New-Generation GPS
Real-Time Run Insights
2,000-Nit Bright Display
35 g* Nordic Lightweight Design
Upgraded Heart Rate
10-Day Daily Battery
Shopping Cart
Your cart is empty
Lightweight Running Watch for Your Next Breakthrough
A breakthrough is shaped long before the finish line. It's built in decisions made early enough to matter. Hold, or push. Adjust, or recover. Every one of them gets easier when you can see clearly. What your effort is costing. Where your pace is taking you. How much you still have in you. Thirty‑five* grams on your wrist, from the first kilometre to the last night's sleep. Readable in full sun, at full stride. Numbers steady enough to build a race plan on. So when the finish comes into view, you already knew it was coming.
Suunto Run 2 |
Suunto Run |
| Size | 46 x 46 x 11.7mm | 46 x 46 x 11.5 mm |
| Size | ||
| 46 x 46 x 11.7mm | 46 x 46 x 11.5 mm | |
| Screen | 2000nit 1.32’’ AMOLED | 600nit 1.32’’ AMOLED |
| Screen | ||
| 2000nit 1.32’’ AMOLED | 600nit 1.32’’ AMOLED | |
| Battery Capacity | 380 mAh | 295 mAh |
| Battery Capacity | ||
| 380 mAh | 295 mAh | |
| Battery Life (Daily Use) | 10 days | 8 days |
| Battery Life (Daily Use) | ||
| 10 days | 8 days | |
| Battery Life (High Performance) | 24h | 20h |
| Battery Life (High Performance) | ||
| 24h | 20h | |
| Offline Maps | YES | NO |
| Offline Maps | ||
| YES | NO | |
| GPS & Heart rate | Upgraded version | Old version |
| GPS & Heart rate | ||
| Upgraded version | Old version | |
| Storage | 4 / 64 GB | 4 GB |
| Storage | ||
| 4 / 64 GB | 4 GB | |
FAQ
With dual-frequency, all-constellation GPS it lasts about 24 hours, enough for a full marathon plus the training around it. In everyday use it goes several days, and longer again in battery-saver mode.
This one's exclusive to Suunto. As you run, the watch works out your projected finish time in real time from your current pace, the route's elevation, the distance you've covered, and your fitness, so you can adjust your pacing on the fly. Your actual finish still depends on weather, terrain, hydration, and how you're feeling, so treat it as a guide.
There's a whole set: a Virtual Pacer mode, Race mode, and target modes for time, distance, ascent, and calories, among others. Guided workouts are supported too.
Yes. The Run series has its own Marathon mode, which adds dedicated data screens on top of the standard running view, including your finish prediction and remaining energy.
Yes. You can ping your phone to make it ring, and control music playback on your phone, including play, pause, skipping tracks, and volume.
It's water resistant to 5 ATM (50 m), which covers swimming, showering, and running in the rain. It isn't made for snorkeling, scuba diving, or diving off boards. Rinse it with fresh water after you swim.
There are 35 sport modes. Running is the focus, with road, trail, treadmill, and track, but you also get cycling, swimming, hiking, gym, triathlon, and more.
Yes. The heart rate sensor is all-new and much steadier during exercise.
Suunto Run 2 features an ultra-lightweight 35 g watch body. With the official Suunto silicone strap, the total weight is 53 g. The strap can also be replaced with other compatible options to suit individual preferences.
