Suunto Blog
From Road to Trail: How to Transition to Trail Running
You know how to train, how to pace yourself and how to build endurance on the road. But what happens when the road ends?
If you are thinking about trying trail running, you may be asking: Am I ready? Does my road fitness still count? What do I need to change?
The good news is that your road fitness is a real foundation to build on. This guide covers what carries over, what changes once the surface stops cooperating, and how to ease into trail running one step at a time.
Part 1: Are You Ready to Move From Road to Trail?
Yes. If you already run regularly, you have a solid fitness base to build on. Regular running is the qualification here, and pace, distance and race results are beside the point.
What matters more is choosing a trail that matches your current ability.
Which Trail Should You Start On?
Before your first trail run, weigh three things:
Elevation: how much climbing and descending will you take on?
Technical difficulty: is the trail smooth and runnable, or rocky, loose and uneven?
Duration and conditions: how long are you likely to be out, and what are the weather and trail conditions like?
Difficulty comes from gradient, surface and conditions as much as from distance. A short, steep or technical route can be far more demanding than a longer, smoother one.
How Much Should You Run?
For your first few trail runs, work in time rather than mileage. If you normally run for an hour on the road, start with a similar hour on an approachable trail and let the distance land where it lands.
Part 2: What Should You Keep From Road Running?
A lot more than you might think. Everything you built on the road comes with you.
Aerobic Fitness
The aerobic engine you built on the road stays valuable on the trail. Road runs remain an effective way to maintain that fitness, especially in weeks when trails are hard to reach.
Endurance and Consistency
Your ability to keep moving for long periods, and to train consistently week after week, still matters. Plenty of your running can stay on the road.
Speed
Speed matters too. Faster running supports your overall running ability, even as pace becomes a less reliable measure of performance on varied terrain.
All of it carries over. What changes is how you apply it in a different environment.
Part 3: What Needs to Change on the Trail?
The fitness comes with you. How you manage effort, distance and a less predictable environment is what shifts.
Pace → Effort
On the road, pace is a useful way to judge your effort. On trails, climbs, descents and changing surfaces can swing your pace dramatically from one kilometer to the next.
Instead of holding your usual road pace, keep your effort appropriate for the terrain in front of you.
Distance → Time on Feet
The same distance takes much longer on a trail, especially once elevation or technical ground is involved.
That makes time on feet the more useful way to think about a trail run. A slower pace often means a harder run, because the terrain keeps you out there longer.
Running → Running Plus Hiking
Trail running includes hiking. On steep climbs and demanding ground, hiking is often the more efficient way to manage your effort.
It is a normal part of the sport, and experienced trail runners do it on every big climb.
Predictable Surface → Variable Terrain
Road running lets you settle into a consistent rhythm. Trails ask you to adapt to changes in gradient and surface throughout the run.
Your pace and effort will move with the terrain. Learning to work with that variability is the heart of the transition.
Part 4: Tips for a Smooth Transition
Keep the running routine you already have and add trail-specific sessions where they fit, giving yourself time to adapt.
Start with manageable trails: choose smoother routes with moderate elevation first, then build distance, elevation or technicality as you get comfortable with the demands.
Build time on feet, not just mileage: a trail run takes much longer than the same distance on the road, so base your early sessions on familiar run durations.
Keep your first runs simple: pick straightforward routes where you know what to expect and can cut the run short easily. That leaves you free to focus on terrain, effort and elevation while everything else stays familiar.
Plan for the extra time: the same distance takes longer on the trail, so build that into your preparation. Think about how long you expect to be out and plan hydration and fuel around it, especially on longer or more remote runs.
A watch with free offline maps and route navigation helps here too. Load the route before you leave, follow it through the climbs, and track time on feet and ascent alongside pace.
Ready to work on your trail-running technique? Get expert advice on uneven terrain, climbing and trail skills from eight-time World Mountain Running Grand Prix champion Jonathan Wyatt.
Takeaway
Moving from road to trail is a change of environment, not a change of identity. The fitness and experience you already have still count, and you are simply learning to apply them somewhere new.
Readiness here is something you build by going. Start with what you have, choose trails that meet you where you are, and let experience guide what comes next.
Road to Trail Running FAQ
1. Am I Ready to Start Trail Running?
If you run regularly, yes. Regular running is the only prerequisite. Choose a trail that matches your current ability and start there.
2. How Long Should My First Trail Run Be?
Work in time rather than distance. If an hour is a normal road run for you, start with an hour on an approachable trail and let the distance fall where it falls.
3. Is It Normal to Walk During a Trail Run?
Yes. Hiking the steep climbs is standard practice at every level of the sport, and it is usually the most efficient way to manage your effort.
4. Do I Need Trail Running Shoes to Start?
On smooth, dry trails, road shoes will carry you through your first few runs. Once you move onto loose, rocky or wet ground, trail shoes give you the grip and underfoot protection that makes the difference.
5. Will Trail Running Make Me Slower on the Road?
Trail running builds strength, stability and aerobic fitness that all support your road running. Keeping some faster road sessions in the week maintains your leg speed and your feel for pace.
6. How Do I Judge Trail Difficulty?
Look at elevation gain, technical difficulty and expected duration together. A short, steep, rocky route can be far harder than a longer, smoother one.
Aerobic Threshold: Are You Training at the Right Intensity?
Endurance performance depends on how well your body keeps producing energy over time. Speed and training hours matter, but so does the efficiency that lets you hold an effort mile after mile.
You may already track VO₂ max, lactate threshold, and heart rate zones. Aerobic threshold (AeT) is another useful measure, and one that often gets overlooked. Knowing yours helps you plan low-intensity training, build endurance for longer efforts, and keep each workout at the right intensity.
At a Glance:
Aerobic threshold is a key physiological marker of aerobic fitness in endurance athletes.
Testing and training data can help estimate your aerobic threshold heart rate and guide workout intensity.
Training to develop your aerobic threshold can improve your ability to use fat as fuel and support endurance over time.
Aerobic threshold, lactate threshold, anaerobic threshold, and VO₂ max describe different aspects of fitness.
Suunto training data can help you follow changes in aerobic fitness and refine your training over the long term.
Table of Contents
What Is Aerobic Threshold?
Why Does Aerobic Threshold Matter?
Aerobic Threshold vs. Anaerobic Threshold, Lactate Threshold, and VO₂ Max
What Is a Good Aerobic Threshold?
How to Determine Aerobic Threshold
How to Improve Your Aerobic Capacity?
Takeaways
FAQ
Aerobic threshold (AeT) helps define the upper end of low-intensity endurance exercise. It is generally associated with the first lactate threshold (LT1) or the first ventilatory threshold (VT1). LT1 is identified from changes in blood lactate as exercise intensity rises, while VT1 is identified from changes in breathing and gas exchange. Because the tests measure different responses, the results do not always line up exactly.
Below your aerobic threshold, your body can get a relatively large share of its energy from fat while using less glycogen. As intensity rises above AeT, it gradually relies more on carbohydrates, including stored glycogen, to meet the higher energy demand. Fatigue also begins to build more quickly.
AeT is not a fixed switch between fat and carbohydrate use, and crossing it does not mean your body suddenly relies mainly on anaerobic energy production. Your body's energy systems work together during exercise, and lactate is produced even when oxygen is available.
For endurance athletes, aerobic threshold is a useful indicator of aerobic fitness. As it improves, you can sustain a stable aerobic effort at a higher intensity and use fat and carbohydrates more effectively to meet your energy needs.
In practice, that means you can produce more speed or power during low-intensity training. After a period of consistent training, for example, you might run faster at the same heart rate in similar weather, on a similar route, and with a similar level of freshness. That can be a sign of better aerobic performance. It is less useful for comparing one athlete with another: maximum heart rate, thresholds, and running economy vary between people, so pace at a given heart rate cannot tell the whole story.
Developing your aerobic threshold can also help you hold a steady output at higher intensities and use fat more effectively as fuel. That helps spare your limited glycogen stores during long efforts and delay fatigue. These adaptations are especially valuable for marathons, trail running, and triathlons, where you need to sustain your effort for hours.
AeT also gives you a practical reference for planning training. Using your individual threshold as a guide to the upper limit of easy work helps you build aerobic volume without adding unnecessary fatigue, leaving more room to recover before your next session.
Aerobic threshold, lactate threshold, anaerobic threshold, and VO₂ max all come up in endurance training. Each describes a different aspect of how your body handles exercise.
Aerobic threshold reflects your aerobic base and your ability to sustain an effort over time. It is commonly used to help define the range for low-intensity aerobic training.
Lactate threshold describes a threshold identified from changes in blood lactate. Its meaning depends on the definition and test being used. LT1 is closely related to AeT. The second lactate threshold (LT2) occurs at a higher exercise intensity.
Anaerobic threshold usually refers to an intensity near LT2 or the second ventilatory threshold. It marks the region where you are approaching the limit of your ability to sustain a hard effort. Above it, lactate accumulates more rapidly and the time you can keep going becomes limited.
VO₂ max is the maximum rate at which your body can take in, transport, and use oxygen during maximal exercise. It reflects the upper limit of your cardiorespiratory capacity, but it does not directly tell you what race intensity you can sustain. Even a high VO₂ max may not translate into strong endurance performance if your lactate threshold and aerobic base are underdeveloped.
There is no single number that makes an aerobic threshold 'good.' Age, fitness, sport, training history, and your current physical condition all influence it.
For context, research has reported VT1, a marker associated with AeT, at around 50–60% of VO₂ peak. Treat that as a broad reference rather than a target. Results vary with training status, test methods, and individual physiology. Well-trained endurance athletes can generally sustain a stable aerobic effort at higher intensities.
What matters in training is knowing which physiological threshold your threshold heart rate represents. That helps you set appropriate heart rate zones and manage intensity more accurately. Alongside how the effort feels, look at long-term changes in heart rate, pace, and power under similar conditions to assess whether your aerobic fitness is improving.
You can assess aerobic threshold in a lab or estimate it in the field. Lab tests use blood lactate or gas exchange data to identify physiological turning points. Field methods use cues such as your ability to talk, heart rate, and pace to guide training intensity. Results can differ between methods, so use the same approach and similar conditions when tracking changes over time.
1. Laboratory Assessment: Lactate and Gas Exchange Testing
Lactate Testing
Lactate testing measures blood lactate as exercise intensity increases in stages. The first clear change in the lactate curve can help estimate aerobic threshold.
In some protocols, LT1 may occur at a blood lactate concentration of around 1.5–2.0 mmol/L, but there is no single concentration that defines the threshold for everyone.
Gas exchange testing, performed during a cardiopulmonary exercise test (CPET), measures oxygen uptake, carbon dioxide production, and breathing patterns as exercise intensity increases. These measurements help identify physiological markers such as VT1.
By measuring respiratory and metabolic responses directly, CPET provides a detailed assessment of aerobic fitness. It requires specialized equipment and a controlled testing environment.
2. Field Estimation: Practical Methods for Everyday Training
The MAF Method (Maximum Aerobic Function)
The MAF method combines a training heart rate guideline with a repeatable way to track performance. The MAF 180 Formula starts with 180 minus your age, then adjusts for health and training history. The result provides a suggested training heart rate, rather than a direct measurement of your aerobic threshold.
The MAF Test tracks pace, speed, or power at a chosen heart rate. Repeating it over time can help you monitor progress, but changes in performance still need to be considered alongside the conditions and how you felt that day.
The Talk Test
The talk test is a simple way to gauge effort without specialized equipment. As you approach aerobic threshold, your breathing usually deepens, but you can still speak in full sentences and hold a reasonably comfortable conversation. As intensity rises further, talking becomes less comfortable.
The Heart Rate Drift Test
A heart rate drift test looks at how your heart rate changes during a sustained, steady effort. Choose a flat route, maintain a consistent pace or power output, and compare your heart rate in the first and second halves of the session.
A noticeable rise at the same output may suggest that the effort is becoming harder to sustain aerobically. A smaller change generally suggests that you are handling the effort well. Weather, fatigue, hydration, and route conditions can also affect heart rate drift. Use repeated tests to follow trends over time rather than treating a single result as a precise measurement of AeT.
Tracking Aerobic Fitness With Suunto
Your Suunto watch and Suunto app can help you follow changes in aerobic fitness over time. Metrics such as VO₂ max and training load, along with lactate threshold estimates on supported models, provide context for understanding how your endurance is developing.
For a closer look at exercise intensity around your aerobic threshold, use a compatible heart rate belt with Suunto ZoneSense. ZoneSense analyzes the timing between heartbeats to assess your body's response to exercise, helping you identify intensity changes associated with thresholds such as AeT and LT1. You can also review these insights after your workout.
These estimates can help guide training, but they do not replace laboratory lactate or gas exchange testing.
Improving aerobic threshold takes consistent endurance training at a level you can handle, plus enough recovery for your body to adapt. The aim is to sustain more speed or power with less physiological strain, rather than continually pushing your heart rate higher. Start from your current fitness, establish a routine you can maintain, and then adjust duration and intensity gradually.
1. Building an Aerobic Base With Easy Runs and Long Runs
Easy runs and long slow distance training both help you accumulate low-intensity endurance work. Regular easy runs build consistency, while gradually extending some of those runs develops your ability to keep going for longer.
Keep the effort below your individual AeT, at a level where you can talk comfortably. Let pace respond to the effort instead of pushing harder to hold a set number. If you use Zone 2 on your watch as a guide, first check the zone model and your personal settings.
If you are new to running or returning after a break, a run-walk approach can help you ease in. Daniels’ Running Formula includes the following session:
(1) Walk for 5 minutes.
(2) Run easily for 1 minute, then walk for 1 minute. Repeat 10 times.
(3) Finish with a 5-minute walk.
The session takes 30 minutes, with 10 minutes of running. Keep the running portions at E (Easy) intensity: relaxed, comfortable, and conversational. Use this as a starting point and adjust it to your fitness. You do not need to force yourself to complete every repetition or the full duration.
Source: Jack Daniels, Daniels’ Running Formula, 3rd ed., Human Kinetics, 2014. Chapter 7, “Fitness Training,” Table 7.1, “White Starting Plan,” Weeks 1–4, Day 1.
2. Improving Aerobic Threshold With Steady Aerobic Workouts
Once you have a consistent training routine, you can add steady aerobic workouts close to AeT. Here, 'steady' means holding an even, controlled output. It does not automatically mean lactate threshold intensity or a tempo run.
As you adapt, gradually extend your runs or increase distance. Change one variable at a time rather than increasing frequency, duration, and intensity together. With a compatible Suunto watch, you can create structured workouts in Suunto app with warm-up, main set, and cool-down phases to help keep the session on track.
3. Managing Training Intensity With the 80/20 Training Method
The 80/20 approach is a way to distribute training intensity: roughly 80% at low intensity and 20% at higher intensities. The easy work generally stays below AeT, helping you accumulate endurance volume and build an aerobic base. Harder sessions are chosen to match your goals and develop speed and the ability to sustain higher-intensity efforts. Together, they provide different training stimuli while helping you manage overall fatigue.
The ratio applies to your training over a period of time, not to every individual workout. It also changes depending on whether you count sessions or actual time at each intensity. Adapt the balance to your fitness, goals, and recovery rather than trying to hit the percentages exactly.
Learn more about Training Intensity Management here.
Tip: Finding your AeT is one step in building a training plan. As you record workouts with a Suunto sports watch, look at VO₂ max, training load, and heart rate variability (HRV) together to follow your training status and changes in aerobic fitness. Over time, that record can help you see how your body is responding and adjust the training ahead.
Takeaways
Aerobic threshold connects a physiological marker with everyday training decisions. Understanding it helps you choose appropriate intensities and track your endurance development over time. The value lies in how you apply it: train consistently, give your body time to adapt, and look for improvements in what you can actually sustain out on the road or trail.
FAQ
Is Aerobic Threshold the Same as Zone 2?
Not exactly. Aerobic threshold is a physiological reference point, while Zone 2 is a training intensity range. AeT often sits near the upper end of Zone 2 in five-zone models, but the boundaries vary by system.
Should I Train at or Below My Aerobic Threshold?
Keep everyday easy sessions below AeT. Steady workouts close to AeT are also useful, with intensity adjusted for session length, recovery, and conditions.
Can Walking Help Improve My Aerobic Base?
Yes, if it provides enough stimulus for your current fitness. Brisk walking or a run-walk approach helps beginners build endurance while keeping the effort manageable.
How Long Does It Take to Improve Aerobic Threshold?
There is no fixed timeline, because progress depends on your training history, consistency, volume, and recovery. Look for trends across a training block, such as a faster pace at the same heart rate under similar conditions.
Can an Aerobic Threshold Calculator Give an Accurate Result?
A calculator gives you an estimate, and its accuracy depends on the method and your input data. Treat the result as a starting point and check it against how you feel and perform during training.
Does Heart Rate Drift Mean I Have Exceeded My Aerobic Threshold?
Not necessarily. Heat, hydration, fatigue, and exercise duration can all raise your heart rate at a steady pace. Heart rate drift alone does not prove that you have exceeded AeT.
Running Heart Rate: What’s Normal and How to Use It
Sooner or later, most runners look back at their workout data and ask the same thing: “Is my heart rate normal when I run?” Yours might already be sitting at 160 bpm on what feels like an easy effort, while someone else holds a faster pace at a noticeably lower number. So what does that actually tell you?
Knowing what moves your heart rate, and how to read it while you train, helps you judge intensity accurately, make better decisions session to session, and notice when your body’s response to running starts to change.
At a Glance
Your running heart rate is a window into exercise intensity and how your body is responding to training.
Heart rate zones make intensity easier to control and easier to match to the goal of each run.
Running too fast, hot weather, dehydration, fatigue, and short sleep can all push your heart rate up.
Consistent training, real recovery, and better running habits improve your heart rate response over time.
Tracking your heart rate trends with Suunto gives you a clearer picture of your training progress and cardiovascular fitness.
What Is a Normal Running Heart Rate?
There is no single “normal” running heart rate. Whether your number sits in a reasonable range depends on the bigger picture: your age, maximum heart rate, fitness level, current exercise intensity, and overall physical condition.
Rather than chasing one universal number, here are a few ways to put your running heart rate in context:
1. Consider Your Maximum Heart Rate
Your maximum heart rate is an important reference point for gauging exercise intensity and setting your heart rate zones. Since factors such as age, genetics, and individual physiology can all affect maximum heart rate, two runners can have very different training intensities at the exact same heart rate.
The most common formula for estimating maximum heart rate is:
Maximum heart rate = 220 − age
Keep in mind that this is only an estimate. Your actual maximum heart rate may be quite different from the number predicted by the formula. For a more personalized approach, you can determine your maximum heart rate through testing and use the heart rate reserve (HRR) method to set your heart rate zones.
2. Consider Your Running Intensity and Training Goal
Runs are not meant to feel the same. Easy runs and long runs sit at lower intensities, while tempo runs, threshold sessions, and intervals are built to drive your heart rate up.
So the same heart rate means different things in different sessions. A number that looks high on an easy run can be exactly right in the middle of hard intervals.
3. Pay Attention to How You Feel
Heart rate isn't the only way to tell how hard you're working. Your own perception can provide valuable context, too.
The simplest version is the talk test. If you can hold a conversation reasonably comfortably while running, you are probably working at a lower intensity. Once you are down to short sentences, or a few words at a time, the intensity has climbed a long way.
4. Compare Your Heart Rate With Your Own History
Instead of comparing your heart rate with other runners, look at how your own heart rate changes under similar conditions: the same pace, the same route, the same weather.
If the same pace starts costing you a lower heart rate, or the same heart rate starts buying you a faster pace, your cardiovascular fitness and running efficiency are heading in the right direction.
Why Is My Running Heart Rate Higher Than Expected?
A higher-than-expected heart rate during a run doesn't necessarily mean something is wrong. Your pace, fitness level, weather, recovery status, and even the type of heart rate sensor you're using can all affect your heart rate while running.
1. Your Easy Pace May Be Too Fast
Many runners treat their usual pace as the definition of an easy run. But easy is set by effort, not by a number on the watch. It is defined by how hard that pace is for you right now.
If your current pace already sits above your aerobic capacity, your body has to work harder to meet the demands of the run, and your heart rate climbs into a higher zone even when the pace feels relatively slow.
Your easy pace also moves as your fitness improves. What feels comfortably easy today can be noticeably faster after a few months of consistent training.
2. Your Aerobic Base Is Still Developing
For newer runners, or anyone with less training behind them, a higher heart rate at the same pace often just means the aerobic base is still being built.
With consistent low-intensity aerobic training, your cardiovascular system and your ability to use oxygen become more efficient. Over time, the same pace starts costing you fewer beats, and you can run faster without driving your heart rate as high.
3. Heart Rate Sensor Limitations
Sometimes the number on your watch is telling only part of the story. Wrist-based optical heart rate sensors are sensitive to how tightly the watch is worn, arm movement, temperature, sweat, and skin contact.
When a reading looks out of step with how you feel, cross-check it against a Suunto heart rate belt. In sessions where heart rate swings quickly, such as intervals and tempo runs, a belt gives you steadier and more responsive feedback.
Plenty of other things can lift your heart rate above its usual level, including hot or humid weather, dehydration, short sleep, accumulated training fatigue, uphill running, rough terrain, caffeine, and psychological stress. Each one adds to the physiological demand of the run, so your heart works harder to hold the same pace and the number climbs even though your pace has not.
How to Use Heart Rate for Running Training
The most common five-zone model divides training intensity into Zone 1 through Zone 5, gradually moving from low-intensity effort to near-maximal exertion.
For runners, Zone 2, Zones 3–4, and Zone 5 are often the most relevant:
Zone 2 (around 60%–70% of HRmax) is the foundation for building aerobic fitness. Your breathing should remain controlled, and you should still be able to hold a simple conversation. It's well suited to easy runs, long runs, and everyday aerobic training.
Zones 3–4 (around 70%–90% of HRmax) cover moderate-to-high intensity training. As the intensity rises, your breathing becomes noticeably heavier. Zone 3 is commonly used for steady-state runs and some tempo work, while Zone 4 sits closer to lactate-threshold intensity and is often used for tempo and threshold training.
Zone 5 (around 90%–100% of HRmax) represents near-maximal effort. It's typically sustainable only for short periods and is most commonly reached during high-intensity intervals and sprint efforts.
Different heart rate zone models don't always use exactly the same percentage ranges. For general fitness guidance, the American Heart Association considers moderate-intensity exercise to be roughly 50%–70% of maximum heart rate, while vigorous exercise is around 70%–85%. Suunto sports watches use maximum heart rate as the default basis for calculating zones, while the Suunto Run also supports heart rate reserve (HRR) and lactate-threshold heart rate as alternative zone methods, allowing you to choose a system that better matches your training needs.
How to Lower Your Running Heart Rate
If your heart rate is higher than expected during a run, the most straightforward solution is usually to reduce your current exercise intensity. This is especially important during easy runs or Zone 2 sessions. You don't need to force yourself to maintain a certain pace if doing so keeps pushing your heart rate above your target range.
1. In the Moment
Here are a few things you can try:
Slow your pace: Give your heart rate some time to come down, then gradually pick up the pace again if it feels appropriate.
Use run-walk intervals when needed: If your heart rate remains high even after slowing down, take a short walking break and resume running once it has settled.
Adjust your goal to match how you feel that day: Hot weather, high humidity, fatigue, and poor sleep can all push your heart rate higher than usual. On days like these, it's perfectly reasonable to dial back your target intensity.
Don't go out too fast: Start with a proper warm-up and let your heart rate rise gradually before settling into your target training zone.
Don't fixate on a single heart rate number: Heart rate zones are just one tool for gauging training intensity. You don't need to force every run into a specific heart rate range simply to keep the number down. Instead, consider your pace, perceived effort, and training goal together when deciding how hard you're actually running.
Small adjustments to your running form may also help reduce unnecessary energy expenditure. For example, slightly increasing your cadence, avoiding overstriding, and minimizing excessive vertical movement can make your stride more efficient.
2. Long-Term Improvement
If you're looking to bring your heart rate down over time, consistency matters more than quick fixes:
Make low-intensity training a regular part of your routine: Zone 2 training can help build your aerobic base and is a valuable foundation for everyday running.
Increase your training load gradually: Rather than suddenly adding more mileage or intensity, build your workload progressively to give your body time to adapt.
Mix up your training intensity: Once you've established a solid low-intensity base, you can add different types of workouts based on your fitness level and goals, including tempo runs, interval training, and long runs.
Give your body enough time to recover: Avoid stacking hard sessions back-to-back, and keep an eye on recovery signals such as sleep, HRV, and overall fatigue.
Learn more about Recovery here.
As your training builds and your aerobic fitness improves, the same pace should start costing you a lower heart rate. Give it time. Adaptations like these usually take several weeks or more of consistent training before they show up clearly.
Monitor Running Heart Rate Over Time
A single run can tell you a lot about how your body responded that day, but it doesn't necessarily tell you much about long-term progress. Tracking and comparing your heart rate over time gives you a much clearer picture of how your body is adapting to training.
With a Suunto sports watch, you can monitor your heart rate in real time while running and review key metrics such as heart rate, pace, cadence, and vertical oscillation after your workout.
For more consistent and responsive heart rate tracking, you can also pair your watch with Suunto heart rate devices. Looking at heart rate alongside pace, training load, and recovery over time is far more informative than focusing on the highest heart rate from a single run.
Takeaways
The most useful question isn't simply whether your running heart rate is “high” or “low.” What matters is whether it matches your training goal, your current physical condition, and your long-term performance. Understanding your heart rate zones, managing training intensity appropriately, and tracking how your heart rate changes relative to your pace can turn heart rate data into a genuinely useful tool for better training.
How Yao Miao Adapted Her Way Back to the CCC Podium
Eight years after her last CCC, Yao Miao returned to the race carrying an injured knee.
She still finished third—her fifth Chamonix podium in six starts across eight years, giving her the second-highest number of top-three finishes in UTMB Finals history.
The challenge was formidable even before the race began. An emergency reroute increased the course from the planned 101 km to 107.8 km, with 6,198 m of climbing. Torrential rain turned the trails slick and muddy, while three former CCC champions—representing three generations of winners across six years—lined up in one of the deepest women’s fields the race had seen.
Yao stopped the clock in Chamonix at 12:15:41. When asked how she had remained at the top of the sport for so long, she gave a two-word answer:
HARD WORK.
The numbers show how much work went into her return. But this is not simply a story about how far she ran or how high she climbed. It is a story about what happened when her preparation stopped going to plan—and how, each time the race presented a new problem, she found a way to respond.
Build: Six Weeks of Relentless Preparation
878 km and 31,234 m of Climbing
In the six weeks before CCC, the SUUNTO APP recorded 98 hours and 34 minutes of training for Yao, covering 878 km with 31,234 m of elevation gain.
That is more than 16 hours of training and 5,000 vertical meters per week. To put the climbing in perspective, 31,234 m is roughly equivalent to ascending Mount Everest three and a half times. Athletes at a similar level typically accumulated around 20,000 to 25,000 m over the same period; Yao logged 5,000 to 10,000 m more.
The volume gave her the aerobic strength and climbing durability she would need in the Alps. Living and training in Lijiang at more than 2,400 m above sea level provided a strong altitude base, while arriving in Chamonix a month early gave her time to adapt before race day.
The foundation was there. Then, three weeks before the start, the plan changed.
Break: An Old Knee Injury Returns
On August 8, Yao aggravated an old knee injury at the Swiss round of the Golden Trail World Series.
Her response was not to train harder. It was to back off.
Over the following week, her elevation gain fell from approximately 5,000 m to 1,300 m—a reduction of more than 70%. Rehabilitation and active recovery replaced much of the workload.
The change was visible in her SUUNTO data. After consecutive mountain sessions and the strain of adapting to a new environment, her fitness balance had fallen to approximately -79.
In the final week before the race, her fitness level stood at 117, fatigue at 68, and fitness balance at +40. Her long-term fitness had dipped slightly, but fatigue had fallen much faster.
She had not trained her way back to a perfect peak. Instead, she had reduced fatigue faster than she lost fitness and arrived at the start line ready enough to compete. That distinction would shape everything that followed.
Rebuild: Training for the Race She Could Still Run
Yao’s preparation shifted along with her condition.
Across the six-week block, Yao logged approximately 91 hours across five heart-rate zones. Zone 2 aerobic work accounted for 31 hours and 3 minutes, while Zone 3 aerobic endurance and threshold work added another 25 hours and 30 minutes.
During the taper, she reduced her highest-intensity Zone 5 work by approximately 40 minutes while adding around five and a half hours in Zone 4. The emphasis moved away from all-out effort and toward sustained work closer to race intensity.
It was a measured compromise: preserve the engine, protect the knee, and reach the start line without making the injury worse.
Between July 29 and August 27, her average recovery reading was approximately 75%. It fell to around 20% at the worst point in early August, then returned to 80%–100% on most days from mid-August onward.
She had done what she could. The rest would depend on how well she adapted once the race began.
Race: Making Her Intentions Clear
The First 10 km: 1,400 m Up at 169 bpm
CCC offered no gentle introduction. The opening 9.4 km climbed approximately 1,400 m to Tête de la Tronche, with gradients reaching 35%.
Yao did not choose a conservative start. She averaged 8:47 min/km and approximately 169 bpm over the first 10 km, reaching the checkpoint as the leading woman in 1:22:34.
She also raced without poles. On gradients of up to 35%, that demanded exceptional leg strength and core stability while allowing her to conserve upper-body energy for the later stages.
It was a clear statement: the knee injury had changed her preparation, but not her ambition.
The next challenge was very different. Over roughly 20 km, the course dropped about 1,500 m—the kind of terrain most likely to expose an injured knee.
Yao ran the 30–40 km split at 4:50 min/km, descending 989 m. From kilometers 40 to 50, she accelerated to 4:32 min/km while descending another 584 m.
Downhill running can expose the knees to impact forces equivalent to three to five times body weight. At Yao’s approximate weight of 50 kg, each foot strike represented an estimated load of 150 to 250 kg. Over a 20 km descent—roughly 20,000 foot strikes—the cumulative stress was immense.
The speed was there, but the cost was becoming visible. Race footage showed her downhill movement tightening, a common protective response when the knee is painful. Toni McCann passed her from behind.
Yao adjusted again.
Her original strategy had been to conserve energy uphill, run normally on the descents, and attack the flatter sections. With the long downhill aggravating her knee, that plan was no longer realistic. She began pressing on climbs, where the discomfort was less severe, and easing back on descents and flatter terrain.
She could not control the injury. She could control how she raced around it.
Interrupted by a Train, Back Into the Lead
At around kilometer 68, CCC delivered another problem no training plan could anticipate.
Toni McCann reached a railway crossing just as a train was passing and officials stopped her for approximately two minutes. Yao arrived shortly afterward and was also held briefly.
Her watch captured the interruption. At around 7:07 into the race, her heart rate dropped sharply from approximately 145 bpm to 132 bpm. When the route reopened, it returned to around 150 bpm within minutes.
Yao refueled quickly, settled back into her rhythm, and retook the lead.
Then came one of the race’s decisive climbs. Between kilometers 70 and 80, the course gained 1,155 m. Yao averaged 9:24 min/km, 156 bpm, and approximately 145 W through the section. The steady power and heart-rate data showed that she had regained the lead without a reckless surge.
She reached Trient more than three minutes ahead of McCann. The gap narrowed to approximately 1:58 at kilometer 82.9, then to around one minute as Yao entered Vallorcine at kilometer 90.1. The race remained finely balanced.
The train had stopped her momentum. It had not stopped her race.
Endure: Passed Late, but Never Falling Apart
The final 17 km still contained approximately 787 m of climbing. By then, the accumulated fatigue, rain-soaked terrain, and persistent knee pain were converging.
Yngvild Kaspersen and Toni McCann both passed Yao in the closing stages. On the final climbs, the drive in her stride became visibly more restrained.
But she did not unravel.
Her heart rate remained mostly between 145 and 150 bpm, even as the terrain forced her pace to slow. Once she completed the final climb, she found another gear. Over the last 6.1 km, she averaged 6:11 min/km.
The podium order had been decided, but Yao was still racing. She reorganized her effort, kept moving, and ran across the finish line.
Afterward, she smiled and described the ordea:
“MY KNEE A LITTLE PAIN.”
The Result Was Third Place. The Story Was Adaptation.
Yao did not control the injury, the course change, the rain, the train crossing, or the two rivals who passed her late in the race.
What she controlled was her response.
She built an enormous training base. When her knee failed, she reduced the workload and prioritized recovery. When descending became painful, she changed her race strategy. When a train interrupted the competition, she reset and retook the lead. When she was passed in the final stages, she kept her effort together and finished running.
Third place was the result. But the real story was everything it took to get there. It was also Yao’s fourth consecutive podium in Chamonix—another chapter in a record built through consistency as much as speed.
HARD WORK.
For Yao, those words were not a slogan. They were the thread connecting every adjustment, every setback, and every step back to the podium.
The SUUNTO APP will keep recording the work behind whatever challenge comes next. And for Yao, as she turns the page to her next challenge, her journey promises to remain as extraordinary as ever—or simply put, Miao-velous.
What Is a Tempo Run? Intensity, Workouts and Tips
A tempo run looks simple from the outside: run a little faster than your easy pace. What it actually tests is your control of intensity. The effort has to be hard enough to create a real training stimulus and restrained enough to stay clear of an all-out effort that costs you days of recovery. Placed well in a training plan, tempo work becomes the bridge between everyday running and race day, teaching you to hold your breathing, your form, and your pace together as the effort builds.
At a Glance
A tempo run is a sustained effort at a moderately hard intensity.
Judge tempo intensity using pace, RPE, and heart rate together.
Runners at different fitness levels need different approaches to tempo training.
Plan your tempo runs around your overall training load and recovery.
Suunto helps you plan, track, and analyze your tempo training over time.
Table of Contents
Why Should You Do Tempo Runs?
How to Find Your Tempo Run Intensity?
Example Tempo Run Workouts for Different Levels
How Suunto Helps You Track and Improve Your Tempo Runs
FAQ
A tempo run is a sustained effort at a moderately hard intensity. Next to an easy run it is faster and carries a higher heart rate. Next to interval training it sits below maximal intensity and runs continuously rather than in short repeats.
You can run it as one continuous block or break it into several long tempo segments with short periods of easy running between them. What defines it is a steady, challenging effort, not a specific pace or a specific duration.
Typically:
Intensity: Close to lactate threshold
Duration: Around 20–60 minutes, depending on fitness level
Perceived effort (RPE): 7–8/10
Simply put, a tempo run should feel comfortably hard. The effort is clearly challenging, but you can still maintain a steady pace and good running form without pushing yourself close to exhaustion.
The main benefit of tempo running is that it trains your body to hold a steady effort at higher intensities.
1. Improve Lactate Threshold
Tempo runs are a mainstay of lactate threshold training and one of the most effective ways to raise your threshold and your ability to sustain higher intensities.
Lactate threshold is the intensity at which blood lactate starts rising more rapidly as exercise intensity increases. Consistent tempo training improves your body’s ability to process lactate, which lets you hold a steady effort at a faster pace.
2. Improve Running Economy
Tempo runs can also improve running economy, which describes how efficiently your body uses energy at a given pace. Regular higher-intensity running helps your body adapt to faster speeds and hold efficient form and steady pacing once fatigue arrives.
3. Improve Race-Specific Endurance
Tempo runs get you familiar with the intensity and pace that racing demands. For longer events such as the half marathon and marathon, they prepare your body for sustained work at higher intensity and build your ability to hold pace and effort when tired. Depending on your training plan, tempo work can sit alongside race-pace training, though the two are not identical.
4. Build Mental Resilience
Tempo runs train more than your legs. They also build your tolerance for fatigue and discomfort. Holding a higher intensity for an extended period means keeping your pace and effort under control while fatigue steadily builds.
Getting the intensity right is what makes a tempo run work. Too easy and the session lacks enough stimulus to drive adaptation. Too hard and it becomes interval training, with the fatigue and recovery cost that comes with it.
The three common ways to judge it are pace, rate of perceived exertion (RPE), and heart rate zones. Use them together rather than trusting any one on its own.
1. Pace
Pace helps you control your speed during a tempo run, but no single tempo pace works for everyone.
Your tempo pace shifts with fitness level, race performance, terrain, weather, and how you feel on the day. Two runners will have different tempo paces, and the same runner will need different paces under different conditions.
Treat pace as an external measure of output, read alongside RPE and heart rate, to confirm you are training at the intensity you intended.
2. Rate of Perceived Exertion (RPE)
RPE uses how the effort feels to judge exercise intensity.
In the commonly used 0–10 scale:
0: No effort at all
1–2: Very easy, with almost no strain
3–4: Easy, with comfortable conversation
5–6: Moderate effort, with a noticeable training load
7–8: Hard effort, requiring focus to maintain your pace
9: Very hard, close to maximal effort
10: Maximal effort, impossible to sustain for long
Tempo runs typically land at RPE 7 to 8 out of 10. Breathing is noticeably faster at that intensity. You can still exchange a few words, though holding a normal conversation is difficult.
3. Heart Rate Zone
Heart rate gives you a more direct read on the load your body is carrying than pace alone, which makes it a useful reference through a tempo run.
Some training systems place tempo intensity at around 85% to 90% of maximum heart rate, though the exact range varies by system and by individual. Because zone models draw their boundaries differently, defining a tempo run simply as zone 3 or zone 4 is unreliable.
Percentages of maximum heart rate are a general reference, and different zone models produce different training zones. Suunto lets you set heart rate zones from your own data, so you can use real-time heart rate to gauge your intensity through a tempo run.
The workouts below are examples. Set your actual tempo intensity from your own pace, RPE, or target heart rate zone.
1. Beginner: Short Tempo Intervals
For runners new to tempo training, breaking the work into shorter efforts with easy running between them is a good place to start.
Example:
5 minutes of easy running to warm up
3 minutes of tempo running, followed by 1 minute of easy running; repeat twice
5 to 10 minutes of easy running to cool down
This structure gets beginners familiar with tempo intensity. As they adapt, they can gradually add repetitions.
2. Intermediate: Longer Tempo Efforts
Once shorter tempo efforts feel comfortable, extend the length of each tempo segment.
Example:
15 to 20 minutes of easy running to warm up
15 to 30 minutes of tempo running
10 to 15 minutes of easy running to cool down
Compared with shorter intervals, this asks you to hold a steady intensity for longer, which puts the emphasis on sustained effort.
3. Advanced: Continuous Tempo Run
Runners with a solid endurance base and experience of tempo training can focus on holding a steady effort through one longer continuous block.
Example:
15 minutes of easy running to warm up
30 to 40 minutes of continuous tempo running
For half marathon and marathon training, longer tempo runs work as race-specific sessions that prepare you for sustained higher intensity. McMillan also lists 15 to 40 minutes of continuous tempo running as a form of lactate threshold training in its half marathon training guide.
Tip: Progress your tempo runs gradually. As the effort becomes more manageable, extend the tempo duration, shorten the recovery between intervals, or build toward a longer continuous block. If you struggle to maintain the target intensity or your pace drops noticeably in the second half, reduce the tempo duration or allow more recovery before progressing further.
Suunto sports watches support tempo training from end to end: planning the workout, following it through the run, and reviewing it afterward.
1. Before Running
Create a Workout & Set Target Zones
On Suunto watches that support structured workouts, you can build a session in the Suunto app and sync it to your watch. Some models also let you create simple structured workouts on the watch itself. For example:
15 minutes of warm-up
30 minutes of tempo running with a target heart rate zone
Repetitions and workout steps set as needed
10 minutes of cool-down
During the session, your watch guides you through each step and helps you hold your target intensity.
2. During Running
Through a tempo run, Suunto tracks your training in real time:
Heart Rate
Check that you are holding your target training zone. It keeps the intensity high enough to create a real stimulus and controlled enough to stay clear of interval territory.
Pace and Distance
Watch that your pace stays steady while the session meets its intended goal. A tempo run is built on consistent effort, so steady pacing matters. The aim is to finish the workout as planned rather than let fatigue cut it short.
3. After Running
Afterward, Suunto helps you review:
Training Load
See what the tempo run contributed to your overall training load, so you can keep the stimulus meaningful and spot a sudden jump before it disrupts the sessions ahead.
Progress Over Time
Tracking CTL, ATL, TSB, and VO₂ max shows how your training load, training status, and aerobic fitness are moving over time.
The Suunto app and compatible watches let you review long-term training data, including training history and training trends.
Recovery Needs
Recovery after a tempo run depends on sleep, HRV, training fatigue, and your daily condition. The Suunto app and your watch help you read your recovery status and decide whether to run the next session as planned or ease the intensity and give yourself more time.
Finding the right intensity, and adjusting your volume as your fitness changes, is what makes every tempo run serve your long-term goals. Read training intensity, body feedback, and long-term data together and a tempo run becomes more than a faster session. It becomes a deliberate, adaptable part of your training plan.
FAQ
What Is a Tempo Run for 5K?
For 5K runners, tempo pace usually sits slower than 5K race pace but hard enough to create a training stimulus, typically held for 20 to 40 minutes. Set the exact pace from your fitness level, using RPE 7 to 8 out of 10 as a reference alongside heart rate and perceived effort.
Is a 20-Minute Tempo Run Good?
Yes.
A 20-minute tempo run is a classic workout format. For beginners, 20 minutes already delivers an effective training stimulus. More advanced runners can extend it to 30 to 40 minutes or move to longer tempo intervals.
What Is a 3:2:1 Tempo Run?
A 3:2:1 tempo run is a progressive tempo workout built from segments of different lengths, typically 3 minutes, 2 minutes, and 1 minute, with intensity rising through each one. It is good practice for pace control and for holding a higher effort as fatigue builds.
Do Tempo Runs Increase VO₂ Max?
Tempo runs can contribute to VO₂ max, though they are not the primary type of training used to develop maximum oxygen uptake. Those gains come mainly from high-intensity interval training and repeated efforts close to VO₂ max intensity.
Tempo runs primarily improve lactate threshold, aerobic endurance, and your ability to sustain higher intensities.
What Is CTL? A Guide to Long-Term Training Fitness
In endurance sports, one workout only tells part of the story. Long-term fitness is built from the training you accumulate across weeks and months, and from how well your body adapts to it. Chronic Training Load (CTL) is the metric that tracks that longer arc. Here is how it is calculated, how to read it, and how to use it to plan your training and recovery.
At a Glance
CTL reflects long-term training load and the fitness you have accumulated.
TSS measures the stress of a single workout, while CTL, ATL, and TSB track long-term load, short-term fatigue, and the balance between them.
There is no single best CTL. The right one is the level you can sustain.
Build your training load gradually and give recovery enough room.
Read CTL alongside performance and recovery rather than chasing a higher number.
Suunto tracks CTL, training load, and recovery so you can follow your long-term progress.
Table of Contents
What Is CTL?
How Is CTL Calculated? From TSS to CTL, ATL, and TSB
What Is a Reasonable CTL?
How to Build Your CTL Safely
How Does Suunto Help You Track CTL and Training Progress?
What Is CTL?
As training accumulates, your body adapts to the stress of exercise and your fitness moves with it. A run that felt hard a few months ago can feel comfortable after a consistent block of training.
That change is the product of accumulated load rather than any single session. CTL (Chronic Training Load) is the metric that tracks the accumulation. It is a useful reference for your training base and your fitness trend, though it measures load rather than fitness itself.
In the Suunto training load system, CTL is a weighted average of your training load across the past 42 days by default, so it reflects how the last several weeks of training have fed your long-term base.
In training load analysis, CTL, ATL, TSS, and TSB are not independent metrics. They are all part of the same training load framework:
Metric
Meaning
What It Reflects
TSS
Training stress
The impact of a single workout
CTL
Long-term training accumulation and training base
ATL
Acute Training Load
Fatigue from recent training
TSB
Training Stress Balance
The relationship between long-term load and recent fatigue
From TSS to CTL and ATL
CTL is not built from training time, distance, or the intensity of any one session. It is built from the TSS (Training Stress Score) each workout generates. Think of CTL as a weighted average of daily TSS across the past 42 days, with recent training carrying more weight than older training.
TSS scores the stress of a single workout, usually from duration and intensity together. A long easy session and a short hard one can land on a similar TSS despite being very different workouts.
As training accumulates, past TSS values feed both the long-term and the short-term view of your load.
CTL holds the long view. ATL is a weighted average of TSS over the past 7 days, so it reflects recent load and the fatigue that comes with it. TSB is the gap between the two, which is what tells you how long-term load and recent fatigue are sitting relative to each other.
Because CTL covers a long window, one heavy session barely moves it. It shifts slowly as load accumulates. ATL is far more reactive and climbs quickly when volume jumps, which is exactly what makes it a good read on recent fatigue.
TSB: Connecting Training Load and Recovery
In the training load system used by Suunto:
TSB = CTL − ATL
A simple way to understand TSB is:
TSB < 0: Recent fatigue is relatively high, which is common when training load is increasing.
TSB ≈ 0: Long-term training load and recent fatigue are relatively balanced.
TSB > 0: Recent training load is lower than long-term training load, generally indicating lower levels of fatigue.
How Do These Metrics Work Together in Training?
During a training load build-up, increasing TSS usually causes ATL to rise more quickly, while CTL gradually increases as training accumulates. TSB may fall, reflecting the buildup of fatigue alongside the increased training stimulus.
During a pre-race taper, reducing training volume causes ATL to drop more quickly, while CTL declines more slowly. As a result, TSB rises. This allows athletes to reduce recent fatigue while maintaining the training base built through long-term training.
There is no single best CTL that works for everyone. A reasonable CTL depends on factors such as the sport, training experience, race goals, weekly training volume, and ability to recover.
For cyclists, CTS Coaches notes that CTL can vary widely. Century and non-competitive Gran Fondo riders are often around 40–100, while Masters racers and other competitive cyclists commonly fall around 70–120.
These numbers are best used as reference ranges, not fixed targets. Instead of asking how high your CTL should be, start by asking: Does this CTL match your current training level, and can you maintain it consistently over time?
Your CTL Trend Matters More
The trend in your CTL can help you understand how your training is progressing:
CTL steadily increasing: Usually indicates that your long-term training load is building and can be a sign of growing training fitness.
CTL staying stable: May mean you’re maintaining your current training base or going through a period of race preparation or training adjustment.
CTL gradually decreasing: Doesn’t necessarily mean your fitness is declining. Recovery periods, reduced training, or a pre-race taper can all cause a temporary drop in CTL. However, if training volume stays low or stops for a long period, a continued decline may reflect reduced training stimulus.
CTL quickly increasing: Means training load is building rapidly. If the increase outpaces your ability to recover and adapt, you may experience accumulated fatigue, lower training quality, longer recovery times, or declining performance.
TrainingPeaks coaching resources have suggested adding around 5–8 CTL points per week as a general reference, but this is a rule of thumb for training planning, not a target that applies to every athlete.
Training experience, current CTL, injury recovery, sleep quality, life stress, and recovery capacity all affect how quickly you can safely build your CTL. For beginners, those returning to training, or anyone who hasn’t been recovering well, a much slower rate of increase may be more appropriate.
When building CTL, the key is to find the right balance between training and recovery:
Progress gradually: Avoid large increases in training volume or intensity over a short period.
Stay consistent: Consistent training over time is more effective for building CTL than occasional sessions with an extremely high training load.
Plan recovery periods: CTL may temporarily drop when training load is reduced, but that doesn’t mean you’ve lost the benefits of your previous training.
Listen to your body: If you’re experiencing persistent fatigue, declining workout quality, or poor recovery, adjust your training rather than continuing to chase a higher CTL.
For endurance athletes, the value of training load data lies in understanding whether your training is driving positive adaptations and how to adjust your training next. By tracking data such as heart rate, workout duration, exercise intensity, and training history, Suunto helps you monitor long-term changes and plan your training more effectively.
Where Can You See CTL in Suunto?
Supported Suunto watches and the Suunto App let you view training load, training trends, and progress over time.
In the Suunto App
Go to DASHBOARD > PROGRESS or TRAINING ZONE > PROGRESS to view your training trends.
On your watch
You can add the PROGRESS or TRAINING widget from the app menu. The metrics available may vary by model. On Suunto Run, you can use the Training Volume widget to view your training information for the current week. Ramp Rate shows how quickly your CTL is increasing or decreasing over time.
How Can CTL Guide Your Training?
CTL is steadily increasing, with good recovery and performance: Your current training load is generally manageable. You can maintain your current training rhythm and gradually increase the load according to your plan.
CTL is rising too quickly, ATL is climbing rapidly, and TSB remains low: Your recent training load may be increasing too fast. Look at your performance and recovery to decide whether to reduce training volume or schedule more recovery.
CTL temporarily drops, while recovery and performance improve: This may be a normal part of a recovery week or pre-race taper. There’s no need to increase training load just to keep CTL from dropping.
You can also consider sleep, HRV, perceived fatigue, muscle soreness, and training performance to get a more complete picture of whether your current training load is right for you.
Learn more about recovery here.
Takeaways
CTL is not a score to push higher. It is a way of understanding your long-term training. Rather than chasing a specific number, find a training rhythm you can sustain, built around your goals, your recovery, and what your performances are actually telling you.
