Suunto Ambit
Black
Integrated GPS with heart rate monitoring option for the Outdoor Explorer
THE GPS FOR EXPLORERS
You could call it a watch, but that hardly seems fair. GPS navigation, speed, heart rate, altitude, weather conditions – it's all at your fingertips. Upgrade with thousands of Suunto Apps to inspire your next adventure. Suunto Ambit — conquer new territory with the first GPS for Explorers.
PRODUCT HIGHLIGHTS
- Outdoor and training functions
- Personalize with 1000+ free Sports Apps
- Robust design with long battery life (15h/50h)
SPECIFICATIONS
Measurements50 x 50 x 18.1 mm / 1.97 x 1.97 x 0.71 "
Weight78 g / 2.75 oz
Bezel material:Aluminum
Glass material:Mineral crystal
Case material:Polyamide
Strap material:Elastomer
What's in the box?Suunto Ambit Black, USB cable, and Quick Guide
Country of manufactureFI
TECHNICAL SPECIFICATIONS
Bezel materialAluminum
Glass materialMineral crystal
Case materialPolyamide
Strap materialElastomer
Declination correctionyes
Water resistance100 m
Battery typerechargeable lithium-ion
Firmware upgradable✔
Time, date✔
Alarm clock1 daily alarm
Dual time✔
Automatic timekeeping✔
Countdown timer✔
Stopwatch timer✔
LanguageEN, DE, ES, FI, FR, IT, NL, PT, SV
BacklightLED
Configurable backlightbrightness / mode
Button lock✔
Invert display✔
Display typematrix
Display resolution128 x 128
Metric and imperial units✔
Battery indicatorpercentage / icon
Memory left indicator✔
PHYSICAL SPECIFICATIONS
Operating temperature-20° C to +60° C / -5° F to +140° F
Storage temperature-30° C to +60° C / -22° F to +140° F
Recommended charging temperature0° C to +35° C / +32° F to +95° F
BATTERY LIFE
In time mode30 days
Training mode with GPS15, 50 h
COMPASS
Digital compass✔
Tilt compensationfull
Direction scaledegrees / mils
Needlenorth indicator
Globally balanced✔
Compass accuracy5°
Compass resolution1°
CONNECTIVITY
Connectivity (between devices)Suunto ANT
Data transferUSB cable
SUUNTO APPS
Compatible with Suunto Apps✔
Max. nr. of apps per sport mode1
Logging of app specific metrics✔
Most recommended apps by activity✔
Create own metrics with advanced formulas✔
Chrono, GPS, HR, weather and altitude datayes, excluding weather
Running, cycling, swimming datayes, excluding cycling power/swimming
Rich math functions, if/then-logic, sound, backlight, etc.✔
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
Satellite systemsGPS
GPS recording rate1, 60 s
Coordinate systemsWGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000)
Waypoint and visual route navigation✔
Max. nr. of Points of Interest (POIs)100
Find back✔
Route points per route / POIs in watch1000 / 100
GPS track analysis✔
Track logging, viewing and sharing✔
Route planning✔
ALTIMETER
Barometric altitude✔
Altitude graph✔
GPS altitude✔
Altitude differenceyes** ** available as Suunto Apps
Total ascent/descentair pressure based
Vertical speedair pressure based
Automatic alti/baro profile✔
Log recording rate1, 10 s
Resolution1 m
Range-500 - 9000 m
WEATHER
Sunrise/sunset timesyes** Available via software update on Oct 17th
Storm alarmyes** Available via Software Update in October
Sea level pressure✔
Temperature✔
Temperature display range-20° C to +60° C / -4° F to +140° F
Temperature resolution1°
Pressure resolution1 hPa / 0.03 inHg
Max weather recording lengthpast 26 hours
Sea level pressure graph✔
Tide informationyes** ** available as Suunto Apps
TRAINING FUNCTIONS
HEART RATE
RR interval✔
Heart rate in beats per minute✔
Heart rate graph in real time✔
Calories✔
Peak Training Effect✔
Recovery time✔
Speed and heart rate-based guidance during exercise✔
Real-time average and max heart rate✔
EPOC & V02 max values✔
Heart rate in % of max hr✔
Heart rate limits✔
SPEED AND DISTANCE
GPS speed and distanceIntegrated
Chrono✔
Foot POD supportSuunto Foot POD / ANT+
Bike POD supportSuunto Bike POD / ANT+
Distance based autolaps✔
Laps>1000
Autopause✔
TRAINING LOAD
Training analysis✔
Training logbook with story and image support✔
SPORT EXPERTISE
SWIMMING
Openwater swim pace and distance✔
CYCLING
Cycling speed✔
Average speed in real time✔
Hill incline in real timeyes, available as Suunto Apps
RUNNING
Running pace✔
Suunto FusedSpeed™✔
Foot POD calibrationmanual
Average pace in real time✔
Lap comparisons by kilometer/mile✔
Marathon End-time Estimator✔
Average stride lengthif cadence present
Running cadencewatch or Foot POD
SPORT MODES
Customizable sport modes and displays10 modes / 8 displays per mode
Special Offer Just for You!
You’ve added a product to your cart - now unlock an exclusive deal! Grab this offer before you check out
Powered by Salepify App
