1 / 12
SUUNTO EON CORE BLACK
1/12
Money-back guarantee
30-Days Return
Warranty Repair
SKU: SS022740000
Suunto EON Core
Black
26,750 ฿
The traditional outdoor watch for off-grid adventures.
  • Mineral crystal screen with composite bezel
  • Large vivid screen and large buttons
  • Dive functions, and digital compass features built with Suunto Fused? RGBM 2 decompression model
  • 10 to 20 hours of diving time, full charged
  • Maximum operating depth up to 80m
  • All diving modes, customizable for your own display
  • Display up to 10 tank pressures on watch with Suunto Tank Pod
    Choose Your Color
    Quantity
    Free shipping on orders of ฿6000 or more.
    26,750 ฿
    Compare +
    30-Days Return
    Warranty Repair
    Customizable
    Digital compass
    Wireless tank pressure
    For all diving
    Wireless mobile connection
    Outstanding readability with great versatility
    BENEFITS
    Easy to read
    Read all the important diving details at a glance from a clear, legible screen. Large numbers and texts with high contrast colors are easy to see even in murky waters or when diving at night time.
    Grows with you
    Suunto EON Core is ready out-of-the-box, but you can easily customize your own dive modes in Suunto app. Choose from different view styles and select the details you want to see while diving. By customizing your dive modes you can also define your settings regarding gas, algorithm and dive alarms. User updatable software easily via Suunto Link makes Suunto EON Core a loyal diving partner for years to come.
    Compact and comfortable
    The lightweight composite case with an elastomer strap or bungee is comfortable to use both on a wrist or with a dry suit. The display's resistant mineral glass shields the screen from scratches and large buttons are easily pressed with or without gloves. Suunto EON Core comes in pure white, fresh lime or always stylish black, and is conveniently rechargeable through USB.
    Connect and transfer
    Follow your gas pressure conveniently straight from your wrist. Get tank pressure on your display wirelessly by pairing your Suunto EON Core with the Suunto Tank POD before diving.
    Transfer your dive logs easily over Bluetooth to your mobile phone. In Suunto app you can relive, and share your diving adventures, build an all-inclusive dive history by enriching your dive logs with photos, comments and dive location. Review and analyze all your dive data including dive time, maximum depth, device settings, gas consumption (when using Suunto Tank POD).
    Suunto app is available in the App Store and Google Play.
    SPECIFICATIONS
    • Weight
      154 g / 5.43 oz
    • Bezel material:
      Composite
    • Glass material:
      Mineral crystal
    • Case material:
      Reinforced composite
    • Strap material:
      Elastomer, Bungee
    • What's in the box?
      Suunto EON Core Black, USB Cable, Quick Guide, Safety leaflet, Display scratch guard sticker, International warranty leaflet
    • Country of manufacture
      FI
    TECHNICAL SPECIFICATIONS
    • Bezel material
      Composite
    • Glass material
      Mineral crystal
    • Case material
    • Strap material
      Elastomer, Bungee
    • Weight
      154 g / 5.43 oz
    • Flip display
    • Water resistance
      80 m (ISO 6425, EN 13319)
    • Battery type
      rechargeable lithium-ion
    • Firmware upgradable
    • Time, date
    • Alarm clock
      1 daily alarm
    • Stopwatch timer
    • Language
    • Backlight
      LED
    • Configurable backlight
    • Display type
      color TFT
    • Display resolution
      320 x 240
    • Metric and imperial units
    • Battery indicator
      icon + dive hours remaining
    PHYSICAL SPECIFICATIONS
    • Operating temperature
    • Storage temperature
    COMPASS
    • Digital compass
    • Tilt compensation
      up to 45°
    • Declination correction
    • Direction scale
      degrees
    • Needle
      compass rose
    • Globally balanced
    • Compass accuracy
      +/- 15°
    • Compass resolution
      1°
    CONNECTIVITY
      inductive (up to 20 Tank PODs), Bluetooth Smart
    • Compatible with Suunto app
    • Compatible with SuuntoLink
    • Compatible with DM5
    • Log transfer
      Bluetooth Smart / USB cable
    • Smartphone compatibility
      Most common models supported
    OUTDOOR FUNCTIONS
    WEATHER
    • Temperature
    • Temperature display range
    • Temperature resolution
      1° C / 1.5° F
    DIVING FUNCTIONS
    BASIC
    • Altitude adjustment
    • Ascent time display
      0 - 999 min ( > after 999)
    • CNS/OTU (OLF) calculation
    • Custom displays
      4 per dive mode
    • Decompression model
      Suunto Fused™ RGBM 2
    • Decompression profile options
      continuous and stepped
    • Deep Stop
    • Dive history
      lifetime
    • Dive time
      0 to 999 min
    • Gas consumption (real-time)
    • Gas max pO2
      manual 0.5 - 1.6 / fixed 1.6
    • Gas switching
    • Gas time
    • Gases
      up to 10 gases (Oxygen 5 - 99% / Helium 0 -95%)
    • Gauge
    • Logbook bookmarks
    • Logbook memory
    • Logbook sampling rates
      10 s
      80m
    • Nitrox (and air)
    • No fly time
    • No-decompression planner
    • Personal adjustment
      P+2, P+1, P0, P-1, P-2
    • Rebreather (CCR), fixed point
    • Safety Stop
    • Surface time
      0 to 100 h
    • Timer
    • Trimix (mixed gas)
    • Visual style
      Classic/Graphical/Prominent
    • Wireless air integration
      optional (up to 20 different tanks with Suunto Tank POD)
    DIVE ALARMS AND NOTIFICATIONS
    • CNS/OTU (OLF) 80% / 100%
    • Deepstop violation
    • Diluent high pO2
    • Diluent low pO2
    • Diluent switched automatically
    • Dive time
    • Gas time
    • High pO2 (hyperoxic)
    • ICD warning
    • Low pO2 (hypoxic)
    • Maximum depth
    • Tank pressure
    • Too fast ascent
    REBREATHER
    • Diluents
      up to 10 diluents (Oxygen 5 - 99% / Helium 0 - 95%)
    • Bailout
    • High/low setpoints
    • Custom setpoint
    • Manual/automatic setpoint switching
    Recommended products
    HOW TO USE VIDEOS
    You can now create dive modes for the Suunto EON family and Suunto D5 in Suunto app.
    How to adjust basic settings on your Suunto EON Core dive computer.
    How to get started with your Suunto EON Core dive computer.
    How to connect a Tank POD to your Suunto EON Core.
    How to attach the Bungee Adapter Kit on your Suunto EON Core.
    How to activate alarms on your Suunto EON Core dive computer.
    How to set gasses on your Suunto EON Core dive computer.
    How to use the dive planner on your Suunto EON Core dive computer.
    Support for Suunto EON Core
