1 / 3
SUUNTO A-10
NH Compass
SUUNTO A-10
NH Compass
SUUNTO A-10
NH Compass
1/3
Money-back guarantee
30-Days Return
Warranty Repair
SKU: SS021237000
Suunto A-10
NH Compass
$900
A robust, easy to use compact compass for general recreational use.
  • High grade steel needle with jewel bearing
  • Exceptionally stable & fast needle
  • Fixed declination correction scale
  • Balanced for northern hemisphere
  • Detachable snap-lock lanyard
Choose Your Color
Quantity
Free shipping on orders of NT$5000 or more.
$900
Compare +
30-Days Return
Warranty Repair
Made in Finland
Limited lifetime warranty
MINIMALISTIC BASEPLATE COMPASS FOR HIKERS AND SCOUTS
Stable operation
The compass liquid used by Suunto is specially formulated to provide damping over a large temperature range while preventing the needle from sticking.
The lanyard with wristlock is easy to detach for working with the map.
Made in Finland
All Suunto compasses are handcrafted at our factory with 100% renewable energy.
SPECIFICATIONS
  • Measurements
    56 x 104 x 10 mm / 2.2 x 4.09 x 0.39 "
  • Weight
    30 g / 1.06 oz
  • Bezel material:
    Plastic
  • What's in the box?
    Suunto A-10 NH Compass, lanyard, Quickrelease, Quick Guide
  • Country of manufacture
    FI
TECHNICAL SPECIFICATIONS
  • Bezel material
    Plastic
  • Metric scales
    cm with distance helpers
  • Imperial scales
    inch with distance helpers
  • Declination correction
    fixed scale
  • Weight
    30 g / 1.06 oz
  • Water resistance
    insensitive to water pressure
  • Battery type
    no battery required
  • Lanyard quick release
  • Attachment
    lanyard
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
COMPASS
  • Direction scale
    degrees
  • Needle
    high grade steel
  • Liquid filled and jewel bearing
  • Compass accuracy
    2.5°
  • Compass resolution
    2°
Recommended products
