You've probably felt it on a long run or in a road race. You start on fresh legs with energy to spare, then the second half arrives, your stride gets heavier and your pace slips. The buffer you built early disappears fast.
That's where the negative split comes in, the pacing strategy sports science keeps returning to: hold back early, finish strong. It shapes how you spend your fuel, how efficiently you move and how steady you stay mentally in the closing miles. This article breaks down the physiology, the finish-line data, and how to execute and review a negative split.
What Is a Negative Split in Running?
A negative split means running the second half faster than the first, at a higher average speed. A second half about 1% to 3% faster than the first is usually treated as a typical negative split.
One caveat: studies set their own thresholds for what counts as a negative or even split, based on their samples, so there's no single cutoff. The table below is a simple way to tell the three strategies apart rather than a precise dividing line:
Why Negative Split Running Works: Physiological and Psychological Mechanisms
The key to a negative split is really about distributing your energy: the same total effort, split differently between the two halves. Go out too fast and the extra metabolic cost is hard to make up by slowing down later. The next three sections explain the mechanisms behind that, and why holding back early matters.
Sparing Muscle Fuel to Delay Fatigue
In endurance running, the balance of energy you draw from fat and from carbohydrate (glycogen) shifts with intensity. Start too fast, at too high an intensity, and you burn through glycogen much faster.
Hold that intensity too long and metabolites that interfere with muscle contraction build up inside the cell, raising the risk of fading early. Keep the first half in a moderate range instead and you may draw more of your energy from fat, saving limited glycogen for the second half and delaying the late-race drop-off.
Delaying Core Temperature Rise and Cardiac Drift
Fuel is only part of the picture. Thermoregulation and cardiovascular stability also shape endurance performance. Go out too fast and you generate more metabolic heat early, so more blood goes to the skin for cooling and less reaches your working muscles. The faster heat builds up, the shorter the time to exhaustion; as core temperature climbs, the nervous system limits muscle output to keep the body from overheating.
Rising core temperature and ongoing dehydration can also trigger or worsen cardiac drift, where heart rate keeps climbing even at a steady pace. An overly aggressive first half often brings on cardiac drift earlier and makes it harder to sustain effort late in the race. A gentler start slows early heat build-up, supports thermoregulation and limits cardiac drift, so your cardiovascular output stays steadier through the second half.
Holding Perceived Exertion on a Gradual Rise
Pacing is also a mental game. Through teleoanticipation, the brain adjusts effort based on how much distance is left and how the body feels. At the same running speed, runners who anticipate a longer effort typically experience lower perceived exertion (RPE).
Holding back in the first half works with that mechanism, letting RPE rise gradually and stay manageable as the race goes on, so you reach your limit near the finish rather than before halfway.
What Real-World Race Data Reveals About Negative Splits
The theory favors going out steady and finishing faster, but race data tells a more nuanced story: pacing is closely tied to performance level. Seeing how mass finishers and elites differ helps you set realistic expectations.
Pacing Trends in Mass Finishers vs. Elite Runners
In big mass-participation marathons, positive splits, where the second half is slower, are still the most common pattern, and the faster the runner, the smaller the pace variation tends to be. A study of the New York City Marathon found positive splits across every performance group, but faster runners showed much smaller pace variation across 5 km splits than slower finishers. In real races, large negative splits are rare, and steady, even pacing is far more common among faster runners than in the rest of the field.
At the elite end, consistency and a strong finish stand out even more. Eliud Kipchoge ran clear negative splits at Berlin 2018 and London 2019, covering 54% and 55% of each race slightly below his average speed.
Practical Takeaways for Runners
Seeing how evenly the best runners pace themselves raises a fair question: should recreational runners chase a negative split or an even one? In practice, faster finishers tend to share the same core trait: minimal pace variation across the whole race.
On race day, you can't fully predict the temperature, how well you slept or how the course will wear on you. Aiming for a slight negative split, with a conservative first half and a steady or slightly faster second half, is smart risk management against blowing up. If you know your fitness and the course well, an even split is just as sound. Both come down to the same discipline: a controlled start.
How Runners Can Set and Execute a Negative Split
Fuel demands and race duration vary widely by distance, so adapt how you set and execute a negative split to the distance and conditions.
Executing a Negative Split in 5K and 10K Races
In 5K and 10K races, average intensity sits at or just above threshold, leaving less room to adjust pace than in a marathon.
Even in elite 5,000 m and 10,000 m track races—where the opening kilometer is often fast—the middle section stays steady before a strong push over the final 1 to 2 km. In practice, hold back in the first kilometer rather than getting pulled along by the crowd, settle your breathing and rhythm, lock onto goal pace through the middle, and save your push for the last 1 to 2 km.
Executing a Negative Split in the Half and Full Marathon
In the half and full marathon, glycogen and thermoregulation come under growing pressure as the race goes on. Aim for a slight negative split, treating a 1% to 3% faster second half as a guide rather than a target you must hit. Break the race into three stages:
- Start and early miles (hold the ceiling): Settle at or slightly slower than your goal average pace.
- Middle of the race (steady transition): Ease onto goal pace and hold it, staying patient through halfway.
- Final stretch (gradual release): Use your breathing and what's left in your legs to lift the pace slightly, at a level you can hold to the finish.
Adjusting the Strategy for Heat, Hills, and Ultramarathons
Some races call for a different approach. In these three situations, shift your focus:
- Heat: Heat stress cuts into your physiological reserve and how much discomfort you can tolerate, shrinking the room to speed up late. Rising temperatures usually slow overall pace, so start with adjusted expectations and keep heart rate and perceived effort in check first.
- Rolling hills: Climbs and descents change the pace needed for the same metabolic effort. Most runners slow on the way up and speed up on the way down. If the second half climbs, hold even effort rather than forcing a faster pace.
- Ultramarathons (such as 100 km or 100 miles): Over very long distances, most finishers, elites included, slow in the second half. The priority shifts to controlling early effort so the late-race drop-off stays as small as possible.
How Runners Can Train for Negative Split Pacing
A negative split is a capacity you build over training cycles as much as a race-day tactic. Here are three sessions to work into your week.
Progression Runs: Stepping Up Pace from Easy to Threshold
A progression run is a pace-control session. Start at an easy aerobic pace, lift gradually as the distance builds and finish near lactate threshold or goal race pace. A midweek 10 km progression tempo works well: steady aerobic effort early, then the last 3 km at about 90% to 95% of lactate threshold speed. It teaches your body how it feels to move from an easy start to harder output.
