Recording an exercise
In addition to daily activity tracking, you can use your watch to record your training sessions or other
activities to get detailed feedback and follow your progress.
To record an exercise:
Put on a heart rate sensor (optional).
Scroll up to the exercise icon and select with the middle button.
Press upper right or lower right button to scroll through the sport modes and press the middle button
to select the one you want to use.
Above the start indicator, a set of icons appear, depending on what you are using with the sport mode
(such as heart rate and connected GPS). The arrow icon (connected GPS) flash gray while searching and
turn green once a signal is found. The heart icon (heart rate) flash gray while searching and when
once a signal is found, it turns into a colored heart attached to a belt if you are using a heart rate
sensor or a colored heart without the belt if you are using the optical heart rate sensor.
If you are using a heart rate sensor but the icon turns to green only (meaning that the optical heart
rate sensor is active), check that the heart rate sensor is paired, seePairing PODs and sensors, and select the sport mode again.
You can wait for each icon to turn green or start the recording as soon as you like by pressing the
middle button.
Once the recording is started, the selected heart rate source is locked and cannot be changed during
the ongoing training session.
While recording, you can switch between displays with the middle button.
Press the upper right button to pause the recording. Stop and save with the lower right button or
resume with the upper right button.
If the sport mode you selected has options, such as setting a duration target, you can adjust them before
starting the recording by pressing the lower right button. You can also adjust sport mode options while
recording by keeping the middle button pressed.
After you stop the recording, you are asked how you felt. You can answer or skip the question (seeFeeling). Then you get a summary of the activity that you can browse through with the upper or lower right
buttons.
If you made a recording you don't want to keep, you can delete the log entry by scrolling down toDeleteand
confirm with the middle button. You can also delete logs in the same way from the logbook.
Speed and distance calibration
Suunto 3 Fitnessis able to measure running and walking speed and distance using the built-in
accelerometer of the watch. The accelerometer needs to be calibrated to your personal stride length and
movement. Uncalibrated, the watch cannot correctly measure speed and distanced.
The easiest way to calibrate your watch is to record the first running or walking exercises with connected
GPS (SeeConnected GPS). When using the GPS of your mobile phone, the speed and distance calibration is done automatically in
the background.
To manually calibrate your watch:
Record a walking and running exercise with a known distance (for example on a track) and for at least 12
minutes, seeRecording an exercise
Edit the distance after your exercise in the summary by pressing the middle button when the distance
is highlighted.
To get the most accurate result, manually calibrate your watch separately for both running and walking.
Sport modes
Your watch comes with a wide range of pre-defined sport modes. The modes are designed for specific
activities and purposes, from a casual walk outside to cross country skiing.
When you record an exercise (seeRecording an exercise), you can scroll up and down to see the short list of sport modes. Select theOthericon at
the end of the short list to view the complete list of sport modes.
Each sport mode has a unique set of displays that show different data depending on the selected sport
mode. You can edit and customize the data shown on the watch display during your exercise with Suunto app.
Learn how to customize sport modes inSuunto app (Android)orSuunto app (iOS).
Sport mode power saving options
You can use the following power saving options to extend battery life:
Display timeout: normally, the display is always on during your exercise. When you turn on the display
timeout, the display turns off after 10 seconds to save battery power. Press any button to turn the
display back on.
To activate power saving options:
Before you start an exercise recording, press the lower button to open the sport mode options.
Scroll down toPower savingand press the middle button.
Adjust the power saving options as you want and keep the middle button pressed to exit the power saving
options.
- Scroll back up to the start view and start your exercise as normal.
If the display timeout is on, you can still get mobile notifications as well as sound and vibration
alerts.
Using targets when exercising
It is possible to set different targets with yourSuunto 3 Fitnesswhen exercising.
If the sport mode you selected has targets as an option, you can adjust them before starting the recording
To exercise with general target:
Before you start an exercise recording, press the lower right button to open the sport mode options.
SelectTargetsand press the middle button.
ToggleGeneralon by pressing the middle button.
SelectDurationorDistance.
- Select your target.
- Press lower left button to go back to the sport mode options.
When you have general targets activated, a progress bar is visible on every data display.
You will also receive a notification when you have reached 50% of your target and when your selected
target is fulfilled.
To exercise with intensity target:
ToggleIntensityon
SelectHeart rateorPace.
- Select your target zone.
Connected GPS
Suunto 3 Fitnessis able to record speed and distance when running and walking based on your
wrist movement, but this must be calibrated to your personal stride length and movement. You can either
calibrate manually (seeSpeed and distance calibration), or let the connected GPS do it automatically. The wrist-based speed and distance is automatically
calibrated whenever you use connected GPS.
In addition to more accurate speed and distance, with connected GPS you also get a track from your
exercise that you can view on a map in the Suunto app.
To use connected GPS:
Pair your watch with the Suunto app, seeSuunto app.
- Allow Suunto app to use location services.
- Keep Suunto app active.
- Start a sport mode with GPS.
The GPS icon on your watch blinks grey while searching and turns green when the connection to your phone's
GPS is established.
Not all sport modes use GPS. If you don't see the icon, it means the sport mode is for an activity where
GPS is not needed, like running on a treadmill or swimming in a pool, or that yourSuunto 3 Fitnessis not paired with your phone.
Using connected GPS increases battery power consumption on your mobile device. GPS accuracy may vary
depending on your mobile device and surrounding conditions. Buildings, for example, can block GPS
signals. Please also be aware that GPS data is not available for all mobile operating system versions
and that existing support may be withdrawn without notice.
Interval training
Interval workouts are a common form of training consisting of repetitive sets of high and low intensity
efforts. WithSuunto 3 Fitness, you can define your
own interval training for each sport mode.
When defining your intervals, you have four items to set:
Intervals: on/off toggle that enables interval training. When you toggle this on, an interval training
display is added to your sport mode.
- Repetitions: the number of interval + recovery sets you want to do.
Interval: the length of your high intensity interval, based on distance or duration.
Recovery: the length of your rest period between intervals, based on distance or duration.
Keep in mind that if you use distance to define your intervals, you need to be in a sport mode that
measures distance. The measurement can be based on mobile assisted GPS, wrist based speed or from a foot
or bike POD, for example.
To train with intervals:
- From the launcher, select your sport.
Scroll down toIntervalsand
Toggle intervals on and adjust the settings described above.
Scroll up toBackand confirm with the middle button.
Press the upper right button until you are back at the start view and start your exercise as normal.
Press the lower left button to change the view to intervals display and press the upper right button
when you are ready to start your interval training.
If you want to stop the interval training before you have completed all your repetitions, keep the
middle button pressed to open the sport mode options and toggle offIntervals.
While you are in the intervals display, buttons work as normal, for example, pressing the upper right
button pauses the exercise recording, not just the interval training.
After you have stopped your exercise recording, interval training is automatically toggled off for that
sport mode. The other settings, however, are maintained so you can easily start the same workout the next
time you use the sport mode.
Swimming
You can use yourSuunto 3 Fitnessfor swimming in pools.
When you use a pool swimming sport mode, the watch relies on the pool length to determine distance. You
can change the pool length as needed under the sport mode options before you start swimming.
The wrist heart rate sensor may not work under water. Use a chest heart rate sensor to get a more
reliable HR tracking.
Feeling
If you are training regularly, following how you feel after each session is an important indicator of your
overall physical condition.
There are five degrees of feeling to choose from:
Poor
Average
Good
Very good
Excellent
What these options mean exactly are up to you to decide. The important thing is that you use them
consistently.
For each training session, you can record how you felt in the watch directly after stopping the recording
by answering the 'How was it?' question.
You can skip answering the question by pressing the middle button.
Display theme
To increase the readability of your watch screen while exercising, you can change between light and dark
themes.
With the light theme, the display background is light and the numbers dark.
With the dark theme, the contrast is reverse, with the background dark and the numbers light.
The theme is a global setting that you can change in your watch from any of your sport mode options.
To change display theme in sport mode options:
From the watch face, press the upper right button to scroll toExerciseand
Go to any sport mode and press the lower right button to open the sport mode options.
Scroll down toThemeand
Switch between Light and Dark by pressing the upper right and lower right buttons, and accept with the
middle button.
Scroll back up to exit the sport mode options and start (or exit) the sport mode.
Logbook
You can access the logbook from the launcher.
Scroll through the log by pressing the upper right or lower right buttons. Press the middle button to open
and view the entry of your choice.
To exit the log, press the lower left button.
Daily activity
Activity tracking
Your watch keeps track of your overall activity level throughout the day. This is an important factor
whether you just aim to be fit and healthy or you are training for an upcoming competition. It is good to
be active, but when training hard, you need to have proper rest days with low activity.
The activity counter automatically resets at midnight every day. At the end of the week, the watch
provides a summary of your activity.
From the watch face display, press the lower right button until you see your total steps for the day.
Your watch counts steps using an accelerometer. The total step count accumulates 24/7, also while
recording training sessions and other activities. However, with some specific sports, such as swimming and
cycling, steps are not counted.
In addition to steps, you can press the upper left button to see estimated calories for the day.
The large number in the center of the display is the estimated amount of active calories you have burned
during the day. Below this you see the total calories burned. The total includes both active calories and
your Basal Metabolic Rate (see below).
The ring in both displays indicates how close you are to your daily activity goals. These targets can be
adjusted to your personal preferences (see below).
You can also check your steps over the last seven days by pressing the middle button once. Press the
middle button again to see calories burned over the last seven days.
While in steps or calories display, press the lower right button to see the exact numbers for each day.
Activity goals
You can adjust your daily goals for both steps and calories. While in the activity display, keep the
middle button pressed to open the activity goal settings.
When setting your steps goal, you define the total number of steps for the day.
The total calories you burn per day is based on two factors: your Basal Metabolic Rate (BMR) and your
physical activity.
Your BMR is the amount of calories your body burns while at rest. These are the calories your body needs
to stay warm and perform basic function like blink your eyes or beat your heart. This number is based on
your personal profile, including factors such as age and gender.
When you set a calorie goal, you define how many calories you want to burn in addition to your BMR. These
are your so-called active calories. The ring around the activity display advances according to how many
active calories you burn during the day compared to your goal.
Instant HR
The instant HR display provides a quick snapshot of your heart rate. The display shows your current heart
rate.
To view instant HR:
From the watch face view, press the bottom right button to scroll to the instant HR display.
Press the lower left button to exit the display and return to the watch face view.
Daily HR
The daily HR display provides a 12-hour view of your heart rate. This is a helpful source of information
about, for example, your recovery after a hard training session.
The display shows your heart rate over 12 hours as a graph. The graph is plotted using your average heart
rate based on 24-minute time slots. In addition, you get your lowest heart rate during the 12-hour period.
Your minimum heart rate from the last 12 hours is a good indicator of your recovery state. If it is higher
than normal, you probably are not yet fully recovered from your last exercise.
If you record an exercise, the daily HR values reflect the elevated heart rate from your training. But
keep in mind that the graph rates are averages. If your heart rate peaks at 200 bpm while exercising, the
graph does not show that maximum value, but rather the average from the 24 minutes during which you hit
that peak rate.
Before you can see your daily HR graph, you need to activate the daily HR feature. You can toggle the
feature on or off from the settings underActivity. If you
are in the heart rate display, you can also access the activity settings by keeping the middle button
pressed.
With the daily HR feature on, your watch activates the optical heart rate sensor on a regular basis to
check your heart rate. This slightly increases battery power consumption.
Once activated, your watch needs 24 minutes before it can start displaying daily HR information.
To view daily HR:
- From the watch face view, press the lower right button to scroll to the instant HR display.
- Press the middle button to switch to the daily HR display.
Pressing the the lower right button in the Daily HR display will show how much energy you consume every
hour, based on you heart rate.
Adaptive training guidance
YourSuunto 3 Fitnessautomatically generates a
7-day training plan to help you maintain, improve, or boost your aerobic fitness. The weekly training
loads and workout intensities are different in the three training programs.
Select your fitness goal:
Select the “maintain” option if you are already fairly fit and want to maintain your current fitness
level. This option can also be useful for people just getting started with regular exercise. Once you get
going, you can always change the program you follow to a more demanding one.
The “improve” option is targeted at improving your aerobic fitness with a moderate progress curve. If you
want to improve your fitness more quickly, choose the “boost” program. This will bring you harder workouts
and faster results.
The training plan consist of planned exercises with a target duration and intensity. Each exercise is
planned with the goal of helping you maintain and improve your fitness gradually without over-stressing
your body. If you miss an exercise, or do a little more than planned,Suunto 3 Fitnessautomatically adapts your training
plan accordingly.
When you start a planned exercise, your watch will guide you with visual and audio indicators to help you
stay at the right intensity and keep track of your progress.
The HR zones settings (seeHeart rate zones) affect
the adaptive training plan. The upcoming activities in the training plan include intensity. If your HR
zones are not set correctly, the intensity guidance during a planned exercise may not correlate to the
real intensity of your exercise.
To see your next planned training sessions:
From the watch face, press the lower right button to scroll to the training insight view.
Press the middle button to view your plan for the current week.
Press the lower right button to see additional information; training day, duration and intensity level
(based on the heart rate zones, seeIntensity zones.
Press the lower left button to exit the planned exercise views and return to the time display.
Today's planned activity is also visible when pressing the middle button in the watch face view.
Adaptive training guidance has the goals of maintaining, improving, or boosting your fitness. If you are
already very fit and exercise frequently, the 7-day plan may not suite your existing routine.
CAUTION:
If you have been ill, the training plan may not adjust enough when you start exercising again. Be extra
cautious and exercise easy after an illness.
WARNING:
The watch cannot tell if you have an injury. Follow the recommendations of your doctor to recover from
the injury before following the training plan in your watch.
To disable your personalized training plan:
- Under the settings menu, go toTraining.
Toggle theGuidanceto off.
If you don't want the adaptive guidance but would like an exercise goal, you can define a target number of
hours as your weekly goal from the settings underTraining.
- DisableGuidance.
- SelectWeekly goal. by pressing the middle button.
Select your newWeekly goalby pressing the upper
Confirm by pressing the middle button.
Real-time guidance
If you have a planned exercise scheduled for the current day, that activity appears as the first option in
the sport mode list when you enter the exercise view to start an exercise recording. If you want real-time
guidance, start the recommended exercise as you would a normal recording, seeRecording an exercise.
When exercising according to a planned exercise, you will see a green progress bar and percentage of your
progress. The goal is estimated based on planned intensity and duration. When you exercise within the
planned intensity (based on your heart rate), you should reach the goal around the planned duration.
Higher exercise intensity will get you to the goal faster. Similarly a lower intensity will take longer.
Training insight
Suunto 3 Fitnessprovides an overview of your training
activity.
Press the lower right button until you see your training totals for the current week.
The training goal can not be modified if the adaptive training guidance is on. To turn off the adaptive
training guidance and modify your training goal, seeAdaptive training guidance.
Press the middle button twice to see all performed activities for the current week and your progress for
the last 3 weeks.
From the totals view you can press the upper left button to toggle between your top three sports.
Press the lower right button to see the summary for the current week. The summary includes total time,
distance and calories for the sport chosen in the totals view.
Recovery time
Recovery time is an estimate in hours of how long your body needs to recuperate after training. The time
is based on the duration and intensity of the training session, as well as your overall fatigue.
Recovery time accumulates from all types of exercise. In other words, you accumulate recovery time on
long, low intensity training session as well as at high intensity.
The time is cumulative across training sessions, so if you train again before the time has expired, the
newly accumulated time is added to the remainder from your previous training session.
To view your recovery time:
From the watch face, press the lower right button until you see the training and recovery display.
- Press the upper left button to toggle between training and recovery.
Because recovery time is an estimation only, the accumulated hours count down steadily regardless of your
fitness level or other individual factors. If you are very fit, you may recover faster than estimated. On
the other hand, if you have the flu, for example, your recovery may be slower than estimated.
Sleep tracking
A good night's sleep is important for a healthy mind and body. You can use your watch to track your sleep
and follow how much sleep you are getting and how well you are sleeping.
When you wear your watch to bed,Suunto 3 Fitnesstracks your sleep based on accelerometer data.
To track sleep:
Go to your watch settings, scroll down toSleepand
Toggle onSleep tracking.
Set the times for going to bed and waking up according to your normal sleep schedule.
The last step defines your bedtime. Your watch uses that period to determine when you are sleeping (during
your bedtime) and reporting all sleep as one session. If you get up for a drink of water during the night,
for example, your watch still counts any sleep after that as the same session.
If you fall asleep earlier, or sleep longer, than your set bedtime, your watch will track your sleep as
long as a part of your sleep is in within your set bedtime and wake up time.
If you go to bed far outside of your bedtime, the watch may not count that to your sleep session.
Once you have enabled sleep tracking, you can also set your sleep target. A typical adult needs between 7
and 9 hours of sleep per day, though your ideal amount of sleep may vary from the norms.
All sleep measurements, except for sleep quality and average HR, are based on movement only, so they are
estimates that may not reflect your actual sleep habits.
Sleep quality
In addition to duration, your watch can also assess sleep quality by following your heart rate variability
during sleep. The variation is an indication of how well your sleep is helping you rest and recover. Sleep
quality is shown on scale from 0 to 100 in the sleep summary, with 100 being the best quality.
Measuring heart rate while sleeping
To get sleep quality measured, ensure that Daily HR (seeDaily HR) and sleep tracking are enabled.
Automatic Do Not Disturb mode
You can use the auto Do Not Disturb setting to automatically enable Do Not Disturb mode while you sleep.
Sleep trends
When you wake up, you are greeted with a summary of your sleep. The summary includes the total duration of
your sleep, as well as the estimated time you were awake (moving around), when you went to bed, when you
woke up and your average HR sleep quality.
You can follow your overall sleep trend with the sleep insight. From the watch face, press the lower right
button until you see theSleepduration display. The
first view shows your last sleep compared to your sleep duration target.
While in the sleep display you can press the middle button once to view your average sleep duration and
then your average heart rate while sleeping over the last seven days. The data can be viewed as numbers
instead of graphs by pressing the lower right button.
From theSleepdisplay, you can keep the middle
button pressed to access sleep tracking settings and the latest sleep summary.
Stress and recovery
Your resources are a good indication of your body's energy levels and translate into your ability to
handle stress and cope with the day's challenges.
Stress and physical activity deplete your resources, while rest and recovery restore them. Good sleep is
an essential part of ensuring your body has the resources it needs.
When your resource levels are high, you will likely feel fresh and energetic. Going for a run when your
resources are high means you'll probably have a great run, because your body has the energy it needs to
adapt and improve as a result.
Being able to track your resources can help you manage and use them wisely. You can also use your
resource levels as a guide to identify stress factors, personally effective recovery boosting
strategies, and the impact of good nutrition.
Stress and recovery uses optical heart sensor readings and to get those during the day, daily HR must be
enabled, seeDaily HR.
It is important that your Max HR and Rest HR are set to match your heart rate to ensure that you get the
most accurate readings. By default, the Rest HR is set to 60 bpm and the Max HR is based on your age.
These HR values can easily be changed in the settings underGENERAL->PERSONAL.
Use the lowest heart rate reading measured during your sleep as your Rest HR.
Press the lower right button to scroll to the stress and recovery display.
The gauge around this display indicates your overall resource level. If it is green, it means you are
recovering. The status and time indicator tell you your current state (active, inactive, recovering or
stressed) and for how long you have been in that state. In this screenshot, for example, you have been
recovering for the last four hours.
Press the middle button to see a bar chart of your resources over the last 16 hours.
The green bars indicate periods where you have been recovering. The percentage value is an estimate of
your current resource level.
Fitness level
Good aerobic fitness is important for your overall health, well-being and sports performance.
Your aerobic fitness level is defined as VO2max (maximal oxygen consumption), a widely recognized
measure of aerobic endurance capacity. In other words, VO2max shows how well your body can use oxygen.
The higher your VO2max, the better you can use oxygen.
The estimation of your fitness level is based on detecting your heart rate response during each recorded
running or walking workout. To get your fitness level estimated, record a run or walk with a duration
for at least 15 minutes while wearing yourSuunto 3 Fitnesswith connected GPS or calibrated
speed.
If connected GPS is not available, you have to manually calibrate your watch before you can walk/run for
15 minutes and get your fitness level estimated, seeSpeed and distance calibration.
After a successful calibration, your watch is able to provide an estimation of your fitness level for
all running and walking workouts.
Your current estimated fitness level is shown in the fitness level display. From the watch face, press
the lower right button to scroll to the fitness level display.
If the watch hasn't estimated your fitness level yet, the fitness level display will instruct you
further.
Historical data, from recorded running and walking workouts, plays a role in ensuring the accuracy of
your VO2max estimate. The more activities you record with yourSuunto 3 Fitness, the more accurate your VO2max estimate
becomes.
There are six fitness levels, from low to high: very poor, poor, fair, good, excellent and superior. The
value is dependent of your age and gender and the higher value you have, the better your fitness level
is.
Press the upper left button to view your estimated fitness age. Fitness age is a metric value that
reinterprets your VO2max value in terms of age. Regularly engaging in the right types of physical
activity will help you boost your VO2max value and reduce your fitness age.
Improvement of VO2max is highly individual and it depends on factors such as age, gender, genetics and
training background. If you are already very fit, increasing your fitness level will be slower. If you
are just starting to exercise regularly, you may see a quick increase in fitness.
Chest heart rate sensor
You can use a Bluetooth® Smart compatible heart rate sensor, such as the Suunto Smart Sensor, with yourSuunto 3 Fitnessto get accurate information about
your exercise intensity.
If you use the Suunto Smart Sensor, you also have the added advantage of heart rate memory. The sensor
memory function buffers data if the connection to your watch is interrupted, for example, when swimming
(no transmission under water).
It also means you can even leave your watch behind after starting a recording. For more information,
please refer to the Suunto Smart Sensor User Guide.
SeePairing PODs and sensorsfor instructions
on how to pair an HR sensor with your watch.
Pair your watch with Bluetooth Smart PODs and sensors to collect additional information when recording
an exercise.
Suunto 3 Fitnesssupports the following types of PODs
and sensors:
You cannot pair anything if airplane mode is on. Turn off airplane mode before pairing. SeeAirplane mode.
To pair a POD or sensor:
Go to your watch settings and selectConnectivity.
SelectPair sensorto get the list of sensor types.
Press the lower right button to scroll through the list and select the sensor type with the middle
button.
Follow the instructions in the watch to complete pairing (refer to sensor or POD manual if needed),
pressing the middle button to advance to the next step.
If the POD has required settings, you are prompted to enter a value during the pairing process.
Once the POD or sensor is paired, your watch searches for it as soon as you select a sport mode that
uses that sensor type.
You can see the full list of paired devices in your watch from the settings underConnectivity»Paired devices.
From this list, you can remove (unpair) the device if needed. Select the device you want to remove, and
tapForget.
Calibrating foot POD
When you pair a foot POD, your watch automatically calibrates the POD using connect GPS with Suunto app
on your mobile phone. We recommend using the automatic calibration, but you can disable it if needed
from the POD settings underConnectivity»Paired devices.
For the first calibration with GPS, you should select a sport mode where the foot POD is used, e.g.
running. Start the recording and run at a steady pace on a level surface, if possible, for at least 15
minutes.
Run at your normal average pace for the initial calibration, and then stop the exercise recording. The
next time you use the foot POD, the calibration is ready.
Your watch automatically re-calibrates the foot POD as needed whenever GPS speed is available.
Timers
Your watch includes a stopwatch and countdown timer for basic time measurement. From the watch face,
open the launcher and scroll up until you see the timer icon. Press the middle button to open the timer
display.
When you first enter the display, it shows the stopwatch. After that, it remembers whatever you used
last, stopwatch or countdown timer.
Press the lower right button to open theSet timershortcuts menu where you can change the timer settings.
Stopwatch
Start the stopwatch by pressing the middle button.
Stop the stopwatch by pressing the middle button. You can resume by pressing the middle button again.
Reset by pressing the lower button.
Exit the timer by keeping the middle button pressed.
Countdown timer
In the timer display, press the lower button to open the shortcuts menu. From there you can select a
pre-defined countdown time or create custom countdown time.
Stop and reset as needed with the middle and lower right buttons.
Intensity zones
Using intensity zones for exercising helps guide your fitness development. Each intensity zone stresses
your body in different ways, leading to different effects on your physical fitness. There are five
different zones, numbered 1 (lowest) to 5 (highest), defined as percentage ranges based on your maximum
heart rate (max HR) or pace.
It is important to train with intensity in mind and understand how that intensity should feel. And don't
forget that, regardless of your planned training, you should always take time to warm up before an
exercise.
The five different intensity zones used inSuunto 3 Fitnessare:
Zone 1: Easy
Exercising at zone 1 is relatively easy on your body. When it comes to fitness training, intensity this
low is significant mainly in restorative training and improving your basic fitness when you are just
beginning to exercise, or after a long break. Everyday exercise – walking, climbing stairs, cycling to
work, etc. – is usually performed within this intensity zone.
Zone 2: Moderate
Exercising at zone 2 improves your basic fitness level effectively. Exercising at this intensity feels
easy, but workouts with a long duration can have a very high training effect. The majority of
cardiovascular conditioning training should be performed within this zone. Improving basic fitness
builds a foundation for other exercise and prepares your system for more energetic activity. Long
duration workouts at this zone consume a lot of energy, especially from your body’s stored fat.
Zone 3: Hard
Exercising at zone 3 begins to be quite energetic and feels like pretty hard going. It will improve your
ability to move quickly and economically. In this zone, lactic acid begins to form in your system, but
your body is still able to completely flush it out. You should train at this intensity at most a couple
of times per week, as it puts your body under a lot of stress.
Zone 4: Very hard
Exercising at zone 4 will prepare your system for competition type events and high speeds. Workouts in
this zone can be performed either at a constant speed or as interval training (combinations of shorter
training phases with intermittent breaks). High-intensity training develops your fitness level quickly
and effectively, but done too often or at too high intensity may lead to overtraining, which may force
you to take a long break from your training program.
Zone 5: Maximal
When your heart rate during a workout reaches zone 5, the training will feel extremely hard. Lactic acid
will build up in your system much faster than it can be removed, and you will be forced to stop after a
few dozen minutes at most. Athletes include these maximum-intensity workouts in their training program
in a very controlled manner, fitness enthusiasts do not require them at all.
Heart rate zones
Heart rate zones are defined as percentage ranges based on your maximum heart rate (max HR).
By default, your max HR is calculated using the standard equation: 220 - your age. If you know your
exact max HR, you should adjust the default value accordingly.
The 7-day training plan (seeAdaptive training guidance) is based on the HR zone
limits. If the limits or the max HR does not reflect your personal values, the training plan may not
optimally guide you to your desired fitness level.
Suunto 3 Fitnesshas default and activity-specific HR
zones. The default zones can be used for all activities, but for more advanced training, you can use
specific HR zones for running and cycling activities.
Set max HR
Set your maximum HR from the settings underTraining»Intensity zones»Default zones
- Select the max HR (highest value, bpm) and press the middle button.
- Select your new max HR by pressing the upper right or lower right buttons.
- Press the middle button to select the new max HR.
- Press the lower left button to exit the HR zones view.
You can also set your maximum HR from the settings underGeneral»Personal.
Set default HR zones
Set your default HR zones from the settings underTraining»Intensity zones»Default zones
Scroll up/down by pressing the upper right or lower right buttons and press the middle button when the
HR zone you want to change is highlighted.
- Select your new HR zone by pressing the upper right or lower right buttons.
- Press the middle button to select the new HR value.
- Keep the middle button pressed to exit the HR zones view.
SelectingResetin the HR zones view will reset the
HR zones to the default value.
Set activity specific HR zones
Set your activity specific HR zones from the settings underTraining»Intensity zones»Advanced zones
Choose the activity (running or cycling) that you want to edit (by pressing upper right or lower right
buttons) and press the middle button when the activity is highlighted.
- Press the middle button to toggle the HR zones on.
Using HR zones when exercising
When you record an exercise (seeRecording an exercise), and have selected heart rate
as an intensity target (seeUsing targets when exercising), an HR zone gauge,
divided into five sections, is shown around the outer edge of the sport mode display (for all sport
modes that support HR). The gauge indicates in which HR zone you are currently training by lighting up
the corresponding section. The small arrow in the gauge indicates where you are within the zone range.
Your watch alerts you when you hit your selected target zone. During your exercise the watch will prompt
you to speed up or slow down, if your heart rate is outside the selected target zone.
In addition, there is a dedicated display for HR zones in the sport mode default display. The zone
display shows your current HR zone in the middle field and the background color of the gauge also
indicates which HR zone you are training in.
In the exercise summary, you get a breakdown of how much time you have spent in each zone.
Pace zones
Pace zones work just like HR zones but the intensity of your training are based on your pace instead of
your heart rate. The pace zones are shown either as metric or imperial value depending on your settings.
Suunto 3 Fitnesshas five default pace zones that you
can use or you can define your own.
Pace zones are available for running.
Set pace zones
Set your activity specific pace zones from the settings underTraining»Intensity zones»Advanced zones
- Choose running and press the middle button.
Scroll down by pressing the lower right button and press the middle button to toggle the pace zones
on.
pace zone you want to change is highlighted.
- Select your new pace zone by pressing the upper right or lower right buttons.
- Press the middle button to select the new pace zone value.
- Keep the middle button pressed to exit the pace zones view.
Using pace zones when exercising
When you record an exercise (seeRecording an exercise), and have selected pace as an
intensity target (seeUsing targets when exercising) a pace zone gauge,
divided into five sections, is viewed. These five section are shown around the outer edge of the sport
mode display. The gauge indicates the pace zone you have chosen as an intensity target by lighting up
you to speed up or slow down, if your pace is outside the selected target zone.
