Weather
                From the watch face view, swipe up or press the lower button to
                scroll to the weather widget.
                The weather widget provides you with information of the current
                weather. It shows the current temperature, wind speed and
                direction and current weather type both as text and icon.
                Weather types can be, for example, sunny, cloudy, rainy etc.
                Swipe up or press the lower button to see more detailed weather
                data such as humidity, air quality and forecast data.
                  Make sure that you sync your watch with Suunto app regularly
                  to get the most accurate weather data.
              Notification and status
                If you have paired your watch with Suunto app, you can get
                notifications of incoming calls and text messages, for example,
                on your watch.
                When you pair your watch with the app, notifications are on by
                default. You can turn them off from the settings under
                Notifications .
                  Messages received from some apps used for communication might
                  not be compatible with
                    Suunto 9 Peak Pro
                When a notification arrives, a pop-up appears on the watch face.
                Press the middle button to remove the popup. If the message
                doesn't fit on the screen, press the lower button or swipe up to
                scroll through the full text.
                Below Actions , you can
                interact with the notification (the available options vary
                depending on your phone and which of your mobile apps sent the
                notification).
                For apps used for communications, you can use your watch to send
                a Quick reply . You can
                select and modify the predefined messages in Suunto app.
              Notification history
                If you have unread notifications or missed calls on your mobile
                device, you can view them on your watch.
                From the watch face, press the middle button until you reach the
                notification widget and then press the lower button to scroll
                through the notification history.
                The notification history is cleared when you check the messages
                on your mobile device.
              Media controls
                Your
                Suunto 9 Peak Pro
                can be used to control the music, podcast, other media played on
                your phone or being cast from your phone to another device. The
                media controls widget is on by default but can be turned off by
                swiping up from watch face and select
                Media controls .
                  You need to pair your watch with your phone before you can use
                  Media controls.
                To access the media controls widget, press the lower button from
                watch face or, during an exercise, press the middle button until
                the media control widget is shown.
                In the media control widget, the buttons have the following
                functions:
Play/Pause: Upper button
                  Next track/episode: Upper button (long press)
                  Previous track/episode and volume: Lower
                  button (will open media control options)
              Press the middle button to exit the media control widget.
                  If your watch has a touch screen, the media controls can also
                  be used by tapping the icons on the screen.
              Heart rate
                scroll to the heart rate (HR) widget.
                The HR widget provides a quick snapshot of your heart rate and a
                12-hour graph of your heart rate. The graph is plotted using
                your average heart rate based on 24-minute time slots.
                Your minimum heart rate from the last 12 hours is a good
                indicator of your recovery state. If it is higher than normal,
                you probably are not yet fully recovered from your last training
                session.
                If you record an exercise, the daily HR values reflect the
                elevated heart rate and calorie consumption from your training.
                But keep in mind that the graph and consumption rates are
                averages. If your heart rate peaks at 200 bpm while exercising,
                the graph does not show that maximum value, but rather the
                average from the 24 minutes during which you hit that peak rate.
                Before you can see the daily HR widget values, you need to
                activate daily HR feature. You can toggle the feature on or off
                Activity .
                With this feature on, your watch activates the optical heart
                rate sensor on a regular basis to check your heart rate. This
                slightly increases battery power consumption.
                Once activated, your watch needs 24 minutes before it can start
                display heart rate information.
                Swipe right or long press the middle button to return to the
                watch face view.
              Steps and calories
                From the watch face, swipe up or press the lower button until
                you see your total steps and estimated calories for the day.
                Your watch keeps track of your overall activity level throughout
                the day. This is an important factor whether you just aim to be
                fit and healthy or you are training for an upcoming competition.
                It is good to be active, but when training hard, you need to
                have proper rest days with low activity.
                The activity counter automatically resets at midnight every day.
                At the end of the week (Sunday), the watch provides a summary of
                your activity showing your average for the week and daily
                totals.
                Your watch counts steps using an accelerometer. The total step
                count accumulates 24/7, also while recording training sessions
                and other activities. However, with some specific sports, such
                as swimming and cycling, steps are not counted.
                The top value in the widget shows the total step count for that
                day and the bottom value is the estimated amount of active
                calories you have burned so far during the day. Below this you
                see the total calories burned. The total includes both active
                calories and your Basal Metabolic Rate, BMR (see below).
                The half rings in the widget indicates how close you are to your
                daily activity goals. These targets can be adjusted to your
                personal preferences (see below).
                You can also check your steps and calories burned over the last
                seven days by swiping up from the widget.
              Activity goals
                You can adjust your daily goals for both steps and calories by
                swiping up from the widget. Your daily goals can also be
                adjusted under
                Settings »
                Activity .
                When setting your steps goal, you define the total number of
                steps for the day.
                The total calories you burn per day is based on two factors:
                your Basal Metabolic Rate (BMR) and your physical activity.
                Your BMR is the amount of calories your body burns while at
                rest. These are the calories your body needs to stay warm and
                perform basic function like blink your eyes or beat your heart.
                This number is based on your personal profile, including factors
                such as age and gender.
                When you set a calorie goal, you define how many calories you
                want to burn in addition to your BMR. These are your so-called
                active calories. The ring around the activity display advances
                according to how many active calories you burn during the day
                compared to your goal.
              Logbook
                Your watch provides an overview of your training activity via a
                logbook.
                In the logbook you can see a summary of your current training
                week. The summary includes the total duration and an overview of
                which days you have exercised.
                Swiping up gives you information on which activities you have
                performed and when. Selecting one of the activities, by pressing
                the middle button, provides you with even more details and also
                the possibility to delete the activity from your logbook.
              Sun & Moon
                From watch face, swipe up or press the lower button to scroll to
                the Sun & Moon widget. Your watch will give you the time
                until the next sunset or sunrise, depending on which one comes
                next.
                If you select the widget, you get more details such as the time
                when the sun rises and sets, and also the current moon phase.
              Training
                The training widget provides you with information on the
                training load for the current week and also the total duration
                on all of your training sessions.
                This widget also gives you guidance on how your form is, if you
                start losing fitness, if you are maintaining it or if you
                currently do productive training.
                The CTL (Chronic Training load) value is a weighted average on
                your long term TSS (Training Stress Score), the more you train
                the higher your fitness is.
                The ATL (Acute Training Load) value is the 7-day weighted
                average of your TSS and basically tracks how fatigued you
                currently are.
                The TSB (Training Stress Balance) value shows your form which is
                basically the difference between long-term, chronic training
                load (CTL) and short-term, acute training load (ATL).
                  Please refer to www.suunto.com or Suunto app to
                  learn more about Suunto's training load analysis concept.
              Recovery, training
                The recovery training widget shows your current form and your
                workout feelings the last week as well as your last 6 weeks.
                Please note that you need to register you feeling after each
                workout to get this data, see Feeling .
                This widget will also tell you how your recovery matches your
                current training load.
              Recovery, HRV (Heart Rate Variability)
                Heart Rate Variability (HRV) is a measure of the variation in
                time between heartbeats and its value is a good predictor of
                overall health and well-being.
                HRV helps you to understand your recovery state and it measures
                your physical and mental stress and implies how ready your body
                is to train.
                To be able to get an effective average HRV, you need to track
                your sleep at least three times a week over a longer period to
                establish your HRV range.
                Different situations and conditions such as a relaxed holiday,
                physical and mental exertion or developing flu can lead to
                changes in HRV.
                  learn more about HRV recovery.
              Progress
                The progress widget provides you with data that helps you to
                increase your training load over a longer period of time,
                whether it is the training frequency, duration or intensity.
                Every training session gets a Training Stress Score (TSS) (based
                on the duration and the intensity) and this value is the base
                for calculating the training load for both short and long-time
                averages. From this TSS value, your watch can calculate your
                fitness level (defined as VO₂max) and CTL (Chronic Training
                Load).
                The ramp rate is a metric that monitors your rate of increase or
                decrease in your fitness over a set time.
                Your aerobic fitness level is defined as VO₂max (maximal oxygen
                consumption), a widely recognized measure of aerobic endurance
                capacity. In other words, VO₂max shows how well your body can
                use oxygen. The higher your VO₂max, the better you can use
                oxygen.
                The estimation of your fitness level is based on detecting your
                heart rate response during each recorded running or walking
                workout. To get your fitness level estimated, record a run or
                walk with a duration for at least 15 minutes while wearing your
                Suunto 9 Peak Pro
                The widget also views your estimated fitness age. Fitness age is
                a metric value that reinterprets your VO₂max value in terms of
                age.
                  Improvement of VO₂max is highly individual and it depends on
                  factors such as age, gender, genetics and training background.
                  If you are already very fit, increasing your fitness level
                  will be slower. If you are just starting to exercise
                  regularly, you may see a quick increase in fitness.
              Sleep
                A good night's sleep is important for a healthy mind and body.
                You can use your watch to track your sleep and follow how much
                sleep you are getting on average.
                When you wear your watch to bed,
                Suunto 9 Peak Pro
                tracks your sleep based on accelerometer data.
              To track sleep:
                  Go to your watch settings, scroll down to
                  Sleep and press the
                  middle button (or activate sleep tracking from the sleep
                  widget).
                    Toggle on
                    Sleep tracking .
                    Set the times for going to bed and waking up according to
                    your normal sleep schedule.
                After you have defined your bedtime, you can choose to have your
                watch in Do Not Disturb mode during your sleeping hours and also
                choose if you want to measure your Blood oxygen during your
                sleep.
                Step 3 above, defines your bedtime. Your watch uses that period
                to determine when you are sleeping (during your bedtime) and
                reporting all sleep as one session. If you get up for a drink of
                water during the night, for example, your watch still counts any
                sleep after that as the same session.
                  If you go to bed before your bedtime and also wake up
                  after your bedtime, your watch does not count that as
                  a sleep session. You should set your bedtime according to the
                  earliest you may go to bed and the latest you may wake up.
                Once you have enabled sleep tracking, you can also set your
                sleep target. A typical adult needs between 7 and 9 hours of
                sleep per day, though your ideal amount of sleep may vary from
                the norms.
              Sleep trends
                When you wake up, you are greeted with a summary of your sleep.
                The summary includes, for example, the total duration of your
                sleep, as well as the estimated time you were awake (moving
                around) and the time you were in deep sleep (no movement).
                In addition to the sleep summary, you can follow your overall
                sleep trend with the sleep widget. From the watch face, swipe up
                or press the lower button and select the
                Sleep widget. The first
                view shows your last sleep and a graph of the last seven days.
                While in the sleep widget, you can swipe up to see the sleep
                details for your last sleep.
                  All sleep measurements are based on movement only, so they are
                  estimates that may not reflect your actual sleep habits.
              Sleep quality
                In addition to duration, your watch can also assess sleep
                quality by following your heart rate variability during sleep.
                The variation is an indication of how well your sleep is helping
                you rest and recover. Sleep quality is shown on scale from 0 to
                100 in the sleep summary, with 100 being the best quality.
                Measuring heart rate, blood oxygen and heart rate variability
                (HRV) while sleeping
                If you wear your watch during the night, you can get additional
                feedback on your heart rate, HRV and blood oxygen level (needs
                to be activated in the sleep tracking settings) while sleeping.
                To keep the optical heart rate on during the night, ensure that
                Daily HR is enabled (see Heart rate ).
              Automatic Do Not Disturb mode
                You can use the auto Do Not Disturb setting to automatically
                enable Do Not Disturb mode while you sleep.
              Resources
                Your resources are a good indication of your body's energy
                levels and translate into your ability to handle stress and cope
                with the day's challenges.
                Stress and physical activity deplete your resources, while rest
                and recovery restore them. Good sleep is an essential part of
                ensuring your body has the resources it needs.
                When your resource levels are high, you will likely feel fresh
                and energetic. Going for a run when your resources are high
                means you'll probably have a great run, because your body has
                the energy it needs to adapt and improve as a result.
                Being able to track your resources can help you manage and use
                them wisely. You can also use your resource levels as a guide to
                identify stress factors, personally effective recovery boosting
                strategies, and the impact of good nutrition.
                Stress and recovery uses optical heart sensor readings and to
                get those during the day, daily HR must be enabled, see
                Heart rate .
                It is important that your Max HR and Rest HR are set to match
                your heart rate to ensure that you get the most accurate
                readings. By default, the Rest HR is set to 60 bpm and the Max
                HR is based on your age.
                These HR values can easily be changed in the settings under
                General »
                Personal .
                  Use the lowest heart rate reading measured during your sleep
                  as your Rest HR.
                From the watch face, press the lower button to scroll to the
                resources widget.
                The color around the widget icon indicates your overall resource
                level. If it is green, it means you are recovering. The status
                tells you your current state (active, inactive, recovering or
                stressed). The bar chart shows your resources over the last 16
                hours and the percentage value is an estimate of your current
                resource level.
              Alti & Baro
                Suunto 9 Peak Pro
                constantly measures absolute air pressure using the built-in
                pressure sensor. Based on this measurement and your altitude
                reference value, it calculates altitude or air pressure.
                CAUTION:
                  Keep the area around the two air pressure sensor holes located
                  at six o'clock on the side of your watch free of dirt and
                  sand. Never insert any objects into the holes as this may
                  damage the sensor.
                the alti & baro widget. The widget has three views that can
                be accessed by swiping up and down. The first view displays the
                current altitude.
                Swipe up to see the barometric pressure and the barometer trend
                graph.
              Swipe up again to see the temperature.
              Swipe right or press the middle button to go back.
                Be sure to have your altitude reference value set correctly (see
                Altimeter ). The altitude of your current location
                can be found from most topographic maps or major on-line map
                services such as Google Maps.
                Changes in local weather conditions affect altitude readings. If
                local weather changes often, you should reset the altitude
                reference value regularly, preferably before starting your next
                journey.
              Automatic alti-baro profile
                Weather and altitude changes both cause a change in air
                pressure. To handle this,
                Suunto 9 Peak Pro
                automatically switches between interpreting changes in air
                pressure as altitude or weather changes based on your movement.
                If your watch senses vertical movement, it switches to measuring
                altitude. When you are viewing the altitude graph, it is updated
                with a maximum delay of 10 seconds.
                If you are at a constant altitude (less than 5 meters of
                vertical movement within 12 minutes), your watch interprets air
                pressure changes as weather changes and adjusts the barometer
                graph accordingly.
              Compass
                Suunto 9 Peak Pro
                has a digital compass that allows you to orient yourself in
                relation to magnetic north. The tilt-compensated compass gives
                you accurate readings even if the compass is not horizontally
                level.
                You can access the compass by swiping up from the watch face or
                by pressing the lower button.
              The compass widget includes the following information:
                - Arrow pointing to magnetic north
                - Heading cardinal
                - Heading in degrees
                - Altitude
                - Barometric pressure
                To exit the compass widget, swipe right or use the middle
                button.
                While you are in the compass widget, you can swipe up from the
                bottom of the screen or press the lower button to open a list of
                shortcuts. The shortcuts give you quick access to navigation
                actions such as checking the coordinates of your current
                location or selecting a route to navigate.
                Swipe down or press the upper button to exit the list of
                shortcuts.
              Calibrating compass
                If the compass is not calibrated, you are prompted to calibrate
                the compass when you enter the compass widget.
                If you want to re-calibrate the compass, swipe up or press the
                lower button from compass widget and start the calibration again
                from the settings.
              Setting declination
                To ensure correct compass readings, set an accurate declination
                value.
                Paper maps point to true north. Compasses, however, point to
                magnetic north – a region above the Earth where the Earth’s
                magnetic fields pull. Because magnetic North and true North are
                not at the same location, you must set the declination on your
                compass. The angle in between magnetic and true north is your
                declination.
                The declination value appears on most maps. The location of
                magnetic north changes yearly, so the most accurate and
                up-to-date declination value can be found from websites such as
                www.magnetic-declination.com .
                Orienteering maps, however, are drawn in relation to magnetic
                north. If you are using an orienteering map, you need to turn
                the declination correction off by setting the declination value
                to 0 degrees.
                You can set your declination value from the
                Settings under
                Navigation »
                Declination .
              Timer
                Your watch includes a stopwatch and countdown timer for basic
                time measurement. From the watch face, swipe up or press the
                lower button until you reach the timer widget.
                When you first enter the widget, it shows the stopwatch. After
                that, it remembers whatever you used last, stopwatch or
                countdown timer.
                Swipe up or press the lower button to open the
                Set timer shortcuts menu where
                you can change the timer settings.
              Stopwatch
                Start and stop the stopwatch by pressing the upper button. You
                can resume by pressing the upper button again. Reset by pressing
                the lower button.
              Exit the timer by swiping right or use the middle button.
              Countdown timer
                In the timer widget, swipe up or press the lower button to open
                the shortcuts menu. From there you can select a pre-defined
                countdown time or create custom countdown time.
              Stop and reset as needed with the upper and lower buttons.
                Exit the timer by swiping right or by pressing the middle
                button.
              Blood oxygen
                WARNING:
                    Suunto 9 Peak Pro
                  is not a medical device and the blood oxygen level indicated
                  by
                    Suunto 9 Peak Pro
                  is not intended for diagnosing or monitoring medical
                  conditions.
                You can measure your blood oxygen levels with
                Suunto 9 Peak Pro
                . From the watch face view, swipe up or press the lower button
                to scroll to the Blood oxygen widget.
                Blood oxygen level can provide an indication of overtraining or
                fatigue and the measurement can also be a helpful indicator of
                high altitude acclimation progress.
                Normal blood oxygen levels are between 96% and 99% at sea level.
                At high altitudes, healthy values can be slightly lower.
                Successful acclimation to high altitude makes the value increase
                again.
              How to measure your blood oxygen level:
                  From the watch face, swipe up or press the lower button to
                  Select Measure now .
                - Hold your hand still while the watch is measuring.
                  If the measuring failed, please follow the in-watch
                  instructions.
                  When the measuring is complete, your blood oxygen value is
                  displayed.
                You can also measure your blood oxygen level during your
                Sleep .
