When preparing for a marathon, trail race or middle- or long-distance event, some runners turn to altitude for a different training stimulus. Once there, many find that a pace that felt comfortable at sea level is suddenly hard to hold. So can you still get the training benefits you're after when you're running slower?
The answer lies in seeing that slower pace as part of your whole training plan. This guide explains how altitude affects running performance, how to choose an approach, plan your training cycle and monitor your body's response based on your race goals, and how to decide whether altitude training is right for your race preparation.
What Is Altitude Training for Runners?
For runners, altitude training combines natural high-altitude exposure or simulated low-oxygen (hypoxic) exposure with running-specific workouts, tailored to your event and race goals. The aim is to improve running performance or prepare for a race at altitude. Depending on the setup, you may live, sleep or train in a low-oxygen environment. Sports science also uses the term hypoxic training for these approaches, and the two overlap considerably.
At altitude, your body gradually adjusts to cope with the lower oxygen available. This process is called altitude acclimatization, and it happens whether you're training at altitude or simply staying there. How well you adapt plays a big part in how you progress your training and recover.
How Does Altitude Training Affect Running Performance?
Altitude affects performance in stages. In the short term, lower oxygen availability usually reduces performance. After a period of training and acclimatization, you may handle the demands of running at altitude better, and for some runners those adaptations also support endurance performance back at lower elevations.
Short-Term Effects on Running Performance
As altitude rises, atmospheric pressure and the partial pressure of oxygen in the air you breathe both fall. The proportion of oxygen in the air stays almost the same, but your body can deliver less of it to working muscles, and VO₂ max usually drops too. A pace that feels manageable at low altitude takes a higher relative effort up high, making it harder to hold your usual speed or run for as long. You'll notice this most in harder sessions such as tempo runs and interval training.
Longer-Term Effects on Running Performance
Longer exposure to low oxygen can bring adaptations in your blood and in how your breathing and cardiovascular system are regulated, helping you meet the oxygen demands of running at altitude. Some of these changes may also support endurance performance back at lower elevations. Adapting to altitude and improving performance at sea level are two different outcomes, though.
- Support endurance performance after returning to lower elevations: Low oxygen can stimulate the release of erythropoietin (EPO), which drives red blood cell production. With enough exposure and adequate iron stores, total hemoglobin mass (Hb mass) may increase, helping your body deliver more oxygen to working muscles. This may support gains in VO₂ max and long-distance running performance.
- Improve running endurance at altitude: With longer hypoxic exposure, your body may adapt through a stronger breathing response and adjustments in heart rate and stroke volume. These changes can help you sustain exercise at altitude, hold a given pace at a given intensity, or run for longer.
How to Plan Your Altitude Training
Altitude training means more than moving your usual workouts uphill. Start by assessing your current training base, then choose a method and altitude to suit your race goals. You'll also need to plan workout intensity, how long you're exposed to low oxygen and how you recover after returning to lower elevations.
Start with a Solid Aerobic Base
Before trying altitude training, you should have an established running routine, consistent training volume and the ability to recover normally from workouts suited to your fitness. If you're coming back from injury, or your training and recovery have been inconsistent, sort those out first and add hypoxic training once you're on stable footing.
A solid aerobic base helps you handle the extra demands of altitude training, but acclimatization still takes time. Even very fit runners need time to adapt to lower oxygen and should watch for symptoms of altitude sickness.
Choose an Altitude Training Method
Depending on your race goals and your living and training situation, there are three main approaches. "High" and "low" refer to relatively higher or lower elevations, or the equivalent hypoxic conditions; no single altitude threshold applies to every setup.
| Training Method |
Living Environment |
Training Environment |
Main Uses and Limitations |
| Live High–Train High (LHTH) |
Higher altitude or corresponding hypoxic conditions |
Can be used to prepare for high-altitude races. Runners are exposed to low oxygen availability both while living and training, but maintaining higher running speeds during workouts may be more difficult. |
| Live High–Train Low (LHTL) |
Lower altitude or normoxic conditions |
Combines extended hypoxic exposure with training at lower elevations, helping runners maintain the speeds needed for key workouts. Requires access to suitable training locations, transportation, or simulated hypoxic conditions. |
| Live Low–Train High (LLTH) |
Adds hypoxic exercise training while allowing runners to maintain their usual living arrangements. The effects depend on the type of exercise and exposure schedule, and this approach is not equivalent to living in a low-oxygen environment for extended periods. |
Consider Simulated Altitude Training
Each of these methods can also use simulated altitude. If you can't spend an extended period at a natural high-altitude location, hypoxic tents, hypoxic rooms or masks connected to hypoxic gas systems let you arrange low-oxygen exposure while sleeping, resting or training. These devices usually lower the oxygen concentration of the air you breathe, providing a hypoxic stimulus at normal atmospheric pressure.
Simulated hypoxia can stand in for some natural altitude exposure, such as in live high, train low (LHTL), but the adaptations and performance gains may differ from natural altitude. Before choosing this route, check that the equipment and daily exposure time meet the needs of your training plan. Short spells of equipment use don't add up to a full altitude training cycle.
Choose an Appropriate Altitude
When it comes to altitude, higher isn't always better. The key is balancing the hypoxic stimulus against training quality.
In practice, approximately 2,000 to 2,500 m is a commonly cited range for living at altitude and hypoxic exposure. It isn't the ideal altitude for every runner, though, and not every workout needs to happen there. With LHTH, you need to balance living and training in the same environment, while LHTL lets you schedule key workouts lower down. With simulated hypoxic equipment, judge your exposure by the conditions it creates rather than the altitude of where you live.
Adjust Running Intensity at Altitude
Once you arrive at altitude, manage your training load first, then gradually bring race-specific workouts back based on how you're training and recovering. Plan for the transition to your next training phase after you leave altitude, too.
- Set an initial training load: Use recent workouts you can complete consistently and recover from normally as your reference. Scale back your training when you first arrive rather than trying to hold your usual pace and volume right away.
- Progress according to your body's response: Focus on easy aerobic running at first. Once your sleep, daily energy and post-workout recovery settle, gradually increase your training demands. Resist the urge to make up missed volume all at once after a single good session.
- Preserve key race-specific workouts: Work out which sessions need a higher absolute speed and which still deliver the right stimulus at a slower pace. Schedule the faster ones at lower elevations if needed, and manage the load by adjusting reps and recovery.
- Prepare for the next phase: The end of your altitude block should set you up for what comes next. If you'll keep training at lower elevations, keep your training load consistent. If race day is close, follow your pre-race marathon taper, cutting volume while keeping some familiar intensity so you have time to recover.
Plan Your Altitude Training and Race Timeline
To give your body time to adapt to lower oxygen and develop the related physiological changes, altitude training usually needs to last several weeks, with approximately 3 to 4 weeks a common reference. Your schedule should also reflect the demands of your event. For endurance events like the marathon, altitude training can fit into a continuous aerobic block. For events that rely more on speed and speed endurance, keeping the quality of event-specific workouts comes first.
If you're racing an endurance event at low altitude, a common coaching approach is to schedule your race about 2 to 3 weeks after returning to lower elevations, leaving time for recovery and final race preparation.
If your goal is a high-altitude trail running event, the priority is arriving at the race location, or a similar elevation, in advance. For races at moderate altitude, arriving about two weeks early is a useful reference, and routes that climb higher need more time to acclimatize, depending on the elevation profile. The post-altitude race window for lowland events doesn't apply to these races.
How to Monitor Your Adaptation to Altitude
How can you tell whether your body is adapting to lower oxygen? Combining training performance, how you feel, sleep and recovery metrics lets you track your response over time and build a fuller picture of your adaptation.
Track Pace, Heart Rate and Perceived Effort
During altitude training, record your pace, heart rate, elevation and route for every workout, then add notes on perceived effort and how well you completed the session.
When reviewing your data, compare workouts with similar elevation, routes and weather. At a similar perceived effort, is your pace becoming more consistent? At a similar pace, how are your heart rate and perceived effort changing? Are you recovering normally after each session?
Monitor Sleep, HRV and Blood Oxygen
Low oxygen at altitude can disrupt sleep, making you more likely to wake in the night or feel less rested in the morning. Combine sleep duration, nighttime heart rate and HRV to track your sleep and recovery, along with how you feel on waking and any fatigue, paying close attention to trends over several days.
Blood oxygen saturation (SpO₂) tracks a factor closely tied to altitude: the percentage of your hemoglobin carrying oxygen. SpO₂ usually falls at altitude and can drop further during exercise, which is one reason holding your usual aerobic output feels harder.
If your sports watch supports blood oxygen measurement, compare your resting or nighttime SpO₂ readings with your running performance, breathing and fatigue to understand how altitude is affecting your training. These readings don't reflect your blood oxygen in real time during a run, so use them as context rather than to set pace or intensity targets the way you would heart rate zones.
A rise in SpO₂ alone doesn't prove your training adaptations have improved, and a normal reading doesn't rule out altitude sickness. Watch-based SpO₂ data is for general reference only: it can't diagnose or rule out medical conditions and should never be the only basis for deciding whether to keep training.
Note: If you experience symptoms that may indicate altitude sickness, such as headache or nausea, stop training and do not ascend to a higher elevation. If symptoms continue or worsen after resting, descend and seek medical attention. If you experience shortness of breath at rest, difficulty walking steadily, or changes in consciousness, seek emergency medical assistance immediately and descend to a lower elevation as soon as possible with assistance.
Takeaways
Altitude training brings together environment, physiological adaptation and race preparation. Every decision, from method and altitude to intensity, training length, race timing and how you read your training and recovery data, shapes whether it supports your running goals. Seen as part of your whole race preparation, every slowdown or adjustment at altitude makes sense in the context of your full training cycle.
FAQ
Can Altitude Training Improve Sea-Level Running Performance?
It can, but not every runner benefits, and faster race times aren't guaranteed. Becoming better adapted to low oxygen is one thing; whether that translates into faster running at lower elevations is another.
Is Altitude Training Necessary for Every Runner?
No. Altitude training is worth considering when your target event is at altitude or your training plan has a specific need for hypoxic adaptation. For everyone else, regular training is usually all you need to prepare for a race, with no need for altitude camps or simulated hypoxic equipment.
