1 / 8
Suunto Ambit3 Peak Black (HR)
1/8
Money-back guarantee
30-Days Return
Warranty Repair
SKU: SS020674000
The GPS watch for explorers with heart rate monitoring, weather functions and mobile connection
30-Days Return
Warranty Repair
CLASSIC ADVENTURE COMPANION
Whether you’re reaching for the top of the summit or a new personal best, Suunto Ambit3 Peak will be there to help you. A GPS watch designed for adventures that reach the edges of the map, it provides everything you need to find your way, stay safe and follow your progress.
KEY FEATURES
Fitness level tracking
WIRELESS TANK PRESSURE
VIBRATION ALARMS
DIGITAL COMPASS
WIRELESS MOBILE CONNECTION
INTERCHANGEABLE STRAPS
RECHARGEABLE BATTERY
UPDATABLE SOFTWARE
BENEFITS
Right tools for the outdoors
Accurate altitude measurements are delivered by FusedAlti, which combines GPS with barometric altitude. The barometric trend predicts changes in weather and the storm alarm lets you know when it’s time to find shelter. Sunrise and sunset times keep you informed of remaining daylight hours.
Adventure-proof
Looking to go off the grid or on a longer journey? Suunto Ambit3 Peak comes with up to 200 hours of battery life with the GPS turned on that lets you explore longer. Designed for durability, you can rely on it on your treks off the beaten path. It’s also water resistant up to 100 meters.
Read more about Suunto app
Sports tracking essentials
Keep track of your exercises, progress and recovery with ten customizable sport modes and detailed information on your exercises. You can also connect your watch to Suunto app and view your exercises there or take advantage of Suunto’s wide network of partners to access more features and training tools.
SPECIFICATIONS
  • Measurements
    50 x 50 x 18 mm / 1.97 x 1.97 x 0.71 "
  • Weight
    89 g / 3.14 oz
  • Bezel material:
    Steel
  • Glass material:
    Mineral crystal
  • Case material:
    Polyamide
  • Strap material:
    Elastomer
  • What's in the box?
    Suunto Ambit3 Peak Black, Suunto Smart Sensor and black heart rate belt (size M), USB cable, quick guide, warranty leaflet
  • Country of manufacture
    FI
TECHNICAL SPECIFICATIONS
  • Bezel material
    Steel
  • Glass material
    Mineral crystal
  • Case material
    Polyamide
  • Strap material
    Elastomer
  • Weight
    89 g / 3.14 oz
  • Water resistance
    100 m
  • Battery type
    rechargeable lithium-ion
  • Firmware upgradable
  • Time, date
  • Alarm clock
    1 daily alarm
  • Dual time
  • Automatic timekeeping
  • Countdown timer
  • Stopwatch timer
  • Language
  • Backlight
    LED
  • Configurable backlight
    brightness / mode
  • Button lock
    customizable
  • Invert display
  • Display type
    matrix
  • Display resolution
    128 x 128
  • Metric and imperial units
  • Battery indicator
    percentage / icon
  • Autoscrolling of exercise displays
  • Memory left indicator
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
BATTERY LIFE
  • In time mode
    30 days
  • Training mode with GPS
    20, 30, 200 h For more information www.suunto.com/software-updates
COMPASS
  • Digital compass
  • Tilt compensation
    full
  • Declination correction
  • Direction scale
    degrees / mils
  • Needle
    north indicator
  • Compass accuracy
  • Compass resolution
CONNECTIVITY
    Bluetooth Smart
  • Watch customization
    USB cable
  • Data transfer
    Wireless / USB cable
    with Suunto App
    Strava, TrainingPeaks, MapMyFitness and others (available in Suunto app)
  • Smartphone compatibility
    iPhone, Android
SUUNTO APPS
  • Compatible with Suunto Apps
  • Max. nr. of apps per sport mode
    5
  • Logging of app specific metrics
  • Most recommended apps by activity
  • Create own metrics with advanced formulas
  • Chrono, GPS, HR, weather and altitude data
  • Running, cycling, swimming data
  • Rich math functions, if/then-logic, sound, backlight, etc.
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
  • Satellite systems
    GPS
  • GPS recording rate
    1, 5, 60 s
  • Coordinate systems
    WGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000)
  • Max. nr. of Points of Interest (POIs)
    250
  • Find back
  • Route altitude profile navigation in real-time
  • Route points per route / POIs in watch
    1000 / 250
  • GPS track analysis
  • Track back
    yes
    in Suunto App
  • Route planning
    in Suunto Movescount.com
ALTIMETER
  • Barometric altitude
  • Altitude graph
  • GPS altitude
  • Altitude difference
    yes** ** available as Suunto Apps
  • Total ascent/descent
    air pressure based
  • Vertical speed
    air pressure based
  • Automatic alti/baro profile
  • Log recording rate
    1, 10 s
  • Resolution
    1 m
  • Range
    -500 - 9999 m
WEATHER
  • Sunrise/sunset times
  • Storm alarm
  • Sea level pressure
  • Temperature
  • Temperature display range
  • Temperature resolution
  • Pressure resolution
    1 hPa / 0.03 inHg
  • Max weather recording length
    past 26 hours
  • Sea level pressure graph
  • Tide information
  • Weather trend indicator
TRAINING FUNCTIONS
HEART RATE
  • RR interval
  • Calories
    1, 10 s
  • Peak Training Effect
  • Recovery time
  • Speed and heart rate-based guidance during exercise
  • Real-time average and max heart rate
  • Real time EPOC
  • Heart rate in % of max hr
  • Heart rate limits
SPEED AND DISTANCE
  • GPS speed and distance
    Integrated
  • Chrono
  • Foot POD support
    Bluetooth Smart
  • Bike POD support
    Bluetooth Smart
  • Distance based autolaps
  • Laps
    > 1000
    1, 10 s
  • Autopause
TRAINING RECOVERY
  • Sleep recovery test (Firstbeat™)
TRAINING LOAD
  • Log summary on the watch with lap details
  • Training analysis
    in Suunto App
  • Training logbook with story and image support
    in Suunto App
SPORT EXPERTISE
SWIMMING
  • Pool swim pace and distance
  • Openwater swim pace and distance
    Yes, with Suunto Smart Heart Rate Belt & Suunto Smart Sensor
  • Stroke efficiency (SWOLF)
  • Automatic intervals
  • Swim styles detection with personal style teaching
CYCLING
  • Cycling speed
  • Average speed in real time
    Bluetooth Smart
  • Aerodynamic drag in real time (with power sensor)
  • Bike Power 3s, 10s, 30s (with power sensor)
  • Cadence POD Support
    Bluetooth Smart
  • Hill incline in real time
    yes, available as Suunto Apps
  • Multiple Bike POD support
  • Normalized Power (Suunto Apps / TM by Training Peaks)
RUNNING
  • Running pace
  • Suunto FusedSpeed™
  • Running power
    with Stryd sensor
  • Foot POD calibration
    manual or GPS
  • Average pace in real time
  • Lap comparisons by kilometer/mile
  • Marathon End-time Estimator
  • Average stride length
  • Running cadence
    watch or Foot POD
  • Running Performance (Firstbeat™)
MULTISPORTS
SPORT MODES
    10 modes / 8 displays per mode
Recommended products
Support for Suunto Ambit3 Peak
