1 / 7
Suunto Traverse Alpha Concrete
1/7
Money-back guarantee
30-Days Return
Global Support
SKU: SS023446000
Note: Prices may vary slightly due to exchange rates. The final amount will be shown at checkout.
GPS/GLONASS watch with versatile outdoor functions for fishing and hunting
30-Days Return
Global Support
Sold out
Go explore
Suunto Traverse Alpha combines strong build quality with a full set of outdoor features. It is your guide in the wild, keeping you on track with GPS/GLONASS navigation. Specific fishing and hunting features provide useful tools for your activity, including moon phase calendar, shot detection, sunrise alert, weather trend, and red backlight for nighttime use. Plan your routes and keep a diary of your fishing and hunting trips with Suunto Movescount. The strap pattern in Traverse Alpha Concrete draws inspiration from the camouflage pattern used by the Finnish military.
PRODUCT HIGHLIGHTS
  • Master your territory with GPS/GLONASS navigation
  • Dedicated functions for fishing, hunting and hiking
  • Made in Finland, tested to military standards
SPECIFICATIONS
  • Measurements
    50 x 50 x 15 mm / 1.97 x 1.97 x 0.59 "
  • Weight
    75 g / 2.65 oz
  • Bezel material:
    Stainless steel
  • Glass material:
    Sapphire crystal
  • Case material:
    Composite
  • Strap material:
    Textile
  • What's in the box?
    Suunto Traverse Alpha Concrete, USB cable, quick guide, warranty leaflet
  • Country of manufacture
    FI
TECHNICAL SPECIFICATIONS
  • Bezel material
    Stainless steel
  • Glass material
    Sapphire crystal
  • Case material
    Composite
  • Strap material
    Textile
  • Weight
    75 g / 2.65 oz
  • Flashlight backlight option
  • Vibration alert
  • Water resistance
    100 m
  • Battery type
    rechargeable lithium-ion
  • Firmware upgradable
  • Time, date
  • Alarm clock
    1 daily alarm
  • Dual time
  • Automatic timekeeping
  • Countdown timer
  • Stopwatch timer
  • Language
  • Backlight
    LED
  • Configurable backlight
    color / brightness / mode
  • Button lock
    customizable
  • Invert display
  • Display type
    matrix
  • Display resolution
    128 x 128
  • Metric and imperial units
  • Battery indicator
    percentage / icon
  • Memory left indicator
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
BATTERY LIFE
  • In time mode
    14 days
  • Training mode with GPS
    10, 15, 100 h
COMPASS
  • Digital compass
  • Tilt compensation
    full
  • Declination correction
  • Direction scale
    degrees / mils
  • Needle
    north indicator
  • Compass accuracy
  • Compass resolution
CONNECTIVITY
    Bluetooth Smart
  • Watch customization
    USB cable
  • Data transfer
    Wireless / USB cable
    with Suunto App
    Strava, TrainingPeaks, MapMyFitness and others (available in Suunto app)
  • Smartphone compatibility
    Most common models supported
SUUNTO APPS
  • Compatible with Suunto Apps
  • Max. nr. of apps per sport mode
    4
  • Logging of app specific metrics
  • Most recommended apps by activity
  • Create own metrics with advanced formulas
  • Chrono, GPS, HR, weather and altitude data
  • Rich math functions, if/then-logic, sound, backlight, etc.
24/7
ACTIVITY TRACKING
  • Step counter
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
  • Satellite systems
    GPS, GLONASS
  • GPS recording rate
    Best, Good, OK
  • Coordinate systems
    WGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000)
  • Max. nr. of Points of Interest (POIs)
    250
  • Find back
    in Suunto Movescount.com
  • Route altitude profile navigation in real-time
  • Route points per route / POIs in watch
    1000 / 250
  • GPS track analysis
    in Suunto App
  • Track back
    yes, incorporated with breadcrumb trail
    in Suunto App
  • Route planning
ALTIMETER
  • Barometric altitude
  • Altitude graph
  • GPS altitude
  • Altitude difference
    in log summary, and real time as an App
  • Total ascent/descent
    air pressure based
  • Vertical speed
    air pressure based
  • Automatic alti/baro profile
  • Log recording rate
    1, 10 s
  • Resolution
    1 m
  • Range
    -500 - 9999 m
WEATHER
  • Sunrise/sunset times
  • Storm alarm
  • Sea level pressure
  • Temperature
  • Temperature display range
    -20° C to +60° C / -4° F to +140° F
  • Temperature resolution
  • Pressure resolution
    1 hPa / 0.03 inHg
  • Max weather recording length
    past 26 hours
  • Moon phase calendar
  • Sea level pressure graph
  • Tide information
    yes** ** available as Suunto Apps
  • Weather trend indicator
TRAINING FUNCTIONS
HEART RATE
  • Calories
    1, 10 s
  • Heart rate in % of max hr
SPEED AND DISTANCE
  • GPS speed and distance
    Integrated
  • Chrono
  • Distance based autolaps
  • Laps
    > 1000
    1, 10 s
  • Autopause
TRAINING LOAD
  • Log summary on the watch with lap details
  • Training analysis
    in Suunto App
  • Training logbook with story and image support
    in Suunto App
SPORT EXPERTISE
CYCLING
  • Cycling speed
    based on GPS
  • Average speed in real time
    based on GPS
RUNNING
  • Running pace
  • Suunto FusedSpeed™
  • Average pace in real time
  • Lap comparisons by kilometer/mile
HUNTING
  • Automatic shot detection
  • Hunting specific POI types
  • Moonrise / moonset alert
  • Moonrise and moonset times for selected date
  • Red backlight, compatible with night vision goggles
  • Sunrise / sunset alert
FISHING
  • Fishing specific POI types
  • Storm alarm
  • Temperature
SPORT MODES
    5 modes / 4 displays per mode
Videos
Suunto Traverse's display views.
How to change time and date settings on Suunto Traverse and Traverse Alpha GPS watches.
How to change unit settings on Suunto Traverse and Traverse Alpha GPS watches.
How to change display contrast on Suunto Traverse and Traverse Alpha GPS watches.
How to change language on Suunto Traverse and Suunto Traverse Alpha GPS watches.
First time start up with Suunto Traverse.
How to change vibration settings on Suunto Traverse and Traverse Alpha GPS watches.
Support for Suunto Traverse
Find how to videos, FAQs, tutorial articles and detailed support information for your Suunto watch.
