Technical specifications
Suunto Smart Sensor Module
Weight: 9.4 g/0.33 oz (battery included)
- Diameter: 36.5 mm/1.44 in
- Thickness: 8 mm/0.32 in
Operating temperature: -20° C to +60° C/-5° F to +140° F
Storage temperature: -30° C to +60° C/-22° F to +140° F
- Water resistance: 30 m/98 ft
- Battery type: CR2025
- Battery life: ~ 500 hours
Transmission frequency: 2.4GHz (Bluetooth)
Suunto Chest Strap
- Weight: 31.2 g/1.10 oz
- Width: 30 mm/1.18 in
- Length: (see table below)
| Size |
Chest circumference |
| Small |
56-82 cm / 22-32 in |
| Medium |
70-110 cm / 28-43 in |
| Large |
96-160 cm / 38-63 in |
Radio transceiver
- Bluetooth® Smart compatible
Communication frequency: 2402-2480 MHz
Maximum transmission power: <0 dBm (conducted)
- Range: ~3 m/9.8 ft
Manufacturer
Suunto Oy
Tammiston kauppatie 7 A
FI-01510 Vantaa
FINLAND
Compliance
CE
Hereby, Suunto Oy declares that the radio equipment of Model:
Movesense is in compliance with Directive 2014/53/EU. The full
text of the EU declaration of conformity is available at the
following internet address: suunto.com/EUconformity.
Product name: SUUNTO SMART SENSOR
Model: Movesense
Frequency band: 2402-2480 MHz
Maximum output power: <0 dBm
Range: ~3 m
FCC compliance
This device complies with Part 15 of the FCC Rules. Operation is
subject to the following two conditions:
(1) this device may not cause harmful interference, and
(2) this device must accept any interference received, including
interference that may cause undesired operation. This product has
been tested to comply with FCC standards and is intended for home
or office use.
Changes or modifications not expressly approved by Suunto could
void your authority to operate this device under FCC regulations.
NOTE: This equipment has been tested and found to comply with the
limits for a Class B digital device, pursuant to part 15 of the
FCC Rules. These limits are designed to provide reasonable
protection against harmful interference in a residential
installation. This equipment generates, uses and can radiate radio
frequency energy and, if not installed and used in accordance with
the instructions, may cause harmful interference to radio
communications. However, there is no guarantee that interference
will not occur in a particular installation. If this equipment
does cause harmful interference to radio or television reception,
which can be determined by turning the equipment off and on, the
user is encouraged to try to correct the interference by one or
more of the following measures:
- Reorient or relocate the receiving antenna.
Increase the separation between the equipment and receiver.
Connect the equipment into an outlet on a circuit different from
that to which the receiver is connected.
Consult the dealer or an experienced radio/TV technician for
help.
Amer Sports United States
2030 Lincoln Avenue
84401 Ogden
United States
www.amersports.com
+1 855 258 0900
ISED REGULATORY COMPLIANCE
This device contains licence-exempt transmitter(s) that comply
with Innovation, Science and Economic Development Canada’s
licence-exempt RSS(s).
Operation is subject to the following two conditions:
(1) this device may not cause interference, and
(2) this device must accept any interference, including
interference that may cause undesired operation of the device.
Patent notice
This product is protected by patents and pending patent
applications and their corresponding national rights. For a list
of the current patents, visit:
patents
Additional patent applications have been filed.
Trademark
Suunto Smart Heart Rate Belt
, its logos, and other Suunto brand trademarks and made names are
registered or unregistered trademarks of Suunto Oy. All rights are
reserved.
Warranty
Suunto warrants that during the Warranty Period Suunto or a Suunto
Authorized Service Center (hereinafter Service Center) will, at
its sole discretion, remedy defects in materials or workmanship
free of charge either by a) repairing, or b) replacing, or c)
refunding, subject to the terms and conditions of this
International Limited Warranty. This International Limited
Warranty is valid and enforceable regardless of the country of
purchase. The International Limited Warranty does not affect your
legal rights, granted under mandatory national law applicable to
the sale of consumer goods.
Warranty Period
The International Limited Warranty Period starts at the date of
original retail purchase.
The Warranty Period is two (2) years for Watches, Smart Watches,
Dive Computers, Heart Rate Transmitters, Dive Transmitters, Dive
Mechanical Instruments, and Mechanical Precision Instruments
unless otherwise specified.
The Warranty Period is one (1) year for accessories including but
not limited to Suunto chest straps, watch straps, chargers,
cables, rechargeable batteries, bracelets and hoses.
The Warranty Period is five (5) years for failures attributable to
the depth measurement (pressure) sensor on Suunto Dive Computers.
Exclusions and Limitations
This Limited Warranty does not cover:
normal wear and tear such as scratches, abrasions, or
alteration of the color and/or material of non-metallic
straps, b) defects caused by rough handling, or c) defects
or damage resulting from use contrary to intended or
recommended use, improper care, negligence, and accidents
such as dropping or crushing;
- printed materials and packaging;
defects or alleged defects caused by use with any product,
accessory, software and/or service not manufactured or supplied
by Suunto;
- non-rechargeable batteries.
Suunto does not warrant that the operation of the Product or
accessory will be uninterrupted or error free, or that the Product
or accessory will work with any hardware or software provided by a
third party.
This Limited Warranty is not enforceable if the Product or
accessory:
- has been opened beyond intended use;
has been repaired using unauthorized spare parts; modified or
repaired by unauthorized Service Center;
serial number has been removed, altered or made illegible in any
way, as determined at the sole discretion of Suunto; or
has been exposed to chemicals including but not limited to
sunscreen and mosquito repellents.
You must provide proof of purchase to access Suunto warranty
service. For instructions how to obtain warranty service, visit
support
, contact your local authorized Suunto retailer, or call Suunto
Contact Center.
Limitation of Liability
To the maximum extent permitted by applicable mandatory laws, this
Limited Warranty is your sole and exclusive remedy and is in lieu
of all other warranties, expressed or implied. Suunto shall not be
liable for special, incidental, punitive or consequential damages,
including but not limited to loss of anticipated benefits, loss of
data, loss of use, cost of capital, cost of any substitute
equipment or facilities, claims of third parties, damage to
property resulting from the purchase or use of the item or arising
from breach of the warranty, breach of contract, negligence,
strict tort, or any legal or equitable theory, even if Suunto knew
of the likelihood of such damages. Suunto shall not be liable for
delay in rendering warranty service.
Copyright
Copyright © Suunto Oy. All rights reserved. Suunto, Suunto
product names, their logos and other Suunto brand trademarks and
names are registered or unregistered trademarks of Suunto Oy. This
document and its contents are proprietary to Suunto Oy and are
intended solely for the use of clients to obtain knowledge and
information regarding the operation of Suunto products. Its
contents shall not be used or distributed for any other purpose
and/or otherwise communicated, disclosed or reproduced without the
prior written consent of Suunto Oy. While we have taken great care
to ensure that information contained in this documentation is both
comprehensive and accurate, no warranty of accuracy is expressed
or implied. This document content is subject to change at any time
without notice. The latest version of this documentation can be
downloaded at
apac.suunto.com
