Made in Finland
Limited lifetime warranty
Exceptionally stable & fast needle
🔺See the Run Ahead
Spring Adventure | New Prices |
| Free returns
The ultimate performance watch out now!
Shopping Cart
Money-back guarantee
30-Days Return
Warranty Repair
A robust, easy to use compact compass for general recreational use.
30-Days Return
Warranty Repair
Made in Finland
Fast, simple and accurate, A-10 baseplate compasses are quick to learn and ideal for navigating with a map and compass. For calculating the distances, A-10 has both metric and empirical scales printed in red to stand out on topographic map.
The Earth’s magnetic field does not flow evenly between the magnetic poles along the surface of the planet. To overcome this, A-10 has two variants with needles balanced for either the northern or southern hemisphere.
The compass liquid used by Suunto is specially formulated to provide damping over a large temperature range while preventing the needle from sticking.
The lanyard with wristlock is easy to detach for working with the map.
All Suunto compasses are handcrafted at our factory with 100% renewable energy.
