SAFETY
Types of safety precautions
- is used in connection with a procedure or situation that may result in serious injury or death.
- is used in connection with a procedure or situation that will result in damage to the product.
- is used to emphasize important information.
- is used for extra tips on how to utilize the features and functions of the device.
Safety precautions
Keep the USB cable away from medical devices such as pacemakers, as well as key cards, credit cards and similar items. The USB cable device connector includes a strong magnet which may interfere with the operation of medical or other electronic devices and items with magnetically stored data.
Allergic reactions or skin irritations may occur when the product is in contact with skin, even though our products comply with industry standards. In such event, stop use immediately and consult a doctor.
Always consult your doctor before beginning an exercise program. Overexertion may cause serious injury.
Only for recreational use.
Do not entirely rely on the GPS or battery lifetime of the product. Always use maps and other backup material to ensure your safety.
ENSURE THE WATER RESISTANCE OF THE DEVICE! Moisture inside the device may seriously damage the unit. Only an authorized Suunto Service Center should do service activities.
Do not use Suunto USB Cable in areas where flammable gases are present. Doing so may cause an explosion.
Do not disassemble or remodel Suunto USB Cable in any way. Doing so may cause an electric shock or fire.
Do not use Suunto USB cable if cable or parts are damaged.
You must only charge your device using USB adapters that comply with the IEC 62368-1 standard and have a maximum output of 5 V. Non-compliant adapters are a fire hazard and a risk to personal injury and might damage your Suunto device.
DO NOT allow the connector pins of the USB cable to touch any conductive surface. This may short circuit the cable, making it unusable.
Only use the provided charging cable when charging your Suunto Nautic S.
DO NOT use the USB cable when Suunto Nautic S is wet. This may cause an electrical failure. Ensure the cable connector and the connector pin area on the device are dry.
Do not apply solvent of any kind to the product, as it may damage the surface.
Do not apply insect repellent on the product, as it may damage the surface.
Do not throw the product away, but treat it as electronic waste to preserve the environment.
Do not knock or drop the product, as it may get damaged.
Colored textile straps might bleed onto other fabrics or skin when new or wet.
At Suunto we use advanced sensors and algorithms to generate metrics that can help you in your activities and adventures. We strive to be as accurate as possible. However, none of the data our products and services collect is perfectly reliable, nor are the metrics they generate absolutely precise. Calories, heart rate, location, movement detection, shot recognition, physical stress indicators and other measurements may not match the real world. Suunto products and services are intended for recreational use only and are not meant for medical purposes of any kind.
Dive safety
Suunto Nautic S is a dive computer designed to be used for recreational scuba diving and freediving. The device displays essential information before, during and after the dive to enable safe decision making. Suunto Nautic S can be used as a standalone product or in combination with the Suunto Tank POD, which measures the tank pressure and transmits the pressure reading information to the dive computer. The combination of Suunto Nautic S and the Suunto Tank POD is categorized as Personal Protective Equipment under the EU Regulation 2016/425 and protects against risks listed under PPE Risk Category III (a): substances and mixtures which are hazardous to health.
Suunto strongly recommends that you do not engage in any diving activity type without proper training and a complete understanding and acceptance of the risks. Always follow the rules of your training agency.
Make sure you fully understand how to use your dive instrument and what its limitations are by reading all the printed documentation and the online user manual. Always remember that you are responsible for your own safety.
All computers experience failures. It is possible that this device may suddenly fail to provide accurate information during your dive. Always have a plan on how to handle failures, use a backup dive device and only dive with a buddy. In the unlikely event that the dive computer malfunctions during a dive, follow the emergency procedures provided by your certified dive training agency to immediately and safely ascend. Contact Suunto customer support if you experience a system error.
Because any decompression model is purely theoretical and does not monitor the actual body of a diver, there is always a risk of decompression illness (DCI) for any dive. An individual’s physiological makeup can vary from day to day. The dive computer cannot account for these variations. You are strongly advised to remain well within the exposure limits provided by the dive computer to minimize the risk of DCI.
If you suspect risk factors that tend to increase the possibility of DCI exist, Suunto recommends that you use the personal setting to make calculations more conservative and consult a physician with experience in diving medicine before you dive.
When diving at altitudes greater than 300 m (980 ft), the altitude setting must be correctly selected for the computer to calculate the decompression status. Failure to select the correct altitude setting or diving above the maximum altitude limit will result in erroneous dive and planning data. It is recommended that you acclimatize to the new altitude before diving. Always use the same personal and altitude adjustment settings for the actual dive and for the planning.
Suunto strongly recommends that the device not be used for any commercial or professional diving activities. The demands of commercial or professional diving may expose the diver to depths and conditions that tend to increase the risk of DCI.
Before diving, always check that your dive computer is functioning properly, the display is working, the battery level is OK, tank pressure is correct, and your settings are correct.
Check your dive computer regularly during a dive. If you believe or conclude that there is a problem with any computer function, abort the dive immediately and safely return to the surface. Contact Suunto customer support and return your computer to an authorized Suunto Service Center for inspection.
The dive computer should never be traded or shared between users while in use. Its information will not apply to someone who has not been wearing it throughout a dive, or sequence of repetitive dives. Its dive profiles must match that of the user. No dive computer can take into account dives made without the computer. Thus, any diving activity up to four days prior to initial use of the computer may cause misleading information and must be avoided.
For safety reasons, you should never dive alone. Dive with a designated buddy. You should also stay with others for an extended time after a dive as the onset of possible DCS may be delayed or triggered by surface activities.
ONLY TRAINED DIVERS SHOULD USE A DIVE COMPUTER! Insufficient training for any kind of diving, including freediving, may cause a diver to commit errors, such as incorrect use of gas mixtures or improper decompression, that may lead to serious injury or death.
Do not participate in freediving and scuba diving activities on the same day.
This device is recommended for use with compressed air. The compressed air supply must comply with the quality of compressed air specified in the EU standard EN 12021:2014 (requirements for compressed gases for breathing apparatus). This device can also be used with enriched air (nitrox) breathing gases.
Diving with mixed gases has dangers that are not familiar to divers diving with air. Appropriate training courses for diving with enriched air is essential prior to the use of this kind of equipment with oxygen content greater than 21%.
In nitrox use, the maximum operating depth and no decompression time are dependent on the oxygen content of the gas. When the oxygen limit fraction indicates that the maximum limit is reached, you must immediately take action to reduce oxygen exposure. Failure to take action to reduce oxygen exposure after a CNS%/OTU warning is given can rapidly increase the risk of oxygen toxicity, injury, or death.
Do not dive with gas if you have not personally verified its content and entered the analyzed value into your dive computer. Failure to verify tank contents and enter the appropriate gas values where applicable into your dive computer will result in incorrect dive planning information.
YOU ARE ADVISED TO AVOID FLYING ANY TIME THE COMPUTER COUNTS DOWN THE NO-FLY TIME. ALWAYS ACTIVATE THE COMPUTER TO CHECK THE REMAINING NO-FLY TIME PRIOR TO FLYING! Flying or traveling to a higher altitude within the no-fly time can greatly increase the risk of DCS. Review the recommendations given by Divers Alert Network (DAN). There can never be a flying-after-diving rule that is guaranteed to completely prevent decompression sickness!
If you have a pacemaker, we recommend you do not scuba dive. Scuba diving creates physical stresses on the body which may not be suitable for pacemakers.
You must read the printed quick guide and online user guide of your dive computer. Failure to do so may lead to improper use, serious injury or death.
Make sure your Suunto dive computer always has the latest software with updates and improvements. Check before every dive trip from www.suunto.com/support, if Suunto has released a new software update for your device. When a new software update is available, you must install it before diving. Updates are made available to improve your user experience and are part of Suunto's philosophy of continuous product development and improvement.
