Suunto Traverse Alpha
Download PDF
        SAFETY
      SAFETY
Types of safety precautions
            WARNING:
          - is used in connection with a procedure or situation that may result in serious injury or death.
            CAUTION:
          - is used in connection with a procedure or situation that will result in damage to the product.
          - is used to emphasize important information.
          - is used for extra tips on how to utilize the features and functions of the device.
Safety precautions
            WARNING:
          ALLERGIC REACTIONS OR SKIN IRRITATIONS MAY OCCUR WHEN PRODUCT IS IN CONTACT WITH SKIN, EVEN THOUGH OUR PRODUCTS COMPLY WITH INDUSTRY STANDARDS. IN SUCH EVENT, STOP USE IMMEDIATELY AND CONSULT A DOCTOR.
            WARNING:
          ALWAYS CONSULT YOUR DOCTOR BEFORE BEGINNING AN EXERCISE PROGRAM. OVEREXERTION MAY CAUSE SERIOUS INJURY.
            WARNING:
          ONLY FOR RECREATIONAL USE.
            WARNING:
          DO NOT ENTIRELY RELY ON THE GPS OR BATTERY LIFETIME, ALWAYS USE MAPS AND OTHER BACKUP MATERIAL TO ENSURE YOUR SAFETY.
            CAUTION:
          DO NOT APPLY SOLVENT OF ANY KIND TO THE PRODUCT, AS IT MAY DAMAGE THE SURFACE.
            CAUTION:
          DO NOT APPLY INSECT REPELLENT ON THE PRODUCT, AS IT MAY DAMAGE THE SURFACE.
            CAUTION:
          DO NOT THROW THE PRODUCT AWAY, BUT TREAT IT AS ELECTRONIC WASTE TO PRESERVE THE ENVIRONMENT.
            CAUTION:
          DO NOT KNOCK OR DROP THE DEVICE, AS IT MAY BE DAMAGED.
        At Suunto we use advanced sensors and algorithms to generate metrics that can help you in your activities and adventures. We strive to be as accurate as possible. However, none of the data our products and services collect is perfectly reliable, nor are the metrics they generate absolutely precise. Calories, heart rate, location, movement detection, shot recognition, physical stress indicators and other measurements may not match the real world. Suunto products and services are intended for recreational use only and are not meant for medical purposes of any kind.
        GETTING STARTED
      Using buttons
Suunto Traverse Alpha has five buttons which allow you to access all the features.
- press to access the start menu
- press to pause or resume a recording or timer
- press to increase a value or move up in the menu
- keep pressed to start recording or access a list of available modes
- keep pressed to stop and save a recording
- press to change displays
- press to enter/accept a setting
- keep pressed to access/exit the options menu
- press to activate the backlight
- press to decrease a value or move down in the menu
- keep pressed to activate flashlight
- press to deactivate flashlight
- press to return to the previous menu
- press to add a lap during a recording
- keep pressed to lock/unlock buttons
- press to access additional display views
- keep pressed to save POI
      When changing the values, you can increase the speed by keeping or pressed until the values start to scroll faster.
Set up
To start using your watch:
- Keep pressed to wake up the device.
- Press or to scroll to the desired language and press to select.
- Follow the startup wizard to complete initial settings. Set values with or and press to accept and go to the next step.
After completing the setup wizard, charge the watch with the supplied USB cable until the battery is fully charged.
          If a blinking battery symbol is displayed, Suunto Traverse Alpha needs to be charged before starting.
        If the battery dies, and you recharge the product, press and hold START to start the product
Adjusting settings
You can change the settings of your Suunto Traverse Alpha directly in the watch.
To change the settings in the watch:
- Keep pressed to enter the options menu.
- Scroll the menu with and .
- Press to enter a setting.
- Press and to adjust the setting values and confirm with .
- Press to return to the previous menu or keep pressed to exit.
        FEATURES
      Activity monitoring
Suunto Traverse Alpha measures your daily steps and estimates calories burned during the day based on your personal settings.
Your approximate daily step count is available as a default view in the time display. Press to change to the step counter view. The step count is updated every 60 seconds.
Daily step count and calories burned are displayed under DISPLAYS » Steps . The values are reset daily at midnight.
        Activity monitoring is based on your movement as measured by sensors in the watch. The values provided by activity monitoring are estimations and not intended for medical diagnostics of any kind.
Step history
Suunto Traverse Alpha provides a complete history of your step count. The step display shows your daily steps, as well as an overview of weekly, monthly and yearly trends. You can show/hide the step display from the start menu under DISPLAYS » Steps . When activated, you can view your step history by pressing to scroll through active displays.
           While in the steps display, you can press
          to see your 7-day, 30-day and yearly trends.
Alti-Baro
Suunto Traverse Alpha continuously measures absolute air pressure using the built-in pressure sensor. Based on this measurement and reference values, it calculates altitude or sea level air pressure.
Three profiles are available: Automatic , Altimeter and Barometer . For information on setting profiles, see Matching profile to activity.
To view alti-baro information, press while in the time display or activate the alti-baro display from the display menu.
You can change to different views by pressing .
In altimeter profile, you can see:
- altitude + temperature
- altitude + sunrise/sunset
- altitude + reference point
- 12h altitude graph + altitude
In barometer profile, you get the corresponding views:
- barometric pressure + temperature
- barometric pressure + sunrise/sunset
- barometric pressure + reference point
- 24h barometric pressure graph + barometric pressure
Sunrise and sunset time views are available when GPS has been activated. If GPS is not active, sunrise and sunset times are based on the last recorded GPS data.
You can show/hide the alti-baro display under the start menu.
To hide the alti-baro display:
- While in the time display, press .
- Scroll to DISPLAYS with and press .
- Scroll to End Alti-Baro and press .
- Keep pressed to exit.
Repeat the procedure and select Alti-Baro to show the display again.
        If you are wearing your Suunto Traverse Alpha on your wrist, you will need to take it off in order to get an accurate temperature reading because your body temperature will affect the initial reading.
Getting correct readings
If your outdoor activity requires accurate sea level air pressure or altitude, you need to calibrate your Suunto Traverse Alpha by entering either your current altitude or the current sea level air pressure.
        Absolute air pressure and known altitude reference = sea level air pressure. Absolute air pressure and known sea level air pressure = altitude.
The altitude of your location can be found from most topographic maps or Google Earth. A sea level air pressure reference for your location can be found using the websites of national weather services.
          CAUTION:
        Keep the area around the sensor free of dirt and sand. Never insert any objects into the sensor openings.
If FusedAlti is activated, the altitude reading is corrected automatically using FusedAlti together with altitude and sea level pressure calibration. For more information, see FusedAlti.
Changes in local weather conditions affect altitude readings. If local weather changes often, it is advisable to reset the current altitude reference value frequently, preferably before starting your journey when the reference values are available. As long as the local weather stays stable, you do not need to set reference values.
To set the sea level pressure and altitude reference values:
- Scroll to ALTI-BARO with and enter with .
- Press to enter Reference . The following setting options are available:
- FusedAlti: GPS is switched on and the watch starts calculating altitude based on FusedAlti.
- Altitude : Set your altitude manually.
- Sea level pressure : Set the sea level pressure reference value manually.
- Set the reference value using and . Accept the setting with .
        When not recording an activity, press in the alti-baro display to get directly to the ALTI-BARO menu.
Use example: Setting the altitude reference value
You’re on the second day of your two-day hike. You realize that you forgot to switch from the barometer profile to the altimeter profile when you started in the morning.You know that the current altitude readings of your Suunto Traverse Alpha are wrong.
So, you hike to the nearest location shown on your topographic map for which an altitude reference value is provided. You correct your Suunto Traverse Alpha altitude reference value accordingly and switch to the altimeter profile. Your altitude readings are correct again.
The altimeter profile should be selected when your outdoor activity involves changes in altitude (such as hiking in the mountains).
The barometer profile should be selected when your outdoor activity does not involve changes in altitude (such as canoeing).
To get correct readings, you need to match the profile to your activity. You can either let Suunto Traverse Alpha decide a suitable profile for the activity using the automatic profile, or choose a profile yourself.
To set the alti-baro profile:
- Scroll to Profile with and enter with .
- Change the profile with or and confirm your selection with .
Incorrect readings
If the altimeter profile is on for an extended period of time with the device in a fixed location while the local weather changes, the device will give incorrect altitude readings.
If you use the altimeter profile and the weather changes frequently while you climb in altitude or go down in altitude, the device will give you incorrect readings.
If you use the barometer profile for an extended period of time as you climb in altitude or go down in altitude, the device assumes that you are standing still and interprets your changes in altitude as changes in sea level air pressure. It will therefore give you incorrect sea level air pressure readings.
Using altimeter profile
The altimeter profile calculates altitude based on reference values. The reference value can either be sea level air pressure or altitude. When the altimeter profile is activated, the altimeter icon is shown at the top of the alti-baro display.
Using barometer profile
The barometer profile shows the current sea level air pressure. This is based on the reference values and the constantly measured absolute air pressure.
When the barometer profile is activated, the barometer icon is shown on the display.
Using automatic profile
The automatic profile switches between the altimeter and barometer profiles according to your movement.
It is not possible to measure weather and altitude changes at the same time, as both cause a change in the surrounding air pressure. Suunto Traverse Alpha senses vertical movement and switches to measuring altitude, when needed. When altitude is shown, it is updated with a maximum delay of 10 seconds.
If you are at a constant altitude (less than 5 meters of vertical movement within 12 minutes), Suunto Traverse Alpha interprets all pressure changes as weather changes. The measurement interval is 10 seconds. The altitude reading remains steady and if the weather changes, you will see changes in the sea level air pressure reading.
If you are moving in altitude (more than 5 meters of vertical movement within 3 minutes), Suunto Traverse Alpha interprets all pressure changes as movements in altitude.
Depending on which profile is active, you can access the altimeter or barometer in the alti-baro display with .
      When you are using the automatic profile, barometer or altimeter icons are not shown on the alto-baro display.
Autopause
Autopause pauses the recording of your activity when your speed is less than 2 km/h (1.2 mph). When your speed increases to more than 3 km/h (1.9 mph), the recording continues automatically.
You can turn autopause on/off for each sport mode in Movescount under the advanced settings for the sport mode.
Backlight
Pressing activates the backlight.
By default, the backlight turns on for a few seconds and turns off automatically.
There are four backlight modes:
- Normal : The backlight turns on for a few seconds when you press and when the alarm clock sounds. This is the default setting.
- Off : The backlight is not switched on by pressing a button or when the alarm clock sounds.
- Night : The backlight turns on for a few seconds when you press any button and when the alarm clock sounds.
- Toggle : The backlight turns on when you press and stays on until you press again.
You can change the general backlight setting in the watch settings under GENERAL » Tones/display » Backlight .
You can change backlight color, when using red backlight, setting the brightness to 10% makes it possible to view the backlight through night vision goggles.
You can adjust the backlight brightness (in percent), in the watch settings under Tones/display » Backlight .
          When the and buttons are locked, you can still activate the backlight by pressing .
          Setting the backlight color to red will not affect the color of flashlight
Flashlight
In addition to normal backlight modes, Suunto Traverse Alpha has one additional mode where the backlight is automatically set to maximum brightness and can be used as a flashlight. To activate the flashlight, keep pressed.
The flashlight stays on for about four minutes. You can turn it off at any time by pressing or .
Button lock
Keeping pressed locks and unlocks buttons.
You can change the button lock behavior in the watch settings under GENERAL » Tones/display » Button lock .
Your Suunto Traverse Alpha has two button lock options:
- Actions only : Start and options menus are locked.
- All buttons : All buttons are locked. Backlight can be activated in Night mode.
          Select the Actions only button lock setting to avoid accidentally starting or stopping your log. When the and buttons are locked, you can still change displays by pressing and views by pressing .
Compass
Suunto Traverse Alpha has a digital compass that allows you to orient yourself in relation to magnetic north. The tilt-compensated compass gives you accurate readings even if the compass is not horizontally level.
You can show/hide the compass display from the start menu under DISPLAYS » Compass .
The default compass display includes the following information:
- middle row: compass heading in degrees
- bottom row: press to see current time, cardinal direction or empty (no value)
You can change the compass display information from the options menu under General » Formats » Compass unit . Select which is the primary value in the center of the compass display: degrees, Mils or cardinals.
The compass switches to power saving mode after one minute. Reactivate it with .
Calibrating compass
If you have not used the compass before, you must first calibrate it. Turn and tilt the watch in multiple directions until the watch beeps, indicating calibration is complete.
If the calibration is successful, the text Calibration successful is displayed. If the calibration does not succeed, the text Calibration failed is displayed. To retry the calibration, press .
If you have already calibrated the compass and want to re-calibrate it, you can manually start the calibration process.
To manually start compass calibration:
- Scroll to NAVIGATION with and enter with .
- Scroll to Settings with and select with .
- Scroll to Compass with and select with .
- Press to select Calibration .
Setting declination
To ensure correct compass readings, set an accurate declination value.
Paper maps point to true north. Compasses, however, point to magnetic north – a region above the Earth where the Earth’s magnetic fields pull. Because magnetic North and true North are not at the same location, you must set the declination on your compass. The angle in between magnetic and true north is your declination.
The declination value appears on most maps. The location of magnetic north changes yearly, so the most accurate and up-to-date declination value can be obtained from the internet (for example www.magnetic-declination.com ).
Orienteering maps, however, are drawn in relation to magnetic north. This means that when you are using orienteering maps you need to turn the declination correction off by setting the declination value to 0 degrees.
To set the declination value:
- Scroll to Declination with and select with .
- Turn the declination off by selecting -- , or select W (west) or E (east). Set the declination value with or .
- Press to accept the setting.
            You can also access the navigation menu and compass settings by pressing while navigating.
Setting bearing lock
You can mark the direction to your target in relation to North with the bearing lock feature.
To lock a bearing:
- With the compass active, hold the watch in front of you and turn yourself towards your target.
- Press to lock the current degree displayed on the watch as your bearing.
- An empty triangle indicates the locked bearing in relation to the North indicator (solid triangle).
- Press to clear the bearing lock.
          When using the compass while recording an activity, the button only locks and clears the bearing. Exit the compass view to make a lap with .
Countdown timer
You can set the countdown timer to count down from a preset time to zero. You can show/hide it from the start menu under DISPLAYS » Countdown .
When activated, the countdown timer can be accessed by pressing until see the display.
The default countdown time is five minutes. You can adjust this time by pressing .
              You can pause/continue the countdown by pressing .
            Countdown timer is not available while activity recording is ongoing.
Displays
Your Suunto Traverse Alpha comes with several different features, such as compass (see Compass) and stopwatch (see Stopwatch). These are handled as displays that can be viewed by pressing . Some of them are permanent, others you can show or hide as you like.
To show/hide displays:
- Press to enter the start menu.
- Scroll to DISPLAYS by pressing and press .
- In the list of display, toggle any feature on/off by scrolling to it with or and pressing . Keep pressed to exit the displays menu if needed.
Your sport modes (see Sport modes) also have multiple displays that you can customize to view different information while recording an activity.
Adjusting display contrast
Increase or decrease the display contrast of your Suunto Traverse Alpha in the watch settings.
To adjust the display contrast:
- Press to enter the GENERAL settings.
- Press to enter Tones/display .
- Scroll to Display contrast with and enter with .
- Increase the contrast with , or decrease it with .
Inverting display color
Change the display between dark and light through the settings in the watch.
To invert the display in the watch settings:
- Scroll to Invert display with and invert with .
FusedAlti
                  FusedAlti
                By default, altitude is measured with FusedAlti during recordings that use GPS and during navigation. When GPS is switched off, altitude is measured with the barometric sensor.
If you do not want to use FusedAlti in altitude measurement, set your reference value with altitude or sea level pressure.
You can search for a new reference value with FusedAlti by activating it in the options menu under ALTI-BARO » Reference » FusedAlti.
In good conditions it takes 4-12 minutes for FusedAlti to find a reference value. During that time, Suunto Traverse Alpha shows barometric altitude with '~' before the reading to indicate that the altitude may not be correct.
Find back
Suunto Traverse Alpha automatically saves the starting point of your recording if you are using GPS. With Find back, Suunto Traverse Alpha can guide you directly back to your starting point (or to the location where the GPS fix was established).
To find back:
- Keep pressed to access the options menu.
- Press to select NAVIGATION .
- Scroll to Find back with and select with .
The navigation guidance is shown as one of the views in the breadcrumb display.
Hunting with shot recognition
The automatic shot detection feature was developed specifically for hunting. It works best with hunting rifles and shotguns. It is not intended for handguns or other firearms.
Shot recognition is on by default when you record an activity using the hunting sport mode.
The shot detection algorithm uses a complex formula that takes into account motion patterns from both wrist and gun recoil movement measured by the accelerometer in the watch.
The automatic shot detection works with the watch on either wrist. However, for some users, the shot detection rate is more accurate when the watch is on the trigger hand.
We recommend that the watch strap is secured tightly on the wrist to eliminate disturbance from other sources of movement.
Results may vary depending on many factors, including firearm type, grip type, and accessories such as a support or suppressor. In some cases, a shot may be detected based on movement that is similar to a recoil, even though no shot is actually fired.
Your total shot count is updated on the watch display during the recording, and each shot location is stored.
              Compass accuracy may be affected when shot recognition is active. Movement resembling the gun recoil may be mistakenly interpreted as a shot. Not all gun calibers are recognizable, and use of recoil dampening devices hinder shot recognition.
Icons
The following icons are displayed in Suunto Traverse Alpha :
|   | alarm |
|   | altimeter |
|   | barometer |
|   | battery |
|   | Bluetooth |
|   | button lock |
|   | button press indicators |
|   | current display |
|   | down/decrease |
|   | fish |
|   | flashlight |
|   | GPS signal strength |
|   | heart rate |
|   | highest point |
|   | incoming call |
|   | lowest point |
|   | message/notification |
|   | missed call |
|   | moonrise |
|   | moonset |
|   | next/confirm |
|   | pairing |
|   | settings |
|   | shot |
|   | sport mode |
|   | storm |
|   | sunrise |
|   | sunset |
|   | up/increase |
POI icons
The following POI icons are available in Suunto Traverse Alpha :
|   | animal print |
|   | begin |
|   | big game |
|   | bird |
|   | building/home |
|   | camp/camping |
|   | car/parking |
|   | cave |
|   | crossroad |
|   | emergency |
|   | end |
|   | fishing spot |
|   | food/restaurant/cafe |
|   | forest |
|   | geocache |
|   | info |
|   | lodging/hostel/hotel |
|   | meadow |
|   | mountain/hill/valley/cliff |
|   | road/trail |
|   | rock |
|   | sight |
|   | scrape/rub |
|   | small game |
|   | stand |
|   | trail cam |
|   | water/waterfall/river/lake/coast |
|   | waypoint |
Logbook
The logbook stores the logs of your recorded activities. The maximum number of logs and the maximum duration of a single log depends on how much information is recorded in each activity. GPS accuracy (see GPS accuracy and power saving), for example, directly impact the number and duration of logs that can be stored.
You can view the log summary of your activity right after you have stopped recording or through the Logbook under the start menu.
The information shown in the log summary is dynamic: it changes depending on factors such as sport mode and whether or not you used an heart rate belt or GPS. By default, all logs include at minimum the following information:
- sport mode name
- time
- date
- duration
- laps
If the log includes GPS data, the logbook entry includes a view of the full route track as well as the altitude profile of the track.
                  You can see many more details of your recorded activities in Suunto app.
To view log summary after stopping a recording:
- Keep pressed to stop and save the recording.
- Press to view the log summary.
You can also view the summaries of all your recorded sessions(logs) in the logbook. In the logbook recorded sessions are listed according to date and time.
To view summary log in the logbook:
- Scroll to Logbook with and enter with .
- Scroll the logs with or and select a log with .
- Browse the summary views of the log with .
Memory left indicator
If more than 50 % of the logbook has not been synchronized with Suunto app, Suunto Traverse Alpha displays a reminder when you enter the logbook.
The reminder is not displayed once the unsynced memory is full and Suunto Traverse Alpha begins overwriting old logs.
Moon phases
                    You can follow moon phases based on your last known GPS
                    location with the moon phase display. Show/hide the display
                    DISPLAYS
                    Moon phase
                    . When activated, you can view moon phases by pressing
                    to scroll through the active displays.
By default, the moon phase display shows you the moon phase for your current location and date.
To view other dates for your current location:
- While in the moon phase display, press BACK LAP.
- Scroll through future or past dates with START and LIGHT.
- Select a date other than today with NEXT to see the moon phase information for that date.
- Return to today’s date by pressing BACK LAP again.
Movescount
Movescount allows you to customize your watch to best meet your needs.
Start by installing SuuntoLink:
- Go to www.suunto.com/suuntolink .
- Download, install and open the latest version of SuuntoLink.
- Follow the instructions to create your Movescount account.
- Go to www.movescount.com and log in.
        The first time your Suunto Traverse Alpha is connected to Movescount, the watch settings are transferred from the watch to your Movescount account. The next time you connect your Suunto Traverse Alpha to your Movescount account, changes in settings and sport modes you make in Movescount and in the watch are automatically synchronized.
Navigating with GPS
Suunto Traverse Alpha uses the Global Positioning System (GPS) to determine your current position. GPS incorporates a set of satellites that orbit the Earth at an altitude of 20,000 km at the speed of 4 km/s.
The built-in GPS receiver in Suunto Traverse Alpha is optimized for wrist use and receives data from a very wide angle.
Getting GPS signal
Suunto Traverse Alpha activates GPS automatically when you select a sport mode with the GPS functionality, determine your location, or start navigating.
            When you activate GPS for the first time, or have not used it for a long time, it might take longer than usual to get a GPS fix. Subsequent GPS starts will take less time.
            To minimize GPS initiation time, hold the watch steady facing up and make sure you are in an open area with a clear view of the sky.
            Regularly synchronize your Suunto Traverse Alpha with Suunto app to get the latest satellite orbit data (GPS optimization). This reduces the time needed to get the GPS fix and improves track accuracy.
Troubleshooting: No GPS signal
- For an optimal signal, point the GPS part of the watch upwards. The best signal can be received in an open area with a clear view of the sky.
- The GPS receiver usually works well inside tents and other thin covers. However, objects, buildings, dense vegetation or cloudy weather can reduce the GPS signal reception quality.
- GPS signal does not penetrate any solid constructions or water. Therefore do not try to activate GPS inside buildings, caves or under water.
GPS grids and position formats
Grids are lines on a map that define the coordinate system used on the map.
Position format is the way the GPS receiver's position is displayed on the watch. All the formats relate to the same location, they only express it in a different way. You can change the position format in the watch settings in the options menu under GENERAL » Formats » Position format .
You can select the format from the following grids:
                latitude/longitude is the most commonly used grid and has three
                different formats:
                - WGS84 Hd.d°
- WGS84 Hd°m.m'
- WGS84 Hd°m's.s
- UTM (Universal Transverse Mercator) gives a two-dimensional horizontal position presentation.
- MGRS (Military Grid Reference System) is an extension of UTM and consists of a grid zone designator, 100,000-meter square identifier and a numerical location.
Suunto Traverse Alpha also supports the following local grids:
- British (BNG)
- Finnish (ETRS-TM35FIN)
- Finnish (KKJ)
- Irish (IG)
- Swedish (RT90)
- Swiss (CH1903)
- UTM NAD27 Alaska
- UTM NAD27 Conus
- UTM NAD83
- NZTM2000 (New Zealand)
            Some grids cannot be used in the areas north of 84°N and south of 80°S, or outside the countries that they are intended for.
When customizing sport modes, you can define the GPS fix interval using the GPS accuracy setting in Suunto Movescount. The shorter the interval, the better the accuracy during recording.
By increasing the interval and lowering the accuracy, you can extend the battery life.
The GPS accuracy options are:
- Best : ~ 1 sec fix interval, highest power consumption
- Good : ~ 5 sec fix interval, moderate power consumption
- OK : ~ 60 sec fix interval, lowest power consumption
- Off : no GPS fix
You can adjust the predefined GPS accuracy of the sport mode if needed only during a recording and while navigating. For instance, if you notice you are low on battery, you could adjust the setting to extend battery life.
Adjust GPS accuracy in the start menu under NAVIGATION » Settings » GPS accuracy .
GPS and GLONASS
Suunto Traverse Alpha uses a Global Navigation Satellite System (GNSS) to determine your location. The GNSS can use signals from both GPS and GLONASS satellites.
By default your watch searches for GPS signals only. In some situations and locations already the world, using GLONASS signals can improve location accuracy. However, keep in mind that using GLONASS consumes more battery than using GPS only.
You can activate or deactivate GLONASS at any time, even while recording an activity.
The activate or deactivate GLONASS:
- Scroll to GNSS with and select with .
- Choose GPS & GLONASS to activate GLONASS. If already active, choose GPS to deactivate GLONASS.
          GLONASS is only used if GPS accuracy is set to best. (See GPS accuracy and power saving).
Notifications
If you have paired your Suunto Traverse Alpha with Suunto app (see Suunto app), you can get call, message and push notifications on the watch.
To get notifications on your watch:
- Press to scroll to CONNECTIVITY and press .
- Press to scroll to Notifications .
- Toggle on/off with .
- Exit by keeping pressed.
With notifications on, your Suunto Traverse Alpha gives an alert (see Tones and vibration) and displays a notification icon in the bottom row of the time display with each new event.
To view notifications on your watch:
- Scroll to NOTIFICATIONS with and press .
- Scroll through the notifications with or .
Up to 10 notifications can be listed. Notifications remain in your watch until you clear them from your mobile device. However, notifications older than one day are hidden from view in the watch.
Recording activities
Use sport modes (see Sport modes) to record activities and view various information during your outing.
Out of the box, Suunto Traverse Alpha has three sport modes, Hiking, Hunting and Fishing. Start a recording by pressing and then press to enter RECORD .
So long as there is only one sport mode in the watch, the recording starts immediately. If you add other sport modes, you need to select the sport mode you want to use and then press to start the recording.
            You can also quickly start the recording by keeping pressed.
Points of interest
Suunto Traverse Alpha includes GPS navigation which allows you to navigate to a pre-defined destination stored as a point of interest (POI).
                You can also start navigating to a POI when you are recording an activity (see Recording activities).
To navigate to a POI:
- Scroll to NAVIGATION with and press .
- Scroll to POIs (Points of interest) using and press .
- Scroll to the POI you wish to navigate to with or and select with .
- Press again to select Navigate . If you are using the compass for the first time, you need to calibrate it (see Calibrating compass). After activating the compass, the watch starts searching for a GPS signal. All navigating is recorded. If your watch has more than one sport mode, you are prompted to select one.
- Start navigating to the POI.
The watch displays the breadcrumb display, showing your position and the position of the POI.
By pressing you can access additional guidance:
- distance and direction to POI in straight line
- distance to POI and estimated time en route based on your current speed,
- difference between your current altitude and the POI altitude
When stationary or moving slowly (<4 km/h), the watch shows you the direction to the POI (or waypoint if navigating a route) based on the compass bearing.
While moving (>4 km/h), the watch shows you the direction to the POI (or waypoint if navigating a route) based on GPS.
The direction to your target, or bearing, is shown with the empty triangle. Your direction of travel, or heading, is indicated by the solid lines at the top of the display. Aligning these two ensures you are moving in the correct direction.
Checking your location
Suunto Traverse Alpha allows you to check the coordinates of your current location using GPS.
To check your location:
- Scroll to Location with and press .
- Press to select Current .
- The watch starts searching for a GPS signal and displays GPS found after acquiring the signal. After that your current coordinates are shown on the display.
                You can also check your location while you are recording an activity by keeping pressed to access NAVIGATION in the options menu or by pressing while in the breadcrumb display.
Adding a POI
Suunto Traverse Alpha allows you to save your current location or define a location as a POI.
You can store up to 250 POIs in the watch.
When adding a POI, select a POI type (icon) and POI name from a predefined list.
To save a POI:
- Select Current or select Define to manually change longitude and latitude values.
- Press to save the location.
- Select a suitable name for the location. Scroll through the name options with or . Select a name with .
- Press to save the POI.
                When recording a hunting or fishing activity, long pressing displays a shortlist of activity-specific POIs. To view the entire list, select SHOW ALL .
                You can quickly save your current location as a POI by keeping pressed. This can be done from any display when not recording an activity.
Deleting a POI
You can delete a POI directly in the watch.
To delete a POI:
- Scroll to POIs (Points of interest) with and press .
- Scroll to the POI you wish to delete with or and select with .
- Scroll to Delete with and press .
- Press to confirm.
Routes
You can create a route in Movescount, or import a route created with another service.
To add a route:
- Sync your Suunto Traverse Alpha with Movescount using Suuntolink and the supplied USB cable.
Routes could also be deleted through Movescount.
Navigating a route
You can navigate a route you have transferred to your Suunto Traverse Alpha from Movescount (see Routes) or from a log in your logbook with GPS data. You get a preview of the route based on the route list or logbook selection.
If you are using the compass for the first time, you need to calibrate it (see Calibrating compass). After activating the compass, the watch will begin searching for a GPS signal. After the watch acquires a GPS signal, you can begin to navigate a route.
To navigate a route:
- Scroll to Routes or NAVIGATION and press to enter .
- Scroll to the route you want to navigate with or and press .
- Press to select Navigate . All navigating is recorded. If you watch has more than one sport mode, you are prompted to select one.
- Select Forwards or Backwards to chose the direction you want to navigate (from the first waypoint or the last).
- Start navigating. The watch informs you when you are approaching the beginning of the route.
- The watch informs you when you have arrived at your destination.
                You can also start navigating while recording an activity (see Recording activities).
During navigation
During navigation, press to scroll the following views:
- full track view showing the whole route
- zoomed-in track view of the route: by default, the zoomed-in view is scaled to a 100 m (0.1 mi) scale; the scale is larger if you are far away from the route
Track view
The full track view shows you the following information:
- (1) arrow indicating your location and pointing to the direction of your heading.
- (2) the beginning and end of the route
- (3) The closest POI is shown as an icon.
- (4) scale of the track view
                In the full track view the north is always up.
Map orientation
You can change the map orientation in the options menu under NAVIGATION » Settings » Map » Orientation .
- Heading up : Displays the zoomed-in map with the heading pointing up.
- North up : Displays the zoomed-in map with the north pointing up.
Ascent profile view
The ascent profile view shows you the following information:
- Remaining ascent
- Real-time altitude profile graph
- Remaining descent
If you veer too far off the route track, the profile graph is not updated. Instead, the text Off route is shown below the graph. You need to return to the track to get accurate ascent calculations.
Service menu
To access the service menu, keep and pressed simultaneously until the watch enters the service menu.
The service menu includes the following items:
                    Info
                    - Air pressure : shows the current absolute air pressure and temperature.
- Version : shows the current software and hardware version.
- BLE : shows the current Bluetooth Smart version.
                    Display
                    - LCD test : allows you to test that the LCD works properly.
                    ACTION
                    - Power off : allows you to put the watch into deep sleep.
- GPS reset : allows you to reset GPS.
                Power off is a low power state. Follow the normal startup procedure to wake up the device. All settings except time and date are maintained. Just confirm them through the startup wizard.
                The watch switches to power saving mode when it is static for 10 minutes. The watch re-activates when moved.
                Service menu content is subject to change without notice during updates.
Resetting GPS
In case the GPS unit cannot find a signal, you can reset GPS data in the service menu.
To reset GPS:
- In the service menu, scroll to ACTION with and enter with .
- Press to scroll to GPS reset and enter with .
- Press to confirm GPS reset, or press to cancel.
              Resetting GPS resets GPS data and compass calibration values. Saved logs are not removed.
Sport modes
Sport modes are your way to customize how activities are recorded. Different information is shown on the displays while recording depending on the sport mode. Suunto Traverse Alpha comes with three predefined sport modes for Hiking, Hunting and Fishing.
In Suunto Movescount you can create custom sport modes, edit the predefined sport mode, delete sport modes, or simply hide them so that they are not shown in your RECORD menu (see Recording activities).
A custom sport mode can contain up to four displays. You can choose which data appears on each display from a comprehensive list of options.
You can transfer up to five sport modes created in Movescount to your Suunto Traverse Alpha .
Stopwatch
The stopwatch is a display that can be turned on or off from the start menu.
To activate the stopwatch:
- Scroll to Stopwatch with and press .
When activated, the timer can be accessed by pressing until the timer appears.
                  The stopwatch is not visible while recording an activity.
To use the stopwatch:
- In the activated stopwatch display, press to start measuring time.
- Press to make a lap, or press to pause the stopwatch. To view the lap times, press when the stopwatch is paused.
- Press to continue.
- To reset the time, keep pressed when the stopwatch is paused.
While the stopwatch is running, you can:
- press to switch between the time and lap time shown on the bottom row of the display.
- switch to Time display with .
- enter the options menu by keeping pressed.
If you no longer want to see the stopwatch display, deactivate the stopwatch.
To hide the stopwatch:
- Scroll to End stopwatch with and press .
Sunrise and sunset alerts
In addition to the sunrise and sunset times you can view in different displays in Traverse Alpha, you can set specific sunrise and sunset alerts to help time your activities on your expeditions. You can set an alarm for the sunrise and sunset alerts separately in the options menu under General » Alerts . Turn each alarm on/off and set how many minutes before the event that the alarm should sound.
Suunto app
With the Suunto app, you can further enrich your Suunto Traverse Alpha experience by analyzing and sharing your trainings, connecting to partners and much more. Pair with the mobile app to get notifications on your Suunto Traverse Alpha .
To pair your watch with Suunto app:
- Download and install Suunto app on your compatible mobile device from the App Store, Google Play in addition to several popular app stores in China.
- Start Suunto app and turn on Bluetooth if it is not on already.
- On your watch, keep pressed to enter the options menu.
- Scroll to PAIR with and select with
- Press to select MobileApp .
- Return to the app and tap the watch icon in the upper left corner of the screen. When the name of the watch appears, tap PAIR.
- Enter the passkey shown on your watch display into the paring request field on your mobile device and tap PAIR to finalize the connection.
                  Some features require an internet connection over Wi-Fi or mobile network. Carrier data connection fees may apply.
Syncing with mobile app
If you have paired your Suunto Traverse Alpha with Suunto app, all your new training sessions are automatically synced when the Bluetooth connection is active and in working range. The Bluetooth icon on your Suunto Traverse Alpha flashes when data is being synced.
If your mobile device has an active data connection and Bluetooth is on, logs are synced with Suunto app when automatic syncing is on. If there is no data connection, syncing is delayed until a connection is available.
This default setting can be changed from the options menu if you have paired your watch with the mobile app.
To turn off automatic syncing:
- Scroll to CONNECTIVITY with and select with .
- Press again to enter the MobileApp sync setting.
- Toggle off with and keep pressed to exit.
When automatic syncing is off, you cannot get or view notifications on your watch.
Suunto Apps
Suunto Apps allow you to further customize your Suunto Traverse Alpha . Visit Suunto App Zone under Community in Movescount.com to find Apps, such as various timers and counters, available for your use. If you cannot find what you need, create your own App with Suunto App Designer. You can create Apps, for example, for calculating your estimated marathon result, or the slope grade of your skiing route.
                  Suunto Apps in Movescount refers to apps you can use in your watch. Not to be confused with Suunto app which is a mobile app used for analyzing and sharing your trainings, connecting to partners and much more.
To add Suunto Apps to your Suunto Traverse Alpha :
- Go to the App zone section in Movescount community to browse existing Suunto Apps. To create your own App, select App Designer .
- Add Suunto App to a sport mode. Connect your Suunto Traverse Alpha to your Movescount account to synchronize Suunto App to the watch. The added Suunto App will show the result of its calculation while you exercise.
                You can add up to five Suunto Apps to each sport mode.
Time
The time display on your Suunto Traverse Alpha shows the following information:
- top row: date
- middle row: time
- bottom row: change with to show additional information such as sunrise/sunset, altitude and battery level.
In the options menu under GENERAL » Time/date , you can set the following:
- Dual time
- Alarm
- Time and date
Alarm clock
You can use your Suunto Traverse Alpha as an alarm clock. Turn the alarm on/off and set the alarm time in the options menu under GENERAL » Time/date » Alarm .
When the alarm is switched on, the alarm symbol is shown on most of the displays.
When the alarm sounds, you can:
- Snooze by pressing . The alarm stops and restarts every five minutes until you stop it. You can snooze up to 12 times for a total of one hour.
- Stop by pressing . The alarm stops and restarts the same time the following day, unless you switch the alarm off in the options menu.
                    When snoozing, the alarm icon blinks in the time display.
Time syncing
Your Suunto Traverse Alpha time can be updated through your mobile phone, computer (Suuntolink) or GPS time.
When you connect your watch to the computer with the USB cable, Suuntolink by default updates your watch time and date according to the computer clock.
GPS time
GPS time corrects the offset between your Suunto Traverse Alpha and the GPS time. GPS time checks and corrects the time whenever a GPS fix is found (for example when recording an activity, or saving a POI).
GPS time is on by default. You can turn it off in the options menu under GENERAL » Time/date » Time & date .
Daylight Saving Time
Suunto Traverse Alpha supports Daylight Saving Time (DST) time adjustments if GPS time is on
You can adjust the Daylight Saving Time setting in the options menu under GENERAL » Time/date » Time & date .
There are three settings available:
- Automatic – automatic DST adjustment based on GPS location
- Winter time – always winter time (no DST)
- Summer time – always summer time
Tones and vibration
Tones and vibration alerts are used for notifications, alarms and other key events. Both can be adjusted separately in the options menu under GENERAL » Tones/display » Tones or Vibration .
For each alert type, you can select from the following options:
- All on : all events trigger tones/vibration
- All off : no events trigger tones/vibration
- Buttons off : all events other than pushing buttons trigger tones/vibration
Track back
With Suunto Traverse Alpha you can retrace your route any time during a recording with the help of the breadcrumb display.
You can also navigate a track from the logbook with recorded activities that include GPS data. Follow the same procedure as in Navigating a route. Scroll to Logbook instead of Routes , and select a log to start navigating.
Weather indicators
In addition to the barometer graph (see Using barometer profile), Suunto Traverse Alpha has two weather indicators: weather trend and storm alarm.
The weather trend indicator is displayed as a view in the time display, providing you a quick way to check weather changes.
The weather trend indicator is comprised of two lines forming an arrow. Each line represents a 3-hour period. A change in barometric pressure greater than 2 hPa (0.59 inHg) over three hours triggers a change the direction of the arrow. For example:
|   | pressure dropping heavily over the last six hours |
|   | pressure was steady, but rising heavily over the last three hours |
|   | pressure was rising heavily, but dropping heavily over the last three hours |
Storm alarm
A significant drop in barometric pressure typically means a storm is coming and you should take cover. When the storm alarm is active, Suunto Traverse Alpha sounds an alarm and flashes a storm symbol when the pressure drops 4 hPa (0.12 inHg) or more during a 3-hour period.
The storm alarm is off by default. You can turn it on in the options menu under GENERAL » Alerts » Storm alarm .
                    The storm alarm does not work if you have altimeter profile activated.
When a storm alarm sounds, pressing any button ends the alarm. If no button is pressed, the alarm repeats once after five minutes. The storm symbol remains on the display until the weather conditions stabilize (pressure drop slows down).
A special lap (called 'storm alarm') is generated when a storm alarm occurs while recording an activity.
        CARE AND SUPPORT
      Handling guidelines
Handle the unit with care – do not knock or drop it.
Under normal circumstances the watch does not require servicing. After use, rinse it with fresh water, mild soap, and carefully clean the housing with a moist soft cloth or chamois.
      Remember to register your Suunto Traverse Alpha at apac.suunto.com/support to get personalized support.
Water resistance
Suunto Traverse Alpha is water resistant to 100 meters (330 feet), which is equivalent to 10 bars. The meter value relates to an actual diving depth and is tested in the water pressure used in the course of the Suunto water resistance test. This means you can use the watch for swimming and snorkeling, but it should not be used for any form of diving.
          Water resistance is not equivalent to functional operating depth. The water resistance marking refers to static air/water tightness withstanding shower, bathing, swimming, poolside diving and snorkeling.
To maintain water resistance, it is recommended to:
- never use the device for other than intended use.
- contact an authorized Suunto service, distributor or retailer for any repairs.
- keep the device clean from dirt and sand.
- never attempt to open the case yourself.
- avoid subjecting the device to rapid air and water temperature changes.
- always clean your device with fresh water if subjected to salt water.
- never knock or drop the device.
Charging the battery
The duration on a single charge depends on how Suunto Traverse Alpha is used and in what conditions. Low temperatures, for example, reduce the duration of a single charge. In general, the capacity of rechargeable batteries decreases over time.
          In case of abnormal capacity decrease due to defective battery, Suunto warranty covers the battery replacement for one year or for at maximum 300 charging times, whichever comes first.
The battery icon indicates the charge level of the battery. When the battery charge level is less than 10%, the battery icon blinks for 30 seconds. When the battery charge level is less than 2%, the battery icon blinks continuously.
When battery level drops very low during a recording, the watch stops and saves the recording. The watch can still show time, but buttons are deactivated.
Charge the battery by attaching it to your computer with the supplied USB cable, or charge with a USB-compatible wall charger. It takes approximately 2-3 hours to fully charge an empty battery.
        You can change the GPS fix interval during a recording to save battery life. See GPS accuracy and power saving.
              Handling guidelines Water resistance Charging the battery
        REFERENCE
      Technical specifications
General
- Operating temperature: -20° C to +60° C (-5° F to +140° F)
- Battery charging temperature: 0° C to +35° C (+32° F to +95° F)
- Storage temperature: -30° C to +60° C (-22° F to +140° F)
- Weight: ~70g (2.8 oz)
- Water resistance: 100 m (300 ft)
- Glass: sapphire lens
- Power: rechargeable lithium-ion battery
- Battery life: ~10 - 100 hours depending on selected GPS accuracy; ~14 days with GPS off
Memory
- Points of Interest (POIs): max. 250
Radio transceiver
- Bluetooth® Smart compatible
- Communication frequency: 2402-2480 MHz
- Maximum transmission power: <0 dBm (conducted)
- Range: ~3 m/9.8 ft
Barometer
- Display range: 950 to 1060 hPa (28.05 to 31.30 inHg)
- Resolution: 1 hPa (0.03 inHg)
Altimeter
- Display range: -500 m to 9999 m (-1640 ft to 32805 ft)
- Resolution: 1 m (3 ft)
Thermometer
- Display range: -20° C to +60° C (-4° F to +140° F)
- Resolution: 1°
Chronograph
- Resolution: 1 s until 9:59'59, after that 1 min
Compass
- Resolution: 1 degree (18 mils)
- Accuracy: +/- 5 degrees
GPS
- Technology: SiRF star V
- Resolution: 1 m/3 ft
- Frequency band: 1575.42 MHz
Manufacturer
Suunto Oy
Tammiston kauppatie 7 A
FI-01510 Vantaa
FINLAND
Compliance
CE
Hereby, Suunto Oy, declares that the radio equipment type OW151 is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: www.suunto.com/EUconformity.
FCC compliance
This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions:
(1) this device may not cause harmful interference, and
(2) this device must accept any interference received, including interference that may cause undesired operation. This product has been tested to comply with FCC standards and is intended for home or office use.
Changes or modifications not expressly approved by Suunto could void your authority to operate this device under FCC regulations.
NOTE: This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
- Reorient or relocate the receiving antenna.
- Increase the separation between the equipment and receiver.
- Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
- Consult the dealer or an experienced radio/TV technician for help.
Amer Sports United States
2030 Lincoln Avenue
84401 Ogden
United States
+1 855 258 0900
ISED REGULATORY COMPLIANCE
This device contains licence-exempt transmitter(s) that comply with Innovation, Science and Economic Development Canada’s licence-exempt RSS(s).
(1) this device may not cause interference, and
(2) this device must accept any interference, including interference that may cause undesired operation of the device.
NOM-121-SCT1-2009
Trademark
Suunto Traverse Alpha , its logos, and other Suunto brand trademarks and made names are registered or unregistered trademarks of Suunto Oy. All rights are reserved.
Patent notice
This product is protected by pending patent applications and their corresponding national rights: US 7,271,774 , US 7,324,002, US 13/794,468, US 14/195,670, US7489241. Additional patent applications have been filed.
International Limited Warranty
Warranty Period
The Warranty Period is two (2) years for Watches, Smart Watches, Dive Computers, Heart Rate Transmitters, Dive Transmitters, Dive Mechanical Instruments, and Mechanical Precision Instruments unless otherwise specified.
The Warranty Period is one (1) year for accessories including but not limited to Suunto chest straps, watch straps, chargers, cables, rechargeable batteries, bracelets and hoses.
The Warranty Period is five (5) years for failures attributable to the depth measurement (pressure) sensor on Suunto Dive Computers.
Exclusions and Limitations
            - normal wear and tear such as scratches, abrasions, or alteration of the color and/or material of non-metallic straps, b) defects caused by rough handling, or c) defects or damage resulting from use contrary to intended or recommended use, improper care, negligence, and accidents such as dropping or crushing;
- printed materials and packaging;
- defects or alleged defects caused by use with any product, accessory, software and/or service not manufactured or supplied by Suunto;
- non-rechargeable batteries.
- has been opened beyond intended use;
- has been repaired using unauthorized spare parts; modified or repaired by unauthorized Service Center;
- serial number has been removed, altered or made illegible in any way, as determined at the sole discretion of Suunto; or
- has been exposed to chemicals including but not limited to sunscreen and mosquito repellents.
You must provide proof of purchase to access Suunto warranty service. You must also register your product online at apac.suunto.com/register to receive international warranty services globally. For instructions how to obtain warranty service, visit apac.suunto.com/warranty , contact your local authorized Suunto retailer, or call Suunto Contact Center.
Limitation of Liability
Copyright
© Suunto Oy 3/2016. All rights reserved. Suunto, Suunto product names, their logos and other Suunto brand trademarks and names are registered or unregistered trademarks of Suunto Oy. This document and its contents are proprietary to Suunto Oy and are intended solely for the use of clients to obtain knowledge and information regarding the operation of Suunto products. Its contents shall not be used or distributed for any other purpose and/or otherwise communicated, disclosed or reproduced without the prior written consent of Suunto Oy. While we have taken great care to ensure that information contained in this documentation is both comprehensive and accurate, no warranty of accuracy is expressed or implied. This document content is subject to change at any time without notice. The latest version of this documentation can be downloaded at www.suunto.com .
          Technical specifications Compliance Trademark Patent notice
            Copyright
