Suunto 9 Peak Pro
Pearl Gold
Pro version of multisport watch for smaller wrists.
- Sapphire touchscreen and stainless steel bezel
- 10.8 mm thin sport watch body
- Powerful processor and redesigned user interface
- 5 satellite systems for best positioning accuracy
- 40 hours of battery life in the best GPS mode
- Advanced training metrics with 95+ sport modes
Durability and looks,
combined
Suunto 9 Peak Pro is a powerful multisport watch with extended battery life and military-grade durability.
The ultra thin and timeless design makes it beautiful on the outside, too.
Enjoy the smooth interface
In sports, every second counts. Thanks to the powerful chipset, Suunto 9 Peak Pro reacts faster to your touch than ever before.
We also completely redesigned the user interface, making it even more intuitive to use and easier to read.
Best-in-class battery life and improved GPS
Even on longer adventures, Suunto 9 Peak Pro is a reliable companion. It features the best battery life of similar-sized sports watches: up to 40 hours in the best GPS mode.
The superior GPS allows you to see your location, pace and distance with greater accuracy, even in challenging environments.
Battery life
With Suunto 9 Peak Pro, you can push your limits without worrying about running out of power. Performance mode is activated by default at the start of exercise. If you need to keep going longer, you can change the mode in the watch settings.
Training, continuous tracking
Up to 40 hours
Performance mode, best GPS accuracy (single-band)
Up to 300 hours
Up to 21 days
Daily heart rate on, display wakes on wrist-raise
Up to 30 days
Extremely tough.Extremely elegant.
The robustness of the Suunto 9 Peak Pro was tested according to US military standards. Waterproof up to 100 meters, it is built from the highest quality materials, such as sapphire glass, stainless steel and titanium in selected versions.
Toughness can still look elegant. Together with its predecessors, the Suunto 9 Peak Pro is the thinnest GPS multisport watch on the market.
Made for adventures, from trails to underwater
What’s your exercise of choice? With presets for more than 95 sport modes, you’re good to go whether you’re at the gym or climbing a mountain. Receive personalized feedback on your training load, progress and recovery, calculated based on heart rate variability (HRV). For more information, follow your efforts in Training Zone on Suunto App or coaching tools such as TrainingPeaks.
With a dedicated snorkeling mode, Suunto 9 Peak Pro is ready to accompany you on your underwater adventures.
Enhance your experience with Suunto app and SuuntoPlus™
Suunto app helps you plan, analyse and share your routes, workouts and activity data. You can connect to over 200 partner apps, such as Strava, komoot and TrainingPeaks.
Within the app, you'll find the SuuntoPlus™ Store, where you can customize your watch even further with new features and connected devices. Make it yours!
SPECIFICATIONS
Measurements43 x 43 x 10.8 mm / 1.69 x 1.69 x 0.43 "
Weight64 g / 2.26 oz
Bezel material:Stainless steel
Glass material:Sapphire crystal
Case material:Glass fibre reinforced polyamide
Strap material:Silicone
What's in the box?Suunto 9 Peak Pro Pearl Gold, charging cable, printed user documentation
Country of manufactureCN
TECHNICAL SPECIFICATIONS
MUSIC
Control your music with watch✔
Bezel materialStainless steel
Glass materialSapphire crystal
Case materialGlass fibre reinforced polyamide
Strap materialSilicone
Wrist sizes125-175 mm or 125-200 mm depending on the model (accessory straps -215 mm)
Strap width22 mm
Integrated wrist heart rate✔
Customizable watch faces✔
Touch screen lock✔
Touch display✔
Color display✔
Vibration alert✔
Water resistance100 m
Battery typerechargeable lithium-ion
Firmware upgradable✔
Time, date✔
Alarm clock✔
Dual time✔
Automatic timekeeping✔
Countdown timer✔
Stopwatch timer✔
LanguageEN, CS, DA, DE, EL, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, HE, ZH*, TH*, ZHTW* Chinese language is only available in the China edition watches.
BacklightLED
Configurable backlightautomatic brightness
Button lockduring exercise
Display size1,2"
Display typematrix
Display resolution240 x 240
Metric and imperial units✔
Automatic daylight saving time✔
Automatic firmware updates over the air✔
Battery indicatorpercentage / icon
Blood oxygen✔
Always-on display✔
PHYSICAL SPECIFICATIONS
Operating temperature-20° C to +55° C / -5° F to +130° F
Storage temperature-20° C to +55° C / -5° F to +130° F
Recommended charging temperature0° C to +35° C / +32° F to +95° F
BATTERY LIFE
Intelligent charge reminders✔
In time mode30 days
With 24/7 tracking and mobile notifications21 days
Training mode with GPS40h / 70h / 300h
COMPASS
Digital compass✔
Tilt compensation✔
Declination correction✔
Direction scaledegrees / mils
Needlenorth indicator
Compass accuracy5°
Compass resolution1°
CONNECTIVITY
Connectivity (between devices)Bluetooth
Compatible with Suunto app✔
Phone notifications on the watch✔
Media controls on watch✔
Send predefined replies to incoming messages from watchAndroid only
Compatible with online sports communities✔
Watch software updates from cloud✔
Automatic over the air software updates✔
Smartphone compatibilityMost common models supported
24/7
ACTIVITY TRACKING
Step counter✔
Calories burned✔
Activity targets✔
Activity history✔
Calorie burn rate and heart rate during daily activities✔
Daily minimum heart rate tracking✔
SLEEP TRACKING
Sleep duration✔
Bed times✔
Time awake✔
Deep sleep✔
Average and minimum heart rate during sleep✔
Light sleep✔
HRV from sleep✔
Sleep quality✔
STRESS AND RECOVERY
Daily resource level✔
Stress and recovery status✔
HRV measurement✔
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
Satellite systemsGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportL1
Simultaneous satellite systems4
Max connected satellites32
Intelligent battery modesPerformance, Endurance, Tour, Custom
GPS recording rateBest, OK, Low
Waypoint and visual route navigation✔
Zoom levels in navigation✔
Auto zoom based on route shape✔
Breadcrumb trail in real time✔
Route planning with altitude profile✔
Outdoor terrain and satellite maps✔
Global heatmaps for 20 sports✔
Route planning with heatmaps✔
Personal route library synced to watch✔
Snap to route✔
Point of Interest (POI) navigation✔
ETA (estimated time of arrival), remaining distance✔
GPS track analysis✔
Track logging, viewing and sharing✔
ETA (estimated time of arrival)✔
Bearing navigation✔
Outdoor maps by satellite, terrain and topography in web by Mapbox, Google Maps & Android✔
ALTIMETER
Barometric altitude✔
GPS altitude✔
Combined GPS and barometric altitude (FusedAlti™)✔
Altitude in daily mode✔
Altitude acclimation with blood oxygen✔
Total ascent/descent✔
Vertical speed✔
Automatic alti/baro profile✔
Log recording rate1 s
Resolution1 m
Range-500 - 9999 m
WEATHER
Sunrise/sunset times✔
Storm alarm✔
Sea level pressure✔
Temperature✔
Temperature display range-20° C to +55° C / -5° F to +130° F
Temperature resolution1° C / 1.5° F
Pressure resolution1 hPa
Altitude graph shown in exercise summary✔
TRAINING FUNCTIONS
INTERVAL TRAINING
Setup intervals✔
Interval guidance during training✔
Structured intervals✔
HEART RATE
Heart rate measured from wrist✔
Heart rate belt compatibilityBluetooth Smart belts
RR intervalwith Suunto Smart Heart Rate Belt & Suunto Smart Sensor
Heart rate in beats per minute✔
Records heart rate in swimming✔
Heart rate graph in real time✔
Real-time average heart rate✔
Calories✔
Peak Training Effect✔
Personal heart rate zones✔
Fitness level (VO2max)✔
Recovery time✔
SPEED AND DISTANCE
Cadence based speed and distance✔
GPS speed and distance✔
Chrono✔
Foot POD supportBluetooth Smart
Autolaps✔
Manual laps✔
Analysis of pace, speed graphs and tracks on the map✔
TRAINING RECOVERY
Feeling stored after training to watch✔
Training based recovery time✔
TRAINING LOAD
Logbook with exercise details✔
Log summary on the watch with lap details✔
Training load with totals by sport✔
Training logbook for long term overviews✔
Exercise summary with lap details✔
SHARE AND RELIVE
Exercise sharing to social media✔
Exercise rating and commenting✔
Follow other members and get feedback via activity stream✔
ADAPTIVE TRAINING GUIDANCE
Intensity and duration based real-time guidance during workout✔
SPORT EXPERTISE
SWIMMING
Pool swim pace and distance✔
Openwater swim distance✔
Swimming time by pool length, lap, total✔
Swimming stroke rate, count and type✔
Stroke efficiency (SWOLF)✔
Automatic intervals✔
Interval lap table✔
CYCLING
Cycling speed✔
Average speed in real time✔
Bike POD with speed/cadence supportBluetooth Smart
Bike power meter supportBluetooth Smart
Bike Power (W), average and maximum (with power sensor)Bluetooth Smart
Bike Lap and Lap Maximum Power (with power sensor)✔
Real-time lap table with avg HR, avg power and avg speed✔
Interval guidance with power/speed/heart rate✔
RUNNING
Running pace✔
Suunto FusedSpeed™✔
Snap to route✔
Running powerfrom wrist or with Stryd sensor
SuuntoPlus™ Ghost runner✔
Foot POD calibrationautomatic
Lap table in watch and Suunto app✔
Average, max, lap pace in real time✔
Interval guidance with running pace/heart rate/distance✔
MULTISPORTS
Change sport mode during exercise✔
Preconfigured multisport modes✔
Post-analysis of multisport exercise by sport✔
Multisport exercise summary on watch✔
SPORT MODES
Customizable sport modes and displays✔
Graphical displays in sport modes✔
Pre-installed sport modes on watch> 95
SuuntoPlus™Yes, check the details from here
DIVING FUNCTIONS
FREEDIVING
Depth meter for snorkeling10 m
Recommended products
Special Offer Just for You!
You’ve added a product to your cart - now unlock an exclusive deal! Grab this offer before you check out
Powered by Salepify App
