Activation and pre-checks
Unless the dive mode turned off, the dive mode activates automatically when you dive deeper than 1.2 m (4 ft). However, you should switch to dive mode before diving to check altitude and personal settings, battery condition and so on.
Each time your Suunto DX enters dive mode, a series of automatic checks are performed. All graphical display elements are turned ON, and the backlight and the beep are activated. After this, your altitude and personal settings are displayed along with the maximum operating depth (MOD), gas content, and PO2 values. Then the battery level is checked.
Between consecutive dives, the automatic checks also show current tissue saturation.
Before leaving on a dive trip, it is highly recommended that you switch to dive mode to make sure everything is functioning properly.
After the automatic checks, Suunto DX enters surface mode. At this point, you should perform your manual checks before entering the water.
Ensure that:
Suunto DX is in the correct mode and provides complete displays.
- Altitude setting is correct.
- Personal setting is correct.
- Deepstops are set correctly.
- Unit system is correct.
- Correct temperature and depth are shown.
- The alarm beeps.
Wireless Transmitter pre-check
If the optional wireless tank pressure transmitter is used, check that:
- Tank gas and O2 settings are correct.
- The transmitter is properly installed and the tank valve is open.
- The transmitter and Suunto DX are paired.
- The transmitter is sending data (wireless transmission icon blinks, tank pressure is displayed).
- There is no transmitter low battery warning.
- There is enough gas for your planned dive. Check the pressure reading against your back-up pressure gauge.
Battery indicators
Temperature or internal oxidation can affect the battery voltage. If you store your Suunto DX for a long period or use it in cold temperatures, the low battery warning may appear even though the battery has enough capacity.
In these cases, re-enter dive mode and check the battery power. If the battery is low, the Low Battery warning comes on.
If the low battery icon appears in surface mode, or if the display looks faded, the battery may be too low. Battery replacement is recommended.
For safety reasons, the backlight and buzzer (sound) cannot be activated when the low battery warning is displayed.
Alarms, warnings and notifications
Suunto DX has audible and visual alarms designed to let you know when important limits or presets are being reached.
The two audible alarm types indicating high or low priority:
| Alarm type |
Sound pattern |
Duration |
| High priority |
2.4 s sound + 2.4 s break |
| Low priority |
0.8 s sound + 3.2 s break |
In addition, there are three audible guidance notifications:
| Instructional beep |
Sound pattern |
Interpretation |
| Ascending |
Start ascending |
| Descending |
Start descending |
| Descending-ascending |
Change gas |
Suunto DX displays information during the alarm breaks in order to save battery life.
High priority alarms:
| Alarm |
Explanation |
High priority alarm followed by 'Start ascending' beep, repeated for maximum three minutes
PO2 value blinks
PO2 value greater than the adjusted value. Current depth is too deep for the gas in use. You should immediately ascend or change to a lower O2% gas. |
High priority alarm followed by 'Change gas' beep, sounded two times.
PO2 value blinks
PO2 value is smaller than 0.18 bar (Mixed or CCR mode only). The depth is too shallow and the ambient pressure is too low for the current gas. The oxygen content is too low; you may lose conscious. You should immediately switch the gas. |
| High priority alarm followed by 'Start descending' beep, repeated for maximum three minutes Er blinks and an arrow points downwards. |
Decompression ceiling depth exceeded. You should immediately descend to, or below, the ceiling. |
High priority alarm, repeated three times.
SLOW blinks.
Maximum ascent rate of 10 m/min (33 ft/min) exceeded. Slow down your ascent rate. |
Low priority alarms:
| Alarm type |
Alarm reason |
Low priority alarm followed by 'Start ascending' beep, sounded two times.
ASC TIME blinks and an arrow points upwards.
No-decompression dive becomes a decompression stop dive. Depth is below the decompression floor level. You should ascend to, or above, the floor. |
| Low priority alarm followed by Change gas' beep. The gas mix percentage value blinks. |
Gas change is recommended (Mixed or CCR mode only). You should change to a gas more favorable to decompression. Ascent time calculation assumes that the gas is changed and is therefore only accurate if you have changed the gas accordingly. |
| Low priority alarm followed by “Change gas” beep, sounded once. The backlight is lit and text "Set Point selected is displayed shortly. |
The setpoint has been switched automatically upon reaching the defined depth (CCR mode only). |
Low priority alarm followed by 'Start descending' beep.
DEEPSTOP blinks and an arrow points downwards.
Mandatory deepstop violated. You should descend to complete the deepstop. |
Low priority alarm followed by 'Start descending' beep, repeated for three minutes.
An arrow points downwards.
Mandatory safety stop violated. You should descend to complete the safety stop. |
Low priority alarm followed by two short beeps.
DEEPSTOP and timer displayed.
Deepstop depth reached. Make the mandatory deepstop for the duration shown by the timer. |
Low priority alarm, repeated twice.
Tank pressure value blinks.
Tank pressure reaches the defined alarm pressure or the fixed alarm pressure, 50 bar (700 psi). Acknowledge the alarm by pressing any button. |
OLF% value blinks if PO2 value is greater than 0.5 bar.
OLF value at 80% or 100% (Mixed or CCR mode only). Acknowledge the alarm by pressing any button. |
Maximum depth value blinks
Defined maximum depth or the maximum depth of the device exceeded. Acknowledge the alarm by pressing any button. |
| Low priority alarm, repeated twice; dive time value blinks |
Defined dive time exceeded. Acknowledge the alarm by pressing any button. |
Visual alarms
| Symbol on display |
Indication |
Attention - extend surface interval |
| Er |
Violated decompression ceiling or bottom time is too long |
Do not fly |
Ascent rate
The ascent rate is displayed as a vertical bar along the right side of the display.
When the maximum allowed ascent rate is exceeded, the lower segment of the bar starts to blink and the top segment stays solid.
Continuous ascent rate violations result in mandatory safety stops. See Safety stops and deepstops .
WARNING:
DO NOT EXCEED THE MAXIMUM ASCENT RATE! Rapid ascents increase the risk of injury. You should always make the mandatory and recommended safety stops if you have exceeded the maximum recommended ascent rate. If the mandatory safety stop is not completed, the decompression algorithm penalizes your next dive(s).
Backlight
To active the backlight while diving, press MODE.
Otherwise, keep MODE pressed until the backlight activates to use the backlight.
You can define how long the backlight stays on when you activate it or turn the backlight off altogether.
To set backlight duration:
- While in time mode, keep DOWN pressed.
- Press DOWN to scroll to Backlight and press SELECT.
- Set duration or turn off with DOWN or UP.
- Press MODE to save and exit to settings.
When the backlight is off, it does not illuminate when an alarm sounds.
Bookmarks
At any time during a dive, you can add a bookmark to the dive log by pressing SELECT.
You can view bookmarks when scrolling the dive profile in the logbook.
Each bookmark records present depth, time, water temperature, heading (if the compass is enabled), and tank pressure (if available).
Calendar clock
The calendar clock is the default mode of Suunto DX .
Time
In the time settings, you can set the hours, minutes, seconds, and format (12 or 24-hour).
To set time:
- Press UP to scroll to Time and press SELECT.
- Set hours with DOWN or UP and confirm with SELECT.
- Repeat for minutes and seconds. Set the format with DOWN or UP and confirm with SELECT.
- Press MODE to exit.
Date
The date and weekday are shown in the bottom row of time mode. Press DOWN to toggle between views.
To set the date:
- Press UP to scroll to Date and press SELECT.
- Set year with DOWN or UP and accept with SELECT.
- Repeat for month and day.
Units
In the units setting, choose whether the units are displayed in the metric or Imperial system.
- Press UP to scroll to Units and press SELECT.
- Press DOWN to toggle between Metric and Imperial and confirm with SELECT.
Dual time
Dual time allows you to keep track of the time in a second time zone. Dual time is shown in the bottom left of the time mode display by pressing DOWN.
To set dual time:
- Press UP to scroll to Dual Time and press SELECT.
- Repeat for minutes.
Alarm clock
Suunto DX has a daily alarm which can be set to activate once, on weekdays or every day.
When the daily alarm activates, the screen blinks and the alarm sounds for 60 seconds. Press any button to stop the alarm.
To set the daily alarm:
- Press UP to scroll to Alarm and press Select.
- Select alarm activation with DOWN or UP and confirm with Select. The options are Off, Once, Weekdays, or Every Day.
Compass
Suunto DX includes a digital compass.
The tilt-compensated compass gives you accurate readings even if the compass is not horizontally level.
The compass can be activated from either time or dive mode and shows the current bearing and depth.
- While in TIME or DIVE mode, keep SELECT pressed to activate the compass.
- Press MODE to exit the compass display. If you are underwater, keep [SELECT] pressed to exit.
When in dive mode, the compass display includes additional information in the bottom left and right views.
- Press DOWN to scroll through the bottom left views. (tank pressure, max. depth, time)
- Press UP to scroll through the bottom right views. (dive time, temperature, bearing)
Calibrating compass
When you first start using Suunto DX, the compass needs to be calibrated. Suunto DX displays the calibration icon when you enter the compass.
![compass calibrate Dseries]()
Calibrate the compass by slowly rotating the unit in your hand in large figure-8 loops..
During the calibration process, the compass adjusts itself to the surrounding magnetic field.
If the calibration fails,Try Again appears. If calibration continues to fail, move to another location and try again.
When traveling overseas, it is recommended that you recalibrate the compass at the new location before using it.
To manually start the calibration:
- While in the compass view, keep DOWN pressed.
- Press DOWN to scroll to Calibration.
- Press SELECT to start the calibration.
Setting declination
You should always adjust your compass declination for the area where you are diving to get accurate heading readings. Check the local declination from a trusted source and set the value in Suunto DX.
- Press DOWN to scroll to Declination and press SELECT.
- Press DOWN to toggle to East or West and confirm with SELECT.
- Set Declination Degrees with DOWN or UP.
- Press MODE to save and exit.
Setting compass timeout
You can define how long the compass stays on after you have activated it. Reset the timeout with any button press while using the compass.
After the timeout, the Suunto DX returns to time or dive mode.
To set the timeout:
- While in the compass display, keep DOWN pressed.
- Press DOWN to scroll to Timeout and press SELECT.
- Adjust the timeout time with DOWN or UP.
Setting bearing lock
A bearing is the angle between north and your target. In simple terms, it is the direction you want to travel. Your heading, on the other hand, is your actual direction of travel.
The default bearing is North.
You can set a bearing lock to help you orientate yourself underwater and ensure you maintain your direction of travel. For example, you can set a bearing lock for the direction to a reef before leaving the boat.
The last locked bearing is stored and available the next time the compass is activated. In Dive mode, the locked bearings are also stored in the log. To lock a bearing:
- With the compass active, hold the watch in front of you and turn yourself towards your target.
- Press SELECT to lock the current degree displayed on the watch as your bearing.
- Press SELECT to clear the lock.
If, at any point, your bearing moves outside the compass display, right or left arrows appear to show turn direction.
Suunto DX provides help for navigating square and triangular patterns, as well as navigating a return heading with the following symbols.
| Symbol |
Explanation |
You are traveling towards the locked bearing. |
You are 90 (or 270) degrees from the locked bearing. |
You are 180 degrees from the locked bearing. |
You are 120 (or 240) degrees from the locked bearing. |
Decompression dives
If you exceed the no-decompression limit on a dive, when NO DEC TIME reaches zero, your dive changes into a decompression dive. Therefore, you must perform one or more decompression stops on your way to the surface.
When the decompression dive starts, the NO DEC TIME on your display is replaced by ASC TIME, and a CEILING indicator appears. An upward pointing arrow also prompts you to start your ascent.
Suunto DX provides the decompression information required for ascent with two key values:
CEILING: depth that you should not go above
ASC TIME: optimum ascent time in minutes to surface with defined gases
If you exceed the no-decompression limits on a dive, the dive computer provides the decompression information required for ascent along with subsequent details that are updated as you ascend.
In other words, rather than requiring you to make stops at fixed depths, the dive computer lets you decompress within a range of depths. This is known as continuous decompression.
Ceiling, ceiling zone, floor and decompression range
Before you do a decompression dive, you need to understand the meaning of ceiling, ceiling zone, floor, and decompression range. You need to understand these concepts to be able to correctly interpret the guidance provided by the dive computer.
- The ceiling is the shallowest depth to which you should ascend when doing decompression.
- The ceiling zone is the optimum decompression depth range. It is the range between the ceiling depth and 1.2 m (4 ft) below that ceiling.
- The floor is the deepest depth at which the decompression stop time does not increase. Decompression starts when you pass this depth during your ascent.
- The decompression range is the depth range between the ceiling and floor. Within this range, decompression takes place. However, it is important to remember that the decompression slower at or close to the floor compared to the ceiling zone.
The depth of the ceiling and floor depends on your dive profile. The ceiling depth is fairly shallow when you first enter the decompression dive. But if you remain at depth, the ceiling depth moves downward, and the ascent time increases. The opposite is also true: the floor and ceiling depths may change upwards while you are decompressing.
When conditions are rough, it may be difficult to maintain a constant depth near the surface. In such cases, it is more manageable to maintain a depth somewhat below the ceiling, to ensure that the waves do not lift you above the ceiling. Suunto recommends that you decompress deeper than 4 m (13 ft), even if the indicated ceiling is shallower.
Ascent time
The ascent time shown on your dive computer is the minimum amount of time needed to reach the surface on a decompression dive. This includes:
- Time required to do deepstops
- Ascent time from depth at an ascent rate of 10 m (32.8 ft) per minute
- Time needed for decompression
- Time needed for extra safety stops if ascending too fast during the dive
WARNING:
Your actual ascent time may be longer than displayed by Suunto DX. It may be longer if your ascending speed is slower than 10 m (32.8 ft) per minute or you are doing a decompression stop deeper than the recommended ceiling. Take this into account, since it might increase the amount of required breathing gas to reach the surface.
Decompression guidance
On a decompression dive, there can be three kinds of stops:
- Safety stop
- Deepstop
- Decompression stop
Though not recommended, you may break (ignore) deepstops and safety stops. Suunto DX penalizes such actions with additional stops or other measures, either during the dive or on following dives. For more information, see Safety stops and deepstops.
Suunto DX shows the ceiling value always from the deepest of these stops. Deepstop and safety stop ceilings are always at constant depth when you are at the stop. Stop time is counted down in minutes and seconds.
With decompression stops, the ceiling is always decreasing while you are near the ceiling depth, providing continuous decompression with optimum ascent time.
It is always recommended to keep close to the decompression ceiling when ascending.
Below the floor
The blinking ASC TIME text and an upward arrow indicate that you are below the floor. A low priority alarm will also sound. You should start your ascent immediately. The ceiling depth is shown on the left side of the center field, and the minimum total ascent time on the right side.
Below is an example of a decompression dive with a ceiling of 3 m and total ascent time of 9 minutes.
Above the floor
When you ascend above the floor, the ASC TIME text stops blinking and the upward arrow disappears, as shown below.
This indicates you are in the decompression range. Decompression begins, but slowly. Therefore, you should continue your ascent.
At the ceiling
When you reach the ceiling zone, the display will show you two arrows pointing at each other as shown below.
During the decompression stop, your total ascent time continues to count down towards zero. If the ceiling moves upwards, you can ascend to the new ceiling.
You may surface only after ASC TIME and CEILING have disappeared. This means that the decompression stop and any mandatory safety stop have been completed.
You are advised, however, to stay below the ceiling until the STOP text has also disappeared. This indicates that the three (3) minute recommended safety stop has also been completed.
Above the ceiling
If you ascend above the ceiling during a decompression stop, a downward arrow appears in from of the ceiling depth, and a continuous beeping starts.
In addition, an error warning Er reminds you that you have only three (3) minutes to correct the situation. You must immediately descend to, or below, the ceiling. If you continue to violate the decompression, the dive computer goes into a permanent error mode (Error state (algorithm lock)).
Depth alarm
By default the depth alarm sounds at 30 m (100 ft). You can adjust the depth according to your personal preference or switch it off.
To adjust the depth alarm:
- While in a dive mode, keep DOWN pressed to enter settings.
- Press UP to scroll to Depth Alarm and press SELECT.
- Press UP to toggle the alarm on/off and confirm with SELECT.
- Adjust depth with DOWN or UP and accept with SELECT.
When the depth alarm activates, the backlight blinks and the low priority audible alarm pattern sounds. Acknowledge the alarm by pressing any button.
Display contrast
You can adjust the contrast of the display according to your preference or, for example, to suite changing dive conditions.
- Press UP to scroll to Contrast and press Select.
- Use DOWN or UP to change the contrast from 0 (lowest) to 10 (highest).
Dive history
Suunto DX has a detailed logbook and dive history available in memory mode.
The logbook contains a sophisticated dive profile for each recorded dive. The time between each data point saved in the log is based on the configurable sample rate (see Sample rate).
The dive history is a summary of all recorded dives.
To access dive history:
- Press MODE until you come see MEM.
- Switch between History and Logbook with DOWN or UP.
- When you are viewing the history or logbook, you can press MODE to go back and select the other one. Press MODE a second time to exit.
History
Scuba dive history shows you a summary of the following:
- Dive hours
- Total number of dives
- Maximum depth
The scuba dive history records a maximum of 999 dives and 999 diving hours. When these limits are reached, the counters reset to zero.
Logbook
To access the logbook:
- Press MODE three time until you come to MEM mode.
- Press UP to select Logbook.
- Press DOWN or UP to scroll to the log you wish to look at and press SELECT.
- Press SELECT to scroll through the pages.
Each log has three pages:
- Main page
- maximum depth
- date of dive
- type of dive (indicated by first letter of dive mode, e.g. A for Air mode)
- dive start time
- dive number – from oldest to newest
- gas percentage(s) of the first used gas mix
- total dive time (in minutes in all modes)
- Surface time and warnings page
- maximum depth
- surface time after previous dive
- average depth
- consumed pressure (if enabled)
- warnings
- OLF% (if applicable)
- Dive profile graph
- water temperature
- tank pressure (if enabled)
- gas changes
- setpoint changes
- depth/time profile of the dive
Press UP to step through the dive profile graph or keep UP pressed to auto-scroll.
The dive profile graph shows point by point dive information such as depth, compass heading, decompression info, ceiling and ascent time.
The End of Logs text is displayed between the oldest and most recent dive.
The logbook capacity depends on the sample rate.
If the memory is full, when new dives are added, the oldest dives are deleted.
The contents of the memory remain when the battery is changed (providing that the battery has been replaced according to the instructions).
Several repetitive dives are considered to belong to the same repetitive dive series if the no-fly time has not ended. See Surface and no-fly time.
Dive modes
Suunto DX has the following dive modes:
Air: for diving with regular air
Mixed: for diving using oxygen-enriched and helium gas mixtures
CCR: for rebreather diving
Gauge: for using the dive computer as a bottom timer
Off: turns dive mode off completely; the dive computer does not automatically switch the dive mode when submerged and dive planning mode is hidden
By default, Air mode is activated when you enter dive mode. You can change which mode is activated or turn dive mode off under the general settings.
To change dive modes:
- Press SELECT to enter Dive Mode.
- Change to the desired mode with UP or DOWN and confirm with SELECT.
Each dive mode has its own settings which you need to adjust while in the given mode.
To modify dive mode settings:
- While in a given dive mode, keep DOWN pressed.
- Press DOWN or UP to scroll through the settings.
- Press SELECT to enter a setting.
- Adjust the setting with DOWN or Up and confirm with SELECT.
Some settings cannot be changed until five (5) minutes have elapsed after the dive.
Air mode
Air mode is for diving with regular air and has the following settings:
- Personal/altitude adjustment (see Personal and altitude adjustments)
- Tank pressure (see Tank pressure)
- Tank pressure alarm (see Tank pressure alarm)
- Depth alarm (see Depth alarm)
- Dive time alarm (see Dive time alarm)
- Sample rate (see Sample rate)
- Deepstop (see Safety stops and deepstops)
- Air time (see Air time)
Mixed mode
Suunto DX has a mixed dive mode for diving with oxygen and/or helium mixture in an open system.
Mixed mode has the following settings available:
- Gases
- Tank pressure pairing (see Tank pressure)
- Tank pressure alarm (Tank pressure alarm)
In mixed mode, the default setting is standard air (21% O2 and 0% He), and oxygen partial pressure (PO2) is 1.4 bar (20 psi).
The default setting for maximum oxygen partial pressure is 1.4 bar (20 psi). Valid values are 0.5-1.6 bar (7-23 psi).
Changing gases on multi-gas dives
If you have using more than one gas on a dive, Suunto DX allows you to change enabled gas mixes during the dive.
A dive is always started with Mix1. You can change to another enabled mix that is within the set maximum oxygen partial pressure. The tissue calculation during the dive is based on the mixes you have selected as Primary gases.
To change gases during a dive:
- Keep UP pressed.
- Scroll through the enabled mixes with UP or DOWN and select the gas you want to use with by pressing SELECT.
If no button is pressed within 15 seconds, the dive computer goes back to the dive display without changing the gas mix.
The mix number, O2% and PO2 for the mixes are shown when scrolling. If the set PO2 limit is exceeded, the PO2 value blinks. You cannot change to the gas in this case. The mix is shown, but you cannot select it to use.
When ascending, Suunto DX prompts you to change gas when the PO2 level you have set for the next mix allows a gas change.
CCR mode
CCR mode is a dive mode dedicated to rebreather diving.
The CCR mode has the following settings:
- CC gases (see Closed-circuit gases)
- OC gases (see Open-circuit gases)
- Setpoints (see Setpoints)
- Tank pressure pairing (see Tank pressure )
In CCR mode you can define up to three diluent gases and up to eight bailout gas mixes. Use the setpoint settings to define your high and low set points and switch depths (see Setpoints).
On a rebreather dive, you need at minimum two closed-circuit gases: one is your pure oxygen tank, and the other is a diluent.
The correct oxygen and helium percentages of the diluent gas(es) in your diluent cylinder(s) must always be entered into the dive computer (or through DM5) to ensure correct tissue and oxygen calculation. Diluent gas(es) used on a rebreather dive are found under CC gases in the main menu.
To modify diluent gases
- While in CCR mode, keep DOWN pressed to enter settings.
- Press SELECT to enter CC Gases settings.
Diluent 1 is displayed and is always on (cannot be turned off).
- Press SELECT to move to the oxygen setting.
- Adjust oxygen percentage with DOWN or UP and confirm with SELECT.
- Continue with adjusting helium percentage and PO2 value.
- After pressing SELECT to confirm the PO2 value, press UP to move to the next diluent.
- Repeat steps 4 and 5 for each diluent.
Open-circuit gases
As with closed-circuit gases, you must always define the correct oxygen and helium percentages of open-circuit gases (bailout gases) to ensure correct tissue and oxygen calculation.
Follow the same procedure as the CC gases to define your open-circuit gases under the OC Gases settings.
After entering values for Mix1, you can create additional mixes,Mix2 to Mix8. Each additional mix can be primary, secondary, or off. Mix1 is always set as a primary gas.
To minimize the risk of error during a dive, it is highly recommended that the mixes are set in the proper order. This means that as the mix number rises, so does oxygen content. This is the order they are usually used during the dive. Before a dive, only enable the mixes you actually have available and remember to check the set values to ensure they are correct.
The ascent time is calculated based on the assumption that you start the ascent profile immediately and all the primary gases are changed as soon as their maximum operating depth allows it. That is, using the gases that are set as primary, the most optimal ascent schedule for the moment is calculated.
To see the most pessimistic ascent schedule, that is, a schedule for the situation when gases are not changed at all, you can set the gases as secondary and the time it takes to finish the decompression using the current breathing gas is shown as the ascent time.
Showing the most pessimistic ascent schedule during a long dive may result in the ascent time no longer fitting the reserved field, and the dive watch displays '––'.
While setting the gases, notice that the calculated maximum operating depth is displayed in the upper field. You cannot change to this gas before you have ascended above this depth.
Setpoints
In CCR mode there are two setpoint values that you can set, low and high. Typically you do not need to modify the default setpoint values. However, you can change them as needed either in DM5 or under the CCR mode settings.
- Low set point: 0.4 – 0.9 (default: 0.7)
- High set point: 1.0 – 1.6 (default: 1.3)
To change set point values:
- While in CCR mode, keep DOWN pressed.
- Press UP to scroll to Setpoint and press SELECT.
- Press DOWN or UP to choose Low Setpoint and press SELECT.
- Press DOWN or UP to set value for PO2 and accept with SELECT.
- Repeat steps 2-4 for High Setpoint if necessary.
Setpoint switching
You can use automatic or manual setpoint switching. The automatic low setpoint switch depth is 4.5 m (15 ft) by default, and the high setpoint switch depth is 21 m (70 ft).
The auto setpoint switching is off by default for the low setpoint and on for the high setpoint.
To modify setpoint switching:
- Press UP to scroll to Switch High and press SELECT.
- Press DOWN or UP to to toggle On/Off and press SELECT.
- Press DOWN or UP to set value for for Switch High in meters (m).
- Press SELECT to save
- Repeat steps 2-4 for Switch Low if necessary.
Modify setpoints during a dive
The high and low setpoints or a custom (manual) set point can be adjusted during a dive.
To modify setpoints during a dive:
- While in CCR mode, keep UP pressed.
- Scroll to the setpoint you want to adjust with UP or DOWN.
- Press SELECT to enter the setting.
- Press DOWN or UP to adjust value.
- Press SELECT to save.
Changing gases
In CCR dive mode, Suunto DX allows both setpoint and gas changes to enabled gas mixes during the dive.
To adjust the diluent during a dive:
- Keep UP pressed.
- Scroll through the settings with UP or DOWN to access the CC Diluent setting and press SELECT.
- Scroll through the diluent list with UP or DOWN and press SELECT to select a Diluent.
Enabled open-circuit gas changes are made in the same way and at the same time as the closed-circuit (CC) dive changes to an open-circuit (OC) dive. This feature is useful in bail-out situations.
Hyperoxic and hypoxic mixes
Suunto DX displays the text HYPER if the diluent gas PO2 at the current depth is over 1.6. The text HYPOX is displayed if the diluent gas PO2 at the current depth is less than 0.18.
Gauge mode
With Gauge mode, you can use Suunto DX as a bottom timer.
The timer in the center of the display shows dive time in minutes and seconds and activates at the start of the dive. The total running dive time, in minutes, is in the lower right corner.
The timer in the center of the display can be used as a stopwatch by pressing SELECT during the dive.
Pressing SELECT resets the main timer and adds a bookmark to the dive log. The previously-timed interval is displayed below the main timer.
Gauge mode has the following settings
Gauge mode is a bottom timer only and thus includes no decompression information or calculations.
Dive planning mode
The dive planning mode PLAN NoDeco can be used to plan a dive that does not require decompression. You enter the depth of your upcoming dive, and Suunto DX calculates the maximum time you can stay at that depth without requiring decompression stops.
The dive plan takes into account:
- any calculated residual nitrogen
- dive history from the past four days
To plan dives:
- Press MODE until you see PLAN NoDec.
- The display briefly shows your remaining desaturation time before continuing to the planning display.
- Press DOWN or UP to scroll your upcoming dive depths. The depth moves in 3 m (10 ft) increments from 9 m – 45 m (30 ft – 150 ft). The no-decompression time limit for the selected depth is shown in the center of the display. If you have dived at least once with Suunto DX, the SURFTIME + field appears. You can adjust the surface time with UP.
- Between consecutive dives, you can press SELECT to adjust surface time.
The dive planning mode is disabled if the dive computer is in an error state (see Error state (algorithm lock)) or if the dive mode is off or in Gauge mode.
Dive time alarm
The dive time alarm can be activated and used for several purposes to add to your diving safety. It is simply a countdown timer in minutes.
To set the dive time alarm:
- While in a relevant dive mode, keep DOWN pressed.
- Press DOWN or UP to scroll to Alarm Time.
- Press UP to toggle the alarm on and press SELECT to confirm.
- Adjust the duration with UP or DOWN and accept with SELECT.
Suunto DX has warning indicators that alert you to react to certain situations that would significantly increase the risk of DCI. If you do not respond to these warnings, Suunto DX enters an error state and shows Er on the display. This indicates that the risk of DCI has greatly increased.
If you omit decompression stops for longer than three (3) minutes, the RGBM algorithm is locked for 48 hours. When the algorithm is locked, no algorithm information is available and Er is shown instead. Locking the algorithm is a safety feature, highlighting that the algorithm information is no longer valid.
In such a condition, you should descend back below the ceiling level to continue the decompression. If you fail to do so within three (3) minutes, Suunto DX locks the algorithm calculation and displays Er instead, as shown below. Note that the ceiling value is no longer present.
In this state, you significantly increase your risk of decompression sickness (DCS). Decompression information is not available for the next 48 hours after surfacing.
It is possible to dive with the device when the algorithm is locked, but instead of the decompression information, Er is shown.
If you dive again in this error state, the algorithm lock time resets to 48 hours when you surface.
Oxygen calculations
During a dive, Suunto DX calculates partial pressure of oxygen (PO2), central nervous system toxicity (CNS%) and pulmonary oxygen toxicity, tracked by OTU (oxygen toxicity units).
The oxygen calculations are based on currently accepted exposure time limit tables and principles.
When the dive computer is set in Mixed mode, the Dive Planning mode calculates using the O2% and P O2 values that are currently in the computer.
Oxygen related information displayed by the dive computer is also designed to ensure that all warnings and displays occur at the appropriate phases of a dive. For example, the following information will be shown before and during a dive when the computer is set in Mixed mode:
- The selected O2% on the alternative display
- OLF% alternative display for either CNS% or OTU% (whichever is larger)
- Audible alarms are given and the OLF value starts to blink when the 80% and 100% limits are exceeded.
- Audible alarms are given and the actual PO2 value blinks when it exceeds the preset limit.
- In dive planning, the maximum depth according to the O2% and maximum PO2 selected
There are several factors that can affect your susceptibility to DCS. Such factors vary between divers and from one day to another.
The personal factors which tend to increase the possibility of DCS include:
- exposure to cold water - less than 20°C (68 °F)
- below average physical fitness level
- fatigue
- dehydration
- stress
- obesity
- patent foramen ovale (PFO)
- exercise before or after dive
The five-step personal setting can be used to adjust the algorithm to fit your DCS susceptibility.
| Personal adjustment |
Explanation |
| -2 |
More aggressive. Ideal conditions with excellent physical fitness. Highly experienced with many recent dives. |
| -1 |
Aggressive. Ideal conditions with good physical fitness. Experienced with some recent dives. |
| 0 |
Ideal conditions (default value). |
| 1 |
Conservative. Some risk factors or conditions exist. |
| 2 |
More conservative. Several risk factors or conditions exist. |
In addition to the personal setting, Suunto DX can be adjusted for diving at different altitudes. This adjusts the decompression calculation according to the selected altitude adjustment.
| Altitude adjustment |
Explanation |
| 0 |
0 – 300 m (0 – 980 ft) (default) |
| 1 |
300 – 1500 m (980 – 4900 ft) |
| 2 |
1500 – 3000 m (4900 – 9800 ft) |
To change the personal and altitude adjustment settings:
- While in a dive mode, keep DOWN pressed.
- Press SELECT to enter Personal Altitude settings.
- Press UP to change the Personal adjustment and confirm with SELECT.
- Press UP to change the Altitude adjustment and confirm with SELECT.
WARNING:
Traveling to a higher altitude can temporarily cause changes to the equilibrium of dissolved nitrogen in the body. It is recommended that you acclimatize to the new altitude by waiting at least three (3) hours before diving.
Rebreather diving
Suunto DX has one mode dedicated to rebreather diving, CCR mode. This mode uses fixed high/low setpoint values which you can modify in the watch or through DM5.
Fixed setpoint calculation enables Suunto DX to be used as a backup dive computer on rebreather dives. It does not control or monitor the rebreather unit in any way.
When you select CCR mode (see CCR mode), the gas settings split into two: CC gases (closed-circuit gases) and OC gases (open-circuit gases).
For rebreather dives, Suunto DX should be used as a backup device only. The primary control and monitoring of your gases should be done through the rebreather itself.
Sample rate
The sample rate controls how often information from the dive is saved to the active log. The sample rate options are: 10, 20, 30 and 60 seconds. The default sample rate is 20 seconds.
To change the sample rate:
- Press UP to scroll to Sample Rate and press SELECT.
- Press DOWN or UP to change the rate and confirm with SELECT.
Safety stops are widely considered good diving practice and are a critical part of most dive tables. The reasons for performing a safety stop include: reducing sub-clinical DCI, microbubble reduction, ascent control, and orientation before surfacing.
Suunto DX displays two different types of safety stops: recommended and mandatory.
With every dive over 10 meters (30 feet), there is a three-minute countdown for the recommended safety stop. This stop is taken in the 3-6 m (10-20 ft) range. Suunto DX shows a STOP icon and a three-minute countdown.
When deepstops are enabled, the length of mandatory safety stops is indicated in seconds.
When the ascent rate exceeds 10 m (33 ft) per minute for more than five consecutive seconds, the microbubble build-up may be more than is allowed for in the decompression model.
In this situation, Suunto DX adds a mandatory safety stop to the dive. The time of this stop depends on the speed violation of the ascent rate.
The STOP icon is shown in the display. When you reach the depth zone between 6 m and 3 m (18 ft and 9 ft) the following is displayed:
CEILING and STOP
- Ceiling depth
- Safety stop time
Wait at the ceiling until the mandatory safety stop warning disappears.
WARNING:
NEVER ASCEND ABOVE THE CEILING! You must not ascend above the ceiling during your decompression. In order to avoid doing so by accident, you should stay somewhat below the ceiling.
Deepstops activate when you dive deeper than 20 m (65.6 ft).
If the dive timer is on the screen when deepstop activates, the timer is replaced with deepstop.
After deepstop is over, the user can change between deepstop and the timer by long pressing the MODE button.
Deepstops are presented the same way as safety stops. Suunto DX notifies you that you are in the deepstop area by displaying:
CEILING in the top
DEEPSTOP in the center row
- Stop depth
- Countdown timer
Deepstop is on by default in Air and Nitrox modes. To turn deepstop off:
- Press DOWN to scroll to Deepstop and enter with Select.
- Press UP to toggle on/off.
Software version
You can check the software version and battery status of Suunto DX under the general settings.
- Press UP to scroll to Version and press SELECT.
- The software version is displayed along with the battery voltage.
Stopwatch
The stopwatch can be used to measure elapsed and split times.
To activate the stopwatch:
- While in time mode, scroll through the bottom row view by pressing UP or DOWN until the stopwatch is displayed.
- Press SELECT to start/stop the stopwatch.
- Press DOWN to take split times.
- Keep SELECT pressed to reset the stopwatch.
After stopping the stopwatch, you can scroll through the split times with DOWN.
You can also use the stopwatch while diving for various timing purposes. To activate the stopwatch in dive mode, keep MODE pressed.
Start and stop the stopwatch by pressing SELECT.
If a deepstop activates while you are using the stopwatch, the timer field is not visible.
Once back at the surface, Suunto DX continues to provide post-dive safety information and alarms. If, after your dive, you need to wait until flying, the no-fly symbol displays in all modes.
To access further information about your surface and no-fly times, enter dive mode.
Suunto DX shows the time since you surfaced in the Surf t. field. The airplane symbol indicates that you should not fly. The countdown until you will be safe to fly is shown in the No Fly field.
No-fly time is always at least 12 hours and equals desaturation time when it is more than 12 hours. For desaturation times shorter than 70 minutes, the no-fly time is not displayed.
If decompression is omitted during a dive so that Suunto DX enters error state (see Error state (algorithm lock)), the no-fly time is always 48 hours.
If a dive is done in Gauge mode (bottom timer), the no-fly time is 48 hours.
WARNING:
YOU ARE ADVISED TO AVOID FLYING ANY TIME THE COMPUTER COUNTS DOWN THE NO-FLY TIME. ALWAYS ACTIVATE THE COMPUTER TO CHECK THE REMAINING NO-FLY TIME PRIOR TO FLYING! Flying or traveling to a higher altitude within the no-fly time can greatly increase the risk of DCS. Review the recommendations given by Divers Alert Network (DAN). There can never be a flying-after-diving rule that is guaranteed to completely prevent decompression sickness!
The Divers Alert Network (DAN) recommends the following on no-fly times:
- A minimum surface interval of 12 hours would be required in order to be reasonably assured a diver will remain symptom free upon ascent to altitude in a commercial jetliner (altitude up to 2,400 m (8,000 ft)).
- Divers who plan to make daily, multiple dives for several days, or make dives that require decompression stops, should take special precautions and wait for an extended interval beyond 12 hours before a flight. Further, the Undersea and Hyperbaric Medical Society (UHMS) suggests divers using standard air cylinders and exhibiting no symptoms of decompression sickness wait 24 hours after their last dive to fly in an aircraft with cabin pressure up to 2,400 m (8,000 ft). The only two exceptions to this recommendation are:
- If a diver has less than two (2) hours total accumulated dive time in the last 48 hours, a 12 hour surface interval before flying is recommended.
- Following any dive that required a decompression stop, flying should be delayed for at least 24 hours, and if possible, for 48 hours.
Suunto recommends that flying is avoided until all the DAN and UHMS guidelines, as well as the dive computer’s no-fly conditions, are satisfied.
Dive numbering
If the Suunto DX has not counted the no-fly time down to zero, then repetitive dives belong to the same dive series.
Within each series, the dives are given numbers. The first dive of the series is DIVE 1, the second DIVE 2, and so on.
If you start a new dive with less than five (5) minutes at the surface, Suunto DX treats the new dive as part of the previous dive. The dive time continues where it left off.
After five (5) minutes or more at the surface, any new dives are part of a repetitive dive series. The dive counter displayed in the planning mode adds one to each new dive in the repetitive series.
The planning mode allows you to review the no-decompression limits on the next dive in a series.
Suunto Fused RGBM
Suunto's decompression model development originates from the 1980s when Suunto implemented Bühlmann's model based on M-values in Suunto SME. Since then research and development has been ongoing with the help of both external and internal experts.
In the late 1990s, Suunto implemented Dr. Bruce Wienke's RGBM (Reduced Gradient Bubble Model) bubble model to work with the earlier M-value based model. The first commercial products with the feature were the iconic Suunto Vyper and Suunto Stinger. With these products the improvement of diver safety was significant as they addressed a number of diving circumstances outside the range of dissolved-gas-only models by:
- Monitoring continuous multiday diving
- Computing closely spaced repetitive diving
- Reacting to a dive deeper than the previous dive
- Adapting to rapid ascents which produce high microbubble (silent-bubble) build-up
- Incorporating consistency with real physical laws for gas kinetics
In Suunto Fused™ RGBM the tissue half-times are derived from Wienke’s FullRGBM where human body is modeled by fifteen different tissue groups. FullRGBM can utilize these additional tissues and model the on-gassing and off-gassing more accurately. The amounts of nitrogen and helium on-gassing and off-gassing in the tissues are calculated independently from each other.
The advantage of Suunto Fused RGBM is additional safety through its ability to adapt to a wide variety of situations. For recreational divers it may offer slightly longer no- deco times, depending on the chosen personal setting. For open-circuit technical divers it allows use of gas mixes with helium - on deeper and longer dives helium based gas mixes provide shorter ascent times. And finally, for rebreather divers the Suunto Fused RGBM algorithm gives the perfect tool to be used as a non-monitoring, set point dive computer.
Diver Safety
Because any decompression model is purely theoretical and does not monitor the actual body of a diver, no decompression model can guarantee the absence of DCS. Experimentally it has been shown that the body adapts to decompression to some degree when diving is constant and frequent. Personal adjustment settings are available for divers who dive constantly and are ready to accept greater personal risk.
CAUTION:
Always use the same personal and altitude adjustment settings for the actual dive and for the planning. Increasing the personal adjustment setting from the planned setting as well as increasing the altitude adjustment setting can lead to longer decompression times deeper and thus to larger required gas volume. You can run out of breathing gas underwater if the personal adjustment setting has been changed after dive planning.
Altitude diving
The atmospheric pressure is lower at high altitudes than at sea level. After traveling to a higher altitude, you will have additional nitrogen in your body, compared to the equilibrium situation at the original altitude. This 'additional' nitrogen is released gradually over time and equilibrium is restored. It is recommended that you acclimatize to a new altitude by waiting at least three hours before making a dive.
Before high-altitude diving, you need to adjust the altitude settings of your dive computer so that the calculations take into account the high altitude. The maximum partial pressures of nitrogen allowed by the mathematical model of the dive computer are reduced according to the lower ambient pressure.
As a result, the allowed no decompression stop limits are considerably reduced.
WARNING:
SET THE CORRECT ALTITUDE SETTING! When diving at altitudes greater than 300 m (1000 ft), the altitude setting must be correctly selected in order for the computer to calculate the decompression status. The dive computer is not intended for use at altitudes greater than 3000 m (10000 ft). Failure to select the correct altitude setting or diving above the maximum altitude limit will result in erroneous dive and planning data.
Oxygen exposure
The oxygen exposure calculations are based on currently accepted exposure time limit tables and principles.
The dive computer calculates separately the Central Nervous System oxygen toxicity (CNS) and the Pulmonary Oxygen toxicity, the latter measured by the addition of Oxygen Toxicity Units (OTU).
Both fractions are scaled so that the diver’s maximum tolerated exposure for each is 100%.
Suunto DX does not display CNS% or OTU% but instead displays the larger of the two in the OLF% field. OLF% value is the Oxygen limit fraction or Oxygen Toxicity Exposure.
For example, if the diver’s maximum tolerated exposure for CNS% is 85% and the maximum tolerated exposure for OTU% is 80% the OLF% displays the largest scaled value, here 85%.
WARNING:
WHEN THE OXYGEN LIMIT FRACTION INDICATES THAT THE MAXIMUM LIMIT IS REACHED, YOU MUST IMMEDIATELY TAKE ACTION TO REDUCE OXYGEN EXPOSURE. Failure to take action to reduce oxygen exposure after a CNS/OTU warning is given can rapidly increase the risk of oxygen toxicity, injury, or death.
Tank pressure
When using the optional Suunto Wireless Transmitter, the pressure of your tank is shown in the lower left of the display.
Whenever you start a dive, the remaining air time calculation begins. After 30-60 seconds, the first estimation of remaining air time is shown in the left center of the display.
The calculation is always based on the actual pressure drop in your tank and automatically adapts to your tank size and current air consumption.
The change in your air consumption is based on constant one second interval pressure measurements over periods of 30–60 seconds. An increase in air consumption decreases the remaining air time rapidly, while a drop in air consumption increases the air time slowly. In this way, an overly optimistic air time estimate, caused by a temporary drop in air consumption, is avoided.
The remaining air time calculation includes a 35 bar (500 psi) safety reserve. This means that when the instrument shows the air time to be zero, there is still a small reserve.
Filling your BCD affects the air time calculation due to the temporary increase in air consumption.
The remaining air time is not displayed when either deepstops or the decompression ceiling has been activated. You can check remaining air time by keeping DOWN pressed.
Temperature changes affect the tank pressure and consequently the air time calculation.
Low air pressure warnings
The dive computer warns you with two (2) audible double beeps and a blinking pressure display when the tank pressure reaches 50 bar (700 psi).
Two (2) double beeps sound when the tank pressure reaches the defined alarm pressure and when the remaining time reaches zero.
Wireless transmission
To enable wireless transmission of tank pressure data to Suunto DX requires:
- Installation of Suunto Wireless Transmitter onto your regulator.
- Pairing the transmitter to your Suunto DX.
- Enabling the wireless integration in your Suunto DX settings.
The transmitter enters power saving mode with slower data transmission rate if the tank pressure remains unchanged for more than five (5) minutes.
The optional transmitter sends out a low battery (batt) warning when its battery voltage is getting low. This is shown intermittently instead of the pressure reading. When you get this warning, the tank pressure transmitter's battery needs to be replaced.
Installing and pairing transmitter
When purchasing the Suunto Wireless Transmitter, we strongly recommend that you have your Suunto representative attach the transmitter to the first stage of your regulator.
The unit needs to be undergo a pressure test after installation and typically this requires a trained technician.
In order to receive wireless data, the transmitter and the Suunto DX need to be paired.
The wireless transmitter activates when the tank pressure exceeds 15 bar (300 psi). The transmitter then starts sending pressure data together with a code number.
When your Suunto DX is within 0.3 m (1 ft) of the transmitter, it receives and stores that code. The transmitter and Suunto DX are now paired. Suunto DX will then display the pressure data it receives with this code. This coding procedure prevents data mix-up from other divers also using a Suunto Wireless Transmitter.
The pairing procedure normally only needs to be done once. You may need to redo the pairing procedure if another diver in your group uses the same code.
To assign a new transmitter code:
- Slowly open the tank valve fully to pressurize the system.
- Immediately close the tank valve.
- Quickly depressurize the regulator so that the pressure is reduced to less than 10 bar (145 psi).
- Wait about 10 seconds, and slowly open the tank valve again to re-pressurize above 15 bar (300 psi).
The transmitter assigns a new code automatically. To re-pair the transmitter with your Suunto DX:
- While in a dive mode other than Free or Gauge, keep DOWN pressed to enter the settings.
- Press DOWN to scroll to Tank Press Pairing and press SELECT.
- Make sure Tank Press Pairing is set to On and press SELECT.
- A code number is displayed. Press UP to clear the code.
- Press SELECT.
With the system pressurized to above 15 bar (300 psi), bring your Suunto DX close to the transmitter. When pairing is completed, the dive computer displays the new code number and the transmitted tank pressure.
The wireless transmitter indicator is displayed every time a valid signal is received.
Transmitted data
After pairing, your Suunto DX receives tank pressure data from the transmitter.
Any time the Suunto DX receives a signal, one of the following symbols is shown in the lower left corner of the display.
| Display |
Indication |
| Cd:– |
No code stored, the dive computer is ready for pairing with the transmitter. |
| Cd:10 |
Current code number. Code number can be from 01 to 40. |
The flash symbol is blinking. Pressure reading exceeds allowed limit (over 360 bar (5220 psi)). |
| Last pressure reading followed by no conn
Tank pressure data has not been updated for 1 minute. See below for solutions. |
- - - followed by no conn
Tank pressure data has not been updated for 5 minutes. See below for solutions. |
| no conn |
Text no conn is displayed when the unit receives no data from the transmitter.
The pressure reading has not been updated for over a minute. The last received pressure blinks on and off. The flash symbol is not displayed.
This state may be caused by the :
Transmitter being out of range (>1.2 m (4 ft))
Transmitter is in power saving mode
Transmitter is using a different code. To correct this:
Activate the transmitter by breathing off the regulator. Bring the dive computer closer to the transmitter and check if the flash symbol appears. If it does not, re-pair the transmitter to get a new code.
| batt |
Pressure transmitter battery voltage is low. Change the transmitter battery! |
Tank pressure alarm
There are two tank pressure alarms. The first is fixed at 50 bar (700 psi) and cannot be changed.
The second is user configurable. It can be turned on or off and can be used for a pressure range of 10–200 bar (200-3000 psi).
To set the tank pressure alarm value:
- Press DOWN to scroll to Tank Press Alarm and press SELECT.
- Press UP to turn the alarm on and confirm with SELECT.
- Adjust the pressure level with UP or DOWN and confirm with SELECT.
Air time
Air time can only be displayed when a wireless tank pressure transmitter is installed and in use.
To activate air time:
- Press DOWN to scroll to Air Time.
- Press UP to turn on the air time reading.
- Press SELECT.
Tones
Device tones can be turned on or off. When tones are off, there are no audible alarms.
To set tones:
- Press DOWN or UP to scroll to Tones and press SELECT.
- Press DOWN or UP to toggle on/off and confirm with SELECT.
Water contact
The water contact is located on the side of the case. When submerged, the water contact poles are connected by the conductivity of the water. Suunto DX switches to dive state when water is detected and the depth gauge senses water pressure at 1.2 m (4 ft).
The AC is shown until the water contact deactivates. It is important to keep the water contact area clean. Contamination or dirt can prevent automatic activation/deactivation.
Moisture build-up around the water contact may cause the dive mode to activate. This can happen, for example, when washing your hands or sweating. To save battery power, deactivate the water contact by cleaning it and/or drying it with a soft towel.
