1 / 3
SUUNTO MC-2
/360/IN/D/NH Compass
SUUNTO MC-2
SUUNTO MC-2
1/3
Money-back guarantee
30-Days Return
Warranty Repair
SKU: SS004247001
Suunto MC-2
₱3,640
A professional mirror compass with top-of-the-line features for direction and slope measurements for mountain adventures.
  • High grade steel needle with jewel bearing
  • Balanced for northern hemisphere, imperial scales
  • Adjustable declination correction
  • Mirror for sighting bearings and signaling, with magnifying lens
  • Luminescent markings for working in low light
  • Clinometer combined
  • Detachable snap-lock lanyard with wristlock
    Choose Your Color
    Quantity
    Free shipping on orders of ₱10000 or more.
    ₱3,640
    Compare +
    30-Days Return
    Warranty Repair
    Made in Finland
    Limited lifetime warranty
    Exceptionally stable & fast needle
    *only available in Steel solar & Titanium solar models
    Baseplate with magnifying lens
    Luminescent markings for low light
    Sighting compass for mountain adventures
    Integrated clinometer
    The clinometer is useful in uneven terrain where you need to determine slope gradient to pinpoint your exact location. It also helps to measure altitude.
    The lanyard with wristlock is easy to detach for working with the map.
    Made in Finland
    All Suunto compasses are handcrafted at our factory with 100% renewable energy.
    The compass liquid used by Suunto is specially formulated to provide damping over a large temperature range while preventing the needle from sticking.
    Stable operation
    Mirror for more
    The mirror on a compass serves the dual purpose of allowing you to sight bearings accurately and facilitating signaling by reflecting sunlight.
    Accurate bearings
    Sighting hole and notch in a compass facilitate precise navigation by allowing you to align the compass with distant landmarks and obtain accurate bearings.
    SPECIFICATIONS
    • Measurements
      65 x 101 x 18 mm / 2.56 x 3.98 x 0.71 "
    • Weight
      74 g / 2.61 oz
    • Bezel material:
      Plastic
    • What's in the box?
      Suunto MC-2/360/IN/D/NH Compass, lanyard with wristlock and declination correction tool, Quickrelease, Quick Guide
    • Country of manufacture
      FI
    TECHNICAL SPECIFICATIONS
    • Bezel material
      Plastic
    • Weight
      74 g / 2.61 oz
    • Water resistance
      insensitive to water pressure
    • Battery type
      no battery required
    • Luminous markings
      bezel, orienting markings, direction of travel
    • Lanyard quick release
    • Attachment
      lanyard
    PHYSICAL SPECIFICATIONS
    • Operating temperature
    • Storage temperature
    COMPASS
    • Direction scale
      degrees
    • Needle
      high grade steel
    • Liquid filled and jewel bearing
    • Compass accuracy
      2.5°
    • Compass resolution
      2°
    OUTDOOR FUNCTIONS
    GPS TRACKING & NAVIGATION
    • Magnifying lens
    • Mirror
    • Sighting
      mirror, notch and hole
    CLINOMETER
    • Clinometer
    • Liquid filled
    • Clinometer scales
      0 ± 90°
    • Inclination accuracy
      2°
    • Inclination resolution
      2°
    Recommended products
