel Like? In practice, heart rate isn't the only way to gauge intensity. Your perceived effort can also help you identify whether you're in Zone 2: Comfortable conversation without catching your breath Heavier breathing, but still manageable Finishing the workout with plenty left in the tank Why Does Zone 2 Feel So Slow at First? When many runners first start Zone 2 training, their pace drops noticeably, and they may even need to use a run-walk approach. Early in training, aerobic efficiency and the ability to use fat for fuel are not yet fully developed. At higher paces, the body relies more heavily on glycogen, causing heart rate to rise quickly. With consistent training, you'll gradually notice improvements such as running faster at the same heart rate and experiencing less fatigue after long runs. Why Zone 2 Training Matters for Running The value of Zone 2 training lies in the adaptations it supports across several key aspects of endurance performance, including improving aerobic capacity, increasing sustainable training volume, and supporting higher-intensity training. Build a Strong Aerobic Foundation The primary role of Zone 2 training is to gradually improve the body's ability to produce energy aerobically over time. During low-intensity, sustained exercise, the body continuously relies on oxygen to produce energy. With consistent training, the muscles gradually adapt, including an increased capacity for fat oxidation, allowing the body to use fat more effectively as a fuel source during prolonged exercise. In simple terms, the body becomes more efficient at sustaining the same level of exercise. Increase Training Volume with Less Fatigue Endurance gains depend not only on the stimulus from individual workouts, but also on how much effective training you can consistently complete over time. Compared with high-intensity training, Zone 2 places less stress on the muscles and metabolic systems, which generally means a shorter recovery time. This allows runners to gradually increase training frequency and volume without continually accumulating excessive fatigue. Over time, greater training consistency means more opportunities for the body to adapt, leading to continued training improvements. How to Find Your Zone 2 Heart Rate Zone 2 is not a fixed heart rate number. It can vary depending on factors such as maximum heart rate, lactate threshold, aerobic fitness, and training level. Runners can therefore use different methods to find the Zone 2 range that works best for them. Traditional Calculation Traditional calculation is one of the most common starting points and typically estimates Zone 2 based on maximum heart rate. Zone 2 is generally around 60–70% of maximum heart rate, but because maximum heart rate varies between individuals, age-based formulas are best used as an initial reference. Lactate Testing One of the more accurate ways to determine Zone 2 is to identify your lactate threshold (LT). Lactate threshold represents the point at which the body transitions from a relatively stable aerobic state to a state where blood lactate begins to accumulate more rapidly. The most direct approach is laboratory lactate testing, which measures changes in blood lactate during an incremental exercise test and uses the resulting lactate curve to determine LT. For recreational runners, lactate threshold can also be estimated using indirect tests such as the 30-minute Time Trial, VDOT, and Conconi Test. These methods do not directly measure lactate, but instead indirectly estimate LT using factors such as heart rate, pace, or performance. Once LT is established, you can determine the corresponding lactate threshold heart rate (LTHR). Depending on the training zone model being used, LTHR can then serve as a reference for defining heart rate zones and determining your Zone 2 range. Heart Rate Drift Test The Heart Rate Drift Test is more practical for everyday training. During a sustained low-intensity run, keep your pace relatively steady and observe how your heart rate changes in the second half. If heart rate remains relatively stable, the intensity is generally within a suitable aerobic range. This method requires no laboratory testing, but can be affected by factors such as weather, fatigue, and hydration. Talk Test and Perceived Effort The Talk Test is one of the simplest ways to gauge intensity based on perceived effort. Zone 2 generally feels like an intensity where you can speak in full sentences and carry on a simple, natural conversation. Using Suunto Products Suunto products can make heart rate training easier to apply in practice. Suunto can automatically set default heart rate zones based on maximum heart rate, while on Suunto Run, runners can choose between maximum heart rate, heart rate reserve, and lactate threshold heart rate zone models. You can also customize your heart rate zones to better match your training needs, while Suunto App lets you track long-term changes in heart rate, training load, and recovery to better understand your Zone 2 progress. How to Use Zone 2 Training in Your Running Plan After learning about Zone 2, many runners may wonder: “Should all my training be Zone 2 from now on?” The answer is no. Zone 2 is the foundation of endurance training, but it is not the whole picture. The 80/20 Training Principle Many endurance athletes follow a roughly 80/20 approach, with around 80% of training performed at low intensity (Zone 1–2) and 20% at higher intensities. This structure allows runners to build their aerobic base while maintaining enough high-intensity stimulus to develop speed and race performance. Balance Weekly Training Volume In your training plan, gradually building endurance often means increasing training frequency rather than simply making individual workouts harder. A Rest/ Deload Week every 3–4 weeks can also help reduce accumulated fatigue by temporarily lowering training volume. By balancing training volume with adequate recovery, you can better manage your weekly workload and avoid increasing your training load too quickly. Adjust Zone 2 Intensity Based on Conditions Zone 2 training does not mean maintaining the same pace in every session. Heat, humidity, poor sleep, fatigue, dehydration, and low energy availability can all cause heart rate to rise. Rather than pushing harder to maintain your usual pace, adjust your intensity based on how you feel that day. During longer sessions, make sure to replenish fluids, carbohydrates, and electrolytes to maintain training quality. Use Run-Walk Strategies When Needed For trail runners, keeping the intensity in Zone 2 is generally more challenging than road running. In environments like steep climbs, high altitude, and technical terrain, heart rate can quickly rise. In these situations, slow down or even switch to brisk walking to keep your heart rate within the target zone. As long as the intensity is appropriate, walking can still provide an effective Zone 2 workout. How to Know Your Zone 2 Training Is Working The benefits of Zone 2 training usually do not appear as quickly as the effects of a single high-intensity workout. Instead, they are reflected in gradual improvements in efficiency over time. Runners can look for several signs that their Zone 2 training is working: Heart Rate and Pace Improvements One of the clearest signs of progress is running faster at the same heart rate, or maintaining the same pace at a lower heart rate. These changes indicate that your body is becoming more efficient at handling the same exercise load and that your aerobic efficiency is improving. Better Recovery and Training Consistency The value of Zone 2 is not only reflected in individual runs, but also in your ability to handle training load over time. As your aerobic base improves, you may find that you recover faster after long runs and feel less fatigued the following day. For Suunto users, training load, recovery status, and long-term heart rate trends can help you track how your body is adapting to training. Learn more about Recovery here. When Will You See Results? The benefits of Zone 2 training take time to build rather than appearing overnight. Some runners may notice that running feels easier and their heart rate is more stable within a few weeks, while 2–3 months of consistent training may bring more noticeable changes in pace and long-distance endurance. More significant improvements in endurance typically take several months or longer, making Zone 2 a long-term training approach. TAKEAWAY The value of Zone 2 lies not in deliberately slowing down, but in using consistent training over time to build a stronger aerobic system and greater training capacity. For marathon and trail runners, consistent accumulation matters more than pushing to the limit every time, helping create a stronger foundation for running faster, farther, and more consistently. Next time you run, pay a little less attention to your pace and a little more attention to whether your body is becoming more efficient and more resilient. FAQS Can You Still Get Benefits from Zone 2 Training If You Have to Walk? Yes. For beginners, trail runners, and those training at high altitude, a run-walk approach can be an effective way to stay in Zone 2. The goal is to stimulate the aerobic system, not to maintain continuous running. As long as your heart rate and exercise intensity remain within the target range, brisk walking can still provide an effective Zone 2 workout. Are Zone 2 Heart Rate Zones the Same for Running and Cycling? Not necessarily. Cycling uses different muscle groups, involves less weight-bearing, and has different movement demands than running. For many people, maximum heart rate is also lower when cycling than when running. For this reason, it is best to determine your Zone 2 separately for running and cycling. Can Zone 2 Training Alone Help You Run a Faster Marathon? It can improve your aerobic foundation, but it is not a complete training plan. Zone 2 can help build endurance, increase training volume, and support recovery. However, marathon performance also requires other types of training, including: Marathon-pace training Threshold training Fueling strategy practice The best results come from combining different types of training rather than relying on Zone 2 alone.
August 26 2026
