Suunto 9 Peak Pro Software Updates
Enjoy the convenience of over the air software updates via Suunto app so that your Suunto Race always has the latest and greatest software.
Over the air software update
When an update is available and your watch is connected with Suunto app, the software update will be downloaded to the watch automatically.
Once the software is downloaded to your watch, the watch will update itself during the night as long as the battery level is at least 50%.
If you want to install the update manually before it happens automatically during the night, navigate to Settings > General and select Software update.
Over the past four years, Suunto 9 Peak Pro has received a wide range of new features, enhancements, and software updates.
Today, Suunto 9 Peak Pro remains a feature‑rich, proven, and trusted companion for athletes and adventurers around the world.
Going forward, no additional feature updates or software updates are planned for Suunto 9 Peak Pro. This ensures the device continues providing the stable, reliable performance you depend on.
You don’t need to do anything. Your Suunto 9 Peak Pro will continue to perform exactly as it does today, ready for the adventures ahead.
Your experience continues to grow through the Suunto app, where you can download new watch faces and sport apps for your Suunto 9 Peak Pro.
Release notes
2.50.28
Staged update starting on January 28th 2026
This update brings bug fixes.
Bug fixes:
  • Fixed a bug that disabled structured workouts in pool swimming
  • Fixed a bug that disabled SuuntoPlus guides in custom made sport modes
2.50.26
Staged update starting on January 7th 2026
This update brings new features, improvements and bug fixes.
New features:
  • Connected sensors can be enabled/disabled per sport mode
  • Sensor services can be selected separately in sport mode
  • New default sport modes for duathlon, swimrun and aquathlon
  • New data fields: Instant, avg and lap NGP, Peak power, Peak pace & speed and ascent/descent to next waypoint
  • ZoneSense adjustable as target to follow in sport mode
  • ZoneSense zone distribution shown in log summary
  • Automatic transitions in triathlon sport mode
  • Automatic transitions in swimrun sport mode
  • Circular transition between sports in predefined multisport modes
  • New map orientation selection for north/heading
  • In-store demo mode for events and demo purposes
Improvements:
  • Sport mode options remembered better
  • New paired sensors automatically enabled in compatible sport modes
  • Improved pool swimming accuracy
  • Smoother transition between menus
  • Improved altimeter stability
  • Improved ascent and descent calculation accuracy
  • Several bug fixes and performance improvements
2.48.16
Staged update starting on November 10th 2025
New features:
  • New improved morning report
  • New notification for treadmill calibration
  • All apps selection added to widget list
Improvements and bug fixes:
  • Button lock problem fixed
  • Battery drain problem fixed
2.44.52
Staged update starting on September 25th 2025
This update brings improvements and bug fixes.
New features:
  • Support for pairing multiple sensors of same type. Sensors will need to paired again.
  • Showing sensor information, like battery level and name
  • New recovery state widget to summarize your recovery
  • ZoneSense intensity target setting in sport mode
  • Improved Climb guidance user interface and zoom enabled between waypoints
  • Passcode feature for securing the watch when off wrist
  • Improved swim style detection in pool swimming
  • Notifications show longer content than before when used with iOS
  • Bike sensor wheel size adjustment added
  • Sleep tracking accuracy improved
  • ZoneSense zone indicator fixed
  • Some crash root causes fixed
2.43.12
Staged update starting on June 26th 2025
  • Outdoor track running mode with lane selection for 400m track and custom track lengths 200m - 400m
  • A wide range of new data fields possible to add in sport mode customization
    • ZoneSense duration in aerobic
    • ZoneSense duration in an-aerobic
    • ZoneSense duration in VO2Max
    • Previous lap duration
    • Previous lap avg pace
    • Previous lap avg HR
    • Previous lap avg power
    • Current activity avg pace (in multisport)
    • Current activity avg power (in multisport)
    • Lap ascent duration
    • Lap descent duration
    • Descent duration
    • Ascent duration
    • Moving time
    • Total time
    • Rest time
    • Pause time
    • Swim rest time
    • Average rowing pace
    • Forecasted teperature
    • Forcasted wind
    • Compass heading
    • Current HR zone
    • Current power zone
    • Current pace zone
    • Battery hours
    • Battery percent
    • GPS signal strength
2.40.44
Staged update starting on May 14th 2025.
  • Watch face settings are not reset when watch face is updated in SuuntoPlus store
2.40.38
Staged update starting on March 25th 2025.
  • Treadmill calibration is not anymore affected by outdoor runs
  • Pool swim distance accuracy improved further
  • Daily HR and sleep tracking problems solved
  • WiFi connection stability improved
  • Support for new watch face types
  • Map download speed improved
  • Improved turn-by-turn notification logic
  • Map screen visible during pause
  • 22 New sports introduced. Now more than 100 sports to track with the watch:
    Backcountry skiing, Biathlon, Calisthenics, Chores, Classic skiing, Cyclocross, E-Biking, E-MTB, Field hockey, Futsal, Hand cycling, Meditation, Parkour, Pilates, Skate skiing, Skateboarding, Ski mountaineering, Split boarding, Track running, Vertical Running, Wheelchair sport, Yoga
2.39.34
Staged update starting on January 6th 2025
Temporary downgrade from previous software in order to fix a critical problem caused by the last update. This software is essentially same release as 2.37.48.
2.39.20
Staged update starting on December 16th 2024
New features:
  • Support for the new holiday watch faces in SuuntoPlus store
  • Added support for automatic compass calibration
  • Added a button lock option in the control panel
  • Visual appearance of watch menus improved
  • Outdoor distance accuracy improved with new GNSS firmware
  • Daily HR and sleep tracking problems fixed
  • SuuntoPlus sport Apps display device connection status
  • Several bug fixes and stability improvements
2.37.48
Staged update starting on October 2nd 2024
This update brings following bug fixes:
  • Fixed cases where sleep tracking and OHR stopped working
  • Fixed a case where pool swim distance was wrong in logbook
  • Fixed a case where power consumption remained high after navigation
2.37.34
Staged update starting on September 4th 2024
New features:
  • Watchfaces are now transferred to SuuntoPlus store
  • After the update the watch has only one watch face and new watchfaces can be added to your watch from the SuuntoPlus store in Suunto app
  • Exercise start panel streamlined and made faster
  • Improved capability to determine VO2Max
  • Improvements to Climb Guidance functionality
  • Several cosmetic improvements to menus and watch faces
  • Some language translation corrections
2.35.34
Staged update starting on July 3rd 2024
New features:
  • Climb guidance feature during navigation for routes with elevation data
  • Possibility to select watch face complications
  • Three new watch faces
  • Cumulative data fields as watch face complications
  • Second configurable short cut
  • Screen lock in watch mode
  • Data field on navigation screen
  • Sport mode specific display settings
  • Browse back one screen in sport mode using long press middle button
  • New pause and exercise end user interface with possibility to browse screens
  • Vietnamese language support
  • Improved Emoji support with more characters
  • Improved step counter to avoid misdetection from general hand movements
  • Faster UI browsing
  • New GNSS and OHR software
2.33.16
Staged update starting on May 21st 2024
  • Fixed bug that caused the mobile sync to fail
  • Fixed a problem with SuuntoPlus structured workout guides
2.33.14
Staged update starting on April 23nd 2024
  • Fixed bug that caused device to go blank in charger
  • Fixed a problem with SuuntoPlus device communication
2.33.12
Staged update starting on March 25th 2024.
New features:
  • Log pause resume reminder when starting to move
  • First version of emoji support in mobile notifications
  • Improved training zone data sync perfromance
  • Suunto app sync speed improved
  • Running race estimate problems fixed
2.30.38
Staged update starting on December 18th 2023.
Improvement and bugs fixed:
  • Several improvements to general stability
  • Fixed missing weather icon from the widget
  • Fixed lap button functionality in SuuntoPlus guides
  • Fixed log summary rendering problems in some cases
  • Fixed some sleep tracking and step counter problems
2.30.32
Staged update starting on November 30th 2023.
New features:
  • New intuitive UI structure with mini widgets and richer customization
  • New Training Zone widgets for Training (TSS), Progress (CTL) and Recovery (HRV and TSB)
  • HRV recovery measurement during sleep
  • Multiple clock alarms instead of one
  • Find my phone function
  • Stand up reminder
  • New SuuntoPlus sport apps in some default sport modes
  • Running race estimates for 5k, 10k, half marathon and marathon
Improvements:
  • Improved stability
  • New log summary screen layout
  • Improved notification icons
  • Improved media controls
  • Improved GNSS accuracy with updated GNSS firmware
2.27.8
Staged release starting from June 28th, 2023
New features:
  • Strava live segments on the watch
  • Support for two SuuntoPlus sport apps during session
  • SuuntoPlus sport apps remembered over sessions
  • Support for SuuntoPlus sport app settings
  • New weather widget for day weather forecast
  • Flashlight function in menu
  • Voice guidance through Suunto app
  • Thai and Traditional Chinese languages enabled in global edition
Improvements:
  • Backlight settings improvements
2.22.60
Staged release starting from November 29th, 2022
This update brings improvements to GPS performance in a watch.
Improvements:
  • Shorter time to find GPS signal
  • Improved positioning accuracy
  • Faster GPS re-acquisition after a signal loss
2.22.58
Release starting from October 25th, 2022
This update brings couple of new features as well as some bug fixes.
New features:
  • SuuntoPlusTM device connections support
  • Running power from the wrist
  • Snorkeling and Mermaiding sport modes
