Care and support
Handling guidelines
Handle the unit with care, do not knock or drop it. Do not store the headphones below heavy items as the headphones may get deformed.
Although the headphones are resistant to sweat and rain, do not soak them in water for a long time. When the surface of the product is dirty, wipe it clean with a soft dry cloth. Pay special attention to the microphones, buttons, and charger pins.
Under normal circumstances, the headphones do not require servicing.
Use only original Suunto accessories. Damage caused by non-original accessories is not covered by warranty.
Handling guidelines
Battery and charging
The battery performance on a single charge depends on how you use your headphones and in what conditions. Low temperatures, for example, reduce the duration of a single charge. In general, the capacity of rechargeable batteries decreases over time.
The earbuds are fully charged in one hour, and you can listen to up to 6 hours of music with one charge.
When the battery level of the earbuds is more than 60%, the green LED light will blink when you open the charging case.
When the battery level of the earbuds is less than 60%, the orange LED light will blink when you open the charging case.
When the battery level of the charging case is more than 40%, the green LED light will blink when you close the case.
When the battery level of the charging case is less than 40%, the orange LED light will blink when you close the case.
To check the battery status of your headphones, connect the product to Suunto app. You can see the battery status on the headphones' page in the app.
For charging your headphones, you can use the supplied USB cable or the portable powerbank.
USB cable
The USB charging cable is included in the product package. For charging the case with the cable, connect the end of the cable to the charging port of the case. While the case is charging, the LED light is on. When the battery is fully charged, the LED light turns off.
Charging case
For charging the earbuds while on the move, the package of the product contains a charging case, offering extra 24 hours of battery life.
Before using the charging case, you have to charge it with a USB-C cable. While charging, the orange LED light on the charging case turns on. When the battery is fully charged, the LED light turns green.
To charge your earbuds with the charging case, put the earbuds into the case. The earbuds will automatically connect to the charging case. When the charging starts, the LED light on the charging case turns on for one second.
WARNING:
Before charging, ensure that the charging case is free from any residual liquid. Liquid on the charging ports damage the earbuds and the charging case's circuit.
Disposal
Please dispose of the device in accordance with local regulations for electronic waste. Do not throw it in the garbage. If you wish, you may return the device to your nearest Suunto dealer.
