Made in Finland
Limited lifetime warranty
Mirror for sighting bearings
Exceptionally stable & fast needle
Baseplate with magnifying lens
Luminescent markings for low light
🔺See the Run Ahead
Spring Adventure | New Prices |
| Free returns
Lightweight sports watch designed for runners
The ultimate performance watch out now!
Shopping Cart
Your cart is empty
Money-back guarantee
30-Days Return
Warranty Repair
A professional mirror compass with top-of-the-line features for direction and slope measurements for mountain adventures.
30-Days Return
Warranty Repair
Made in Finland
When venturing out into new territory, MC-2 sighting compasses offer precision navigation with a variety of carefully engineered and dependable features for challenging conditions. Depending on the variant, MC-2 comes with Metric UTM scales and inch ruler or USGS UTM scales.
The Earth’s magnetic field does not flow evenly between the magnetic poles along the surface of the planet. To compensate for the natural tilt in the magnetic field, Suunto compasses use one of two balancing systems and you should choose the variant best serving your needs.
One is a two-zone system with needles balanced for either the northern or southern hemisphere. The second is a unique globally balanced system. A single needle is balanced to work anywhere in the world. This is achieved by a breakthrough construction allowing the needle and magnet to tilt independently.
Correct the declination between map north (North Pole) and magnetic north for trusted navigation. Read more about declination correction.
The compass liquid used by Suunto is specially formulated to provide damping over a large temperature range while preventing the needle from sticking.
The mirror on a compass serves the dual purpose of allowing you to sight bearings accurately and facilitating signaling by reflecting sunlight.
Sighting holes and notch in a compass facilitates precise navigation by allowing you to align the compass with distant landmarks and obtain accurate bearings.
The clinometer is useful in uneven terrain where you need to determine slope gradient to pinpoint your exact location. It also helps to measure altitude.
The lanyard with wristlock is easy to detach for working with the map.
All Suunto compasses are handcrafted at our factory with 100% renewable energy.
