1 / 8
Suunto Smart Heart Rate Belt 2 Black Size M/L
1/8
Money-back guarantee
30-Days Return
Warranty Repair
SKU: SS051638000
Black Size M/L
$299 NZD
Precision for Serious Training.
Accurate heart rate and R-R data for athletes who train by intensity.
Choose Your Color
Quantity
Free shipping on orders of NZ$300 or more.
$299 NZD
Compare +
30-Days Return
Warranty Repair
Trust Every Beat
An ECG front end identifies and rejects the artifacts that distort a heart rate reading, so the trace follows your effort through intervals, surges and long steady work. A new chest-strap construction shields the signal from static noise, holding readings stable from the first minute. High-resolution beat-to-beat R-R data is also what makes real-time ZoneSense possible on a compatible Suunto watch.
Wear It and Forget It
A 13 g transmitter, 36.5 × 36.5 × 8.5 mm, sits low and flat against the chest. The soft strap and silicone grip hold their position through surges and descents, so the belt stays where you set it and your attention stays on the session. Around 460 hours of battery life from a single CR2032 cell keeps maintenance rare.
See How You Actually Run
Paired with a compatible Suunto watch, a six-axis motion sensor measures cadence, ground contact time, vertical oscillation, flight time and left/right ground contact balance, so you can see how your form holds as speed rises and fatigue sets in. Up to 20 hours of rolling R-R memory sits on the belt itself, and your watch reads it back by timestamp to complete the record after reconnecting.
One Belt, Three Screens
Connect to as many as three devices at once over Bluetooth. A watch records the session, a bike computer shows live heart rate, and your phone runs the app alongside both. Every device receives the same live data, so a long ride or a triathlon brick runs start to finish on a single pairing.
IN THE BOX
  • 1 Suunto Smart Heart Rate Belt 2 Smart Module ×1
  • 2 Suunto Smart Heart Rate Belt 2 Chest Strap ×1
  • 3 Quick Guide ×1
  • 4 Warranty ×1
Pairing procedure
To see your heart rate and other data from Suunto Smart Heart Rate Belt 2, pair the transmitter with a compatible Bluetooth host device, such as a Suunto watch, a bike computer or your phone. Here is how to pair it:
Step 1: Power on and start pairing
Put the heart rate belt on to power it on, then start pairing from the host device.
Step 2: Accept pairing request
Press the button on the transmitter for two seconds to accept the pairing request. The host is added to the known hosts list on Suunto Smart Heart Rate Belt 2.
Step 3: Confirm pairing
Suunto Smart Heart Rate Belt 2 appears as SHRM2 followed by the last four digits of its serial number. If several Bluetooth sensors are active nearby, check those digits against the serial number printed on the back of the transmitter. Once paired, the host shows the belt's battery level and the services available from it, if the host supports this.
Step 4: Pair additional hosts
Repeat step 2 for each additional host. Suunto Smart Heart Rate Belt 2 holds an active connection with three hosts at the same time, and the known hosts list holds many more.
Specifications
  • Measurements
    XS/S: 66-102 cm / 26-40.2" M/L: 74-125 cm / 29.1-49.2"
  • Weight
    XS/S: 50.2 g / 1.77 oz M/L: 54.1 g / 1.91 oz
  • Strap material:
    Module: Stainless steel cover plate + fiber reinforced composite material Chest Strap Material: Polyamide/elastane on polyurethane contact surfaces
  • What's in the box?
    Suunto Smart Heart Rate Belt 2 smart module, Chest strap, Printed user documentation
  • Cleaning Instructions
    Rinse after each use. After 2-3 uses, remove the smart module and machine-wash the chest strap at 30°C. Never use any fabric softener.
  • Country of manufacture
    CN
Technical specifications
  • Removable Sensor Module
  • Replaceable Chest Strap
  • Weight
    Smart Module: 12.8 g, XS/S Chest Strap: 37.4 g, M/L Chest Strap: 41.3 g
  • Smart Module Dimensions
    36.5mm x 36.5mm x 8.5mm
  • Chest Size Range
    XS/S: 66-102 cm, M/L: 74-125 cm
  • Water Resistance Depth
    30 m (suitable for swimming)
  • Material
    Smart Module: Stainless steel cover plate + fiber reinforced composite material, Chest Strap: Polyamide/elastane on polyurethane contact surfaces
CONNECTIVITY
  • Bluetooth Pairing
    User controlled acceptance of who can connect. Connection is encrypted.
  • Supported concurrent Bluetooth connections
    3
  • Bluetooth Version
    V5.4
  • Bluetooth Chip Type/Model
    nRF54L15-QFAA
  • Bluetooth Transmission Frequency
    2.402~2.480 GHz
  • Bluetooth Transmission Power
    <0dBm(-6dBm)
  • Bluetooth Transmission Range (In Open Space Without Obstacles)
    >10 meters
PHYSICAL SPECIFICATIONS
  • Operating Temperature
    0℃~ +55℃
  • Storage Temperature
    -20℃~ +55℃
  • Operating Relative Humidity
    45~85%RH
BATTERY LIFE
  • Easy Battery Replacement
  • Battery
    CR2032
  • Standby Time
    3 years
  • Working Hours
    460h
  • Current
    Shutdown Current: <10uA Operating Current: <10 mA
  • Voltage
    Alarm Voltage: 2.7V Power-Off Voltage: 2.6V Rated Voltage: 3.0V
SPORT EXPERTISE
RUNNING
  • Running Form measurement
    Yes
TRAINING FUNCTIONS
HEART RATE
  • Heart Rate Measurement
  • Heart Rate Variability Measurement
  • Memory function
    Yes for the Heart rate variability and heart rate. The memory is only compatible with Suunto Watches. The memory is 20 hours long with a heart rate of 180 BPM.
Recommended products
SUPPORT FOR SUUNTO SMART HEART RATE BELT 2
1. Compatibility: The Suunto Smart Heart Rate Belt 2 is compatible with selected Suunto sports watches. Supported features vary by watch model.
2. Core features: Heart rate, RR intervals, memory, and ZoneSense are supported on Suunto Vertical, Vertical 2, Race, Race 2, Race S, Run, Run 2, and Ocean.
3. Running Form: Supported on Suunto Vertical 2, Race, Race 2, Race S, Run and Run 2. On selected models, Running Form requires a custom sport mode, Suunto Plus, or post-workout analysis.
4. For further information on Suunto Smart Heart Rate Belt 2 compatibility and supported features by watch model, please contact Suunto customer support.
See All See Less
