1 / 11
Suunto Spark Coral Orange
1/11
Photos
Video
Money-back guarantee
30-Days Return
Warranty Repair
SKU: SS051357000
Suunto Spark
Coral Orange
Sale price4,990 ฿
Performance in Every Beat
Lightweight open-ear earbuds offering superior sound and all-day comfort. Designed for training and daily activity.
Choose Your Color
Quantity
Free shipping on orders of ฿6000 or more.
30-Days Return
Warranty Repair
Under 10g each lightweight
Ergonomic open-ear fit
Hi-Res audio with LHDC 5.0
Up to 36hrs battery
IP55 sweat & waterproof
Head gesture control
Sound that Moves You
Open‑ear sport earbuds designed for movement. Suunto Spark delivers powerful bass and clear highs, with an open‑ear fit that keeps you aware of your surroundings. Lightweight and comfortable, Suunto Spark stays securely in place through every run, ride, and workout to keep you focused and energized.
Engineered for Superior Sound
SUUNTO APACSUUNTO APAC
Suunto Spark supports LHDC 5.0 for ultra-clear, high-fidelity audio up to 96 kHz, delivering deep bass and natural clarity. The hybrid multi-driver open-ear system produces powerful, balanced sound. Experience immersive head-tracked spatial audio and fine-tune your listening with preset EQ modes or create your own.
Training Feedback in Real Time
Use the Suunto App to set your cadence from 120 to 200 spm to help improve running efficiency. Enable Sport Mode to track cadence, ground contact, and vertical oscillation in real time. Receive voice updates on pace, heart rate, distance, and laps from your Suunto watch. Complete the Neck Mobility Assessment to track flexibility and range of motion.
Built for Everyday Performance
Open-Ear Design
Keeps you aware of your surroundings.
Designed for the Elements
IP55-rated to withstand sweat, dust, rain, and snow.
All-Day Power
Up to 7 hours per charge and up to 36 hours total playback with the charging case.
Lightweight. All Day Comfort
Weighing under 10g each and finished with soft, skin-friendly silicone, each earbud rests lightly on your ear for lasting comfort throughout the day. The slim, silicone-coated memory-titanium loop follows the shape of your ear, locking the fit in place as you move so you stay focused in the moment.
Immersive Sound
Dual microphones with Environmental Noise Cancellation reduce background noise and improve voice clarity in noisy environments. Suunto Spark’s anti-leakage driver uses active sound control to minimize sound spill for more private listening.
Seamless Connectivity
SUUNTO APAC
Deliver stable, low-latency connections to keep games, calls, and music in sync. Connect to two devices simultaneously and switch between calls, music, or videos without missing a beat. Use the Suunto App to locate misplaced earbuds, check status, customize EQ settings, and adjust features.
Find My Suunto Spark
Bluetooth® 5.4
Dual-Device Connection
Customize Your Earbuds
Device controls
What's in the box
SPECIFICATIONS
  • Measurements
    42.1 x 58.6 mm / 2.68 x2.3 " (per earbud)
    68 x 67.7 x 25.8 mm / 2.68 x 2.67 x 1.02 " (charging case)
  • Weight
    9.7g±0.2g (per earbud)
    57.5g±1g (charging case)
    76.8 g / 2.7 oz (whole unit)
  • Case material:
    Silicone + Titanium Alloy
  • What's in the box?
    Suunto Spark Earbuds, Suunto Spark Charging Case, USB-C to C Charging Cable, Warranty, Quick Start Guide
  • Country of manufacture
    CN
TECHNICAL SPECIFICATIONS
  • Case material
  • Weight
  • Water resistance
    IP55
  • Battery type
    rechargeable lithium-ion
  • Battery Charge Time
    Headphones:≤60m; Charging case:≤100m
  • Firmware upgradable
  • Music only play time
    7-30h
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
CONNECTIVITY
  • Compatible with Suunto app
  • Software updates from cloud
  • Bluetooth
    5.4
  • Bluetooth Range
    >10m
  • Supported Audio codec
    SBC,AAC,LHDC
  • Dual device connection
  • Smartphone compatibility
    Most common models supported
SPEAKER
  • Impedance
    32Ω±15%
  • Frequency range
    20 Hz – 20 kHz (44.1kHz sampling) ; LHDC supports up to 96 kHz sampling (Hi-Res Audio Wireless)
  • Balance
    ≤3 dB @1kHz
  • Sensitivity
    137.5±3dB (at 1KHz 0.8Vrms input ,0dBspl=20u Pa)
  • T.H.D
    < 2% @1kHz
MICROPHONE
  • Sensitivity
    -38dB(1kHz)
  • Frequency range
    100Hz~10KHz
  • S/N Ratio
    65dB
Recommended products
SUPPORT FOR SUUNTO SPARK
Find the full user guide and other detailed support information for your Suunto headphones.
