To see your heart rate and other data from Suunto Smart Heart Rate Belt 2, pair the transmitter with a compatible Bluetooth host device, such as a Suunto watch, a bike computer or your phone. Here is how to pair it:
Black Size XS/S
Precision for Serious Training.
Accurate heart rate and R-R data for athletes who train by intensity.
Choose Your Color
IN THE BOX
- 1 Suunto Smart Heart Rate Belt 2 Smart Module ×1
- 2 Suunto Smart Heart Rate Belt 2 Chest Strap ×1
- 3 Quick Guide ×1
- 4 Warranty ×1
Pairing procedure
Specifications
MeasurementsXS/S: 66-102 cm / 26-40.2" M/L: 74-125 cm / 29.1-49.2"
WeightXS/S: 50.2 g / 1.77 oz M/L: 54.1 g / 1.91 oz
Strap material:Module: Stainless steel cover plate + fiber reinforced composite material Chest Strap Material: Polyamide/elastane on polyurethane contact surfaces
What's in the box?Suunto Smart Heart Rate Belt 2 smart module, Chest strap, Printed user documentation
Cleaning InstructionsRinse after each use. After 2-3 uses, remove the smart module and machine-wash the chest strap at 30°C. Never use any fabric softener.
Country of manufactureCN
Technical specifications
Removable Sensor Module✔
Replaceable Chest Strap✔
WeightSmart Module: 12.8 g, XS/S Chest Strap: 37.4 g, M/L Chest Strap: 41.3 g
Smart Module Dimensions36.5mm x 36.5mm x 8.5mm
Chest Size RangeXS/S: 66-102 cm, M/L: 74-125 cm
Water Resistance Depth30 m (suitable for swimming)
MaterialSmart Module: Stainless steel cover plate + fiber reinforced composite material, Chest Strap: Polyamide/elastane on polyurethane contact surfaces
CONNECTIVITY
Bluetooth PairingUser controlled acceptance of who can connect. Connection is encrypted.
Supported concurrent Bluetooth connections3
Bluetooth VersionV5.4
Bluetooth Chip Type/ModelnRF54L15-QFAA
Bluetooth Transmission Frequency2.402~2.480 GHz
Bluetooth Transmission Power<0dBm(-6dBm)
Bluetooth Transmission Range (In Open Space Without Obstacles)>10 meters
PHYSICAL SPECIFICATIONS
Operating Temperature0℃~ +55℃
Storage Temperature-20℃~ +55℃
Operating Relative Humidity45~85%RH
BATTERY LIFE
Easy Battery Replacement✔
BatteryCR2032
Standby Time3 years
Working Hours460h
CurrentShutdown Current: <10uA Operating Current: <10 mA
VoltageAlarm Voltage: 2.7V Power-Off Voltage: 2.6V Rated Voltage: 3.0V
SPORT EXPERTISE
RUNNING
Running Form measurementYes
TRAINING FUNCTIONS
HEART RATE
Heart Rate Measurement✔
Heart Rate Variability Measurement✔
Memory functionYes for the Heart rate variability and heart rate. The memory is only compatible with Suunto Watches. The memory is 20 hours long with a heart rate of 180 BPM.
Recommended products
1. Compatibility: The Suunto Smart Heart Rate Belt 2 is compatible with selected Suunto sports watches. Supported features vary by watch model.
2. Core features: Heart rate, RR intervals, memory, and ZoneSense are supported on Suunto Vertical, Vertical 2, Race, Race 2, Race S, Run, Run 2, and Ocean.
3. Running Form: Supported on Suunto Vertical 2, Race, Race 2, Race S, Run and Run 2. On selected models, Running Form requires a custom sport mode, Suunto Plus, or post-workout analysis.
4. For further information on Suunto Smart Heart Rate Belt 2 compatibility and supported features by watch model, please contact Suunto customer support.
