1 / 8
Suunto Core Alpha Stealth
1/8
Money-back guarantee
30-Days Return
Warranty Repair
SKU: SS050504000
Suunto Core Alpha
Stealth
6.839.000₫
The traditional outdoor watch for off-grid adventures.
  • Mineral crystal screen with aluminum bezel
  • Night vision goggle friendly to help you stay unnoticed
  • Key outdoor metrics combining altimeter, barometer, compass and weather info
  • Up to 30 m water resistance
  • Multiple watch, date and time functions
  • 12 months of battery life in time mode
  • Up to 10-meter depth for snorkeling
      Choose Your Color
      Free shipping on orders of 4500000₫ or more.
      6.839.000₫
      Compare +
      30-Days Return
      Warranty Repair
      SUUNTO CORE ALPHA
      Suunto Core Alpha packs the key outdoor features in robust construction with a comfortable yet durable textile strap. Combining an altimeter, barometer and compass with weather information, it will bring out the explorer in you. The night vision goggle friendly red backlight helps you stay unnoticed when hunting.
      Suunto Core Alpha is designed and made in Finland with the quality that Suunto is known for. Tested to military standards (MIL-STD-810), the watch will make sure your journey is safe and successful even in the toughest and most demanding conditions. Suunto Core Alpha has passed 9 tests, including pressure, heat/cold, shock, drop, freeze/thaw, rain, humidity and dust.
      Key features
      Barometer
      Compass
      Altimeter
      Red backlight
      Weather functions
      Sunrise and sunset times
      30 m water resistant
      Benefits
      • Altimeter
      • Barometer
      • Compass, adjustable declination
      • Temperature
      • Storm alarm
      • Sunset/sunrise times
      • Tested to military standards
      • Made in Finland
      • Red backlight, night vision goggle friendly
      • Textile strap (Berry amendment compliant)
      • User replaceable battery (CR2032), battery life ~12 months
      • 30 m / 100 ft water resistance
      • Depth meter for snorkeling (10 meters)
      • Metric and imperial units
      • Multilingual menu: EN, DE, ES, FR
      SPECIFICATIONS
      • Measurements
        49.5 x 49.5 x 15.1 mm / 1.95 x 1.95 x 0.59 "
      • Weight
        67 g / 2.36 oz
      • Bezel material:
        Aluminum
      • Glass material:
        Mineral crystal
      • Case material:
        Composite
      • Strap material:
        Textile
      • What's in the box?
        Suunto Core Alpha Stealth and Quick Guide
      • Country of manufacture
        FI
      TECHNICAL SPECIFICATIONS
      • Bezel material
        Aluminum
      • Glass material
        Mineral crystal
      • Case material
        Composite
      • Strap material
        Textile
      • Weight
        67 g / 2.36 oz
      • Wrist sizes
        140-240 mm
      • Water resistance
        30 m
      • Battery type
        CR2032
      • Time, date
      • Alarm clock
        1 daily alarm
      • Dual time
      • Countdown timer
      • Stopwatch timer
      • Language
        EN, DE, ES, FR
      • Backlight
        LED
      • Configurable backlight
        activation: 1 button, all buttons
      • Button lock
      • Display type
        matrix
      • Battery indicator
        low battery indicator
      PHYSICAL SPECIFICATIONS
      • Operating temperature
      • Storage temperature
      BATTERY LIFE
      • In time mode
        12 months
      COMPASS
      • Digital compass
      • Direction scale
        degrees
      • Needle
        north indicator
      • Compass accuracy
        5°
      • Compass resolution
        1°
      OUTDOOR FUNCTIONS
      ALTIMETER
      • Barometric altitude
      • Altitude graph
      • Altitude difference
      • Total ascent/descent
        air pressure based
      • Automatic alti/baro profile
      • Log recording rate
        1, 5, 10, 30, 60 s
      • Resolution
        1 m
      • Range
        -500 - 9000 m
      WEATHER
      • Sunrise/sunset times
      • Storm alarm
      • Sea level pressure
      • Temperature
      • Temperature display range
      • Temperature resolution
        1°
      • Pressure resolution
        1 hPa / 0.03 inHg
      • Max weather recording length
        7 days
      • Sea level pressure graph
      • Weather trend indicator
      SPORT EXPERTISE
      HUNTING
      • Red backlight, compatible with night vision goggles
      DIVING FUNCTIONS
      FREEDIVING
        10 m
      SUPPORT FOR SUUNTO CORE
      Find how to videos, FAQs, tutorial articles and detailed support information for your Suunto watch.
