Suunto Ambit3 Peak Sapphire
Note: Price does not include tax. Price including tax is
₱0
    The GPS outdoor watch with route altitude profile navigation and extremely long battery life
CLASSIC ADVENTURE COMPANION
Whether you’re reaching for the top of the summit or a new personal best, Suunto Ambit3 Peak will be there to help you. A GPS watch designed for adventures that reach the edges of the map, it provides everything you need to find your way, stay safe and follow your progress.
KEY FEATURES
Fitness level tracking
WIRELESS TANK PRESSURE
VIBRATION ALARMS
DIGITAL COMPASS
WIRELESS MOBILE CONNECTION
INTERCHANGEABLE STRAPS
RECHARGEABLE BATTERY
UPDATABLE SOFTWARE
BENEFITS
              Right tools for the outdoors
              Adventure-proof
              Sports tracking essentials
            SPECIFICATIONS
                  Measurements50 x 50 x 17 mm / 1.97 x 1.97 x 0.67 "
                  Weight92 g / 3.25 oz
                  Bezel material:Steel
                  Glass material:Sapphire crystal
                  Case material:Polyamide
                  Strap material:Silicone
                  What's in the box?Suunto Ambit3 Peak Sapphire, USB cable, Quick Guide, Warranty Leaflet
                  Country of manufactureFI
TECHNICAL SPECIFICATIONS
                      Bezel materialSteel
                      Glass materialSapphire crystal
                      Case materialPolyamide
                      Strap materialSilicone
                      Water resistance100 m
                      Battery typerechargeable lithium-ion
                      Firmware upgradable✔
                      Time, date✔
                      Alarm clock1 daily alarm
                      Dual time✔
                      Automatic timekeeping✔
                      Countdown timer✔
                      Stopwatch timer✔
                      LanguageEN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH
                      BacklightLED
                      Configurable backlightbrightness / mode
                      Button lockcustomizable
                      Invert display✔
                      Display typematrix
                      Display resolution128 x 128
                      Metric and imperial units✔
                      Battery indicatorpercentage / icon
                      Autoscrolling of exercise displays✔
                      Memory left indicator✔
PHYSICAL SPECIFICATIONS
                      Operating temperature-20° C to +60° C / -5° F to +140° F
                      Storage temperature-30° C to +60° C / -22° F to +140° F
                      Recommended charging temperature0° C to +35° C / +32° F to +95° F
BATTERY LIFE
                      In time mode30 days
                      Training mode with GPS20, 30, 200 h For more information www.suunto.com/software-updates
COMPASS
                      Digital compass✔
                      Tilt compensationfull
                      Declination correction✔
                      Direction scaledegrees / mils
                      Needlenorth indicator
                      Bearing lock with direction indicator✔
                      Compass accuracy5°
                      Compass resolution1°
CONNECTIVITY
                      Connectivity (between devices)Bluetooth Smart
                      Watch customizationUSB cable
                      Data transferWireless / USB cable
                      Phone notifications on the watchwith Suunto App
                      Compatible with online sports communitiesStrava, TrainingPeaks, MapMyFitness and others (available in Suunto app)
                      Smartphone compatibilityiPhone, Android
SUUNTO APPS
                      Compatible with Suunto Apps✔
                      Max. nr. of apps per sport mode5
                      Logging of app specific metrics✔
                      Most recommended apps by activity✔
                      Create own metrics with advanced formulas✔
                      Chrono, GPS, HR, weather and altitude data✔
                      Running, cycling, swimming data✔
                      Rich math functions, if/then-logic, sound, backlight, etc.✔
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
                      Satellite systemsGPS
                      GPS recording rate1, 5, 60 s
                      Coordinate systemsWGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000)
                      Waypoint and visual route navigation✔
                      Max. nr. of Points of Interest (POIs)250
                      Find back✔
                      Route planning with altitude profile✔
                      Route altitude profile navigation in real-time✔
                      Route points per route / POIs in watch1000 / 250
                      GPS track analysis✔
                      Track backyes
                      Track logging, viewing and sharingin Suunto App
                      Route planningin Suunto Movescount.com
ALTIMETER
                      Barometric altitude✔
                      Altitude graph✔
                      GPS altitude✔
                      Combined GPS and barometric altitude (FusedAlti™)✔
                      Altitude differenceyes** ** available as Suunto Apps
                      Total ascent/descentair pressure based
                      Vertical speedair pressure based
                      Automatic alti/baro profile✔
                      Log recording rate1, 10 s
                      Resolution1 m
                      Range-500 - 9999 m
WEATHER
                      Sunrise/sunset times✔
                      Storm alarm✔
                      Sea level pressure✔
                      Temperature✔
                      Temperature display range✔
                      Temperature resolution1°
                      Pressure resolution1 hPa / 0.03 inHg
                      Max weather recording lengthpast 26 hours
                      Sea level pressure graph✔
                      Tide informationyes** ** available as Suunto Apps
                      Weather trend indicator✔
TRAINING FUNCTIONS
HEART RATE
                      RR interval✔
                      Heart rate in beats per minute✔
                      Records heart rate in swimmingyes, with Suunto Smart Heart Rate Belt & Suunto Smart Sensor
                      Heart rate graph in real time✔
                      Calories✔
                      Peak Training Effect✔
                      Recovery time✔
                      Speed and heart rate-based guidance during exercise✔
                      Real-time average and max heart rate✔
                      Real time EPOCyes** ** available as Suunto Apps
                      Heart rate in % of max hr✔
                      Heart rate limits✔
SPEED AND DISTANCE
                      GPS speed and distanceIntegrated
                      Chrono✔
                      Foot POD supportBluetooth Smart
                      Bike POD supportBluetooth Smart
                      Distance based autolaps✔
                      Laps> 1000
                      Autopause✔
TRAINING RECOVERY
                      Sleep recovery test (Firstbeat™)✔
                      Training based recovery time✔
TRAINING LOAD
                      Log summary on the watch with lap details✔
                      Training analysisin Suunto App
                      Training logbook with story and image supportin Suunto App
SPORT EXPERTISE
SWIMMING
                      Pool swim pace and distance✔
                      Openwater swim pace and distance✔
                      Records heart rate in swimmingYes, with Suunto Smart Heart Rate Belt & Suunto Smart Sensor
                      Swimming time by pool length, lap, total✔
                      Swimming stroke rate, count and type✔
                      Stroke efficiency (SWOLF)✔
                      Automatic intervals✔
                      Swim styles detection with personal style teaching✔
CYCLING
                      Cycling speed✔
                      Average speed in real time✔
                      Bike Power (W), average and maximum (with power sensor)Bluetooth Smart
                      Bike Lap and Lap Maximum Power (with power sensor)✔
                      Aerodynamic drag in real time (with power sensor)yes** ** available as Suunto Apps
                      Bike Power 3s, 10s, 30s (with power sensor)✔
                      Cadence POD SupportBluetooth Smart
                      Hill incline in real timeyes, available as Suunto Apps
                      Multiple Bike POD support✔
                      Normalized Power (Suunto Apps / TM by Training Peaks)yes** ** available as Suunto Apps
RUNNING
                      Running pace✔
                      Suunto FusedSpeed™✔
                      Running powerwith Stryd sensor
                      Foot POD calibrationmanual or GPS
                      Average pace in real time✔
                      Lap comparisons by kilometer/mile✔
                      Marathon End-time Estimatoryes** ** available as Suunto Apps
                      Average stride lengthyes** ** available as Suunto Apps
                      Running cadencewatch or Foot POD
                      Running Performance (Firstbeat™)✔
MULTISPORTS
                      Change sport mode during exercise✔
                      Preconfigured multisport modes✔
                      Post-analysis of multisport exercise by sport✔
SPORT MODES
                      Customizable sport modes and displays10 modes / 8 displays per mode
