1 / 7
Suunto Run 2 Aloe Green
1/7
rotation-icon
Photos
360° View
Money-back guarantee
30-Days Return
Warranty Repair
SKU: SS051641000
Suunto Run 2
Aloe Green
Rp 7.839.000
Lightweight Running Watch for Your Next Breakthrough
  • New-Generation GPS
  • Real-Time Run Insights
  • 2,000-Nit Bright Display
  • 35 g Nordic Lightweight Design
  • Upgraded Heart Rate
  • 10-Day Daily Battery
Choose Your Color
Quantity
Free shipping on orders of Rp2500000 or more.
Rp 7.839.000
Compare +
30-Days Return
Warranty Repair
New-Generation GPS
35 g* Nordic Lightweight Design
Upgraded Heart Rate
See the Run Ahead
A breakthrough is shaped long before the finish line. It's built in decisions made early enough to matter. Hold, or push. Adjust, or recover. Every one of them gets easier when you can see clearly. What your effort is costing. Where your pace is taking you. How much you still have in you. Thirty‑five* grams on your wrist, from the first kilometre to the last night's sleep. Readable in full sun, at full stride. Numbers steady enough to build a race plan on. So when the finish comes into view, you already knew it was coming.
The lightest part of your run
At 35 g, the watch body sits close enough to the wrist that you stop registering it — through long runs, through sleep, through the rest of the day. A stainless steel bezel, Gorilla Glass, and 5 ATM water resistance keep it ready for all of it, so training, recovery, and sleep arrive as one complete picture instead of a partial one.
35 g* / Body Weight
Stainless Steel / Bezel
Gorilla Glass / Lens
Bright enough to run by
Clear at a glance
Pace, heart rate, and distance stay readable in direct sun, so checking a number costs a look rather than a break in rhythm.
2,000 NITS / Brightness
1.32 INCH / Display Size
LTPS AMOLED / Panel Type
Train all week, Charge once
Charging fits around you
Top up once a week and keep Suunto Run 2 on through the night, so the record of your training stays continuous rather than starting over after every charge.
10 Days / Daily Training Use
24 HRS / Dual-Band GPS
+29% / Battery Capacity vs. Suunto Run
The track matches the run
New-Generation Navigation
Suunto Run 2 upgrades to dual-band L1 + L5 positioning across GPS, GLONASS, Galileo, BeiDou, and QZSS. Distance, pace, and the track you record sit closer to the route you actually ran, which is what makes the numbers worth executing a training or race plan on.
A steadier read on your effort
Upgraded Heart Rate
A 12-channel sensor behind 2.5D curved glass gathers more signal at the wrist, so heart rate keeps up with hard intervals, surges, and long efforts in the heat. The effort you feel and the effort Suunto Run 2 reports stay in step, which is what makes it worth training by.
12-Channel / Wrist HR
2.5D / Curved Sensor Glass
24/7 / HR Tracking
See where your effort is taking you
EnergySense
EnergySense reads how hard you are working right now against how much you still have, live on the wrist. Deep into a long run or the back half of a race, holding, easing, or pushing becomes a decision you make based on what you can see rather than on feel alone.
Marathon Time
Marathon Time turns your current pace into a finishing time and keeps updating it as you run. When the target starts to slip, you see it early, while there is still road left to hold, adjust, or push.
The next turn, already on your wrist
Free Offline Maps
Download free worldwide maps to Suunto Run 2 before you head out. On a travel run or an unfamiliar route, roads, place names, and your surroundings stay on the wrist, so the next turn is a glance away rather than a stop and a phone. The same maps carry onto trail sections when the road runs out.
Run with Music
Offline Playback
Load music onto Suunto Run 2 and play them straight from the watch. Long runs head out with everything already on your wrist, so the session belongs to the run and the playlist alone.
What's New in Suunto Run 2
Suunto Run 2
Suunto Run 2
Suunto Run
Suunto Run
Size 46 x 46 x 11.7mm 46 x 46 x 11.5 mm
Size
Screen 2000nit 1.32’’ AMOLED 600nit 1.32’’ AMOLED
Screen
Battery Capacity 380 mAh 295 mAh
Battery Capacity
380 mAh 295 mAh
Battery Life (Daily Use) 10 days 8 days
10 days 8 days
Battery Life (High Performance) 24h 20h
24h 20h
Offline Maps YES NO
Offline Maps
YES NO
GPS & Heart rate Upgraded version Old version
GPS & Heart rate
Storage 4 / 64 GB 4 GB
Storage
4 / 64 GB 4 GB
IN THE BOX
  • 1 Suunto Run 2 Watch
  • 2 Suunto 22mm Athletic 6 Silicone Strap for Sizes (S/M)
  • 3 Quick Guide
  • 4 USB-C Charging Cable
  • 5 Product Safety & Regulatory Information International Limited Warranty
FAQ
Product overview
[8]
Product overview[8]
Product overview
[8]
How long does the battery last?
With dual-frequency, all-constellation GPS it lasts about 24 hours, enough for a full marathon plus the training around it. In everyday use it goes several days, and longer again in battery-saver mode.
What is real-time marathon prediction?
This one's exclusive to Suunto. As you run, the watch works out your projected finish time in real time from your current pace, the route's elevation, the distance you've covered, and your fitness, so you can adjust your pacing on the fly. Your actual finish still depends on weather, terrain, hydration, and how you're feeling, so treat it as a guide.
What marathon training tools does it have?
There's a whole set: a Virtual Pacer mode, Race mode, and target modes for time, distance, ascent, and calories, among others. Guided workouts are supported too.
Is there a dedicated marathon mode?
Yes. The Run series has its own Marathon mode, which adds dedicated data screens on top of the standard running view, including your finish prediction and remaining energy.
Can it find my phone and control music?
Yes. You can ping your phone to make it ring, and control music playback on your phone, including play, pause, skipping tracks, and volume.
How water resistant is it?
It's water resistant to 5 ATM (50 m), which covers swimming, showering, and running in the rain. It isn't made for snorkeling, scuba diving, or diving off boards. Rinse it with fresh water after you swim.
How many sport modes does it have?
There are 35 sport modes. Running is the focus, with road, trail, treadmill, and track, but you also get cycling, swimming, hiking, gym, triathlon, and more.
Is the heart rate accurate?
Yes. The heart rate sensor is all-new and much steadier during exercise.
Specifications
  • Measurements
    46 x 46 x 11.7 mm / 1.83 x 1.83 x 0.46 "
  • Weight
    53g (Case 35g)
  • Bezel material:
    Stainless steel
  • Glass material:
    Gorilla glass
  • Case material:
  • Strap material:
    Silicone
  • What's in the box?
    Suunto Run 2, charging cable, printed user documentation
  • Country of manufacture
    CN
Technical specifications
  • Bezel material:
    Stainless steel
  • Glass material:
    Gorilla glass
  • Case material:
  • Strap material:
    Silicone
  • Weight
    53g (Case 35g)
  • Battery type
    rechargeable lithium-ion
  • Strap width
    22 mm
  • Wrist sizes
    130-200 mm
  • Customizable watch faces
  • Touch screen lock
    during exercise
  • Touch display
  • Color display
  • Water resistance
    50 m
  • Firmware upgradable
  • Time, date
  • Alarm clock
  • Dual time
  • Countdown timer
  • Stopwatch timer
  • Automatic timekeeping
  • Vibration alert
  • Languages
    CS, DA, DE, EL, EN, ES, FI, FR, HE, ID, IT, JA, KM, KO, NL, NO, PL, PT, RU, SV, TR, ZH, TH, ZHTW
  • Backlight
    AMOLED
  • Always-on display
  • Configurable backlight
    automatic brightness
  • Button lock
    during exercise
  • Display size
    1,32\"
  • Display type
    matrix
  • Display resolution
    466 x 466
  • Battery indicator
    percentage / icon
  • Metric and imperial units
  • Blood oxygen
  • Integrated wrist heart rate
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
BATTERY LIFE
  • Daily use: with 1h outdoor exercise per day
    up to 10 days (6 days with AOD on)s
  • Daily use: Smartwatch mode
    up to 13 days
    up to 15 days
    up to 24h
    up to 30h
    24h / 30h /40h
    up to 40h
COMPASS
  • Digital compass
  • Tilt compensation
  • Declination correction
  • Direction scale
    degrees / mils
  • Needle
    north indicator
  • Compass accuracy
    5°
  • Compass resolution
    1°
CONNECTIVITY
  • Smartphone compatibility
    Most common models supported
  • Compatible with Suunto app
    Bluetooth
  • Offline Music on the watch
  • Media controls on watch
    Android only
24/7
ACTIVITY TRACKING
  • Calories burned
  • Step counter
  • Activity targets
    steps, calories
  • Activity history
SLEEP TRACKING
  • Sleep duration
  • Bed times
  • Deep sleep
  • Light sleep
  • REM
  • HRV from sleep
  • Time awake
STRESS AND RECOVERY
  • Stress and recovery status
    Recovery Index
  • HRV measurement
  • Daily resource level
    No, Recovery index instead.
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
  • Offline maps on watch
  • Offline map storage size
    4GB (Standard, maps+music)/64GB (Premium, maps+music)
  • Satellite systems
  • GNSS frequency support
    Dual band (L1+L5)
    4
  • Max connected satellites
    32
  • Intelligent battery modes
    Performance, Endurance, Power saving
  • GPS recording rate
    Best, Good, Low
  • Zoom levels in navigation
  • Snap to route
  • GPS track analysis
ALTIMETER
  • Barometric altitude
  • GPS altitude
  • Altitude in daily mode
  • Total ascent/descent
  • Vertical speed
  • Automatic alti/baro profile
  • Log recording rate
    1 s
  • Resolution
    1 m
  • Range
    -500 - 9999 m
WEATHER
  • Sunrise/sunset times
  • Storm alarm
  • Sea level pressure
  • Temperature
  • Temperature display range
  • Temperature resolution
    1° C / 1.5° F
  • Pressure resolution
    1 hPa
  • Move altitude graph in Move summary
TRAINING FUNCTIONS
INTERVAL TRAINING
  • Setup intervals in watch
  • Structured intervals
HEART RATE
    Bluetooth HR belts
  • Calories
  • Peak Training Effect
  • Recovery time
  • Personal heart rate zones
  • Fitness level (VO2max)
  • Lactate threshold detection
SPEED AND DISTANCE
  • GPS speed and distance
  • Chrono
  • Foot POD support
    Bluetooth Smart
  • Autolaps
  • Manual laps
TRAINING RECOVERY
TRAINING LOAD
SHARE AND RELIVE
SPORT EXPERTISE
SWIMMING
  • Pool swim pace and distance
  • Openwater swim distance
  • Stroke efficiency (SWOLF)
  • Automatic intervals
  • Interval lap table
CYCLING
  • Cycling speed
  • Average speed in real time
  • Bike power meter support
RUNNING
  • Running pace
  • Snap to route
  • Ghost runner
  • Foot POD calibration
    automatic
MULTISPORTS
SPORT MODES
    > 32
Recommended products
SUPPORT FOR SUUNTO RUN 2
Suunto Run 2 features an ultra-lightweight 35 g watch body. With the official Suunto silicone strap, the total weight is 53 g. The strap can also be replaced with other compatible options to suit individual preferences.
See More See Less
